EvilMick007
30.09.2002 23:28:00
File system error 1026 ???? |
Mul on arvutis üks video klipp mida ära kustutada tahaksin, kuid mitte kuidagi ei õnnestu nii winxp kui 98 löövad ette kirja cannot delet file system error(1026) dosis kah ei saanud seda ära kustutada, scandist ei aidanud
| Kommentaarid: 46 loe/lisa |
41 |
XYZ
01.10.2002 08:13:00
| Kui muu ei aita, siis täielik turvakoopia ja formaatimine appi.
| Kommentaarid: 81 loe/lisa |
12 :: |
56 |
Karzum
01.10.2002 08:59:00
| Kui suur see videoklipp on?
| Kommentaarid: 17 loe/lisa |
16 |
XYZ
01.10.2002 09:07:00
REFERENCE NUMBER: CH000368Cannot Delete File: File System Error (1026):
Issue:
Cannot Delete File: File System Error (1026).
Cause:
This issue can be caused by one of two reasons:
Insufficient hard disk space on the computer.
A file is copied or moved to a disk, then deleted, and then the Undo Copy or Undo Move is clicked to try to retrieve the file.
Attempting to copy or delete a file over a network and the server is having difficulties sending the file because of security issues or high network traffic.
Solution:
Verify that the hard disk drive has at least 100 MB of free hard disk space. Additional information on how to determine available hard disk space can be found on document CH000369.
From the Windows desktop right click on the Recycle Bin and click properties.
In Recycle Bin Properties remove the check from "Do not move files to the Recycle Bin. Remove files immediately when deleted"
Click Apply and then ok.
Note: The Undo Copy or Undo Move do not work with a removable media or floppy disk drive.
Verify with the network administrator that there are no security issues or reports of high traffic at the time the error has occurred.
12 :: |
56 |
EvilMick007
01.10.2002 10:44:00
| No vaba ruumi on 3 giga, ja ükski ms-i õpetus ei aidanud, no eks siis proovin formatit, video klipi suuurus on 800 Mega
41 |
Zero1&Only
01.10.2002 16:14:00
01.10.2002 10:44 EvilMick007 kirjutas:
Siis võiks kõvaketta proovi mõttes scandiskiga(DOS-i omaga) üle käia.
Teinekord saab windows valesti aru palju ruumi on järgi jäänud.
Igasugused süsteem restored armastavad võtta kõvakettalt ruumi, mis aga kuskil ei kajastu.
Siis on veel võimalus kontrollida kas asi on ruumipuuduses või mitte.Proovi kopeerida mingit sama suurusega faili ühest kataloogist teise.
[ Seda sõnumit muutis: Zero1&Only on 01.10.2002 16:19 ]
| Kommentaarid: 16 loe/lisa |
EvilMick007
01.10.2002 17:28:00
| Proovisin , faili ei saanud ka dos-is kustutada, ja dosi scandisc kah ei aidanud, kuid PM8.0-ga kustutasin selle hetkel olnud partitsiooni ära ja Tegin uue, kuid arvuti oli ikka jube aeglane, peale seda tegin formati ja nüüd tundub asi korras olevat. õnneks oli kogu see jama väiksema ketta peale nii et sain kõik vajaliku teisele kettale lihtsalt visata.
41 |
univerzoid
29.03.2003 18:57:33
tere
mul tekkis eile mulle täiesti arusaamatult mingil hetkel desktopile fail, mida mul ei õnnestu kustutada ja öeldakse sama asja, et file system error (1026) ning mingit laiendit failil ei ole ja üldse... microsofti support-lehest kah mingit tolku ei olnud. ja dosi all ma ei oska seda pagana sümbolit esile manada, mis seal kolmetähelises nimes esimesel kahel kohal on, et proovida nii kustutada.
oskab keegi avitada?
Locked Ghost
29.03.2003 19:39:06
Niimoodi peaks selle sümboli kätte saama:
dir >> mingi.txt
nüüd "dir" käsu sisu on selles failis
ava fail hex editoriga(või millegagi mis näitab tähemärgi numbrit), ning vaata selle tähemärgi number.
Mine nüüd calculatorisse(advanced), vajuta "hex", sisesta see number(2-kohaline peaks olema), vajuta"dec"
Nuud peaks dosis saama vajutada alt+number, et seda tähte saada
Locked Ghost
29.03.2003 19:41:20
Ahjaa, muid ei-saa-kustutada faile võib proovide kustudada kasutades lühikest dos-i nime(6 esitähte + ~1 (või ~2, kui see on nende esitähtedega teine fail, jne))
Näiteks: on fail athasdfasdfasdfasdfasdfasdfsadfsadfadsfafjhgadofihjarjlbidrufyöidujhli.avi
del athas~1.avi
Kustutatud
Minul töötas ilusti paarist failist lahtisaamiseks
univerzoid
29.03.2003 21:01:57
ei õnnestu nimekirja teha. siin teemas toodud juhendite alusel öeldakse alati, et " too many parametes - > "
ja seal teemas toodud listmakeriga tehtud nimekirjas ei ole seda "__o" faili kirjas.
Locked Ghost
30.03.2003 09:54:36
Hmm? Mis käsu sa siis sinna täpselt kirjutad? Ja mida sa mõtled "ei õnnestu nimekirja teha" all?
See käsk teises teemas peaks töötama, olen isegi mitmeid kordi kasutanud.
univerzoid
30.03.2003 14:16:31
dir *.* > bla.txt
annab vastuseks
too many parameters - >
