reimers66
03.08.2005 00:26:37
remi, thanks sain asja korda billisoft ei ole kuigi tark asi just ma vaatan
| Kommentaarid: 65 loe/lisa |
60 |
Elof
03.08.2005 00:27:35
| remi kirjutas: |
Njah .. mul Vista. |
Vistal on IE7 kaasas
Softpedias oli aga selgelt välja kirjutatud, et sealne versioon XP'le
175 |
remi
03.08.2005 00:33:05
| TanElofJ kirjutas: |
| remi kirjutas: |
Vabandused sel juhul .. ma miskipärast automaatselt eeldasin, et IE7 on vista omanikel.
| Kommentaarid: 16 loe/lisa |
Mr.Cool
03.08.2005 01:23:55
IE7'et saab ilma installimata ka kasutada, kui on soovi lihtsalt proovida:
First extract the IE7-WindowsXP-x86-enu.exe file using something like winrar. Then go to the folder you just extracted and delete the file SHLWAPI.DLL and the folder Update. Then open notepad and just save a blank file in notepad as IEXPLORE.exe.local . Then you will be able to run the iexplore.exe.
Ja väike copy-paste IE team blog'ist, ehk siis uuendused ja bug-fix'id, mis final versiooni tulevad
Im very happy that weve shipped IE 7 beta 1. I wanted to make it clear that we know Beta 1 makes little progress for web developers in improving our standards support, particularly in our CSS implementation. I feel badly about this, but we have been focused on how to get the most done overall for IE7, so due to our lead time for locking down beta releases and ramping up our team, we could not get a whole lot done in the platform in beta 1. However, I know this will be better in Beta 2 and I want to share how we are placing our priorities in IE.
In the web platform team that I lead, our top priority is (and will likely always be) security not just mechanical fix buffer overruns type stuff, but innovative stuff like the anti-phishing work and low-rights IE. For IE7 in particular, our next major priority is removing the biggest causes of difficulty for web developers. To that end, weve dug through a lot of sites detailing IE bugs that cause pain for web developers, like PositionIsEverything and Quirksmode, and categorized and investigated those issues; weve taken feedback from you directly (yes, we do read the responses to our blog posts) on what bugs affect you the most and what features youd most like to see, and weve planned out what we can and cant do in IE7.
In IE7, we will fix as many of the worst bugs that web developers hit as we can, and we will add the critical most-requested features from the standards as well. Though you wont see (most of) these until Beta 2, we have already fixed the following bugs from PositionIsEverything and Quirksmode:
Peekaboo bug
Guillotine bug
Duplicate Character bug
Border Chaos
No Scroll bug
3 Pixel Text Jog
Magic Creeping Text bug
Bottom Margin bug on Hover
Losing the ability to highlight text under the top border
IE/Win Line-height bug
Double Float Margin Bug
Quirky Percentages in IE
Duplicate indent
Moving viewport scrollbar outside HTML borders
1 px border style
Disappearing List-background
Fix width:auto
In addition weve added support for the following
HTML 4.01 ABBR tag
Improved (though not yet perfect) <object> fallback
CSS 2.1 Selector support (child, adjacent, attribute, first-child etc.)
CSS 2.1 Fixed positioning
Alpha channel in PNG images
Fix :hover on all elements
Background-attachment: fixed on all elements not just body
I want to be clear that our intent is to build a platform that fully complies with the appropriate web standards, in particular CSS 2 ( 2.1, once its been Recommended). I think we will make a lot of progress against that in IE7 through our goal of removing the worst painful bugs that make our platform difficult to use for web developers.
In that vein, Ive seen a lot of comments asking if we will pass the Acid2 browser test published by the Web Standards Project when IE7 ships. Ill go ahead and relieve the suspense by saying we will not pass this test when IE7 ships. The original Acid Test tested only the CSS 1 box model, and actually became part of the W3C CSS1 Test Suite since it was a fairly narrow test but the Acid 2 Test covers a wide set of functionality and standards, not just from CSS2.1 and HTML 4.01, selected by the authors as a wish list of features theyd like to have. Its pointedly not a compliance test (from the Test Guide: Acid2 does not guarantee conformance with any specification). As a wish list, it is really important and useful to my team, but it isnt even intended, in my understanding, as our priority list for IE7.
We fully recognize that IE is behind the game today in CSS support. Weve dug through the Acid 2 Test and analyzed IEs problems with the test in some great detail, and weve made sure the bugs and features are on our list - however, there are some fairly large and difficult features to implement, and they will not all sort to the top of the stack in IE7. I believe we are doing a much better service to web developers out there in IE7 by fixing our known bang-your-head-on-the-desk bugs and usability problems first, and prioritizing the most commonly-requested features based on all the feedback we've had.
I do want to be clear that I believe the Web Standards Project and my team has a common goal of making the lives of web developers better by improving standards support, and Im excited that were working together to that end.
- Chris Wilson
http://blogs.msdn.com/ie/Rss.aspx
ups
22.09.2005 15:11:53
| hmh, proovisin ka täna esimest korda...layout on suht segane, pealegi nuppude asetsust ei saa customizeda...sööb 6-ga võrreldes ikka rohkem resursse ja esmapilgul kuidagi kahtlane tundub...ootan kuni full versioon saabub, siis vaatab edasi, seniks kasutan operat...
taifunk
| Kommentaarid: 45 loe/lisa |
36 |
Lorien
01.02.2006 10:08:30
Tirisin ära siis selle Beta 2-e. Esimene mulje on siiani väga positiivne
_________________ Live and let die.
| Kommentaarid: 9 loe/lisa |
2 trini
01.02.2006 19:36:17
See on halb et toolbari ei saa address bariga ühele reale tõsta
15 |
Motiv8
01.02.2006 19:53:01
| 2 trini kirjutas: |
See on halb et toolbari ei saa address bariga ühele reale tõsta  |
Jah ja seepärast ei kõlba see brauser mitte kuhugi...
| Kommentaarid: 17 loe/lisa |
madmeix
01.02.2006 19:57:13
Installisin siis beta 2 peale ja mis ma näen ikka tuduvalt etem kui eelmised versioonid, väike konf ning toimib suurepäraselt. Eriti istub mulle kujundus, jätkake samas vaimus - äkki kunagi hakkan kasutama firefoxi asemel(eriti ei usu).
Mis sest, et paadunud firefoxi fänn ning kasutaja (vahest ka opera) - võib öelda, et ma suht üllatund mis pisipehme on välja last, nüüd jään kohe suure huviga finali ootama!
Ärge kommenteerige, see kõigest minu arvamus!!!
Peace!!!
_________________ Suvi on...
Õues on sügav talv ju...
No sitt suvi on... |
| Kommentaarid: 52 loe/lisa |
45 |
mihhkel
01.02.2006 21:51:07
üks küsimus neile, kes kasutavad eesti LIP-iga Windowsit ja kellel on IE7 installitud:
kas see kasutajaliidese keele ka "ära rikub" (s.t inglisekeelseks teeb)?
_________________ ... |
| Kommentaarid: 25 loe/lisa |
24 |
KillFrenzy
02.02.2006 21:57:36
Proovisin installida, aga poole pealt andis mingi access denied errori ja kõik . Uninstallida sai ka ainult siis kui lisasin registrisse käsitsi mingid kirjed, muidu ütles et wrong user. Tasub vist normaalset versiooni oodata.
133 |
freestyler
03.02.2006 12:36:56
| ie7 muutis teksti kuidagi ümaramaks.. kas seda kuskilt seadistada ka saab?
vull
03.02.2006 13:00:57
roffel. mingi nõme skinn, aga favoriitide manager on ikka sama mõttetu. rohkem ei hakand vaatamagi
| Kommentaarid: 46 loe/lisa |
43 |
-angerjas-
03.02.2006 17:29:49
Juba rekordeid löömas
First bug found in IE Beta 2.0
Discovered in record time
Robert McMillan
An independent researcher needed just 15 minutes to find the first bug in the Beta 2.0 preview release of Microsoft's Internet Explorer 7.0 browser.
Tom Ferris, of Mission Viejo, California, published his findings just hours after Microsoft released the beta code. Ferris discovered the bug, which causes IE to crash when it tries to read a specially crafted HTML (Hypertext Markup Language) file, using an automated security testing tool called a 'fuzzer' that he wrote to test Microsoft's browsers.
"Whenever they patch, I normally run IE through the fuzzing iterations, just to see if there [is something new]," he said. Ferris posted his findings at 4:30am GMT yesterday, the same day IE Beta 2.0 was released, he said.
Right now the bug can be exploited only to crash the browser, but Ferris says it's likely that his attack could eventually be modified to run unauthorised code on a user's machine.
The vulnerability appears to be exclusive to the IE Beta 2.0 browser, Ferris noted. "This is a completely new bug. I've never actually seen this in any browser before," he said.
Microsoft was not immediately able to comment on Ferris's findings. A spokeswoman for the company's public relations agency said Microsoft is "looking into this".
Ferris has previously discovered bugs in the Firefox and Safari browsers, as well as in Windows XP, but even he was surprised at the rapidity with which this latest vulnerability popped up.
The discovery is one of the quickest such bug-findings on record, according to Mikko Hypponen, manager of antivirus research at F-Secure in Helsinki. "It's probably the fastest from launch to exploit that I've ever heard about," he said.
Microsoft spent millions to improve its software development process to make it more secure. The company has promoted IE Beta 2.0 as a more secure product. But Ferris believes his research shows that the software giant still has work to do in this area.
"I think they're still lacking very common security testing methods. I looked at it for 15 minutes and I was able to find a clean bug," he said. "They still have a lot of work to do." |
Ho Ho
03.02.2006 18:35:05
Tegu on beetaga. Oletada et seal buge ei ole on äärmiselt naiivne.
Arvestada tasuks ka sellega et kuna IE7's on üsna palju uut koodi siis on seal ka vastavalt rohkem buge mis näiteks IE6's võivad juba lapitud olla. Seda siis nendes kohtades mis on ümber tehtud.
86 |
Motiv8
13.03.2006 18:36:10
| freestyler kirjutas: |
| ie7 muutis teksti kuidagi ümaramaks.. kas seda kuskilt seadistada ka saab? |
On keegi sellele lahenduse leidnud, tekst näeb tõesti ümaram ja seda nüüd ka outlook expressis? Lihtsalt häirivalt kehv lugeda seda.
Encodingute muutmisest pole ka eriti kasu!
Paistab, et tuleb ka beta2 uninstallida vist...
vull
13.03.2006 18:41:35
see on firefoxi stripdown versioon ju. mõttetu installida
43 |
2 trini
13.03.2006 19:09:02
| Motiv8 kirjutas: |
Paistab, et tuleb ka beta2 uninstallida vist...  |
Kas see ei aita kui Internet Options-Advanced-Enable visual styles... eest linnuke ära võtta?
Mina läpakaga küll mingit muutust ei märka tekstis
viimati muutis 2 trini 13.03.2006 19:10:04, muudetud 1 kord |
15 |
Motiv8
13.03.2006 21:01:12
| 2 trini kirjutas: |
| Motiv8 kirjutas: |
Mina läpakaga küll mingit muutust ei märka tekstis  |
Võtsin linnukese Use Clear Type eest ära, sain pildi endiseks tagasi.
OE-d see võte ei muutnud kahjuks, ei leidnud ka kuidagi, kuidas OE-s seda muuta.
2 trini
14.03.2006 23:44:53
Motiv8,
Sellise progega nagu X-Teq on võimalik sünkroniseerida OE display setingud IE omadega.
http://www.x-setup.net/
Pärast võid ju x-teq maha lasta kui seda kasutada ei soovi.
15 |
Motiv8
18.03.2006 10:52:47
| 2 trini kirjutas: |
Motiv8,
Pärast võid ju x-teq maha lasta kui seda kasutada ei soovi. |
Ah, võtsin s..a maha! Lahendas kõik mured
Slazenger
18.03.2006 11:05:24
mnja, tundub, et see IE lööb küll l2bi ... v2hemalt nii palju kui beta'des n2inud good work, billy-boy... aga noh, ootame l6ppversiooni 2ra, ehk billy suudab ikka persse keerata
| Kommentaarid: 74 loe/lisa |
69 |
macc
19.10.2006 16:06:00
| Update pakkus explorer 7 installi. Installisin. Esimene probleem mida märkasin oli selles, et tekst oli udune. Juskui oleks vale rosolutsioon peal. Igaljuhul katsetama ei hakanud, lasin maha ja kasutan 6. edasi. Ülemist tööriista riba ka ei saanud kokku poole üheks reaks lükata.
| Kommentaarid: 24 loe/lisa |
23 |
kevvu
19.10.2006 16:46:46
Nii hea ta ei ole elus,et mozilla firefoxi hüljata.
_________________ BMW - nimisõna, Saksamaal valmistatav toode, mis tarbib ühte naftaproduktide vedelat segu ja pikendab ostja riista vähemalt poole võrra |
| Kommentaarid: 49 loe/lisa |
49 |
