spikhoff
29.01.2006 11:01:35
G71 ehk GF7900 GTX teema |
link :: Guru 3D
GeForce 7900 GTX released in March
Nvidia's 90nm G71 new high-end flagship graphics chip, possibly planned to ship as the GeForce 7900 GTX, will not launch until March according to moles in the industry.
According to the rumors, the chip will contain 32 pixel-processing pipelines in a core clocked at a hefty 700-750MHz. The GDDR 3 memory will run at 800-900MHz (1.6-1.8GHz, effective). The site's moles point out that the new part will deliver significantly better graphics performance than the GeForce 7800 GTX 512 - to match the older part's performance, the G71 would only need to be clocked to 430MHz, apparently. Nvidia is said to have begun sampling the G71, but it appears the part won't ship in boards until the launch, currently pegged for CeBIT, which runs from 9-15 March. That's the best part of two months after ATI is expected to announce its next-generation part, the R580.
Whether the chip ships then remains to be seen, however. Either way, it's expected to feature 48 pixel-processing pipelines and be clocked at around 650-700MHz. Like all X1000-series chips, the X1900 will support DirectX 9 Shader Model 3.0 and ATI's 40-bit video processing system, Avivo. ®
| Kommentaarid: 59 loe/lisa |
54 |
313 |
Alari A.
29.01.2006 11:46:36
OT:täitsa pees kes krt.jõuab tehnikaga võidu liduda.uusi kaarte tuleb nagu seeni peale vihma krt.ma ei suutnud 6800GT võimsustki ära kasutada
| Kommentaarid: 662 loe/lisa |
543 |
One
29.01.2006 11:47:14
| muidu G71 võiks jätta G70-ga samma teemasse kuna asi on nn edasiarendus mitte uus põlvkond
728 |
xerox
29.01.2006 11:50:09
| palju see asi muidu Eestimaal maksaks, mingi 10k? :d
90 |
Auron
29.01.2006 11:54:43
Keegi ei tea mis see maksma hakkab.Eks asja paneb paika ka see mis ta performance on.Kui sõidab ATI X1900XTX'le tuutusse siis võib hinda kruvida palju tahes.Kui on väga võrdsed siis hakkab kemplemine ja see vast kõige parem kuna viib hinda alla.Kui on nõrgem siis...well ostan ise omale XTX'i
131 |
Ho Ho
29.01.2006 12:12:23
| xerox kirjutas: |
| palju see asi muidu Eestimaal maksaks, mingi 10k? :d |
x1900xt maksab olenevalt poest kuni >11k, eks see läheb umbes samasse auku.
[edit]
Ww, üldiselt ma nõustun sinuga kuid taoline seeriauuenduse jaoks tehtud teema pole siin esmakordne. Viimane suurem mida mäletan oli X850 kohta.
86 |
29.01.2006 12:44:49
| Ho Ho kirjutas: |
| xerox kirjutas: |
x1900xt maksab olenevalt poest kuni >11k, eks see läheb umbes samasse auku. |
X1900XTX on 10K poes meil
_________________ Gamertag: SKGXB | PSN: SKGPS
Müüa: Xbox 360 S 4GB (UUS)
Müüa: Xbox 360 S 250GB (UUS) |
313 |
prigo
29.01.2006 15:02:04
Jah,alguses on need hinnad ikka suhtelislt karvased.
| Kommentaarid: 17 loe/lisa |
15 |
spikhoff
31.01.2006 01:15:35
NVIDIA CFO Marv Burkett and VP Michael Hara at CSFB Annual Technology Conference 2005 revealed more about the GeForce 7 series where the 90nm G72 (GeForce 7200) and G73 (GeForce 7600) will be announced in Q1 next year. G72 will be 64-bit and support TurboCache technology. Marv Burkett revealed that GeForce 7200 and 7600 series will last between one to one and half year. G71 will be 90nm and is expected to be much higher clocked at 750MHz. As for G80, the development process has been smooth and is slated for mid 2006 release which i suppose during Computex 2006. Also G80 will support Shader Model 4.0.
http://www.hkepc.com/bbs/viewthread....extra=page%3D1
http://www.mchsi.com/desmet/outgoing...dvhardware.net
http://www.vr-zone.com.sg/?i=3005
This card could look like this in April 2006?
Nvidia GeForce 7900 Ultra @750MHz / 1.9GHz 256-bit 512MB GDDR 3 SDRAM 1ns (Samsung K4J52324QC-BJ10) 1000MHz
http://www.samsung.com/Products/Semi...mory/index.htm
54 |
Mario153
31.01.2006 12:07:54
| See G71 jutt jookseb nüüd paraleelselt kahes teemas. Mõlemat on üsna nõme jälgida.
| Kommentaarid: 56 loe/lisa |
50 |
Tõnu Tõukemõnu
31.01.2006 18:22:16
| Skeptik kirjutas: |
| Ho Ho kirjutas: |
| xerox kirjutas: |
X1900XTX on 10K poes meil |
Hmm... X1800XT 512MB variant on Eestis kusagil ~9000 kandis. Siit tekib küsimus, kui suureks võiks hinnata X1900XTX ja 1800 seeria tipptaseme vahet vms?
Uusi kaart tuleb viimasel ajal tõesti väga massiliselt.. imho jäi see X1800 seeria üldse kuidagi vahele... paljud seda X1800XT varianti ikka osta jõudsid? Nüüd ta juba vanaraud mõned nädalad ja juba mitmed uued peal
_________________ Tõukan mõnuga |
| Kommentaarid: 12 loe/lisa |
12 |
One
31.01.2006 18:26:56
kirjutage G70 teemasse
728 |
taifunk
| Kommentaarid: 45 loe/lisa |
36 |
