Alari A.
13.04.2005 23:47:27
proovin mplayerit installida kuid nõuab libfontconfig1 ja libvorbis0a.üritan seda puuduvat osa tõmmata siis jälle lõugab,et vajalik mpleyer nokk kinni-saba lahti,saba kinni-nokk lahti
mplayer
Depends: libfontconfig1 (>=2.3.0) but 2.2.3-4ubuntu7 is to be installed
Depends: libvorbis0a (>=1.1.0) but 1.0.1-1 is to be installed
| Kommentaarid: 677 loe/lisa |
550 |
droz
14.04.2005 07:20:52
| sul pakid uuendamata, sest tahab uuemaid versioone. kas konsoolis root kasutajana apt-get update või synapticus reload nupp peaks aitama
| Kommentaarid: 4 loe/lisa |
Alari A.
14.04.2005 14:06:38
krt.ei saa mina ati drivereid tööle.xorg.conf selline:(xorg-driver-fglrx peal,fglrx kernel source peal)
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following commands:
# cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom
# sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum'
# sudo dpkg-reconfigure xserver-xorg
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
# paths to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc104"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "Buttons" "7"
Option "ZAxisMapping" "6 7"
Option "Resolution" "200"
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. Radeon 9800 Pro (R350 NH)"
Driver "ati"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "COMPAQ P910"
Option "DPMS"
HorizSync 30-108
VertRefresh 50-140
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies, Inc. Radeon 9800 Pro (R350 NH)"
Monitor "COMPAQ P910"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1792x1344" "1600x1200" "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
550 |
Tint
14.04.2005 23:01:31
minul on kUbuntuga selline probleem, ehk on siin foorumis veel keegi küsind seda, kuid ei leidnud vastust.
kuna ubuntu 4.10 jättis mulle väga hea mulje, proovisin ära ka kubuntu. ainus probleem mis tekkis, oli see, et kui aptiga lasin mozilla või firefoxi peale, siis font on nende menüüs väga väike ja kuidagi normaalseks ei saa.
otsisin googlest lahendust ja leidsin sellise jutu:
firefox menu fonts smaller and not as "smooth" as usual:
greatshape
03-26-2005, 10:17 AM
I 've just installed kubuntu on my laptop.
Everything works great, but the menu fonts in firefox don't look the same as wih Ubuntu or my other box running Suse 9.2. The are smaller and not as smooth as normal. I have the same in openoffice.
As far as i remember i had this once before about 1 year ago when i installed firefox without XFT+GTK support. After installing the version with GTK+XFT the problem was solved then.
Any idea's?
tnx
Steve
$ sudo apt-get install gtk2-engines-gtk-qt
(or install via synaptic/kynaptic/kpackage)
Once it is installed, go to settings:/LookNFeel/ in Konqueror. Click on the new icon that is there. It is the gnome footprint and says "GTK Styles and Fonts." Under GTK Styles, select "Use another style" and select "Qt." Under "GTK Fonts" Select "Use another font" and change it to whatever you want. I suppse you could leave the two choices at "Use my KDE..." but for some reason, that did not work for me.
Anyway, open up Firefox/thunderbird/synapitc/gaim and marvel at the beauty!
________________________
mina aga sellest abi ei saa. oman eestikeelse toega kubuntut ja ei leia kusagilt kus saaks antud asja muuta.
$ sudo apt-get install gtk2-engines-gtk-qt õnnestus ilusasti kuid edasi ei saa aru, mida tegema peaks.
ehk oskab siin olijatest keegi juhendada mind edasi? peale selle anomaalia töötab kõik vägagi hästi
| Kommentaarid: 34 loe/lisa |
31 |
borru
14.04.2005 23:08:15
kasutajal arrow oli siin paar posti tagasi sama probleem
aitas raido357, pakutud
| Control Center -> Appearance & Themes -> Fonts |
| Kommentaarid: 13 loe/lisa |
Alari A.
14.04.2005 23:08:59
äkki keegi teab mind aidata eelnevas minu postis toodud driveri hädaga
550 |
raido357
14.04.2005 23:11:07
digweed,
Driver "ati" <-- kas siin ei peaks ati asemel mitte "fglrx" olema ? fglrxconfig nimelist softi jooksutasid..
| Kommentaarid: 78 loe/lisa |
Tint
14.04.2005 23:19:03
tänan borru
küsimus selline, soovib ehk keegi ubuntu orikat, saadeti mulle 10 tükki, 2-3 on ehk alles- teised laiali jagatud ( Ubuntu 4.10 The Warty Warthog)
saingi korda oma fondi firefoxis
viimati muutis Tint 15.04.2005 15:36:26, muudetud 1 kord |
31 |
Alari A.
14.04.2005 23:33:00
| raido357 kirjutas: |
digweed,
Driver "ati" <-- kas siin ei peaks ati asemel mitte "fglrx" olema ? fglrxconfig nimelist softi jooksutasid.. |
tahab teha mul XF86Config-4 file st.oma mx310 seaded pean üle tegema?!
fps tõusis pea 10x kuid resot muuta ei saa(17xx korda 13xx)
The X Server does not support the XRandR extension. Runtime resolution changes to the display size are not available.
viimati muutis Alari A. 15.04.2005 09:48:23, muudetud 1 kord |
550 |
raido357
15.04.2005 07:34:36
| digweed, kas midagi muutub kui CRTL plus + / - vajutad ?
Alari A.
15.04.2005 10:17:43
| digweed, kas midagi muutub kui CRTL plus + / - vajutad ? |
mitte essugi ei muutu
550 |
gandalf
15.04.2005 14:34:57
| see kombinatsioon on siiski ctrl-alt-+/-. lihtsalt ctrl-plus toimib fondi muutjana (firefox's )
Alari A.
15.04.2005 16:28:30
1 kala veel:miks ta mul biosest kella muudab 3h taha poole ubuntus kell 6ige kuid winis 3h.taga?time zoned k6ik 6iged est.tallinn
550 |
Ho Ho
15.04.2005 16:31:40
asi lihtsalt selles et linuxi jaoks on BIOS'i kell GMT aja näitaja millele ta ise tarkvaraliselt vastavalt ajatsoonile jupi juurde arvestab. Win kasutab otse biosi kella (Või ol see vastupidi )
87 |
Hardi
15.04.2005 16:45:16
ehe.. jah. Mul keerab ka 3h paigast ära kella , aga seda seetõttu ,et kui Ubuntut installisin
,siis seal kus see "Is the hardware clock set to GMT" vms. valikus valisin vale asja vist
Kuna varem pole seda juhtunud.
_________________ ツ |
| Kommentaarid: 84 loe/lisa |
cbr
15.04.2005 17:26:04
Seda peaks idee järgi saama muuta kah.
/etc/default/rcS:
# Set UTC=yes if your system clock is set to UTC (GMT), and UTC=no if not.
UTC=no |
Et siis seda variablet seades peaks asja korda saama.
| Kommentaarid: 48 loe/lisa |
39 |
Alari A.
15.04.2005 17:54:09
| hardi_k kirjutas: |
Kuna varem pole seda juhtunud. |
jep sinna oligi koer maetud kuna suutsin ubuntu täitsa peeti keerata siis celan installiga parandasin vea
550 |
Hardi
15.04.2005 17:58:22
just proovisin cbr antud varianti , see aitas ka.
Alari A.
15.04.2005 19:42:16
| gandalf kirjutas: |
| see kombinatsioon on siiski ctrl-alt-+/-. lihtsalt ctrl-plus toimib fondi muutjana (firefox's ) |
sellega raso paika ei saa ainult zoomib
kui on nii: Driver "ati" siis Xlib: extension "XFree86-DRI" missing on display ":0.0".
1604 frames in 5.0 seconds = 320.800 FPS
kui on nii:Driver "fglrx" on 0 errorit ning fps 3000 ja up!kuid jah selle juhul ei saa resot muuta mis tundub olevat 1792x1344 peal
550 |
Ho Ho
15.04.2005 21:14:40
| Kas xorg.conf'is on üldse resod ära määratud?
87 |
Alari A.
15.04.2005 21:36:58
| peaks olema.vt minu 14.04.2005 14:06 tehtud posti kus on terve xorg.conf välja toodud
550 |
Tint
15.04.2005 22:08:43
kas sellist themet saaksin ma installida kubuntule? http://nigritude.sourceforge.net/
tegemist on siis winxp themega.
kui jah, siis kuidas?
install.txt fail, mis kaasas on,kde_xp_full-0.9.tar.gz sees, ütleb, et :
Run the scripts :
icons-install-kde.sh
style-install.sh
theme-install-kde.sh
mis moodi see käib : 8)
või teab keegi muud ja paremat moodust oma kubuntule winxp või win2k välimuse saamiseks?
31 |
Ho Ho
15.04.2005 22:14:35
digweed, kas kusagilt desktopi settingutest ei saa resot valida? KDE'l saab igatahes.
| mis moodi see käib |
konsoolis käivitad need skriptid. Selleks mitu variani. Üheks on kirjutada sh skriptinimi, teine on anda skriptile käivitamisõigus:
chmod +x skriptinimi
./skriptinimi |
Nende käskluste andmise ajal pead loomulikult olema skriptidega samas kataloogis
87 |
gandalf
15.04.2005 22:19:08
terminali aknasse
või
kui tahetakse system wide paigutada siis nt.
XPde on projekt mille eesmärgiks on jätta võimalikult xp'lik mulje. et siis windowsi kasutajaid valutult "üle tuua"
Alari A.
16.04.2005 11:56:36
| Ho Ho kirjutas: |
| digweed, kas kusagilt desktopi settingutest ei saa resot valida? KDE'l saab igatahes. |
koht olemas kuid viskab sellise kirja The X Server does not support the XRandR extension. Runtime resolution changes to the display size are not available.
edit:krdi loll-mitu päeva n...i ning väga lihtsalt lahendus leitud xorgits kustutasin kõik resod mis jäid 1280x1024 ülesse
550 |
arrow
16.04.2005 13:31:47
Mul profiilis olev masin ja huvitab, missugune kernel sobiks sellisele protsessorile (amd 64) kõige paremini, praegu mingi i386.
Sooviks siiski 32-bitist süsteemi.
| Kommentaarid: 23 loe/lisa |
23 |
qratman
| Kommentaarid: 28 loe/lisa |
cbr
16.04.2005 16:22:36
| arrow kirjutas: |
Sooviks siiski 32-bitist süsteemi. |
Miks mitte 64-bit?
39 |
Alari A.
16.04.2005 17:25:21
endal peal i386 kui äkki paneks 64bit on neil märgatavat vahet?just kiiruse pooles.
550 |
AxlR
16.04.2005 22:01:44
Sai ka proovitud seda linuxí varianti (ennem kokkupuudet pole olnud).
Tekkis väike probleem wlan-ga nimelt kui laed masina üles on net olemas
aga kui oled eemal masinast mingi 30 minutit siis avastad , et disconnected
ja ei leia ka kohta kust saaks connectida ja miks ta disconnectib ennast.
viimati muutis AxlR 16.04.2005 22:15:05, muudetud 1 kord |
arrow
16.04.2005 22:09:08
kas see i686 mitte inteli oma ei olnud (pole ise praegu linuxis), ja peale selle olen kuulnud, et 64-bit veel liiga toores, et seal kõik probleemivabalt jookseks
Peale selle, missuguse tähisega on 64-bit?
23 |
Ho Ho
16.04.2005 22:16:17
| Kui õieti mäletan siis i686 peaks sobima arvuteile alates P3 ja athlon.
87 |
Alari A.
17.04.2005 00:18:40
ubuntul peaks ipv6 deaf.juba installitud olema?gftp abil ma sisse ei saa ei datasse kui stfi
ühenduseks elion vk.
550 |
qratman
17.04.2005 01:22:50
| Ho Ho kirjutas: |
| Kui õieti mäletan siis i686 peaks sobima arvuteile alates P3 ja athlon. |
Samas ka minu Celeron 400 ja Duron 800 kuuluvad i686 arhitektuuri alla. Ja ainult inteliga seda ei seostata, kuna AMD on ju (vähemalt algselt oli) inteli kloon. Seega AMD puhul on i686 IMO alates K7.
atari_
17.04.2005 05:00:30
athlonitele ja duronitele on imo veel peale i686 sihuke eraldi variant nagu k7
kubuntu puhul sai seda isegi valida... teistel distrodel pole märgand, et k7 pre-kompilleerituna saaks /peab ise sortsust tegema
ja seda kas 64bit masina puhul..on 64bitine linux parem kui i686...saab arvatavasti kõige paremini teada kui ise järgi proovida
| Kommentaarid: 94 loe/lisa |
80 |
indrek
17.04.2005 15:12:29
| i686 spets on vähim ühisosa kõigil vähegi uuematel prosedel alates p2-st ja amd duronist, nii et vaevalt kellelgi desktopis eriti midagi allapoole on. Aga et optimeerida kernel täpselt oma arhitektuuri jaoks, tuleb too ise ära kompileerida - seal saab valida kõigi arhitektuuride vahel. 64-bitise jaoks annab jah mõningase kiirusevõidu 64-bitise jaoks optimeeritud kernel (ja programmid). Päris paljud kasutavad seda, nii et ta on täiesti kasutatav, kuigi mingid pisiprobleemid võivad aegajalt tekkida.
atari_
17.04.2005 15:19:35
kas k6 ja pentium pro pole kah mitte 686..
80 |
raido357
17.04.2005 15:33:37
| atari_ kirjutas: |
| kas k6 ja pentium pro pole kah mitte 686.. |
Pigem ehk 586
indrek
17.04.2005 18:05:18
| k6 oli i586 (ta oli üldse miski imelik asi, üleminekuvorm i686-le). Aga pentium pro oli vist küll juba i686, nii tundub ka kiire netiotsingu järgi. Igal juhul iga järgmine on i686. Aga kui tahta kätte saada kõiki protsessori võimalusi, siis tuleb kernel ise oma arhitektuurile kompileerida. Vastasel korral käitubgi arvuti nagu kiire pentium pro, saamata tulu kõikvõimalikest uutest cachedest, käskudest jne.
Ho Ho
17.04.2005 18:21:49
| cachet kasutatakse olenemata kompileerimise viisist täpselt nii palju kui prosel seda on. Selle kasutust ei kontrolli mitte soft ega OS vaid prose (mälukontroller?) rauas
87 |
Alari A.
17.04.2005 18:37:36
| digweed kirjutas: |
ühenduseks elion vk. |
550 |
atari_
17.04.2005 22:31:16
tiba ot: keegi tergem võiks siia linuxi foorumisse teha mingi eraldi, veidi detailsema teema/juhendi kerneli kompileerimise kohta (mitte, et selle kohta netis vähe materjali oleks... aga siis oleks nagu palju tarkusi ühes kohas+ eesti keeles)
viimati muutis atari_ 18.04.2005 09:51:23, muudetud 1 kord |
80 |
Ho Ho
87 |
indrek
18.04.2005 01:08:16
Nende cachede suuruste kohta on HoHol ilmselt õigus jah. Ei tunne rauaasja üldse. Kusagilt nagu jäi silma, et pentium m jaoks kompileerimine võimaldab mingi cache kasutamist, aga tõenäoliselt panen kapitaalselt mööda.
Kerneli kompileerimisest - seda tasub lihtsalt proovida. Ei ole ta nii raske midagi. Kuigi ega tavadistrotega seda niiväga vaja ei lähe - kiirusevõit peaks 5% ümber jääma. Kiirusevõit muutub oluliseks, kui tegeletakse mingi videoedimise, võibolla ka mingite mängudega, kus protsessorist viimase võtmine täheldatavat lisa annab.
[m.o.b.o]
![[m.o.b.o] [m.o.b.o]](https://foorum.hinnavaatlus.ee/images/avatars/upload/9b21870441b502b62c860cb33871a1d9.gif)
19.04.2005 21:40:28
kasutusel ubuntu 5.04 ja kõik on ilus ja tore kuid mõni päev tagasi hakkas esinema probleem et ei saa klaverilt sisestada Control alt vajavaid sümboleid. mõtlesin et panen uue klaver kasutamise konfi siis kuid selle peale hakkas andma errorit
Error activating XKB configuration.
It can happen under various circumstances:
- a bug in libxklavier library
- a bug in X server (xkbcomp, xmodmap utilities)
- X server with incompatible libxkbfile implementation
X server version data:
The XFree86 Project, Inc
40300001
You are using XFree 4.3.0.
There are known problems with complex XKB configurations.
Try using simpler configuration or taking more fresh version of XFree software.
If you report this situation as a bug, please include:
- The result of <b>xprop -root | grep XKB</b>
- The result of <b>gconftool-2 -R /desktop/gnome/peripherals/keyboard/kbd</b>
ehk oskab keegi selle probleemi puhul abistada
| Kommentaarid: 22 loe/lisa |
20 |
gandalf
19.04.2005 22:15:52
| endal on kah sellist probleemi esinenud aga need veateated peaks järgmise või ülejärgmise sisselogimise ajal kaduma. ei tea miks aga kuna eriti tihti pole vaja seadeid muuta siis ei häiri
Alari A.
22.04.2005 10:06:31
| digweed kirjutas: |
krdi kala on tunnel loodud,estpakist saadud ipd jms.terminali toksitud kui ikka ei toimi
siit juba teine küsimus:updatesin kernel 2.6.10-5-386 kernel 2.6.10-5-k7(või oleks pidanud panema 2.6.10-5-k7 SMP?) peale kuid kuidas ati driverid tööle saada?
vana kerneliga panin xorg ati driverid ja kõik töötas.nüüd reinstallisin driverid+fglrx kernel source drivud kui asi ei toimi
550 |
gandalf
hiir
25.04.2005 00:21:37
Installisin omale kubuntu ja kõik on väga tore, ainult interneti ei saa mitte kuidagi. Lihtsalt pole ühendust ja kõik. Mida peaks tegema, et seda neti ühendust seadistada töötama? Net on mul selline, et kaabel läheb otse LAN-i, ei ole adsl tahtsin sellega öelda.
n22rivana
25.04.2005 13:52:37
Nüüd mina ka 5.04 peal. Kõik väga . Kõik töötab korrektselt. enne ei töötanud DVD kirjutaja. ei näidanud seda kuskil. nüüd, kui installisin 5.04 on seegi olemas. Aga küsimus selline. Kuidas ma saan Ubuntuga n.ö. netiraadiot teha? Palun seletage mulle see võimalikult lihtsalt ära.
