uus teema   vasta Raud »  Protsessorid »  Räägime mäludest alates 400MHz märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 48, 49, 50 ... 57, 58, 59  järgmine
One
sõnum 26.02.2006 19:57:35 vasta tsitaadiga
razor kirjutas:
razor
sõnum 26.02.2006 20:02:34 vasta tsitaadiga
Winterwind kirjutas:
hmm, EPOX-iga jooksevad küll neli klotsi koos ja kõik on kahepoolsed icon_lol.gif
razor kirjutas:
tõenäoliselt ei saa sa 3 (kolme!) pulgaga S939 peal piltigi ette icon_razz1.gif
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 120
weedstone
weedstone
sõnum 27.02.2006 20:28:13 vasta tsitaadiga
tegelt võiks keegi ühtlasi 1-e ja 2-e poolsete mälude erinevuse ka lahti seletada
Kommentaarid: 130 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 125
HDTanel
Overclocker
HDTanel
sõnum 28.02.2006 16:38:54 vasta tsitaadiga
2x256Mb PC3500 Corsair| FSB 285MHz 1T CAS 2-2-2-2 3.7v
https://foorum.hinnavaatlus.ee/viewtopic.php?t=239170
Varsti panen ka 512Mb BH5-d müüki
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
UrmoZ
UrmoZ
sõnum 28.02.2006 16:43:15 vasta tsitaadiga
weedstone kirjutas:
icon_smile.gif copy-paste from TomsHardware:
As PC enthusiasts know, many modules of the same size come in both one- and two-sided versions. It's a good idea to buy double-sized modules whenever possible, because they have a built-in speed advantage over their single-sided brethren. In addition, there are now numerous Intel chipsets with DDR2 support under development that will treat both sides of a memory module together in a kind of RAID relationship. The resulting speed advantage is on the order of 2%, and was measured in the THG labs. In fact, using four single-sided memory modules doesn't help, and doesn't produce the same effect. By comparison with double-sided memory modules, measured performance actually decreases when using single-sided modules.
http://www.tomshardware.com/2006/02/27/in_search_of_true_ddr2_bleeding_edge_memory/page3.html
Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri!
Kommentaarid: 226 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 206
weedstone
weedstone
sõnum 28.02.2006 16:53:15 vasta tsitaadiga
Hmm... et siis 2-e poolsed peaks kiiremad olema?
UrmoZ
UrmoZ
sõnum 28.02.2006 17:06:11 vasta tsitaadiga
weedstone kirjutas:
icon_confused.gif nii võrd, kui võrd....erilist vahet ei ole
Rutz
sõnum 28.02.2006 17:07:31 vasta tsitaadiga
weedstone kirjutas:
Kiiremad, seda vaevalt eriti, aga kahepoolsed peaksid paremini klokkuma küll.
Kommentaarid: 412 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 356
ajuNolk
ajuNolk
sõnum 28.02.2006 21:39:30 vasta tsitaadiga
razor kirjutas:
tõenäoliselt. mina DFI peal näiteks ei saanud. kindlasti mängib rolli pulkade ühe/kahepoolsus, ühepoolseid vast veel isegi saaks ilma suurema jamata icon_razz1.gif
Oli masinas kahepoolne PQI CL2.5, panin juurde kaks kahepoolset kingstoni CL3 ning väga buenolt töötasid 1T ja CL2.5
Imelik, miks siis ei peaks töötama kolm mälu? Plaadiks asus a8n-e
Nelja kingstoniga aga peab leppima 2T, volt ei aidanud midagi, 1T ei ei töötanud lihtsalt...
Sponge
Sponge
sõnum 28.02.2006 21:45:18 vasta tsitaadiga
tahaks kah kuidagi 3 pulka tööle saada, aga kuidagi ei saa icon_razz.gif plaat dfi-sli-dr icon_rolleyes.gif
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
OskarR89
OskarR89
sõnum 28.02.2006 22:11:11 vasta tsitaadiga
Sponge Bob kirjutas:
Ei usu, et saad icon_confused.gif ise ei saanud isegi 4 pulka tööle icon_rolleyes.gif Proovitud igasugu 2T-d ja muud jura, ei boodi lihtsalt icon_rolleyes.gif
Kommentaarid: 152 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 139
UrmoZ
UrmoZ
sõnum 28.02.2006 22:13:10 vasta tsitaadiga
icon_confused.gif SLI-DR ka siin, aga 4 pulka @ 2T töötas küll... 3 pulga kohapealt ei oska öelda, pole proovinud
margusser
sõnum 28.02.2006 22:16:37 vasta tsitaadiga
9npa, 4 pulka panid retsilt, 3 pulka surid
Kommentaarid: 215 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 167
ceemic
24/7@kalal
ceemic
sõnum 28.02.2006 22:19:17 vasta tsitaadiga
Elof
Elof
sõnum 28.02.2006 22:24:32 vasta tsitaadiga
margusser kirjutas:
http://xtremesystems.org/forums/showthread.php?t=85533 icon_rolleyes.gif
margusser
sõnum 28.02.2006 22:28:35 vasta tsitaadiga
Sponge
Sponge
sõnum 28.02.2006 22:35:35 vasta tsitaadiga
Killer89 kirjutas:
õiget biosi tuleb kasutada icon_razz.gif mul töötasid bh5ed + am1 ed kenasti seni maani kui keegi pedekas varastas mult 512mb ära icon_lol.gif ning 3pulka jättis puutumata icon_rolleyes.gif icon_evil.gif
robin
robin
sõnum 28.02.2006 22:37:46 vasta tsitaadiga
Kommentaarid: 55 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 51
sõnum 28.02.2006 22:44:05 vasta tsitaadiga
lanparty rõõm ?
jah need 4 pulka töötavad ilusti... isegi minu väheste kogemuste põhjal s939-ga
OskarR89
OskarR89
sõnum 28.02.2006 22:52:42 vasta tsitaadiga
Killer89 kirjutas:
UrmoZ
UrmoZ
sõnum 28.02.2006 23:06:13 vasta tsitaadiga
olen kasutanud 702 BIOSi (ver. nii TCCD-le kui ka B/CH5-le, nr. 3 oli vist)
sees oli siis 2x512MB TCCD + 2x256MB CH5 (UTT) @ 2,5-3-3-6 200MHz
Sponge
Sponge
sõnum 28.02.2006 23:06:54 vasta tsitaadiga
UrmoZ kirjutas:
erick
erick
sõnum 01.03.2006 10:41:11 vasta tsitaadiga
Chaintech VNF4 Ultra, 3 pulka (512 + 256 + 256) töötavad kenasti.
weasel
weasel
sõnum 02.03.2006 14:00:19 vasta tsitaadiga
Kas keegi on saanud 512MB Apaceri AM1 kividega saanud tööle 1T peal? Kui jah, siis mis volt ja kiirus?
PSN: weaselEST
RKsilver
sõnum 02.03.2006 14:02:06 vasta tsitaadiga
weasel kirjutas:
2x512mb apacher am1 @240Mhz 2.5-4-4-8 1t 3.1v
Kommentaarid: 172 loe/lisa Kasutajad arvavad:  :: 2 :: 3 :: 140
weasel
weasel
sõnum 02.03.2006 14:03:44 vasta tsitaadiga
kutsa99 kirjutas:
weasel kirjutas:
Mul on 2,5-4-4-8 2T 2,7V ja 240MHz. 240 tundub olevat maagiline piir...
RKsilver
sõnum 02.03.2006 14:04:55 vasta tsitaadiga
margusser
sõnum 02.03.2006 14:41:14 vasta tsitaadiga
http://www.vihanepc.com/corsad.PNG
Elof
Elof
sõnum 02.03.2006 15:51:12 vasta tsitaadiga
margusser kirjutas:
1x256mb PC2100 Winbondi BH-75't tegi midagi sarnast. sai vist tiba kõrgendatud voldiga vist isegi üle 200 thumbs_up.gif
margusser
sõnum 02.03.2006 16:42:31 vasta tsitaadiga
Elof
Elof
sõnum 02.03.2006 16:51:24 vasta tsitaadiga
ei osta
Gene
Gene
sõnum 02.03.2006 18:23:31 vasta tsitaadiga
OT: aga selline probleem, et ennem oli arvutis 2x256 PC2700 mälu.
Täna panin 1x512 PC3200 aga kui arvuti sisse lülitan näitab ikka et DDR333 mitte 400 icon_redface.gif
Mis ma tegema pean ? :$
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 15
neoman
sõnum 02.03.2006 18:26:51 vasta tsitaadiga
No aga peabki n2itama , mobo paneb mälu kiiruse vastavalt sellele kumb mälu on aeglasem.
Kommentaarid: 80 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 72
weedstone
weedstone
sõnum 02.03.2006 18:27:18 vasta tsitaadiga
muuda biosist ddr400 peale
Gene
Gene
sõnum 02.03.2006 18:28:08 vasta tsitaadiga
Ennem üritasin aga ei leidnud.
robin
robin
sõnum 02.03.2006 18:28:25 vasta tsitaadiga
clear cmos tegid?
Gene
Gene
sõnum 02.03.2006 18:39:28 vasta tsitaadiga
weedstone
weedstone
sõnum 02.03.2006 18:46:18 vasta tsitaadiga
tegelt idee järgi oleks pidand ka niisama biosist panna et on 400Mhz mälud
Gene
Gene
sõnum 02.03.2006 18:48:30 vasta tsitaadiga
Mul olin see rammi ja fsp suhe vale.
by SPD või kuidas see kirjutatakse pidi panema icon_smile.gif noh st clear mos'ga läkski.
M!nA
M!nA
sõnum 03.03.2006 13:32:40 vasta tsitaadiga
https://foorum.hinnavaatlus.ee/viewtopic.php?t=239662
TEL.:56477545
Kommentaarid: 146 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 110
Gene
Gene
sõnum 04.03.2006 13:25:03 vasta tsitaadiga
Kui mul on prose fsp 166 kas siis on parem kui mälud töötavad prosega 1:1'es või või 400 peal ? icon_rolleyes.gif
korndog412
korndog412
sõnum 04.03.2006 13:29:12 vasta tsitaadiga
ikka 400 peal peaksid paremini töötama
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 99
Gene
Gene
sõnum 04.03.2006 13:32:35 vasta tsitaadiga
Kui BIOS's valida "AUTO" seadistused(kus on kirjas, et paneb automaatselt kõige paremad seaded) siis paneb ta mälud töötama 333mhz peale.
1 inimene soovitas mul ka prosega 1:1'es hoida mälusi aga...
korndog412
korndog412
sõnum 04.03.2006 13:34:47 vasta tsitaadiga
kõige kindlam on ise ära mõõta (siis ei jää midagi hinge kratsima ka) pane mälu 333 peale, võta lahti SPI ( http://www.xtremesystems.com/pi/super_pi_mod-1.5.zip ), jooksuta pane calculate (näiteks 1M), teeb testi ära, pane aeg kirja, nüüd pane mälu 400 peale ja proovi uuesti, kumb kiirem > see parem.
Gene
Gene
sõnum 04.03.2006 13:54:24 vasta tsitaadiga
DDR400 peal oli ajaks 56
DDR333 peal oli ajaks 52
Seega 333 peal ikka parem ehk siis prosega 1:1's. icon_rolleyes.gif
margusser
sõnum 04.03.2006 19:26:13 vasta tsitaadiga
http://www.vihanepc.com/margusser/suva.PNG
timofeje
sõnum 05.03.2006 18:08:46 vasta tsitaadiga
Räägime nüüd tsipa tipp 2GB kittidest....
tahaks oma Corsair 2048-3200C2 kiti mõne kõvema vastu vahetada, aga ei tea mida võtta... vahepeal määriti siin G.Skilli pähe... krt.. ära veensid... aga äkki mõni kõbedam kusagil olemas???
midagi tahaks mis sobib siia juurde:
A64 3800+ Venice E3
MSI K8N Neo2 Platinum
ot:
muide kui keegi tahab minu mälusid väga endale saada siis andku ps'iga teada! aga enne selle kuu lõppu ei liigu nad raudselt kuhugi...(või niikaua kui edale uusi ei leia)
Pakun ainult kolme sorti teenuseid: hea, odav ja kiire. Kahjuks saab korraga valida neist ainult kaks.
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 101
Rutz
sõnum 05.03.2006 18:29:40 vasta tsitaadiga
timofeje kirjutas:
A64 3800+ Venice E3
ot:
Parim variant on hetkel vist veel Infineon CE-6 kivide baasil või siis kui julged võtta Crucial Ballistix´id Micron 5b-d kividega.
Samsung UCCC tundub ka ennast heast küljest näitavat...
http://www.xtremesystems.org/forums/showthread.php?t=67762
ot:
Sa mu Mushkineid ei soovi?
e-Thug
e-Thug
sõnum 07.03.2006 19:33:27 vasta tsitaadiga
Kingston valueram 512mb ddr333 cl2.5
kividel:
0406    I-I
MT  46v64m8
TG   -6T D
Kommentaarid: 230 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 205
Elof
Elof
sõnum 07.03.2006 19:34:40 vasta tsitaadiga
uus teema   vasta Raud »  Protsessorid »  Räägime mäludest alates 400MHz mine lehele eelmine  1, 2, 3 ... 48, 49, 50 ... 57, 58, 59  järgmine
