| Kas formaadiga parandad, haldad, konfid süsteeme? |
| jah |
47% |
[ 200 ] |
| ei |
52% |
[ 222 ] |
| hääli kokku : 422 |
Ho Ho
04.12.2005 23:21:19
Esimeselt lingilt:
"Why would you want to do a low-level format on a modern hard drive? The main reasons are virus infection and development of bad sectors."
Viirusi parandatakse tänapäeval vähe korralikumate tööriistadega kui format.
Bad sectorite vastu reeglna abi ei ole. Praegused kettad adresseerivad badid automaatselt ümber varuks oleva ruumi peale. Kui see otsa saab ning bade enam ümber ei allokeerita võib ketta enamasti nagunii metsa visata.
Samalt lingilt:
"For security purposes, you would want to take another direction"
"IDE hard drives can only be properly low-level formatted at the factory"
"ortunately, all newer hard drives only operate in a translation mode, so we can successfully do a format that could be more properly called a mid-level format. I don't know of any virus that can infect the low-level format installed by the manufacturer."
" 1. All hard drives are initially formatted in native mode, and all, except the oldest IDE drives, operate in translation mode. The special tracks containing information specifically for the controller cannot be accessed in translation mode. Even if you could access this information, the BIOS and operating system would not be able to read the hard drive, as they cannot handle Zoned Bit Recording. (See Software Utilities below for more on Zoned Bit Recording)
2. All computer viruses are programs. They may be Java script, Word Macros, or machine language. They must be run on top of the operating system. The operating system cannot access your IDE hard drives, except when the drives are in translation mode."
Teiselt lingilt:
"If you've explored other areas of this material describing hard disks, you have learned that modern hard disks are much more precisely designed and built, and much more complicated than older disks. Older disks had the same number of sectors per track, and did not use dedicated controllers. It was necessary for the external controller to do the low-level format, and quite easy to describe the geometry of the drive to the controller so it could do the LLF. Newer disks use many complex internal structures, including zoned bit recording to put more sectors on the outer tracks than the inner ones, and embedded servo data to control the head actuator. They also transparently map out bad sectors. Due to this complexity, all modern hard disks are low-level formatted at the factory for the life of the drive. There's no way for the PC to do an LLF on a modern IDE/ATA or SCSI hard disk, and there's no reason to try to do so."
"Warning: You should never attempt to do a low-level format on an IDE/ATA or SCSI hard disk. Do not try to use BIOS-based low-level formatting tools on these newer drives. It's unlikely that you will damage anything if you try to do this (since the drive controller is programmed to ignore any such LLF attempts), but at best you will be wasting your time."
Ehk siis mis on su juttu point kui su enda lingid su öeldule vastu räägivad?
| tahanteada kirjutas: |
| Et kui kettale on tehtud 9 formaati, kuidas on võimalik välja lugeda näiteks 2 formaadi järgne informatsioon sellelt kettalt |
Loe OFFF'i postitust quick ja full formati vahel. Korralikud taastusproged suudavad ka kõige kummalisematest olukordades kustutatud andmeid välja lugeda.
Olen ühelt 1.44MiB flopilt lugenud välja umbes 5a vanuseid töökorras dokumente ja faile koguväärtuses ~5MiB eest ning seda ühe korraga. Kuidas see võimalik oli, ma ei suuda ette kujutada, Ju vist mingi anomaalia.
Btw, kui õieti mäletan siis vähe rangema sisekorraga asutustes on ette nähtud et kõik kustutatu kirjutatakse neli kuni 16 korda üle suvalise bitimustriga et teha andmete taastamine keerukamaks. Ühe korra nullidega üle kirjutamine kohe kindlasti andmete taastamist oluliselt ei takista.
Kui tahaks teha andmete taastamine keerukaks* oleks mõttekas suunata /dev/random /dev/XdY peale tsüklis N korda, iga kell parem kui suvaline "low level format" või kettatootja progedega tehtu full format.
*)mina ei näe selleks põhjust. Võibolla kui on tarvis oma hämaraid tegusid varjata siis veel.
Pealegi, mida halba teeb see kui teha full formati asemel quick format? Siiani olen sind igal poon näinud pasundamas et vead tulenevad sellest et ei viitsita full formatit teha kuid OS'il pole mingit vahet kas vanad andmed kirjutatakse millegagi üle või mitte, tema jaoks on oluline ainult failisüsteem.
87 |
Ohohh
04.12.2005 23:45:10
Mul toanaaber parandas Maci formatiga
(OK. Tegelikult ei olnud asi ainult tekkinud imelikus probleemis. Tal oli samas pool ketast antud linuxile ja ta v6ttis formatiga kogu ketta OSX jaoks)
| Kommentaarid: 6 loe/lisa |
27.01.2006 20:27:34
On küll vana teema ülestõstmine 8) , kuid leidsin hea selgituse miks ma leian alati nii palju aega (kasvõi vajalikul arvul tunde suurte ketaste korral), et täisformaati kasutada ja et miks ma seda suhteliselt sagedasti teen - viimati paar päeva tagasi, et Microlingi poolt kettale ehitatud jaburast failisüsteemist (virtuaalsest kettast) lõplikult ja jäädavalt lahti saada.
Ja kui keegi mu teeoria ümber suudab lükata, saab preemiaks virtuaalse või virtuaalse Coca, sõltuvalt vanusest
Ehk siis: Enne kui maja hakatakse ehitama, rajatakse vundament. Ehk siis - vundmendi kvaliteedist sõltub see kuidas ja kui kaua maja selle vundamendi peal püsti püsib või ümber kukub
Täpselt sama on formaadiga - formaadi kvaliteedist oleneb see kuidas hilisemalt andmebaas sellel on ja töötab 8) Ehk siis nii nagu ei poolda ma suvalisi vundamente millele on püstitatud suvaline majake, nii ei poolda ma ka suvalisi liht-kiirformaate või kopitud virtuaalkettaid. Need jooksevad nii ehk teisiti kiiremini kokku kui korrektne lähenemine
211 |
RCC
27.01.2006 20:38:28
jah õige, - st võtan ketta pakendist välja teen 1 täispartitsiooni (ei jupita) formaadin ära ja töötab kuni oma ketta eluaja lõpuni
aga mitte et ma kahe päeva pärast uuesti pihta hakkan
9 :: |
147 |
iceincube
27.01.2006 20:43:31
nüüd jäi see teema ka mulle silma. Kuna eriti tulemyride ja viirusetõrjetega ei tegele, siis tuleb keskmiselt iga 2 kuu tagant OS-i partatsioonile format peale. See siis kui tõesti enam ei viitsi võidelda viirusega. tund OS-i installi ja kõik vaegused ja üleliigne pahn kadund, ja otsast peale jälle.
sõprade ketastega ei hakka üldse mingit erilist vaeva nägema. Kui WIN joosta ei taha, ajan ahju.
| Kommentaarid: 39 loe/lisa |
37 |
Ho Ho
27.01.2006 21:08:32
| HPTA374 kirjutas: |
| jah õige, - st võtan ketta pakendist välja teen 1 täispartitsiooni (ei jupita) formaadin ära ja töötab kuni oma ketta eluaja lõpuni |
heh, üsna vastupidine minu tegevusele
Ketastel on hunnik partitsioone mis on lisatud LVM2 volume gruppi, vastavalt vajadusele eraldan sealt partitsioone ja/või muudan olemasolevate suurusi ning teen sada muud imet. Näiteks praeguses kodumasinas olev OS on umbes sarnaselt sedasi üle elanud kolm erinevat füüsilist kõvaketast ning kümmekond kopeerimist ühtedelt partitsioonidelt teistele ilma mingeid kloonimisi või backupe kasutamata. Kõik käis vana-hea cp'ga
Mulle lihtsalt meeldib erineva kasutusega asju eraldi hoida. Näiteks valdavalt staatilised asjad on ühtedel partitsioonidel (/usr, /, /opt), tihti muutuvad teistel (/tmp, /var, /usr/portage), suuremad andmefailid omakorda eraldi (/home, mp3, genereeritavad katseandmed). Kokku paikneb OS mul seitsmel eri partitsioonil plus veel lisaks viis muud partitsiooni muude andmetega.
87 |
RCC
27.01.2006 21:25:34
ka mulle meeldib asju eraldi hoida : 1 ketas on os (skasi) mp3 on teine kolmas neljas, avid on 5 staff 6 jne a parte tegema veel? et nad kiiremini täis saaks küll ei taha
9 :: |
147 |
RKsilver
27.01.2006 21:34:19
| igatahes ma üritan ennem repair teha,kui see ei õnnestu siis ketas teisse arvutisse kõik tähtsad asjad teisse arvutisse kettale ja siis format 8)
| Kommentaarid: 172 loe/lisa |
140 |
Ho Ho
27.01.2006 22:27:03
| HPTA374 kirjutas: |
| a parte tegema veel? et nad kiiremini täis saaks küll ei taha |
Kui partitsioonide suuruse muutmine käib paari sõrmeliigutusega siis miks mitte? Installin OS'i või mõne suurema partitsiooni ära ning muudan partitsiooni vastavalt nii suureks et saaks üle jääva ruumi teiste partitsioonide jaoks kasutusse võtta. LVM2 rõõmud
87 |
RCC
27.01.2006 22:30:35
a misasja ma neist ikka muudan
9 :: |
147 |
Ho Ho
27.01.2006 22:47:40
näiteks peale süsteemi installi mutuub /usr kataloogi* maht väga harva vastupidselt winile. Seega võin rahuliku südamega partitsiooni muuta enam-vähem nii suureks et too kataloog sinna peale ära mahuks. Kuna see püsib praktiliselt staatilisena siis ei ole seal karta mingisugust fragmenteerumist ega muid jamasid. Seega kui näiteks wini all teeksin ~10G partitsiooni wini ja program filesi jaoks siis üsna kindlalt on seal mõnda aega umbkaudu 4G vaba ruumi. Aja möödudes, wini uuendades ning lihtsalt dll'ide kuhjudes see ruum pikapeale täitub seega ei saa partitsiooni kohe väikseks teha. Samas on ju tegu raisatud ruumiga, vähemalt senikaua kuni see pole veel täitunud.
*) umbes sarnane windows ja program files'i kataloogile, ainus vahe et igasugu temp ja konfiguratsiooni andmed on mujal katalooigides.
Linuxis taolist asja üldjuhul ei toimu. Mis on installitud on installitud ning ükski programm omavoliliselt sinna kataloogidesse uut inffi ei kirjuta. Selleks on teised kohad mis minul on paigutatud teistele partitsioonidele. Näiteks tmp ja /usr/portage, kust käib lühikese aja jooksul läbi sadu tuhandeid faile, on eraldi partitsioonide peal et hoida ära teiste partitsioonide fragmenteerumist.
LVM2'ga on see lõbu et ta suudab partitsioone luua suvalistest kettaseadmetest ning üks partitsioon võib korraga asuda ühe või mitme ketta erinevates piirkondades, kui just ise ei lase neid ümber migreeruda. Seega iga partitsiooni küljest võetud tüki võib probleemivabalt liita suvalise teise partitsiooni külge. Mis kettaseadmel või ketta piirkonnas see asub ei oma vähimatki tähtsust.
87 |
peab meeldima.
27.01.2006 22:54:58
Ega kui satun arvuti taha, mis ilgelt igasugust jama täis, siis ikka ei viitsi ikka küll tõrjete jms. jamada. Kliendile vajalikud asjad kirjutan cd-le ja format c.
Aga omal pole vist juba 2 aastat formatit teinud. Ei ole vajadust lihtsalt.
_________________ Arbeit macht frei. |
| Kommentaarid: 63 loe/lisa |
61 |
RCC
27.01.2006 22:57:27
ma ei tea mis pisvinn sul on et ta pidevalt üles paistetab ja hirmsasti ruumi võtma hakkab tõsi see automaatne uuendus kipub igast nalja tegema seal kus pole vaja aga reeglina \pisvinn kaust kuigivõrd ei muutu ja programmidega on nii palju sa neid sinna lisad ja ära võtad pmst sama seis mis linnuka all
9 :: |
147 |
raxz
28.01.2006 02:10:50
Ma ei saa aru, kuidas on võimalik arvuti viiruseid ja muud saasta täis korjata.
Ühtegi viirusetõrjet peal ei hoia, kord poole aasta sees saab viirusekontroll ja igasugused spyware kontrollid tehtud, kuid peale küpsiste ei leia programmid midagi. Tulemüüri ei ole samuti installitud.
Arvutit kasutan iga päev mitu tundi, tirin netist igast saasta, surfan erinevatel lehekülgedel, keygene ja cracke otsin ka mõnikord, kuid nendelt kahtlastelt lehtedelt ei tule ka midagi.
Protsesside all jooksevad vaid need programmid, mis mina olen tööle pannud, ühtegi kahtlast kausta pole.
Kas ma olen imelik?
Sõpradel/tuttavatel saab ikka kettaid vormindatud, kuna see lihtsam, kui kümneid viirusi välja ajada.
Eriti juhul, kui viirus on kusagil partitsioonitabelis peidus jne.
| Kommentaarid: 46 loe/lisa |
45 |
Ho Ho
28.01.2006 02:35:54
| HPTA374 kirjutas: |
| ma ei tea mis pisvinn sul on et ta pidevalt üles paistetab ja hirmsasti ruumi võtma hakkab |
Vaadates venna arvutis olevat ~3 kuud vana wini installi näen et wini kataloogi suurus on 1.7GiB. Esimese asjana märkasin et too kataloog on risustatud installi backup'ide (~300M), hunniku logifailide ning desktopi piltidega [sic!] mis minu arvates ei käi süsteemsete programmidega ühte patta. Samuti oli sinna maha jäänud itunes'i installifailid ~60M väärtuses. ~70M oli miski driver cache mis minu teada ei ole süsteemile vajalik fail, Suurema osa ehk siis pea 1G võttis enda alla system32 mis peaks minu teada sisaldama wini enda eluks vajalikke programme-teeke. Sellest pea pool oli dllcache mille otstarbes ja vajalikkuses ma kindel ei ole. Igatahes mis iganes ta on, mulle tundub et selle suurus ei ole normaalne.
Pildike kettaruumi kasutamise kohta wini kataloogis on siin:
Loomulikult saaks kõik selle jama käsitsi kallale minnes ära kõrvaldada kuid minu arvates võiks OS olla ise piisavalt inteligentne et sellist jama ei tekitakski
| HPTA374 kirjutas: |
| reeglina \pisvinn kaust kuigivõrd ei muutu ja programmidega on nii palju sa neid sinna lisad ja ära võtad pmst sama seis mis linnuka all |
Winis kipuvad programmid oma seadeid program files'i kataloogi paigutama seda pika peale suuremaks venitades. Linuxis pannakse valdavalt globaalsed seaded /etc'i ning kasutaja põhised seaded ja andmed /home/kasutajanimi/.programm kataloogi. Ühesõnaga wini laadset common files'i ei panda programmidega samasse kohta.
Lisaks tähendab kasutajapõhiste andmete taoline eraldamine et siis võib kõiki seadeid jagada mitme eri distributsiooni vahel.
87 |
silver010
28.01.2006 04:00:24
nujaa, lugesin umbes pooleni, rohkem ei viitsinud. minuarust on palju kindlam teha kohe algselt esimese win-i peale panemisel ketas kaheks või rohkemaks pardiks, win - esimene part, mängud + suured failid, muu jama - teine part.
kõiki vajalikke service packe, hotfixe hoiad teisel pardil spetsiaalses kaustas, tasuta programmide kõige uuemad installerid samuti, samuti hetkeriistvara kõige uuemad draiverid. midagi nässu läheb, lihtsalt format c ja kogulugu, samuti minuarust on selline tegevus ka dumbuseritele väga lihtne, oletame stsenaariumit: sõber kutsub külla, et tee win korda vms, lähen kohale, ahaa, mingi arvutispets on teinud vaid ühe pardi , viskan kõik vajalikud failid mingisuguse rw meedia või mujale. teen 2 parti ära, win u 10gb, ülejäänud teisele pardile... seletan, et nonii, kõik oma tähtsad asjad ja progede installerid sinna kettale, samuti mängud, mis vähendab tugevalt laadimisaegu ja parandab üldist perfoormansit, siis kui tal endal peaks midagi peeti minema, ei pea ta enam mind kutsuma vaid toimib täpselt nii nagu sai seletatud, mure murtud pikaks ajaks ...
tegelt ma eriti ei mõista miks kasutaja HPTA374 nii meeleheitlikult üritab kõiki siin veenda, et mitte formatit teha, imo palju lihtsam, kindlam ja kiirem viis kordaseadmiseks, ja eriti kaval on veel see kui ketas on näiteks 200gb, peaaegu ääreni täis, raskelt fragmenteerunud ja siis pole küll sealt mingeid kiireid wini või muusid toiminguid loota
| Kommentaarid: 45 loe/lisa |
42 |
iceincube
28.01.2006 04:07:13
see mitme partitsiooniga lahendamine on minu arust ka ikka kige õigem tegu. Vähemalt üks on kindel, et tulevikus vähem peavalu.
Kui ma veel väike olin, oli mul ka üks part ainult ja ohh õudust kui oli vaja Winni uuendama hakata. nüüd muud moodi enam ei oska.
väga mugav on lihtsalt.
ja mis puutub Format C: -sse siis mul on kysimus. Milleks selline käsk siis üldse välja mõeldi, kui mitte kasutamiseks.
Niiet kasutagem oma arvuti(OS)- i kõiki võimalusi.
37 |
28.01.2006 04:17:19
Selles teemas tuleb välja kahe erineva maailma kokkupõrge. Ühed eelistavad vanasid asju parandada või teha nad juba algsena sellised, mis praktiliselt ei kulu, ei vanane. Teised aga lähevad kaasa tarbimiskultuuriga ning viskavad vana asja minema ning võtavad uue mudeli asemele, ei olegi huvitatud pika-ajalisusest, kestvusest ja muust sarnasest. Väga selged paralleelid tekivad aastakümnete taguse maailmapildiga(mitte tingimata Eestis vaid üldse) ja tänapäevaga. Ehk siis vanasti olid "asjad"(autod, jalanõud, kodutehnika) ehitatud pika perspektiiviga ja vastupidavana, tänapäeval on aga kõik nii nõrguke, et lausa eeldab, et sa viskad peale aastast pruukimist vana mudeli minema(kuna see on niikuinii juba moest väljas ja "old") ja soetad uue.
Kui nüüd täiesti teemast välja kalduda siis selline maailmapildi muutus pole ainult mitte "asjadega" toimunud. Kultuuri ja inimsuhetega on lugu täpselt sama.
147 |
remi
28.01.2006 04:18:58
| On küll vana teema ülestõstmine 8) , kuid leidsin hea selgituse miks ma leian alati nii palju aega (kasvõi vajalikul arvul tunde suurte ketaste korral), et täisformaati kasutada ja et miks ma seda suhteliselt sagedasti teen - viimati paar päeva tagasi, et Microlingi poolt kettale ehitatud jaburast failisüsteemist (virtuaalsest kettast) lõplikult ja jäädavalt lahti saada. |
Kui mina saaksin rankiks "Lõuapoolik" siis rohkem ma selle nime alt ei kirjutaks. Häbi oleks, noh.
Aga paistab et sinu jaoks on see meelitus.
Enivei, ML partitsioneerimine on välja kujunenud kasutajaküsitluste põhjal. Suur enamus soovis dariverite jms. jaoks eraldi partisiooni ja nii ka tehti.
Seda juba siis kui sina veel rääkidagi ei osanud.
| Kommentaarid: 16 loe/lisa |
RCC
28.01.2006 13:51:59
Kusjuures sattus paar uuemat mli masinat ja ei jõudnud ma seda paarigigast jupitamist ära kiruda süsteem part oli vist ntfss kah, tulevikus vaja näiteks ringi teha siis saab kurja vaeva näha et staff ära kopida part maha võtta ja fat32 hex teha ja üleüldse sellele xpeele annan sealt kohe kinga
9 :: |
147 |
remi
28.01.2006 20:38:20
Asi selles ongi, et enamuse jaoks on see lisapart abiks pigem. HV kasutajaskond on enamasti suuremate teadmistega ja neile meeldib asju oma käe järgi sättida.
HPTA374, kui sa xp'le kinga annad siis milles probleem .. ei oska kettalt partitsioone maha võtta peale seda?
K_
28.01.2006 23:18:36
Korra olen siiani formatit kasutanud, sest windows oli juba pea 2a vana ja asi läks juba päris läbuks kätte . Muidu format hea asi, mul täpselt windowsi partitsioon ja saan ilusti, kui vajadus windowsi kiiresti välja vahetada (Kui tõesti muud väljapääsu ei näe)
silver010
29.01.2006 00:05:11
| silver010 kirjutas: |
tegelt ma eriti ei mõista miks kasutaja HPTA374 nii meeleheitlikult üritab kõiki siin veenda, et mitte formatit teha, imo palju lihtsam, kindlam ja kiirem viis kordaseadmiseks, ja eriti kaval on veel see kui ketas on näiteks 200gb, peaaegu ääreni täis, raskelt fragmenteerunud ja siis pole küll sealt mingeid kiireid wini või muusid toiminguid loota  |
lisan juurde, et sellist teguviisi eriti enda arvutis ei kasuta, kuna liiga suur häda oleks kõiki asju jälle käejärgi seada(programmide settingud), aga üldiselt sõpradele, ja eriti dambjuuseritele soovitan format teha, vähem häda, vähem aega, kindlam tulemus aga tegelt teemaalustaja võiks selgitada, miks talle on pinnuks silmas xp, ntfs , partitsioneerimine, formati tegemine(quick format sul nüüd küll kõvaketast ei kahjusta/kuluta mingit pidi)
ning lisaks veel, et alati ei ole täiesti kindel kas mõne viiruse, adware, driverijama, muu jama asi on 100%-iliselt kõrvaldatud, ja siis on see näiteks minujaoks juba eetiline asi, et mitte kasutada operatsiooni süsteemi mis võib olla vundamendist alates mäda ning mis võib tekitada andmekadu, ebastabiilsust ja muud
42 |
RCC
29.01.2006 13:51:05
HPTA374, kui sa xp'le kinga annad siis milles probleem .. ei oska kettalt partitsioone maha võtta peale seda?[/quote]
aga mõtle seda et seal võib olla 5x500gb staffi? näiteks stripes ei hakka ju seda ilma päkkappimata maha võtma
9 :: |
147 |
silver010
30.01.2006 03:24:16
tegelt teemaalustaja võiks selgitada, miks talle on pinnuks silmas xp, ntfs , partitsioneerimine, formati tegemine(quick format sul nüüd küll kõvaketast ei kahjusta/kuluta mingit pidi) |
ehk saame kõik targemaks?
42 |
Death
30.01.2006 09:29:37
winil VÄHEMALT 2 partitsiooni ja ehitus nii et poleks vaja aastaid otsast alustada...Linux is olen harjunud klaassikalise 3 partisiooniga(boot, /, home) lahendusega + veel parte stuffi jaoks.
_________________ "To be or not to be?" is a question of when, not if. |
36 |
RCC
30.01.2006 14:18:22
[quote="silver010"]
oled täiesti valesti aru saanud, algsed teema algatamise põhjused olid hoopis teised
9 :: |
147 |
Rimm
30.01.2006 16:00:01
Harrastan u aastas 1 või 2 korda clean installi - kõige pealt vajalik sodi teisele kettale ja siis uus sys. kõik võimalike parandustega üles. Vennale-õele, emale-isale, naisele kah tuleb mõnikord paar korda aastas puhastamine kasuks
| Kommentaarid: 34 loe/lisa |
33 |
silver010
31.01.2006 00:14:40
| HPTA374 kirjutas: |
oled täiesti valesti aru saanud, algsed teema algatamise põhjused olid hoopis teised |
seda ma ei väidagi, et need sinu teemaalgatus põhjused olid, kui teemat veidi lugedes oli selgelt aru saada, et hoidud eeltoodud "asjadest", tekkis huvi, et miks siis
42 |
RCC
31.01.2006 13:52:56
no teema ise räägib enda eest ju, ja muide naljakat pole siin midagi et see siia rubriiki tõsteti
9 :: |
147 |
p2ep
31.01.2006 16:06:48
| Kui ikka saasta täis masinale System restore, 3 viirusetõrjet, 2 spyware eemaldajat, HijackThis ja Win repair ei aita, ei viitsi mina küll ükshaaval exe-sid ja midaiganesveel tervest masinast kopeerima hakata. Nii et ca 1/3 kohaga mina kaa!
| Kommentaarid: 32 loe/lisa |
28 |
Ernits
17.02.2006 22:28:58
Kirja ka mina.....
Enda partitsioonid ja süsteem ka nii planeeritud, et oleks mugav vähemalt iga paari kuu tagant format teha
Nõustun täielikult, ma küll kasutan teist hdd aga põhimte sama. hoiab aega kokku ja kiirendab...
| Kommentaarid: 99 loe/lisa |
86 |
Marduuhin
19.02.2006 11:23:28
Nu 50% juhtudest saab formaadiga kiiremini vinnikese korda, kui igast muu juraga.. Sys. restore on ka suht kena asi.
_________________ Eesti õigekeelsussõnaraamat ÕS 2018 |
108 |
Carl
09.03.2006 13:43:08
xp rekord uptime 4 kuud
xp install peaks olema 4 aastat vana, pidevas ja igapäevases kasutuses
slack masin hetkel üleval olnud 266, rekord 400 päeva kanti.
| Kommentaarid: 48 loe/lisa |
45 |
Popp
05.08.2006 12:48:33
| mul on rekord kuskil 150 päeva....vahepeal sai format C tehtud lausa 3 korda päevas (pole nali). Muidu keskmiselt iga 40-60 päeva tagant. Linuxiga on need jamad ära jäänud
| Kommentaarid: 67 loe/lisa |
54 |
RCC
05.08.2006 13:22:33
ei mäletagi mis see rekord on, aastaid kindlasti vast kolm või neli, ei mäleta enam täpselt misajal uus emaplaat ostetud sai, uptime on raske saada, kuna pidevalt on vool ära, seega üle 100 päeva uppi kahjuks ei tule
9 :: |
147 |
ups
05.08.2006 14:06:02
isiklikule arvutile saab aastas kord-paar win pardile format tehtud, siis kui tõesti on süsteem igast jätteid täis.
tööl hallatavatele arvutitele, mis aetakse kiirelt umbe on tehtud ghost image confitud süsteemist koos programmide jne, seal plaat sisse ja 15min pärast on uus süsteem peal ja igati
| Kommentaarid: 1159 loe/lisa |
725 |
StuffMaster
09.08.2006 16:28:33
| Olen ka asjapulk
| Kommentaarid: 59 loe/lisa |
54 |
Alari A.
09.08.2006 16:33:52
endalegi siin HV mõned "targad" formatit soovitanud
kord vist ei saanud kx projecti drivusi audigyle peale.olen üna kindel,et formati soovitajal ei olnud aimugi mis ime asi on kx projecti driver
| Kommentaarid: 679 loe/lisa |
552 |
doh
09.08.2006 18:27:58
2x viiruse saanud ja formaadi teinud ja muidu mingi 3x Mingeid metsikuid failihunnikuid pole ja formaat koos tarkvara ja driverite installiga võtab ~1h 20min ja samal ajal vaatan telekat! 8)
| Kommentaarid: 52 loe/lisa |
50 |
djkiller
09.08.2006 18:31:38
| ah mina teen nii kui uimane on ei hakak tõesti jändama mingi registrite puhastamisega jne jne .panen uuesti winni peale ehk format ja asi ants;) ise kasutan win 2000. üks kõrvale kalle küssa.kas win xp jookseb paremini kui 2000.ehk buudib end kiiremini üles jne .
| Kommentaarid: 223 loe/lisa |
202 |
Alari A.
552 |
djkiller
09.08.2006 18:43:03
| ei ütle et päris ron nüüd perse all.aga üldse isegi modimata.nuh mälu ja vb hdd sööb rohkem .nüüd kui jälle mälu 512mb (enne oli 1gb) hakkab win uimerdama ja uus kõvaketas kah lollike. nimelt http://www.k-arvutisalong.ee/index.php?lang=est&main_id=50&p_id=014481 ja asi ei jookse kohe üldse nagu varem.nuh mälju jah vähem.enne oli samsungi kõvaketas kah 80gb 2mb
202 |
Death
10.08.2006 09:32:27
Ma ei ta kas ma imelik või mida, aga IMHO XP pangestumine korras raua puhul on võõras nähtus. Sama ka linuxi kohta. Ja "formatit" tehase keskeltläbi üks kord arvuti eluea jooksul, esialgset systeemi paigaldades või kui preinstalli partitsioonidega midagi nihu läheb. Xp installatsioonirekord on 4aastat ja lõpuks lihtsalt sai linuxiga asendatud. Linux on nyd pisut üle aasta peal olnud ja kanantab pisut pideva loomkatsetamise all aga isegi suuremate jamade puhul sai parem olemasolevat lapitud kui otsast alustatud...
36 |
friik1
10.08.2006 09:51:59
Formatit harrastan suhteliselt harva. suuremate süsteemi upgradede järel ning kui mõne eksperimendiga süsteem õhku lastud (õnneks üsna harva ). Enamasti kasutan ikka kõikvõimalikke vahendeid, et süsteemi töös hoida. Milleks raisata pool päeva installile, draiveritele, backupile, programmide paigaldamisele ja confile, kui on võimalik taastada süsteemi endine töökiirus ja stabiilsus?
XP on stabiilne ja töökindel asi. Kõik on kasutajates, kes lihtsalt ei oska süsteemi töökorras hoida. Sõpradel arvuteid hooldades proovin võimalikult palju ette-taha ära teha, et nad jumala eest ei peaks hakkama mingit tundmatut päritolu kahtlase töökindlusega softi installima.
170 |
mTim
10.08.2006 12:06:01
mina just eile tegin low leveli oma 80GB systeemikettale ja panin uue winni, sellest polnud mingit abi.
nimelt oli windowsil kogu aeg probleem, et corrupted file ja corrupted file, koguaeg tegin scndiske koguaeg sai korda, lõpuks hakkas win niipalju erroreid peksma, et jube, mänge installida ei saanud, firefox käima ei läinud ja ühe BSOD sain kah mida ei jõudnud kahjuks lugeda.
Eile panin ka uue wini peale, töötas ilusti, öösel kuulsin läbi une et arvuti tegi 2 korda resa, ok äkki voolukatkestus või miskit. hommikul ärkan üles vaatan: Corrupted file jah tere hommikust sullegi.
tõepoolest Win ketta pealt tegin chkdski aga enam ma taskbari näinud pole oma winil, safe modis kah sisse ei saa...
Nüüd kahtlustan ikkagi mälu ja koju lähen sis hakkan toda testima.
krt ma vist enda arvutile windowsi tsirka 30 korda installinud
_________________ Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad |
| Kommentaarid: 47 loe/lisa |
42 |
Draax
10.08.2006 12:16:32
Loomulikult teen. Mitte küll enda PC-le, selle hoian ise jooksvalt korras.
Tavaline case mille puhul mind appi kutsutakse, on see et arvuti ei tööta, sest mingi viirus on sees. Ega ma mingi paberitega IT-ekspert pole, aga veidi selle kasti hingeelust tean ja kuna enamus abipalujaid on noored neiud, kelle jaoks arvuti = monitor, siis ei saa ju ei öelda.
Selliste juhtumite puhul on format palju lihtsam väljapääs, kui lugematute turvaaukude lappimine ja tulekahju kustutamine viirusetõrje jms. näol. Päästad vajalikud failid ära, clean format, uuesti windows peale, vajalikud uuendused alla laadida, viirusetõrje, nuhkvaratõrje peale ja ära konfida. Võtab kokkuvõtteks vähem aega kui esialgses saastas orienteerumine ja vigade parandamine.
| Kommentaarid: 29 loe/lisa |
29 |
10.08.2006 13:32:56
vinnimeeste elu lihtsustaiseks m6tlesid kanged mehed kunagi v2lja sellise vinge asja nagu norton ghost. siusaldub nt miniPE utiliitide kogumis. arvutid, mida kindlasti eriti haige klaviatuuri ja tooli vahelise tihendi olemasolu korral tuleb korduvalt reinstallida, saaavad kaks partitsiooni ja teisele siis systeemist image. ei kvalifitseeru otseselt formatiks aga v2henab oluliselt selle tegelase jalavaeva, kes seda kuradi formaati teostama peab. (loe: kui ikka neiud formaadi eest maksta tahavad samas aga ise just unelmate naisteks ei kvalifitseeru, oleks kasulik asi enne "jutu konkreetseks muutumist" yhelepoole saada, k6ht t2is syya ja uuele "objektile2 siirduda .
725 |
Death
10.08.2006 13:51:46
Kui masin uue OSiga stabiilne ei püsi, lendab kivi ikka ja alati raua kapsaaeda. Esimene samm on alati memtest, siis kui see ei näita õnnetust, kaan maha ja mobol konded üle vaadata ning näpuga kõik radikad yle kontrollida... Kui sealt midagi silma ei hakka on järgmine liigutus alla klokida. Kui ikka stabiilseks ei saa tuleb toidet syydistada. Siis mobo välja vahetada ja kui siis ka staqbiilne ie saa maja elektrivõrk üle vaadata. Lihtne, kas pole?
36 |
