uus teema   vasta Tarkvara »  Tarkvara »  Internet Explorer 7 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  järgmine
reimers66
reimers66
sõnum 03.08.2005 00:26:37 vasta tsitaadiga
remi, thanks icon_biggrin.gif sain asja korda icon_lol.gif billisoft ei ole kuigi tark asi just ma vaatan
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 60
Elof
Elof
sõnum 03.08.2005 00:27:35 vasta tsitaadiga
remi kirjutas:
TanElofJ kirjutas:
OS: Windows XP
Njah .. mul Vista.
Softpedias oli aga selgelt välja kirjutatud, et sealne versioon XP'le
remi
sõnum 03.08.2005 00:33:05 vasta tsitaadiga
TanElofJ kirjutas:
remi kirjutas:
TanElofJ kirjutas:
OS: Windows XP
Njah .. mul Vista.
Vabandused sel juhul .. ma miskipärast automaatselt eeldasin, et IE7 on vista omanikel.
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 8
Mr.Cool
sõnum 03.08.2005 01:23:55 vasta tsitaadiga
IE7'et saab ilma installimata ka kasutada, kui on soovi lihtsalt proovida:
First extract the IE7-WindowsXP-x86-enu.exe file using something like winrar. Then go to the folder you just extracted and delete the file SHLWAPI.DLL and the folder Update. Then open notepad and just save a blank file in notepad as IEXPLORE.exe.local . Then you will be able to run the iexplore.exe.
Ja väike copy-paste IE team blog'ist, ehk siis uuendused ja bug-fix'id, mis final versiooni tulevad
I’m very happy that we’ve shipped IE 7 beta 1. I wanted to make it clear that we know Beta 1 makes little progress for web developers in improving our standards support, particularly in our CSS implementation. I feel badly about this, but we have been focused on how to get the most done overall for IE7, so due to our lead time for locking down beta releases and ramping up our team, we could not get a whole lot done in the platform in beta 1. However, I know this will be better in Beta 2 – and I want to share how we are placing our priorities in IE.
In the web platform team that I lead, our top priority is (and will likely always be) security – not just mechanical “fix buffer overruns” type stuff, but innovative stuff like the anti-phishing work and low-rights IE. For IE7 in particular, our next major priority is removing the biggest causes of difficulty for web developers. To that end, we’ve dug through a lot of sites detailing IE bugs that cause pain for web developers, like PositionIsEverything and Quirksmode, and categorized and investigated those issues; we’ve taken feedback from you directly (yes, we do read the responses to our blog posts) on what bugs affect you the most and what features you’d most like to see, and we’ve planned out what we can and can’t do in IE7.
In IE7, we will fix as many of the worst bugs that web developers hit as we can, and we will add the critical most-requested features from the standards as well. Though you won’t see (most of) these until Beta 2, we have already fixed the following bugs from PositionIsEverything and Quirksmode:
Peekaboo bug
Guillotine bug
Duplicate Character bug
Border Chaos
No Scroll bug
3 Pixel Text Jog
Magic Creeping Text bug
Bottom Margin bug on Hover
Losing the ability to highlight text under the top border
IE/Win Line-height bug
Double Float Margin Bug
Quirky Percentages in IE
Duplicate indent
Moving viewport scrollbar outside HTML borders
1 px border style
Disappearing List-background
Fix width:auto
In addition we’ve added support for the following
HTML 4.01 ABBR tag
Improved (though not yet perfect) <object> fallback
CSS 2.1 Selector support (child, adjacent, attribute, first-child etc.)
CSS 2.1 Fixed positioning
Alpha channel in PNG images
Fix :hover on all elements
Background-attachment: fixed on all elements not just body
I want to be clear that our intent is to build a platform that fully complies with the appropriate web standards, in particular CSS 2 ( 2.1, once it’s been Recommended). I think we will make a lot of progress against that in IE7 through our goal of removing the worst painful bugs that make our platform difficult to use for web developers.
In that vein, I’ve seen a lot of comments asking if we will pass the Acid2 browser test published by the Web Standards Project when IE7 ships. I’ll go ahead and relieve the suspense by saying we will not pass this test when IE7 ships. The original Acid Test tested only the CSS 1 box model, and actually became part of the W3C CSS1 Test Suite since it was a fairly narrow test – but the Acid 2 Test covers a wide set of functionality and standards, not just from CSS2.1 and HTML 4.01, selected by the authors as a “wish list” of features they’d like to have. It’s pointedly not a compliance test (from the Test Guide: “Acid2 does not guarantee conformance with any specification”). As a wish list, it is really important and useful to my team, but it isn’t even intended, in my understanding, as our priority list for IE7.
We fully recognize that IE is behind the game today in CSS support. We’ve dug through the Acid 2 Test and analyzed IE’s problems with the test in some great detail, and we’ve made sure the bugs and features are on our list - however, there are some fairly large and difficult features to implement, and they will not all sort to the top of the stack in IE7. I believe we are doing a much better service to web developers out there in IE7 by fixing our known bang-your-head-on-the-desk bugs and usability problems first, and prioritizing the most commonly-requested features based on all the feedback we've had.
I do want to be clear that I believe the Web Standards Project and my team has a common goal of making the lives of web developers better by improving standards support, and I’m excited that we’re working together to that end.
- Chris Wilson
http://blogs.msdn.com/ie/Rss.aspx
ups
sõnum 22.09.2005 15:11:53 vasta tsitaadiga
hmh, proovisin ka täna esimest korda...layout on suht segane, pealegi nuppude asetsust ei saa customizeda...sööb 6-ga võrreldes ikka rohkem resursse ja esmapilgul kuidagi kahtlane tundub...ootan kuni full versioon saabub, siis vaatab edasi, seniks kasutan operat...
taifunk
taifunk
sõnum 31.01.2006 22:52:50 vasta tsitaadiga
Avalik testiversioon beta 2 siis saadaval: http://www.microsoft.com/windows/IE/ie7/ie7betaredirect.mspx
Otselink allalaadimiseks: http://download.microsoft.com/download/9/7/1/971d0256-739c-4445-a2fe-f980d7cf3252/IE7B2P-WindowsXP-x86-enu.exe
Screenshotid: http://digitalfive.org/content/internet-explorer-7-public-preview-available.html
Remember this day, men, for it will be yours for all time.
Kommentaarid: 45 loe/lisa Kasutajad arvavad:  :: 3 :: 5 :: 36
Lorien
Lorien
sõnum 01.02.2006 10:08:30 vasta tsitaadiga
Tirisin ära siis selle Beta 2-e. Esimene mulje on siiani väga positiivne icon_smile.gif
Live and let die.
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
2 trini
2 trini
sõnum 01.02.2006 19:36:17 vasta tsitaadiga
See on halb et toolbari ei saa address bariga ühele reale tõsta icon_confused.gif
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 15
Motiv8
Motiv8
sõnum 01.02.2006 19:53:01 vasta tsitaadiga
2 trini kirjutas:
Jah ja seepärast ei kõlba see brauser mitte kuhugi...
Kommentaarid: 17 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 13
madmeix
madmeix
sõnum 01.02.2006 19:57:13 vasta tsitaadiga
Installisin siis beta 2 peale ja mis ma näen ikka tuduvalt etem kui eelmised versioonid, väike konf ning toimib suurepäraselt. Eriti istub mulle kujundus, jätkake samas vaimus - äkki kunagi hakkan kasutama firefoxi asemel(eriti ei usu).
Mis sest, et paadunud firefoxi fänn ning kasutaja (vahest ka opera) - võib öelda, et ma suht üllatund mis pisipehme on välja last, nüüd jään kohe suure huviga finali ootama!
Ärge kommenteerige, see kõigest minu arvamus!!!
Suvi on...
Õues on sügav talv ju...
No sitt suvi on...
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 45
mihhkel
mihhkel
sõnum 01.02.2006 21:51:07 vasta tsitaadiga
üks küsimus neile, kes kasutavad eesti LIP-iga Windowsit ja kellel on IE7 installitud:
kas see kasutajaliidese keele ka "ära rikub" (s.t inglisekeelseks teeb)?
KillFrenzy
KillFrenzy
sõnum 02.02.2006 21:57:36 vasta tsitaadiga
Proovisin installida, aga poole pealt andis mingi access denied errori ja kõik icon_sad.gif . Uninstallida sai ka ainult siis kui lisasin registrisse käsitsi mingid kirjed, muidu ütles et wrong user. Tasub vist normaalset versiooni oodata.
M: Üliharuldane Eesti esimene personaalarvuti ENTEL
freestyler
sõnum 03.02.2006 12:36:56 vasta tsitaadiga
ie7 muutis teksti kuidagi ümaramaks.. kas seda kuskilt seadistada ka saab?
vull
sõnum 03.02.2006 13:00:57 vasta tsitaadiga
roffel. mingi nõme skinn, aga favoriitide manager on ikka sama mõttetu. rohkem ei hakand vaatamagi
Kommentaarid: 46 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 43
-angerjas-
sõnum 03.02.2006 17:29:49 vasta tsitaadiga
First bug found in IE Beta 2.0
Discovered in record time
Robert McMillan
An independent researcher needed just 15 minutes to find the first bug in the Beta 2.0 preview release of Microsoft's Internet Explorer 7.0 browser.
Tom Ferris, of Mission Viejo, California, published his findings just hours after Microsoft released the beta code. Ferris discovered the bug, which causes IE to crash when it tries to read a specially crafted HTML (Hypertext Markup Language) file, using an automated security testing tool called a 'fuzzer' that he wrote to test Microsoft's browsers.
"Whenever they patch, I normally run IE through the fuzzing iterations, just to see if there [is something new]," he said. Ferris posted his findings at 4:30am GMT yesterday, the same day IE Beta 2.0 was released, he said.
Right now the bug can be exploited only to crash the browser, but Ferris says it's likely that his attack could eventually be modified to run unauthorised code on a user's machine.
The vulnerability appears to be exclusive to the IE Beta 2.0 browser, Ferris noted. "This is a completely new bug. I've never actually seen this in any browser before," he said.
Microsoft was not immediately able to comment on Ferris's findings. A spokeswoman for the company's public relations agency said Microsoft is "looking into this".
Ferris has previously discovered bugs in the Firefox and Safari browsers, as well as in Windows XP, but even he was surprised at the rapidity with which this latest vulnerability popped up.
The discovery is one of the quickest such bug-findings on record, according to Mikko Hypponen, manager of antivirus research at F-Secure in Helsinki. "It's probably the fastest from launch to exploit that I've ever heard about," he said.
Microsoft spent millions to improve its software development process to make it more secure. The company has promoted IE Beta 2.0 as a more secure product. But Ferris believes his research shows that the software giant still has work to do in this area.
"I think they're still lacking very common security testing methods. I looked at it for 15 minutes and I was able to find a clean bug," he said. "They still have a lot of work to do."
Ho Ho
Ho Ho
sõnum 03.02.2006 18:35:05 vasta tsitaadiga
Tegu on beetaga. Oletada et seal buge ei ole on äärmiselt naiivne.
Arvestada tasuks ka sellega et kuna IE7's on üsna palju uut koodi siis on seal ka vastavalt rohkem buge mis näiteks IE6's võivad juba lapitud olla. Seda siis nendes kohtades mis on ümber tehtud.
Motiv8
Motiv8
sõnum 13.03.2006 18:36:10 vasta tsitaadiga
freestyler kirjutas:
On keegi sellele lahenduse leidnud, tekst näeb tõesti ümaram ja seda nüüd ka outlook expressis? Lihtsalt häirivalt kehv lugeda seda.
Encodingute muutmisest pole ka eriti kasu!
vull
sõnum 13.03.2006 18:41:35 vasta tsitaadiga
see on firefoxi stripdown versioon ju. mõttetu installida
2 trini
2 trini
sõnum 13.03.2006 19:09:02 vasta tsitaadiga
Motiv8 kirjutas:
Kas see ei aita kui Internet Options-Advanced-Enable visual styles... eest linnuke ära võtta?
viimati muutis 2 trini 13.03.2006 19:10:04, muudetud 1 kord
Motiv8
Motiv8
sõnum 13.03.2006 21:01:12 vasta tsitaadiga
2 trini kirjutas:
Motiv8 kirjutas:
Võtsin linnukese Use Clear Type eest ära, sain pildi endiseks tagasi.
OE-d see võte ei muutnud kahjuks, ei leidnud ka kuidagi, kuidas OE-s seda muuta.
2 trini
2 trini
sõnum 14.03.2006 23:44:53 vasta tsitaadiga
Motiv8,
Sellise progega nagu X-Teq on võimalik sünkroniseerida OE display setingud IE omadega.
http://www.x-setup.net/
Pärast võid ju x-teq maha lasta kui seda kasutada ei soovi.
Motiv8
Motiv8
sõnum 18.03.2006 10:52:47 vasta tsitaadiga
2 trini kirjutas:
Motiv8,
Slazenger
Slazenger
sõnum 18.03.2006 11:05:24 vasta tsitaadiga
mnja, tundub, et see IE lööb küll l2bi ... v2hemalt nii palju kui beta'des n2inud thumbs_up.gif good work, billy-boy... aga noh, ootame l6ppversiooni 2ra, ehk billy suudab ikka persse keerata icon_lol.gif
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 69
macc
sõnum 19.10.2006 16:06:00 vasta tsitaadiga
Update pakkus explorer 7 installi. Installisin. Esimene probleem mida märkasin oli selles, et tekst oli udune. Juskui oleks vale rosolutsioon peal. Igaljuhul katsetama ei hakanud, lasin maha ja kasutan 6. edasi. Ülemist tööriista riba ka ei saanud kokku poole üheks reaks lükata.
kevvu
sõnum 19.10.2006 16:46:46 vasta tsitaadiga
Nii hea ta ei ole elus,et mozilla firefoxi hüljata.
BMW - nimisõna, Saksamaal valmistatav toode, mis tarbib ühte naftaproduktide vedelat segu ja pikendab ostja riista vähemalt poole võrra
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 49
uus teema   vasta Tarkvara »  Tarkvara »  Internet Explorer 7 mine lehele eelmine  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  järgmine
