Mario153
22.02.2006 22:06:02
Club 3D X1900XL 512MB
Mis selle hinnaks võib kujuneda?
| Kommentaarid: 56 loe/lisa |
50 |
One
22.02.2006 22:08:51
| Mario153 kirjutas: |
Mis selle hinnaks võib kujuneda? |
räägitakse, et XL-i hind tuleb sama kui X1800XL-il
ehk siis sinna 5-6k kanti vast eestis..
iseasi palju too konkreetne Club3D kaart maksab
728 |
prigo
22.02.2006 22:13:27
Suht loodan,et Club3d isend tuleb sinna 6k max hind.Selle raha eest oleks väga pro kaart.
| Kommentaarid: 17 loe/lisa |
15 |
-Jack-
| Kommentaarid: 6 loe/lisa |
Anti
23.02.2006 10:56:53
kehvem, 128bit. Ja kõik oleneb mis x800 kaardi vastu, neid ju sada erinevat versiooni.
240 |
-Jack-
23.02.2006 11:01:27
Dr.Peep paneb suht segast, allpool on kirjas, et videokaardi kiirus (bit) 256, aga üleval nimes on 128?
No näiteks x800 gt vastu!
_________________ Ära karda suuri väljaminekuid, karda väikseid sissetulekuid! |
Anti
23.02.2006 11:01:54
| -Jack- kirjutas: |
No näiteks x800 gt vastu! |
x800gt omab ära. 4 piipu rohkem ju.
240 |
-Jack-
23.02.2006 11:09:09
Kuidagi kahtlaselt odav on see x1600 pro agp seal dr.peebus sellise jõudlusega kaardi kohta, x800 gt maksis seal mingi 700.- rohkem?
Ho Ho
23.02.2006 11:15:28
link :: Kivi
Üks "väike" kivike ATI kapsaaeda:
ATIs R5xx line (which is comprised by the X1300, X1600, X1800 and X1900 series) was first released back in October 2005.
Last month we saw the release of the new X1900 series too. Now, let me count the months from October to February; it is 5 months, right? Well, believe it or not, thats the number of months the new X1000 series is out in the market without Linux support
Well, earlier this morning we had spoken with Matthew Tippett from ATI's Linux department for a public comment and he has simply said that the supportive drivers are indeed coming and they will be out eventually, and he also said it will likely not be for a couple of releases at least. With the department's present strategy of releasing monthly Linux drivers as of late, these drivers will likely not be in the hands of the public until sometime this spring, unless of course a miracle was to occur with their development process.
Those unlucky enough to have a X1000 series card, have to settle with the slow vesa driver in order to be able to boot to a GUI and thats not all. If you are unlucky enough to have a TFT which has a non-standard resolution (meaning something other than 640x480, 800x600, 1024x768 etc up to 1600x1200), well, youre screwed, because you cant use it! |
Nii palju siis lubadusest oma Linuxi draivereid parandada
Tõenäoliselt on olukord parem kui aasta tagasi kuid ei midagi eriti korralikku kui pea poole aastaga pole suudetud draiveritesse oma kaartide tugegi panna, enam-vähem talutavast 3d kiirendusest rääkimata.
86 |
erick
23.02.2006 12:34:40
Siinkohal võiks ausalt küsida: milleks inimesed seda kaarti Linuxi all kasutavad üldse?
HL2 ja Doom 3 jooksevad ka 3-4x odavamate kaartidega. Või on vahepeal veel mingeid uusi ja olulisi mänge Linuxile porditud?
96 |
stepzter
23.02.2006 12:39:35
| Quake 4 näiteks. Ja osad inimesed kasutavad Linuxit et tööd teha. (nii uskumatu kui see ka poleks)
| Kommentaarid: 26 loe/lisa |
26 |
Noname
23.02.2006 12:42:34
| stepzter kirjutas: |
| Quake 4 näiteks. Ja osad inimesed kasutavad Linuxit et tööd teha. (nii uskumatu kui see ka poleks) |
töö tegemiseks sellist kaarti vaja?
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
| Kommentaarid: 370 loe/lisa |
320 |
erick
23.02.2006 12:44:40
Seda ma usun, et inimesed kasutavad Linuxit töö tegemiseks. Selles ma ei kahtlegi. Ma lihtsalt kahtlen selles, kas on mõtet osta endale 1-3 uue mängu Linuxi all kellad-viled põhjas mängimiseks 8000-10 000 kroonine videokaart
Töö saab ju kiiremini tehtud ka ilma selleta. Kui räägime profi 3D-kaartidest, siis mingi veidi vanem Quadro on iga kell parem valik kui X1XK seeria mängukaardid.
96 |
lamp
23.02.2006 12:57:37
eks jah see liinuskisupport on rohkem #wecare ja "peaks-tegema-jah" teema, jääb see 0.00000000000000000000000001% turust võtmata, big deal.
ja firegl r5** kaarti vist ikka veel pole?
| Kommentaarid: 189 loe/lisa |
166 |
Revage
| Kommentaarid: 78 loe/lisa |
6 :: |
10 :: |
52 |
One
23.02.2006 13:01:27
| ot: |
| mnjaah, peab tolle ASUS RD580 ikka ära tellima |
728 |
HDTanel
Overclocker
23.02.2006 13:08:08
Peaks Yonahi ostma hoopis
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Scart
23.02.2006 13:19:52
| erick kirjutas: |
Seda ma usun, et inimesed kasutavad Linuxit töö tegemiseks. Selles ma ei kahtlegi. Ma lihtsalt kahtlen selles, kas on mõtet osta endale 1-3 uue mängu Linuxi all kellad-viled põhjas mängimiseks 8000-10 000 kroonine videokaart |
tähtis ei ole mitte see, kas tehakse või mitte- tähtis on see, et üks teine tootja pakub sellist võimalust ja ilmselt üsnagi hästi
101 |
Ho Ho
23.02.2006 13:33:43
| erick kirjutas: |
| HL2 ja Doom 3 jooksevad ka 3-4x odavamate kaartidega. Või on vahepeal veel mingeid uusi ja olulisi mänge Linuxile porditud? |
Olen kindel et mu FX 5600u on Linuxis Q4's kiirem kui x800gt. Näiteks läbi wine mõnd 3d mängu mängida ei ole alla x800xt praktiliselt võimalik kuid minul jookseb WC3 perfektselt.
Linuxi turg on kasutajate arvu poolest minu teada kusagil 2-5%, oleneb kelle statistikat uskuda.
Töö tegemiseks kasutatakse minu teada linuxit üsna mitmes suuremas 3d renderdamisega tegelevas firmas, kui mälu ei peta siis mõnda aega tagasi kasutas ka Pixar mingit Linuxit. Kui ATI professionaalse 3d turule ei sa on see ta enda traagika. Lihtsalt kurb et need (vähesed) Linuxi kasutajad ei saa oma riistvara adekvaatselt kasutada.
Kuna nii mõnegi potentsiaalse kasutaja võib eemale peletada sisuliselt olematu riistvara tugi siis tekib surnud ring: kuni pole korralikku tuge ei ole ka kasutajaid, kuni pole kasutajaid pole ka tuge. NV'l on selles suhtes olukord märksa parem. Ma ei oska küll täpseid võrdlusnumbreid tuua kuid Q3 tundus jooksvat paremini kui winis ning Q4 jooksis Linuxis paremini kui D3 winis. Kuna mul enam wini pole siis ei saa ma ka konkreetseid võrdlusi teha. Kuid kui hästi läheb ning ma venna masinas lõpuks ta ATI draiverid käima saan siis saaksin võrrelda Q3/4 kiirust nii winis kui Linuxis. Ma usun et tulemused oleks paljudele üllatavad
86 |
FeZ
23.02.2006 14:30:11
Ise tellisin ära selle kaardi mõni päev tagasi, toetab uuema ajastu asju (sm3.0, hdr, jms mida x800 ei toeta). Aga noh, ati driverid paranevad suht palju, nagu viimaste 6.2 versioon catalystiga said x1000 seeria kaartide kasutajad palju performancit juurde. Lugesin reviewi, eriti see kokkuvõtte lause jäi silma "is the "middling" X1600PRO worth of attention? We can state with confidence: "Yes!". Despite the slightly misbalanced architecture, high operating speed of the GPU and memory allow producing a performance sufficient for the mid-end systems.". Kuna ma pole miljonär siis suht hea ost imo .
review ise siin: http://www.digital-daily.com/video/x1600_x800_6600gt
(see mälu jahutuse probleem mis tal oli seal, ma pakun et lihtsalt tehase praak, endal kontrollin igaksjuhuks üle tho)
16 |
Elof
23.02.2006 14:35:24
X1600 Pro ei saa mängudes reeglina 6600GT vastugi
va. FEAR
Riddickiga muidugi veider kala 6600GT'l
175 |
FeZ
23.02.2006 14:38:37
no 3dmark06 test mis seal tehtud on, x1600 on parem kui 6600gt, nii overclocked kui ka default kelladega. 3dmark06 on siis teadagi n.ö tuleviku mängude eelkäija. Sama ka mänguga fear .
Teised mängud imo lihtsalt opengl tehnoloogial, mis ati ei ole suutnud HÄSTI driveritega lahendada veel, ja need testid on tehtud catalyst 6.1ega ;]
16 |
Elof
23.02.2006 14:45:59
Samas kui neid tulevikku suunatud teste ei suuda inimliku FPS'ga manada siis on asi ikkagi üsna mõttetu.
Cata 6.1 vs 6.2 paraneb fps 0,n protsenti ?
Igal juhul mingit tõsist eelist 6600GT ees eriti ei paista
HL2 ja Serious Sam 2 on OpenGL ?
Ning 3DMark06 ... sellise kaardi jaoks on test üsna mõttetu.
Nagu oli FX5200 jaoks 3DMark03.
Näitab vaid seda et kaart on võimeline üliaeglaselt teatavaid featuure kasutama.
Rispek'
Päris korralik vahe X1 seeri puhul tõesti
viimati muutis Elof 23.02.2006 15:00:44, muudetud 1 kord |
175 |
Draco
23.02.2006 14:50:34
HL2 on DX9
_________________ Purgatory Judgement |
| Kommentaarid: 12 loe/lisa |
12 |
FeZ
16 |
