Slazenger
21.02.2006 15:38:51
hmm... Winter, natuke postitand pole artikleid hetkel v2 ?
kui ikka selline hind tuleb, siis ma ikka X1900XTX 2ra ei osta K|ngp|n hakkab kindlasti seda r2medalt piinama:P
kindel asi mida oodata !
| Kommentaarid: 74 loe/lisa |
69 |
robin
21.02.2006 20:24:18
tore ju, kui keegi siia uudiseid postitab
| Kommentaarid: 55 loe/lisa |
51 |
margusser
21.02.2006 22:48:07
link :: link
NVIDIA GeForce 7600GT Pics, Specs
NVIDIA's new 6600GT pin compatible component shows its face
Earlier today we reported about NVIDIA's new GeForce 7900GT -- the 90nm die shrink from GeForce 7800GT. As great as high end components are, the largest battles between ATI and NVIDIA will be fought on the mid-range. GeForce 6600GT, NVIDIA's best selling GPU of all time, is getting a little long in the tooth. NVIDIA deserves some well deserved credit for the foresight to keep GeForce 6600GT and 7600GT pin compatible.
Due to the maturity of GeForce 6600GT, many manufacturers have added several features to the PCBs. These features will also appear on GeForce 7600GT. Some manufacturers have told us that boards and final products have been ready to ship for several months but NVIDIA has held off on launch. No details were given as to why. Compared to the new GeForce 7900GT, the reference design for the GeForce 7600GT doesn't seem to support the same audio 4-pin leads.
Quick specifications for GeForce 7600GT from NVIDIA documents:
PCIe native
560MHz core frequency
128-bit memory interface
20.2GB/sec. memory bandwidth
7B pixels/sec. fill rate
730M vertices/sec.
12 pixels per cycle
Built in dual-link DVI support for 2560x1600 resolution
167 |
One
21.02.2006 22:50:45
128bit kaart pannakse X1800GTO-le vastu?
mnjaa, nalja hakkab saama
728 |
tomz
21.02.2006 23:04:59
huvitav mis selle hinnaks kujuneb? ehk tasub isgei proovida
| Kommentaarid: 68 loe/lisa |
Sponge
21.02.2006 23:05:55
| Winterwind kirjutas: |
mnjaa, nalja hakkab saama  |
x800gt 256 bit vs 6600GT 128 bit, Wo O/C vahet ei ole neil ju
| Kommentaarid: 398 loe/lisa |
323 |
Slazenger
21.02.2006 23:07:05
Sponge Bob, midagi sulle ? piinad ta surnuks
69 |
der hammer
21.02.2006 23:07:08
Ma vaatasin kah just ,et wtf 128bit. 6600GT oli juba wtf 128bit
_________________ Tere. |
| Kommentaarid: 149 loe/lisa |
130 |
Sponge
21.02.2006 23:12:00
| Slazenger kirjutas: |
Sponge Bob, midagi sulle ? piinad ta surnuks  |
ära küll ei ütleks jah
323 |
margusser
21.02.2006 23:18:39
link :: link
NVIDIA GeForce 7900GT
Surprise, surprise – here is NVIDIA's upcoming GeForce 7900GT. NVIDIA’s newest GPU, dubbed G71, will debut at CeBit 2006 in Hannover in a few weeks.
NVIDIA's new 7900GT is expected to use new Samsung GDDR3 memory that's reported to be operating at 1.4ns but frequencies are unconfirmed at this point. In contrast, ATI's X1800XT uses GDDR3 memory with a 1.2ns time running at 1400MHz. NVIDIA's 7800GTX 512 uses memory running at an effective rate of 1.7GHz.
We have a few images of the 7900GT from NVIDIA (right). The 7900GT will feature a single slot cooling design, although the cooler demonstrated in the images we captured is not the stock cooler that will appear on the final design. An interesting engineering element on the reference board includes a set of 4-pin leads for what we are told is for an audio jack -- or at least the leads for an audio jack. If it is indeed an input for audio signals (appears to be SPDIF), then for upcoming graphics cards that boast HDMI connectivity, this would definitely make sense. As for the current reference design, there is no such connector featured and we will have to wait for final designs to see what happens.
NVIDIA roadmaps have confirmed to us that the 90nm 7900GT will feature 24 pipelines with a 450MHz core clock. Like the GeForce 7800GTX series, the 7900GT comes with this warning:
Note: For two GeForce 7900 GT-based graphics cards running in NVIDIA SLI configurations, a minimum 450W system power supply (with 12V rating of 26A) is recommended.
Quick specifications for GeForce 7900GT from NVIDIA documents:
PCIe native
450MHz core frequency
256-bit memory interface
40GB/sec. memory bandwidth
11B pixels/sec. fill rate
~900M vertices/sec.
24 pixels per cycle
167 |
Slazenger
21.02.2006 23:20:03
IIILUS !!!!
kui GTX liiga kallis, siis ostan selle
69 |
margusser
21.02.2006 23:21:08
| Sakib et shimmi pole ümber okse.
167 |
One
21.02.2006 23:24:41
kuidagi väga odava mulje jätab see kaart
728 |
Sponge
21.02.2006 23:25:23
| margusser kirjutas: |
| Sakib et shimmi pole ümber okse. |
jah aga ati shimid imevad kah , corest kõrgemad... natuke... silmaga on näha isegi
323 |
margusser
21.02.2006 23:26:01
| Sponge Bob, jajah murdunud nurgad imevad veel rohkem..
167 |
HDTanel
Overclocker
21.02.2006 23:29:26
Hmmm, wtf, kaitsevõre ple ja kaart lühikesem kuidas võtta nüüd
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
margusser
167 |
Tbit
21.02.2006 23:33:06
ilma shim tuleb teisele poole kaal panna, siis on suht sama turvaline kui shim'ga.
|OSTAN|-> T43 pikk jahutus |
230 |
Slazenger
21.02.2006 23:33:22
| core kaitsevõre
69 |
Ho Ho
21.02.2006 23:36:29
kuidagi väga odava mulje jätab see kaart  |
Keda välimus huvitab, peaasi et kiire on
Teoreetiliselt peaks maanduma veidi kiiremale kohale kui vana 256M GTX.
Huvitav kas G71 GTX on lihtsalt tunduvalt kiirem või siiski omab lisaks ka mõnd toru? G70 seerial ju oli GT lisaks madalamale kiirusele ka vähemate torudega.
87 |
One
21.02.2006 23:37:12
egas jah... GT on 450mhz ja 24piipu
GTX 650mhz ja 32piipu?
pigem 650mhz ja 24 piipu..
728 |
21.02.2006 23:54:25
kaks 2-pin connectorit ventidele ?
| Kommentaarid: 85 loe/lisa |
Ho Ho
22.02.2006 00:06:44
pigem 650mhz ja 24 piipu.. |
Siiski ma ei tahaks uskuda et vahe seisneb ainult taktis. Ma oletaks et GT'd on lihtsalt ühe-kahe lukustatud quadiga GTX'id. Vastasel juhul läheks ju üsna palju kive raisku.
87 |
One
22.02.2006 00:08:25
| Ho Ho kirjutas: |
| Vastasel juhul läheks ju üsna palju kive raisku. |
kuidas nad raisku lähevad?
atil X1800XT ja XL samuti 16 piibuga mõlemad..
osad "halvemad" praagitakse mingil x põhjusel välja ja pannakse XL-i peale..
aga jah, äkki nvidial 32 piipu või siis 48 nagu platuun vahepeal mainis..
see GT pcb on kahtlane low end igatahes
728 |
Ho Ho
22.02.2006 00:13:57
Võibolla tuleb see 32/650 asjandus hoopis Ultra nime all välja
87 |
One
22.02.2006 00:15:38
| ot: |
| miks seda Ultra-t vaja kui G80 kohe-kohe tulemas nagu "räägitakse" |
728 |
Ho Ho
22.02.2006 00:21:04
| ot: |
Ega otsest vajadust ei olegi kuid kui peaks tulema selliste kellade ja torude hulgaga kaart siis GTX oleks selle nimetuseks liiga vähe, kiirusevahe tolle GT'ga oleks >2x |
87 |
lamp
22.02.2006 01:41:15
link :: dailytech - NVIDIA 7900GTX Details
noo nemad juba pada ei aja:
Quick specifications for GeForce 7900 GTX:
* PCIe native
* 655MHz core frequency
* 256-bit memory interface
* 52GB/sec. memory bandwidth
* 15B pixels/sec. fill rate
* 1450M vertices/sec.
* 24 pixels per cycle
* Built in twin dual-link DVI support for twin 2560x1600 resolution displays |
169 |
hmekk
22.02.2006 02:37:43
nii et 32 üiipu on oodata g80 -nega ?
_________________ Fotoblogi / Flickr |
8 :: |
68 |
stepzter
22.02.2006 02:53:22
huvitaval kombel saab nendest specidest järeldada, et
a) kiibil on 8.8 vertex shaderi üksust
b) vertex shaderi osa jookseb 725MHz'ga
| Kommentaarid: 26 loe/lisa |
26 |
HDTanel
Overclocker
22.02.2006 10:27:53
| lamp kirjutas: |
* PCIe native
Ma ei saa nagu aru kuda see asi saab kiirem olla kui 7800GTX...
496 |
Slazenger
22.02.2006 10:42:59
piixus ... lootsin, et saan 7900GTX osta, aga .... jamh, l2heb ikka ATi peale
69 |
One
22.02.2006 10:48:11
| stepzter kirjutas: |
| b) vertex shaderi osa jookseb 725MHz'ga |
G70-l jooksis ja vertex osa imho kiiremini kui muud..
aga jah, eks see G71 ole G70-e üleviimine 90nm peale..
saab näha kuidas selle 650mhz-iga on, kas suudetakse ka singel slot jahutus panna
728 |
HDTanel
Overclocker
22.02.2006 11:04:47
piixus ... lootsin, et saan 7900GTX osta, aga .... jamh, l2heb ikka ATi peale  |
Samad sõnad
Saab üle pika aja ATI kaarti piinata.
edit: https://foorum.hinnavaatlus.ee/viewtopic.php?t=238166&highlight=
Ostke ära
Evil1923, nüüd saab pinget anda sulle Teeb volt moddid ära X1900XTX-le siis peaks kärama küll. Uus Opteron kui tuleb võiks ilma coldbuggita olla
496 |
Evil
Hull
22.02.2006 13:25:31
| PlatoonSgtElias kirjutas: |
Evil1923, nüüd saab pinget anda sulle  |
Norm, konkurents on hea.
202 |
lamp
22.02.2006 13:34:45
PlatoonSgtElias kuidas siis nii? või sa tead midagi mida me ei tea.
et kas testijatele saadetud 32-piibulised g71'ed olid oodatust märksa lahjemad?
oletame, et su NDA kukub cebiti ajal, siis ootaks teste ka.
169 |
HDTanel
Overclocker
22.02.2006 14:35:47
Hetkel pole ma G71 isegi näinud mitte... eks ta tuleb enne kui teistele ikka aga noh komoon, kui räägitakse pidevalt, et tuleb 24 piipu, mul ple ka muud infot praegu jagada... siis noo mai usu ausalt, et asi kiirem kui X1900XTX on
edit: Kui on siis 11kilo juures hind jälle. Tutika XTX poest saan ise mingi 9.9k eest kätte näiteks
496 |
Scart
22.02.2006 15:33:42
mitte keegi meist ei tea, kui kiire reaalselt see uus kaart on, ootaks vast ikka enne asja ära kui põhjapanevaid järeldusi tegema hakkame?
101 |
Ho Ho
22.02.2006 15:38:36
Minu arvamus on et 24 toruga ning 655MHz kellaga on ta maksimaalselt 20% kiirem kui 512M GTX, 50% kiirem kui 256M GTX. Lõplik kiiruseerinevus sõltub konkreetsest rakendusest ning sellest kui palju on asi piiratud mälu läbilaske poolt.
Kui peaks siiski tulema 32 toruline variant nendel kelladel oleks too maksimaalselt 60% kiirem kui 512M GTX ning 100% kiirem kui 256M GTX.
Nüüd jääb ainult oodata et teada kui hästi need kelluvad korraliku jahutuse ja vmodidega
87 |
time123
22.02.2006 17:56:37
It also appears that the rumours of the 7900 GTX containing 32 fragment pipes are also untrue. If the DailyTech rumours are to be believed (they've been rather reliable so far), then the 7900 GTX, like the 7800 GTX, will have 24 pipes.
They also mention that there will be a single slot version of the 7900 which is designed for Quad-SLI!
Ma pakun, et ikka omab X1900XTX ära. Nvidial vaja ju juhtpositsioonile tagasi minna.
Kaart tuleb välja 8. või 9. märtsil. wee.
| Kommentaarid: 204 loe/lisa |
179 |
Tykk
22.02.2006 20:13:09
| oskab keegi öelda kumb oleks mõistlikum osta kas 7800GT või 7800GS PCI-E siinile?
robin
22.02.2006 20:18:46
| 7800gt on nendest ainus võimalus, kuna gs on ainult agp.
51 |
margusser
23.02.2006 11:08:27
link :: link
Cards like the GeForce 7800 GTX and Radeon X1900 XT-X may be getting a lot of press lately, and while these cards are impressive to say the least, they don't represent what the majority of users are buying for their PC gaming systems. Gamers on a budget are always interested in advancements in the mid and lower price-range of graphics cards, and efficiency is generally more desirable to users than sheer power when looking for an upgrade. An example of this would be the popularity that we've seen of quality mid-range cards like the X800 GTO and 6800 GS, given their performance and reasonable price tags. Thankfully, NVIDIA has been continuing to make advancements on the budget side of things as well, and one such advancement is their recently released GeForce 7300 GS.
The 7300 GS is graphics card in the $100 or less price range, which offers a lot of the same features available in much more expensive parts for a fraction of the cost. This is a budget card, however, so it will see gaming performance similar to parts like NVIDIA's 6200 and ATI's X300. The 7300 GS that we have for this review is made by EVGA, a company with a good reputation for providing quality graphics hardware at competitive prices.
We've been looking at high end cards quite a bit lately, and it's easy to overlook some of the more humble graphics solutions available from ATI and NVIDIA as such powerful cards take center stage. Most PC users don't need the kind of performance that a card like the X1900 provides, and depending on the types of applications that different users are running, a far less powerful (and thus, inexpensive) card may be the wiser choice. Office computers and home theater systems might only require the most basic hardware acceleration, which is why this category of video cards exist.
Of course, for an avid gamer, a card like the 7300 GS might not cut it, but for those on a budget, this card is worth a look. Today, we take a look at EVGA's version of the 7300 GS and we will talk about the performance and features of this newest budget card from NVIDIA.
Järgmine üllitis.
167 |
One
23.02.2006 11:19:22
| see 7300 ei vääri küll videokaardi nime, kurat int vga on sama kiire kui see sitt okse
728 |
Ho Ho
23.02.2006 11:32:20
Pole tal väga viga midagi, kõvasti kiirem kui x300 ning SM3 tugi ka olemas
87 |
One
23.02.2006 11:33:59
| Ho Ho kirjutas: |
Pole tal väga viga midagi, kõvasti kiirem kui x300 ning SM3 tugi ka olemas  |
x300 pole vast 100 taala kah..
saja taala eest saab X700, millel puudub sm3 tugi aga selle eest on asi kõvasti kiirem kui see 64bit junn
728 |
EvilKatarn
diivanilill
23.02.2006 17:14:53
Mul on plaanis osta 7800GS ja siin tahaks teada et kui suurt toiteplokki vaja on? Endal on praegu 300W CP
viimati muutis EvilKatarn 26.02.2006 12:41:24, muudetud 1 kord |
81 |
Le Inc
23.02.2006 17:59:51
link :: Xbitlab'si testid
| amddude kirjutas: |
| Mul on plaanis osta 7800GS ja siin tahaks teada et kui suurt toiteplokki vaja on? Endal on praegu 350codegen |
Enamus "mainstream" kaarte on oma võimsustarbega 14..50 W piires. Seega peaks kõlbama küll. Vaata linki.
| Kommentaarid: 56 loe/lisa |
54 |
heikis
23.02.2006 19:46:27
| amddude kirjutas: |
toide vaheta kohe mõne kvaliteetsema vastu. need 350W coded suhteliselt ebastabiilsed asjandused. vaata nt chiefteci poole või siis võta ATF-ist rahakotile sobiv fortron
| Kommentaarid: 338 loe/lisa |
290 |
ivar111
23.02.2006 21:58:31
mhh, kas def. jahutusega 7800GT kõrgemale ei lähegi?
| Kommentaarid: 97 loe/lisa |
86 |
