juxx
22.02.2005 01:16:46
lihtsalt üks uus monitor tulnud :) ... |
.. ja peale esimest review lugemist olen üle kere märg....
isend on Dell 2405FPW
..ja lugu on siin :
http://www.extremetech.com/article2/0,1558,1764458,00.asp
hmm.. seda juxxid ostaksid. peaaegu oleksin 20" ära tellinud.. nüüd tuleb raha nats juurde korjata..
Vananematu
27.02.2005 13:24:17
ossa perse, see on nagu emaplaat ja monitor üheskoos...
The UltraSharp 2405FPW ships with some useful amenities, including a four-port USB hubtwo on the main connector panel, two on the side of the display. In addition, the unit has a 6-in-1 USB card reader that supports CompactFlash (type I and II), SD/mini-SD card, Sony Memory Stick / MS Pro, Smart Media and Hitachi Microdrive.
The Dell display also offers a wealth of connectivity options, including VGA, DVI, composite, component, and S-video connections. It also has integrated picture-in-picture (PiP) that works with any pair of inputs. |
mulle ei meeldi see:
| When we move to gray-scale tracking, the default setting for the display is actually a bit under 6500 degrees K. This is a bit unusual, as many displays tend to be factory set to higher color temperatures. This results in a warmer-toned picture. |
muud jutt on päris hea tavalise lcd kohta ning et tal just oma klassi lcd-dest madalam hind on.
kuid kuna siiski kõrgem klass, wide screen ja puha, siis ei jaksa ikka säärast osta...
| Kommentaarid: 31 loe/lisa |
28 |
27.02.2005 13:29:49
| emm, see on nagu USB hub + 6-in-1 card reader + powa ekraan...
| Kommentaarid: 85 loe/lisa |
Vananematu
27.02.2005 13:31:45
| ma sain aru jah, et monitor on lihtsalt erinevate ühendusviiside edastaja kui välja arvata see kaardi lugeja, kuid ikkagi väga tervitatav asi...
28 |
Auron
27.02.2005 13:54:11
Kift asi tõesti
133 |
WerteX
27.02.2005 13:55:50
See võtab sõnatuks .
306 |
taifunk
01.03.2005 21:00:38
Hind tuleb ka kindlasti mõnus
_________________ Remember this day, men, for it will be yours for all time.
viimati muutis taifunk 01.03.2005 21:37:50, muudetud 1 kord |
| Kommentaarid: 45 loe/lisa |
36 |
suurpealik
01.03.2005 21:02:51
Sonyl peaks juba mõnda aega olema väljas enda 19" ja suuremad mudelid, millel arvuti on LCD sees ja peaks mainima, et nägid teised palju stiilsemad välja, hinda oli ... peast ei mäleta, aga vist 999 Euri.
_________________ Apple business solution partner. |
| Kommentaarid: 227 loe/lisa |
195 |
