One
26.02.2006 19:57:35
| razor kirjutas: |
tõenäoliselt ei saa sa 3 pulgaga S939 peal piltigi ette  |
kuidas siis seda mõista? dfi on s939 ja epox on kah s939
728 |
razor
26.02.2006 20:02:34
| Winterwind kirjutas: |
hmm, EPOX-iga jooksevad küll neli klotsi koos ja kõik on kahepoolsed  |
| razor kirjutas: |
tõenäoliselt ei saa sa 3 (kolme!) pulgaga S939 peal piltigi ette  |
khm? loe rahulikult viimased 10 posti läbi
120 |
weedstone
27.02.2006 20:28:13
tegelt võiks keegi ühtlasi 1-e ja 2-e poolsete mälude erinevuse ka lahti seletada
124 |
HDTanel
Overclocker
496 |
UrmoZ
28.02.2006 16:43:15
| weedstone kirjutas: |
| tegelt võiks keegi ühtlasi 1-e ja 2-e poolsete mälude erinevuse ka lahti seletada |
copy-paste from TomsHardware:
As PC enthusiasts know, many modules of the same size come in both one- and two-sided versions. It's a good idea to buy double-sized modules whenever possible, because they have a built-in speed advantage over their single-sided brethren. In addition, there are now numerous Intel chipsets with DDR2 support under development that will treat both sides of a memory module together in a kind of RAID relationship. The resulting speed advantage is on the order of 2%, and was measured in the THG labs. In fact, using four single-sided memory modules doesn't help, and doesn't produce the same effect. By comparison with double-sided memory modules, measured performance actually decreases when using single-sided modules.
http://www.tomshardware.com/2006/02/27/in_search_of_true_ddr2_bleeding_edge_memory/page3.html
_________________ Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri! |
| Kommentaarid: 226 loe/lisa |
206 |
weedstone
28.02.2006 16:53:15
Hmm... et siis 2-e poolsed peaks kiiremad olema?
124 |
UrmoZ
28.02.2006 17:06:11
| Hmm... et siis 2-e poolsed peaks kiiremad olema? |
nii võrd, kui võrd....erilist vahet ei ole
206 |
Rutz
28.02.2006 17:07:31
Kiiremad, seda vaevalt eriti, aga kahepoolsed peaksid paremini klokkuma küll.
| Kommentaarid: 410 loe/lisa |
354 |
ajuNolk
28.02.2006 21:39:30
| razor kirjutas: |
tõenäoliselt. mina DFI peal näiteks ei saanud. kindlasti mängib rolli pulkade ühe/kahepoolsus, ühepoolseid vast veel isegi saaks ilma suurema jamata  |
Miks siis nii, ma julgen vaielda...
Oli masinas kahepoolne PQI CL2.5, panin juurde kaks kahepoolset kingstoni CL3 ning väga buenolt töötasid 1T ja CL2.5
Imelik, miks siis ei peaks töötama kolm mälu? Plaadiks asus a8n-e
Nelja kingstoniga aga peab leppima 2T, volt ei aidanud midagi, 1T ei ei töötanud lihtsalt...
121 |
Sponge
28.02.2006 21:45:18
tahaks kah kuidagi 3 pulka tööle saada, aga kuidagi ei saa plaat dfi-sli-dr
| Kommentaarid: 398 loe/lisa |
323 |
OskarR89
28.02.2006 22:11:11
| Sponge Bob kirjutas: |
tahaks kah kuidagi 3 pulka tööle saada, aga kuidagi ei saa plaat dfi-sli-dr  |
Ei usu, et saad ise ei saanud isegi 4 pulka tööle Proovitud igasugu 2T-d ja muud jura, ei boodi lihtsalt
139 |
UrmoZ
28.02.2006 22:13:10
SLI-DR ka siin, aga 4 pulka @ 2T töötas küll... 3 pulga kohapealt ei oska öelda, pole proovinud
206 |
margusser
28.02.2006 22:16:37
| 9npa, 4 pulka panid retsilt, 3 pulka surid
167 |
ceemic
24/7@kalal
28.02.2006 22:19:17
MSI K8N Neo4-F 3 pulka jooksid veatult
322 |
Elof
175 |
margusser
28.02.2006 22:28:35
Ei mitte otses mõttes, vaid lihtsalt ei läinud tööle
167 |
Sponge
28.02.2006 22:35:35
| Killer89 kirjutas: |
Ei usu, et saad ise ei saanud isegi 4 pulka tööle Proovitud igasugu 2T-d ja muud jura, ei boodi lihtsalt  |
õiget biosi tuleb kasutada mul töötasid bh5ed + am1 ed kenasti seni maani kui keegi pedekas varastas mult 512mb ära ning 3pulka jättis puutumata
323 |
robin
28.02.2006 22:37:46
kas ta oleks ikka pidanud ühe pulga veel varastama?
| Kommentaarid: 55 loe/lisa |
51 |
28.02.2006 22:44:05
lanparty rõõm ?
jah need 4 pulka töötavad ilusti... isegi minu väheste kogemuste põhjal s939-ga
201 |
OskarR89
28.02.2006 22:52:42
õiget biosi tuleb kasutada mul töötasid bh5ed + am1 ed kenasti seni maani kui keegi pedekas varastas mult 512mb ära ning 3pulka jättis puutumata  |
Mis Biosiga sul 4 pulka töötas siis?
139 |
UrmoZ
28.02.2006 23:06:13
olen kasutanud 702 BIOSi (ver. nii TCCD-le kui ka B/CH5-le, nr. 3 oli vist)
sees oli siis 2x512MB TCCD + 2x256MB CH5 (UTT) @ 2,5-3-3-6 200MHz
206 |
Sponge
28.02.2006 23:06:54
| UrmoZ kirjutas: |
sees oli siis 2x512MB TCCD + 2x256MB CH5 (UTT) @ 2,5-3-3-6 200MHz |
mul oli 704 bigtoe mod, töötas kah kenasti
323 |
erick
01.03.2006 10:41:11
| Chaintech VNF4 Ultra, 3 pulka (512 + 256 + 256) töötavad kenasti.
96 |
weasel
02.03.2006 14:00:19
Kas keegi on saanud 512MB Apaceri AM1 kividega saanud tööle 1T peal? Kui jah, siis mis volt ja kiirus?
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
RKsilver
02.03.2006 14:02:06
| weasel kirjutas: |
| Kas keegi on saanud 512MB Apaceri AM1 kividega saanud tööle 1T peal? Kui jah, siis mis volt ja kiirus? |
2x512mb apacher am1 @240Mhz 2.5-4-4-8 1t 3.1v
ega need mälud kõrgemale ei läinud isegi viskas juba vigu
| Kommentaarid: 172 loe/lisa |
140 |
weasel
02.03.2006 14:03:44
| kutsa99 kirjutas: |
| weasel kirjutas: |
ega need mälud kõrgemale ei läinud isegi viskas juba vigu  |
Mul on 2,5-4-4-8 2T 2,7V ja 240MHz. 240 tundub olevat maagiline piir...
RKsilver
02.03.2006 14:04:55
mnjaa äkki 240 selle pärast,et mul s754 ja veel nf4
140 |
margusser
167 |
Elof
02.03.2006 15:51:12
1x256mb PC2100 Winbondi BH-75't tegi midagi sarnast. sai vist tiba kõrgendatud voldiga vist isegi üle 200
175 |
margusser
02.03.2006 16:42:31
osta ära
167 |
Elof
02.03.2006 16:51:24
ei osta
175 |
Gene
02.03.2006 18:23:31
OT: aga selline probleem, et ennem oli arvutis 2x256 PC2700 mälu.
Täna panin 1x512 PC3200 aga kui arvuti sisse lülitan näitab ikka et DDR333 mitte 400
Mis ma tegema pean ? :$
| Kommentaarid: 20 loe/lisa |
15 |
neoman
02.03.2006 18:26:51
No aga peabki n2itama , mobo paneb mälu kiiruse vastavalt sellele kumb mälu on aeglasem.
| Kommentaarid: 80 loe/lisa |
72 |
weedstone
02.03.2006 18:27:18
muuda biosist ddr400 peale
124 |
Gene
02.03.2006 18:28:08
Huh eks ma lähen otsin seda siis biosist
Ennem üritasin aga ei leidnud.
15 |
robin
02.03.2006 18:28:25
| clear cmos tegid?
51 |
Gene
02.03.2006 18:39:28
Toimis, aitäh robin.
15 |
weedstone
02.03.2006 18:46:18
tegelt idee järgi oleks pidand ka niisama biosist panna et on 400Mhz mälud
124 |
Gene
02.03.2006 18:48:30
Mul olin see rammi ja fsp suhe vale.
by SPD või kuidas see kirjutatakse pidi panema noh st clear mos'ga läkski.
15 |
M!nA
110 |
Gene
04.03.2006 13:25:03
Mul oleks 1 väike küsimus
Kui mul on prose fsp 166 kas siis on parem kui mälud töötavad prosega 1:1'es või või 400 peal ?
15 |
korndog412
04.03.2006 13:29:12
| ikka 400 peal peaksid paremini töötama
99 |
Gene
04.03.2006 13:32:35
Kui BIOS's valida "AUTO" seadistused(kus on kirjas, et paneb automaatselt kõige paremad seaded) siis paneb ta mälud töötama 333mhz peale.
1 inimene soovitas mul ka prosega 1:1'es hoida mälusi aga...
15 |
korndog412
04.03.2006 13:34:47
| kõige kindlam on ise ära mõõta (siis ei jää midagi hinge kratsima ka) pane mälu 333 peale, võta lahti SPI ( http://www.xtremesystems.com/pi/super_pi_mod-1.5.zip ), jooksuta pane calculate (näiteks 1M), teeb testi ära, pane aeg kirja, nüüd pane mälu 400 peale ja proovi uuesti, kumb kiirem > see parem.
99 |
Gene
04.03.2006 13:54:24
DDR400 peal oli ajaks 56
DDR333 peal oli ajaks 52
Seega 333 peal ikka parem ehk siis prosega 1:1's.
15 |
margusser
167 |
timofeje
05.03.2006 18:08:46
Räägime nüüd tsipa tipp 2GB kittidest....
tahaks oma Corsair 2048-3200C2 kiti mõne kõvema vastu vahetada, aga ei tea mida võtta... vahepeal määriti siin G.Skilli pähe... krt.. ära veensid... aga äkki mõni kõbedam kusagil olemas???
midagi tahaks mis sobib siia juurde:
A64 3800+ Venice E3
MSI K8N Neo2 Platinum
| ot: |
| muide kui keegi tahab minu mälusid väga endale saada siis andku ps'iga teada! aga enne selle kuu lõppu ei liigu nad raudselt kuhugi...(või niikaua kui edale uusi ei leia) |
_________________ Pakun ainult kolme sorti teenuseid: hea, odav ja kiire. Kahjuks saab korraga valida neist ainult kaks. |
101 |
Rutz
05.03.2006 18:29:40
| timofeje kirjutas: |
A64 3800+ Venice E3
| ot: |
Parim variant on hetkel vist veel Infineon CE-6 kivide baasil või siis kui julged võtta Crucial Ballistix´id Micron 5b-d kividega.
Samsung UCCC tundub ka ennast heast küljest näitavat...
http://www.xtremesystems.org/forums/showthread.php?t=67762
| ot: |
| Sa mu Mushkineid ei soovi? |
354 |
e-Thug
07.03.2006 19:33:27
Kingston valueram 512mb ddr333 cl2.5
kividel:
0406 I-I
MT 46v64m8
TG -6T D |
Oskab keegi öelda, mis see endast kujutab?
| Kommentaarid: 230 loe/lisa |
205 |
Elof
07.03.2006 19:34:40
Ülesildistet' 6ns mälu
175 |
