aise
15.09.2005 23:42:43
päris julm jah, tehku selline 500kw masin siis ostaks hea meelega
| Kommentaarid: 189 loe/lisa |
172 |
Ho Ho
15.09.2005 23:51:44
Osta mõni kurjem elektriauto, neil peaks kilovatte ja pöördemomenti olema rohkem kui enamus rullnoka masinatel.
86 |
Vananematu
16.09.2005 00:33:07
| Välimus oli neil ka päris karm rsk, rohkem tuleviku disain ikkagi.
| Kommentaarid: 31 loe/lisa |
28 |
Scart
17.09.2005 04:06:33
link :: kae siit
väike ot globaalse soojenemise kohta
101 |
marti252
19.09.2005 13:54:02
link :: Midagi huvitavat õli toodangu kohta Saudi Araabias
# Oil discoveries have peeked already 40 years ago.
# According to M King Hubbert Production peaks follow Discovery peaks after approximately 40 years.
# US Oil production already peaked in 1970.
# Non OPEC oil production already peaked in the early 90's.
# World oil production will peak when OPEC peaks
# OPEC peaks when Saudi Arabia peaks
# Saudi Arabia peaks when Ghawar peaks
# Ghawar is aging rapidly and its life expectancy isn't rosy. Matthew Simmons says that the end is in sight.
# Prof. Kenneth Deffeyes predicts PEAK-OIL to happen in 2005
# Bank of Montreal says that Gharwar is in already in decline.
# World oil peak production means the end of cheap oil
# The end of cheap oil means continuing rising oil prices which translates itself into oil shocks.
# French investment bank Ixis-CIB has warned crude oil prices could touch $380 a barrel by 2015.
# Previous oil shocks were an perfect call for recession/Inflation
# Gold is the ultimate Hedge against Inflation
# Rising oil prices brings the historical Gold/Oil average way out of balance
# Historical average of the Gold/Oil ratio suggest a price of Gold exceeding $800 nowadays.
JA VEEL
Lihtsas Inglise keeles selgitatud tekst, mis annab hea ülevaate põhjustest ja tagajärgedest, mis juhtuks, kui USA peaks Iraagist välja tõmbuma
http://www.uruknet.info/?p=m15892&l=i&size=1&hd=0
| Kommentaarid: 9 loe/lisa |
9 |
külaline
20.09.2005 14:38:48
Uus rõõmurull nimega Rita on Mehhiko lahe peale teel.
Sedapuhku lubatakse sihikule otse Texas võtta.
Vaata ise
aali
20.09.2005 20:58:02
| Kui see "rõõmurull" oma rõõmuga sama hästi nakatab, kui eelmine, on USA majandus küll suht f***ed, mis omakorda toob hukatust ka teistele riikidele.
ossa
21.09.2005 09:48:38
Mind küll see USA majandus suht vähe kotib
| Kommentaarid: 20 loe/lisa |
20 |
7 :: |
360 |
Ho Ho
21.09.2005 10:05:20
Samas just USA väikese naftakriisi tõttu tõusis meil siin maarjamaal kütuse hind mitme krooni jagu
86 |
marko
21.09.2005 11:11:18
| ossa kirjutas: |
Mind küll see USA majandus suht vähe kotib  |
sa oled siis see mees kes elab üksi kuskil paksu metsa sees puu otsas?
väiksed riigid paraku (sund)sõltuvad suurtest ja mitte miski väega ei suuda ükski maailma riik tänapäeval elada isolatsioonis. Olgu ta nii suur või vägev kui tahes (hiina). Kõik on sellest aru saanud ja sellepärast käivadki nn. "koostöö läbirääkimised" jms. Miks sa arvad näiteks, et Põhja Korea peaks alluma USA survele? Põhja Korea on ju päris kõva pähkel (võrreldes Eestiga ) aga näed poiss pannakse varsti paika.
| Kommentaarid: 178 loe/lisa |
161 |
külaline
21.09.2005 17:46:58
Paistab, et venelased on oma ilmastiku muutmise katsetega Kuubal õige kaugele saanud
Veel paar lihaselist seeriat sarjast makku-näkku-makku USA naftaosariikidesse ja saabki Vene majanduse naftaekspordi tulude toel aasta lõpuks plusspoolele
alliance
The Transporter
22.09.2005 03:08:11
| Anonymous kirjutas: |
Veel paar lihaselist seeriat sarjast makku-näkku-makku USA naftaosariikidesse ja saabki Vene majanduse naftaekspordi tulude toel aasta lõpuks plusspoolele  |
ma just tahtsin sama öelda
kunagi oli teema et katsetadaxe kunstlikke maavärinaid...
kui kolmas ka veel usa pihta peaks minema..hakka või ise hullu panema
_________________ --- |
| Kommentaarid: 531 loe/lisa |
431 |
ossa
22.09.2005 09:27:36
Tahaks ka oma kaitseks öelda, et naftakriis on pigem Iraagi sõja kui orkaani tulemus, orkaan andis sellele veel lihtsalt omapoolse tõuke. Ennustati juba enne orkaani ju et naftahind hakkab tõusma, tee silmad lahti,Ho Ho,
marko, Põhja-Koreaga on maadeldud mitukümmend aastat ja maadeldakse edasi. See, et kui kirjutati alla mingi leping kommunistidega naiivitarid, homme see enam ei kehti aga see kisub juba poliitikasse 8)
Minu arvates on majanduslikult maailma suurim riik Jaapan 8)
USA-d võrdleksin rohkem Venemaaga-suurriik suurte maavaradega
20 |
Scart
22.09.2005 11:33:10
pidavat juba plussis olema. cnnis oli lugu sellest, et kreml ei tea, mida kõike naftast tuleva rahaga peale hakata
101 |
alliance
The Transporter
431 |
Vananematu
28 |
ossa
23.09.2005 08:29:05
Opec ei suuda enam naftahinda kontrollida
Jõhker saastus seal rafineerimistehase ümber
Kõik on õlilaike täis
20 |
davidco
| Kommentaarid: 92 loe/lisa |
87 |
Scart
24.09.2005 12:12:14
| ossa kirjutas: |
| Tahaks ka oma kaitseks öelda, et naftakriis on pigem Iraagi sõja kui orkaani tulemus, orkaan andis sellele veel lihtsalt omapoolse tõuke. |
misse iraak siia puutub? iraak andis enne sõda siiski küllaltki väikese % kogu maailma naftast ja praegugi toimub eksport, seega ma tõesti ei suuda leida sinu loogikat antud väites. nafta hind on kõrge, sest naftat kui toorainet ei suudeta enam pumbata piisavas koguses terves maailmas.
101 |
ahvilõust
24.09.2005 14:05:46
| davidco kirjutas: |
Rõõmurull on kohal
Miks te seda rõõmurulliks nimetate? See on ju kurb, mis seal juhtub. Vaesed neegrid
_________________ Gdesainer |
| Kommentaarid: 8 loe/lisa |
lauri
24.09.2005 17:07:12
| ahvilõust kirjutas: |
See on ju kurb, mis seal juhtub. Vaesed neegrid  |
tegelt on siin (USAs) mõned valged ja punanahad ka. lisaks terve kari latiinosid, eriti just Texases.
| Kommentaarid: 90 loe/lisa |
80 |
Zajats
24.09.2005 17:51:36
Väike laupäevane tarkusetera
K: Miks pannakse orkaanidele naiste nimesid?
V: sest kui nad tulevad on nad metsikud ja märjad, aga lahkudes võtavad su maja ja auto kaasa!!
| Kommentaarid: 16 loe/lisa |
15 |
Oioi
29.09.2005 23:44:29
Lugemist
Ja veel
Edit:
Asjalik ja argumenteeritud artikkel, miks New Orleansi peaks ülesehitamise asemel hoopis maha jätma:
PES Network
236 |
Le Inc
| Kommentaarid: 56 loe/lisa |
54 |
