aise
15.09.2005 23:42:43
päris julm jah, tehku selline 500kw masin siis ostaks hea meelega
| Kommentaarid: 189 loe/lisa |
172 |
Ho Ho
15.09.2005 23:51:44
Osta mõni kurjem elektriauto, neil peaks kilovatte ja pöördemomenti olema rohkem kui enamus rullnoka masinatel.
87 |
Vananematu
16.09.2005 00:33:07
| Välimus oli neil ka päris karm rsk, rohkem tuleviku disain ikkagi.
| Kommentaarid: 31 loe/lisa |
28 |
Scart
17.09.2005 04:06:33
link :: kae siit
väike ot globaalse soojenemise kohta
101 |
marti252
19.09.2005 13:54:02
link :: Midagi huvitavat õli toodangu kohta Saudi Araabias
# Oil discoveries have peeked already 40 years ago.
# According to M King Hubbert Production peaks follow Discovery peaks after approximately 40 years.
# US Oil production already peaked in 1970.
# Non OPEC oil production already peaked in the early 90's.
# World oil production will peak when OPEC peaks
# OPEC peaks when Saudi Arabia peaks
# Saudi Arabia peaks when Ghawar peaks
# Ghawar is aging rapidly and its life expectancy isn't rosy. Matthew Simmons says that the end is in sight.
# Prof. Kenneth Deffeyes predicts PEAK-OIL to happen in 2005
# Bank of Montreal says that Gharwar is in already in decline.
# World oil peak production means the end of cheap oil
# The end of cheap oil means continuing rising oil prices which translates itself into oil shocks.
# French investment bank Ixis-CIB has warned crude oil prices could touch $380 a barrel by 2015.
# Previous oil shocks were an perfect call for recession/Inflation
# Gold is the ultimate Hedge against Inflation
# Rising oil prices brings the historical Gold/Oil average way out of balance
# Historical average of the Gold/Oil ratio suggest a price of Gold exceeding $800 nowadays.
JA VEEL
Lihtsas Inglise keeles selgitatud tekst, mis annab hea ülevaate põhjustest ja tagajärgedest, mis juhtuks, kui USA peaks Iraagist välja tõmbuma
http://www.uruknet.info/?p=m15892&l=i&size=1&hd=0
| Kommentaarid: 9 loe/lisa |
9 |
külaline
20.09.2005 14:38:48
Uus rõõmurull nimega Rita on Mehhiko lahe peale teel.
Sedapuhku lubatakse sihikule otse Texas võtta.
Vaata ise
aali
20.09.2005 20:58:02
| Kui see "rõõmurull" oma rõõmuga sama hästi nakatab, kui eelmine, on USA majandus küll suht f***ed, mis omakorda toob hukatust ka teistele riikidele.
ossa
21.09.2005 09:48:38
Mind küll see USA majandus suht vähe kotib
| Kommentaarid: 20 loe/lisa |
20 |
21.09.2005 09:54:52
ossa,
hakkab kottima küll, kui maailmas tekivad rahutused, kütusehind tõuseb lakke, Eesti eksport peaks vähenema ja/või Venemaa peaks alustama Baltimaade anastamist
7 :: |
364 |
Ho Ho
21.09.2005 10:05:20
Samas just USA väikese naftakriisi tõttu tõusis meil siin maarjamaal kütuse hind mitme krooni jagu
87 |
marko
21.09.2005 11:11:18
| ossa kirjutas: |
Mind küll see USA majandus suht vähe kotib  |
sa oled siis see mees kes elab üksi kuskil paksu metsa sees puu otsas?
väiksed riigid paraku (sund)sõltuvad suurtest ja mitte miski väega ei suuda ükski maailma riik tänapäeval elada isolatsioonis. Olgu ta nii suur või vägev kui tahes (hiina). Kõik on sellest aru saanud ja sellepärast käivadki nn. "koostöö läbirääkimised" jms. Miks sa arvad näiteks, et Põhja Korea peaks alluma USA survele? Põhja Korea on ju päris kõva pähkel (võrreldes Eestiga ) aga näed poiss pannakse varsti paika.
| Kommentaarid: 178 loe/lisa |
161 |
külaline
21.09.2005 17:46:58
Paistab, et venelased on oma ilmastiku muutmise katsetega Kuubal õige kaugele saanud
Veel paar lihaselist seeriat sarjast makku-näkku-makku USA naftaosariikidesse ja saabki Vene majanduse naftaekspordi tulude toel aasta lõpuks plusspoolele
alliance
The Transporter
22.09.2005 03:08:11
| Anonymous kirjutas: |
Veel paar lihaselist seeriat sarjast makku-näkku-makku USA naftaosariikidesse ja saabki Vene majanduse naftaekspordi tulude toel aasta lõpuks plusspoolele  |
ma just tahtsin sama öelda
kunagi oli teema et katsetadaxe kunstlikke maavärinaid...
kui kolmas ka veel usa pihta peaks minema..hakka või ise hullu panema
_________________ --- |
| Kommentaarid: 531 loe/lisa |
431 |
ossa
22.09.2005 09:27:36
Tahaks ka oma kaitseks öelda, et naftakriis on pigem Iraagi sõja kui orkaani tulemus, orkaan andis sellele veel lihtsalt omapoolse tõuke. Ennustati juba enne orkaani ju et naftahind hakkab tõusma, tee silmad lahti,Ho Ho,
marko, Põhja-Koreaga on maadeldud mitukümmend aastat ja maadeldakse edasi. See, et kui kirjutati alla mingi leping kommunistidega naiivitarid, homme see enam ei kehti aga see kisub juba poliitikasse 8)
Minu arvates on majanduslikult maailma suurim riik Jaapan 8)
USA-d võrdleksin rohkem Venemaaga-suurriik suurte maavaradega
20 |
Scart
22.09.2005 11:33:10
pidavat juba plussis olema. cnnis oli lugu sellest, et kreml ei tea, mida kõike naftast tuleva rahaga peale hakata
101 |
alliance
The Transporter
431 |
Vananematu
28 |
ossa
23.09.2005 08:29:05
Opec ei suuda enam naftahinda kontrollida
Jõhker saastus seal rafineerimistehase ümber
Kõik on õlilaike täis
20 |
davidco
| Kommentaarid: 92 loe/lisa |
87 |
Scart
24.09.2005 12:12:14
| ossa kirjutas: |
| Tahaks ka oma kaitseks öelda, et naftakriis on pigem Iraagi sõja kui orkaani tulemus, orkaan andis sellele veel lihtsalt omapoolse tõuke. |
misse iraak siia puutub? iraak andis enne sõda siiski küllaltki väikese % kogu maailma naftast ja praegugi toimub eksport, seega ma tõesti ei suuda leida sinu loogikat antud väites. nafta hind on kõrge, sest naftat kui toorainet ei suudeta enam pumbata piisavas koguses terves maailmas.
101 |
ahvilõust
24.09.2005 14:05:46
| davidco kirjutas: |
Rõõmurull on kohal
Miks te seda rõõmurulliks nimetate? See on ju kurb, mis seal juhtub. Vaesed neegrid
_________________ Gdesainer |
| Kommentaarid: 8 loe/lisa |
lauri
24.09.2005 17:07:12
| ahvilõust kirjutas: |
See on ju kurb, mis seal juhtub. Vaesed neegrid  |
tegelt on siin (USAs) mõned valged ja punanahad ka. lisaks terve kari latiinosid, eriti just Texases.
| Kommentaarid: 90 loe/lisa |
80 |
Zajats
24.09.2005 17:51:36
Väike laupäevane tarkusetera
K: Miks pannakse orkaanidele naiste nimesid?
V: sest kui nad tulevad on nad metsikud ja märjad, aga lahkudes võtavad su maja ja auto kaasa!!
| Kommentaarid: 16 loe/lisa |
15 |
Oioi
29.09.2005 23:44:29
Lugemist
Ja veel
Edit:
Asjalik ja argumenteeritud artikkel, miks New Orleansi peaks ülesehitamise asemel hoopis maha jätma:
PES Network
236 |
Le Inc
| Kommentaarid: 56 loe/lisa |
54 |
alliance
The Transporter
431 |
corvette
02.10.2005 20:58:37
| Viimane uudis on rootsi poolt väga eeskujulik. Ega muudmoodi alternatiivid ei arenegi kui neid kasutusele ei võeta.
| Kommentaarid: 49 loe/lisa |
48 |
7 :: |
364 |
Ho Ho
02.10.2005 21:23:05
võibolla on tegu samasuguste lubadustega nagu meil praegu valimiste puhul paremale ja vasakule loobitakse
Ma kahtlen väga sügavalt et kõik asendatakse, võibolla ainult teatud osa.
87 |
alliance
The Transporter
03.10.2005 02:30:04
| Tanel kirjutas: |
corvette, huvitav, mida Rootsi mõtleb kasutusele võtta  |
seda tahaks ise ka teada.oma peaga ei oska miskit välja mõelda.kes rootsi keelt oskab,võib lehti tuhlata
431 |
Zajats
03.10.2005 15:04:57
| See on sama tark pealkiri et lõpetame hapniku tarbimise.
15 |
marko
03.10.2005 16:13:15
| Zajats kirjutas: |
| See on sama tark pealkiri et lõpetame hapniku tarbimise. |
vot nüüd tuli küll mõttetera välja.
... et siis sinu loogika järgi sureb kogu elu maa peal välja kui nafta otsa saab?
Rootsi võimetes ma ei kahtle ja nende poliitika võrdsustamine Eesti omaga on ehtne rumalus.
Nagu varemgi korduvalt öeldud on nafta niikaua majanduslikult peale surutud ja alternatiivid tõrjutud, kuni teda jätkub. Ennustuste järgi mitte enam kauaks, seega õigeaegne valmistumine selleks on kindlasti tark tegu. Mõtete ja plaanide avalikustamine ja seejärel tegutsemine on minu seisukohalt õige lähenemine. (Mitte nii nagu meil siin Eestis, kus enne hüpatakse ja siis mõeldakse... kui nii kaugele üldse jõutakse... )
Ning kui naftavarud otsas küll siis ka alternatiivsed võimalused vabanevad majandusliku surutise alt ja saavutavad kasumlikkuse.
161 |
Hiid
03.10.2005 16:41:13
laias laastus, nagu elekteri tootmine, rongid võibolla ka autod saavad ehk kuidagi ka liikuma. Aga puid peab vist hakkama tulevikus oma metsast sulle-mullega tegema jälle.
| Kommentaarid: 664 loe/lisa |
512 |
Muhvini
külaline
03.10.2005 16:54:36
Miks arvad et tulevikus ei võiks olla nii väikest energiaallikat?
Hiid
03.10.2005 17:50:39
millist sa pakuksid reaalselt? kui benakat ei ole, siis mul omal head mõtet küll ei teki, kuidas miniatuurseid mootoreid käitada...
512 |
Scart
03.10.2005 18:15:52
| marko kirjutas: |
Ning kui naftavarud otsas küll siis ka alternatiivsed võimalused vabanevad majandusliku surutise alt ja saavutavad kasumlikkuse. |
huvitav, mille baasil neid alternatiivseid energiaallikaid ikkagi arendatakse, kui odavat energiaallikat pole, mis kogu seda protsessi tagant lükkaks?
101 |
Muhvini
külaline
03.10.2005 18:21:26
| Hiid kirjutas: |
millist sa pakuksid reaalselt? kui benakat ei ole, siis mul omal head mõtet küll ei teki, kuidas miniatuurseid mootoreid käitada...  |
Kui ma oskaksin seda pakkuda, siis ....
Lihtsalt sa ei saa seda ju välistada vaid sellepärast et sina ei oska ettekujutada
03.10.2005 18:22:36
ärgem unustagem, et naftasaadustest tehakse väetisi ja pestitsiite, milleta tänapäeva (mittemahe) põllumajandus hakkama ei saa. Lisaks kulub fossiilseid kütuseid toormaterjalide enda pumpamiseks/kaevandamiseks ja töötlemiseks, ilma milleta ei saa ehitada alternatiivenergiatootjaid.
7 :: |
364 |
Zajats
03.10.2005 20:41:34
| Kõik ei sure, aga erinevate hinnangute põhjal 60-90% panevad jah nupud kokku lähema dekaadi-paarikümne aasta jooksul.
15 |
marko
03.10.2005 21:04:45
| Scart kirjutas: |
| marko kirjutas: |
huvitav, mille baasil neid alternatiivseid energiaallikaid ikkagi arendatakse, kui odavat energiaallikat pole, mis kogu seda protsessi tagant lükkaks? |
imo lähenemine on sul vale.
selgituseks eks ma siis küsin sinu käest seda, et mille järgi hinnatakse kas üks asi on odav või kallis? Kui sa hindad praegu reaalselt eksisteeriva mõõdupuu järgi ja hindad selle põhjal tulevikku siis IMHO teed sellega vea.
| Zajats kirjutas: |
| Kõik ei sure, aga erinevate hinnangute põhjal 60-90% panevad jah nupud kokku lähema dekaadi-paarikümne aasta jooksul. |
Tundub lahmimisena, ehk lisad mõned viited ametlikele dokumentidele kus on ennustatud, et paarikümne aasta jooksul sureb 90% maa faunast välja ainuüksi sellepärast, et nafta otsa saab.
| Tanel kirjutas: |
| ärgem unustagem, et naftasaadustest tehakse väetisi ja pestitsiite, milleta tänapäeva (mittemahe) põllumajandus hakkama ei saa. Lisaks kulub fossiilseid kütuseid toormaterjalide enda pumpamiseks/kaevandamiseks ja töötlemiseks, ilma milleta ei saa ehitada alternatiivenergiatootjaid. |
praegu küll, aga minu isiklike ülioptimistlike ennustuste kohaselt töötavad näiteks mootorsaed päikese patareide jõul mis valmistatud ökovahenditega ja ei sisalda naftasaadusi. Sealjuures salvestavad piisavalt energiat paari tunniga, et töötada 24h.
161 |
Mony
alliance
The Transporter
04.10.2005 05:41:46
| Mony kirjutas: |
www.lifeaftertheoilcrash.net
no comments... |
keegi valgustax ehk-mis seal üldjoontes kirjas on?
431 |
Zajats
04.10.2005 07:52:37
Vabandust jah, jutt ei ole maa faunast/florast vaid inimkonnast. Eelpool nimetatud saidil on kirjas et maailma meedia ei taha eriti rääkida et lähiajal on nafta tootmine vähenemas. Kerge nafta tootmine pidi olema juba languses, jäänud on rasket naftat, mille rafineerimine on kallim ja tehaseid pole nii palju. Kui see kõik tõsi on, siis varsti saame 10 l nädalas bensu näkku.
Üks esimesi peak oili saite on www.dieoff.org Ka see näitab mingi suuna kätte.
15 |
Le Inc
04.10.2005 08:53:35
Tuleb siis vaikselt laskemoona ja soola hakata varuma ... tuulik ülesse või aurukatel hakkama panna ja särtsu tootma. Iga küla võiks endale pisikese jaama ehitada, et võrku väga ära ei poodaks, siis igasse perre tuleks 2A peakaitse.
Sooja vee laseme majade kütteks ja nii see õnn tuleb. Puitu meil on (tuleb vähem tarbima hakata), nii et pole probleemi. Aga oma 500W arvuti peate küll süleraali vastu vahetama ...
54 |
ossa
04.10.2005 09:17:53
Eestlane oli ju alles hiljuti metsas veel, ammuks see nafta meie pinnale jõudis
Sisepõlemismootor on ju kõigest alla 100 aasta vana 8) , enne seda olid auruvedurid ja mis kindel-naftat seal ei kasutatud Sisuliselt vaid üks inimpõlvkond on suuresti naftat kasutanud ja teie nutate, et mis saab, kui naftat ei ole.
Viimane aeg siis autoga kiiremaid ringe teha mööda euroopat
viimati muutis ossa 04.10.2005 09:21:05, muudetud 1 kord |
20 |
Scart
04.10.2005 09:20:12
| marko kirjutas: |
nojah, ma arvan, et sina oled siis esimene reas oma raha annetama, et ehitada tuulikuid ja tuumaelektrijaamu, kui bensiin on 30kr/l ning riik ei suuda enam oma operatiivsõidukeidki teel hoida, rääkimata rekka- ja ehitusmasinatest
101 |
marti252
07.10.2005 22:46:16
link :: Brazil fights oil prices with alcohol
Brasiilias müüakse flex autosid, millel arvuti ise tunneb ära, kas paagis on bensiin, alkohool või nende segu ja valib vastava õhu kütuse segu. Selliseid autosid, peaks eestis ka hakatama müüma. siis paneks küll tagaaias viinavabriku püsti
http://peakoil.com/modules.php?name=Forums&file=viewtopic&t=13604
Veel üks hea link, mis räägib Zimbabwe õli kriisist. See pole aga enam kriis vaid katastroof. Autod jäävad tänavatel seisma, sest bensiini pole. Samuti politsei, kiirabi ja tuletõrje. Vrakid seisavad keset tänavat
viimati muutis marti252 07.10.2005 23:00:21, muudetud 1 kord |
9 |
Ho Ho
07.10.2005 22:54:44
sa ikka tead et piirituse tootmine koduste vahenditega on kordades kallim kui bensu ostmine?
võibolla puupiiritus on odavam, pole eriline asjatundja
87 |
alliance
The Transporter
07.10.2005 23:00:11
no mingi tont ju tegi puukyttega mosse kunagi.mingi veoki variant oli ka vist.aga ega puudki odavad ole.
tulevad aurumasinad tagasi varstii
431 |
marti252
07.10.2005 23:02:26
| Ho Ho kirjutas: |
võibolla puupiiritus on odavam, pole eriline asjatundja |
Kui sa ise kasvatad suhkrupeeti, siis on odavam kui bensiin, sest see ei pea olema puhas nagu joogi piiritus
9 |
