uus teema   vasta Raud »  Kõvad kettad »  File system error 1026 ???? märgi kõik teemad loetuks
EvilMick007
sõnum 30.09.2002 22:28:00 File system error 1026 ???? vasta tsitaadiga
Mul on arvutis üks video klipp mida ära kustutada tahaksin, kuid mitte kuidagi ei õnnestu icon_sad.gif nii winxp kui 98 löövad ette kirja cannot delet file system error(1026) dosis kah ei saanud seda ära kustutada, scandist ei aidanud icon_sad.gif
Kommentaarid: 46 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 41
XYZ
XYZ
sõnum 01.10.2002 07:13:00 vasta tsitaadiga
Kui muu ei aita, siis täielik turvakoopia ja formaatimine appi.
Karzum
Karzum
sõnum 01.10.2002 07:59:00 vasta tsitaadiga
Kui suur see videoklipp on?
XYZ
XYZ
sõnum 01.10.2002 08:07:00 vasta tsitaadiga
REFERENCE NUMBER: CH000368Cannot Delete File: File System Error (1026):
Issue:
Cannot Delete File: File System Error (1026).
Cause:
This issue can be caused by one of two reasons:
Insufficient hard disk space on the computer.
A file is copied or moved to a disk, then deleted, and then the Undo Copy or Undo Move is clicked to try to retrieve the file.
Attempting to copy or delete a file over a network and the server is having difficulties sending the file because of security issues or high network traffic.
Solution:
Verify that the hard disk drive has at least 100 MB of free hard disk space. Additional information on how to determine available hard disk space can be found on document CH000369.
From the Windows desktop right click on the Recycle Bin and click properties.
In Recycle Bin Properties remove the check from "Do not move files to the Recycle Bin. Remove files immediately when deleted"
Click Apply and then ok.
Note: The Undo Copy or Undo Move do not work with a removable media or floppy disk drive.
Verify with the network administrator that there are no security issues or reports of high traffic at the time the error has occurred.
EvilMick007
sõnum 01.10.2002 09:44:00 vasta tsitaadiga
No vaba ruumi on 3 giga, ja ükski ms-i õpetus ei aidanud, no eks siis proovin formatit, video klipi suuurus on 800 Mega
Zero1&Only
sõnum 01.10.2002 15:14:00 vasta tsitaadiga
01.10.2002 10:44 EvilMick007 kirjutas:
Siis võiks kõvaketta proovi mõttes scandiskiga(DOS-i omaga) üle käia.
Teinekord saab windows valesti aru palju ruumi on järgi jäänud.
Igasugused süsteem restored armastavad võtta kõvakettalt ruumi, mis aga kuskil ei kajastu.
Siis on veel võimalus kontrollida kas asi on ruumipuuduses või mitte.Proovi kopeerida mingit sama suurusega faili ühest kataloogist teise.
[ Seda sõnumit muutis: Zero1&Only on 01.10.2002 16:19 ]
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 3 :: 3
EvilMick007
sõnum 01.10.2002 16:28:00 vasta tsitaadiga
Proovisin , faili ei saanud ka dos-is kustutada, ja dosi scandisc kah ei aidanud, kuid PM8.0-ga kustutasin selle hetkel olnud partitsiooni ära ja Tegin uue, kuid arvuti oli ikka jube aeglane, peale seda tegin formati ja nüüd tundub asi korras olevat. õnneks oli kogu see jama väiksema ketta peale nii et sain kõik vajaliku teisele kettale lihtsalt visata.
univerzoid
univerzoid
sõnum 29.03.2003 17:57:33 vasta tsitaadiga
tere
mul tekkis eile mulle täiesti arusaamatult mingil hetkel desktopile fail, mida mul ei õnnestu kustutada ja öeldakse sama asja, et file system error (1026) ning mingit laiendit failil ei ole ja üldse... microsofti support-lehest kah mingit tolku ei olnud. ja dosi all ma ei oska seda pagana sümbolit esile manada, mis seal kolmetähelises nimes esimesel kahel kohal on, et proovida nii kustutada.
oskab keegi avitada?
Locked Ghost
sõnum 29.03.2003 18:39:06 vasta tsitaadiga
Niimoodi peaks selle sümboli kätte saama:
dir >> mingi.txt
nüüd "dir" käsu sisu on selles failis
ava fail hex editoriga(või millegagi mis näitab tähemärgi numbrit), ning vaata selle tähemärgi number.
Mine nüüd calculatorisse(advanced), vajuta "hex", sisesta see number(2-kohaline peaks olema), vajuta"dec"
Nuud peaks dosis saama vajutada alt+number, et seda tähte saada
Locked Ghost
sõnum 29.03.2003 18:41:20 vasta tsitaadiga
Ahjaa, muid ei-saa-kustutada faile võib proovide kustudada kasutades lühikest dos-i nime(6 esitähte + ~1 (või ~2, kui see on nende esitähtedega teine fail, jne))
Näiteks: on fail athasdfasdfasdfasdfasdfasdfsadfsadfadsfafjhgadofihjarjlbidrufyöidujhli.avi
del athas~1.avi
univerzoid
univerzoid
sõnum 29.03.2003 20:01:57 vasta tsitaadiga
ei õnnestu nimekirja teha. siin teemas toodud juhendite alusel öeldakse alati, et " too many parametes - > "
ja seal teemas toodud listmakeriga tehtud nimekirjas ei ole seda "__o" faili kirjas.
Locked Ghost
sõnum 30.03.2003 08:54:36 vasta tsitaadiga
Hmm? Mis käsu sa siis sinna täpselt kirjutad? Ja mida sa mõtled "ei õnnestu nimekirja teha" all?
See käsk teises teemas peaks töötama, olen isegi mitmeid kordi kasutanud.
univerzoid
univerzoid
sõnum 30.03.2003 13:16:31 vasta tsitaadiga
dir *.* > bla.txt
annab vastuseks
too many parameters - >
