EvilMick007
10.09.2005 10:01:32
| [HGM]Aeon kirjutas: |
I found out what the problems were with our current "temp" server. Since we had our temp server at a location which was not a permanent home, it seems as if that location got hit with a bad DDoS attack. While it was not directed at our box specifically, it still affected us.
The server was taken offline and moved due to a liability issue and since it would take the same amount of time to move that box, as it would to just build our new one, we are waiting on our new server. I am working hard to get it in location as soon as possible, but we are looking at least a few days.
Keep checking back for updates. Sorry for any problems, once this is solved we won't have to deal with this again!
_________________ Pentestimise ja küberturbe konsultatsiooni soovi korral võib kirjutada.. |
| Kommentaarid: 46 loe/lisa |
41 |
Demonium
10.09.2005 10:11:49
aga noh mis me siin ikka vaidleme, eks igaüks otsustab ise mis talle meeldib
No offence, aga see pilt on veits üle kasutatud
Ja donation systemi pole mul asja kuna ei oma enda isiklikku krediit kaarti
_________________ The future will be a vast black memory on your grave! |
Snaxez
10.09.2005 10:14:33
| Demonium kirjutas: |
Ja donation systemi pole mul asja kuna ei oma enda isiklikku krediit kaarti |
ma tean jah, aga satus just see pilt ette enne ja ma nii tahtsin seda kuskile panna
| Kommentaarid: 61 loe/lisa |
54 |
Demonium
10.09.2005 10:31:58
ok
Djomka
11.09.2005 09:51:39
ok, ise tulen ka varsti mõni päev mängu sisse...praegu üritan autokooli ja keskkooli asju rööbastesse saada
loodan, et snax ei vihasta
| Kommentaarid: 14 loe/lisa |
12 |
lauri23
11.09.2005 10:08:23
| Tulge parem extreami kastiani serverisse. kõrge exp palju rahvast.
| Kommentaarid: 29 loe/lisa |
29 |
Alandril
11.09.2005 10:28:06
| lauri23 kirjutas: |
| Tulge parem extreami kastiani serverisse. kõrge exp palju rahvast. |
Been there done that. See on vist üks kõige sitemaid servereid mida ma siiamaani olen proovinud
| Kommentaarid: 6 loe/lisa |
lauri23
11.09.2005 11:36:43
Sai ka sellest kõrini juba level 66 gladiaator ja pole kuskil expata. Ehk oskate anda mõne serveri kus on norm exp rate ja hea pvp ka. 7x exp ratega ei ole viitsimist küll jälle peale hakata.
29 |
Snaxez
11.09.2005 12:02:01
| lauri23 kirjutas: |
Sai ka sellest kõrini juba level 66 gladiaator ja pole kuskil expata. Ehk oskate anda mõne serveri kus on norm exp rate ja hea pvp ka. 7x exp ratega ei ole viitsimist küll jälle peale hakata. |
7x on norm exp ja seal tuleb hea pvp
54 |
Demonium
11.09.2005 12:07:18
| lauri23 kirjutas: |
Mitte kuskil?
Lair of Antaras????
Seal on lõpmata viise expata......lihtsalt mine koguaeg alla poole jne siis käi Kariku sillal
lauri23
11.09.2005 12:18:56
| ja aga extreamis on see koht nii üle rahvastatud et seal väga sitt expata.
29 |
LightsabeR
11.09.2005 12:30:38
| lauri23 kirjutas: |
| ja aga extreamis on see koht nii üle rahvastatud et seal väga sitt expata. |
seal jah ühe mobi kohta 10 playerit . Üldse on see l2extreme suht bugine ja lagi ka palju. Ei tea.. eriti ei istu...
14 |
Demonium
11.09.2005 18:30:52
Siis tuleks kohapealset populatsiooni vähendada......võta mingi lambikas ette ja löö maha!
Milles küsimus?
wazaa
11.09.2005 18:37:52
Milles küsimus?  |
samas just sinusuguse mõtlemisega tüüpe vihataksegi üle maailma!
| Kommentaarid: 53 loe/lisa |
40 |
Demonium
11.09.2005 18:44:07
Aga palun, mina ei keela, kui keegi ikka niisama koguaeg neid kolle näo eest ära võtabm mul poogen, saabki teada kui terav mu mõõk on!
Djomka
11.09.2005 18:49:54
| wazaa kirjutas: |
Milles küsimus?  |
samas just sinusuguse mõtlemisega tüüpe vihataksegi üle maailma! |
mina küll selliseid ei vihka, mingu punaseks ja kaotagu oma asjad (muidugi asi selles, et l2x'is pole suuremat probleemi asjade tagasi tegemisega)
ja alati on võimalust ka PvP'd teha, mitte lasta ennast maha PK'da
12 |
Demonium
11.09.2005 18:58:00
Nii sama ma nagu pk-ina ringi ei jookse
aga kurat kui keegi ikka nagu mõnitamise mõttes nina alt kolle ära tuleb võtma siis löön maha kui ta just mingi 30 levelit kõrgem ei ole
No_Limit
11.09.2005 19:05:14
| wazaa kirjutas: |
Milles küsimus?  |
Köhh köhh CAREBEAR! Kui sulle ainult leveldamine pinget pakub, siis lase käia
_________________ Ave, Caesar, morituri te salutant |
40 |
Demonium
11.09.2005 19:13:51
Dominus
11.09.2005 19:28:26
LoL...
anyway enraged saab hoo jälle sisse esmaspäev-teisipäev loodetevasti
76 |
wazaa
11.09.2005 19:31:30
| a, saan aru, et siis kui olen lv30 ja lv60 vend lööb mu maha peaks mingi meeletult lõbus olema?
40 |
No_Limit
11.09.2005 19:54:56
võta kuidas tahad, tahad öelda, sa ei tee üldse PvP'd ega PK'd?
40 |
Djomka
11.09.2005 20:03:20
| wazaa kirjutas: |
| a, saan aru, et siis kui olen lv30 ja lv60 vend lööb mu maha peaks mingi meeletult lõbus olema? |
seda kutsutakse griefimiseks, mis on enamustes serverites keelatud...
12 |
Demonium
11.09.2005 21:03:45
| wazaa kirjutas: |
Ainult mingi vaimse puudega inimene/või siis täielik algaja roniks level 30 characteriga Antaras Lairi >_>
Ta ei jõuaks sinnani väljagi tõenäoliselt......
Sellepärast, et see jutt siin käis ikka Antaras Lairist
LightsabeR
11.09.2005 23:00:58
Aga kogu point on selles, Demonium, et kui sa l2extremes lairis flagid ja sul pool alliance't kaasas pole, siis sa ei jõua punaseks minnagi, enne, kui sind maha lüüakse. Seda siis tiptunnil... siis kui rahvast "vähem", saad ehk isegi oma gear'ist lahti.
| Djomka kirjutas: |
| wazaa kirjutas: |
seda kutsutakse griefimiseks, mis on enamustes serverites keelatud... |
Njah.. ta võib ju keelatud olla, aga kes see hakkab tõestama vastupidist, kui ma näiteks väidan, et see lv 13 tüüp mu lv 10 dwarfi maha lõi ja ma tulin talle kohta kätte näitama. Screenshotid ei tõesta midagi. Üleüldse on GM'idel käed jalad tööd täis, kui nad serverisse sisse logivad ja neil pole aega sellise pisisulide nagu "grieferid" jahtimiseks.
14 |
