raud14
külaline
26.09.2002 13:42:00
emaplaat: Asus Socket 478 P4B533, Intel i845E chipset, ATX
prose: Intel Pentium 4 1.70 GHz 256KB L2 cache 400MHz Bus Socket 478
kõvaketas:_80gb, Maxtor DiamondMax, 7200 rpm.
JNE...
Troll
26.09.2002 13:47:00
tsitaat: |
Enne tee ületamist vaata vasakule ja paremale.
Vaatan nii vasakule kui paremale, aga sinu 3DMargi tulemust ei näe!
_________________ TÜMPA, TÜMPA...EEST ÄRA, TROLL TULEB!!! |
Kommentaarid: 125 loe/lisa |
121 |
rogue
26.09.2002 16:01:00
cpu 1800+@2200+
mem 256mb
pow g4 4200 250/550@315/620
3dmark 11300
Kommentaarid: 21 loe/lisa |
19 |
Nu
26.09.2002 16:34:00
rouge sul see 128mb pow? mälu def kiirus 550?
Kommentaarid: 177 loe/lisa |
157 |
DigeBeni
26.09.2002 18:22:00
... tootja lehel on selline jutt:
You can overclock this card to 310 / 650.
The speed of a Ti-4600 for the price of a Ti-4200
ja minu praktika toetab seda igati, isegi ületab tiba ...
Kommentaarid: 194 loe/lisa |
160 |
Tanelusa
26.09.2002 21:28:00
Nii siin on asjad mida tegin,et saada lolli SDRAMMiga 7k-d kätte
WindowsXP & ServicePack1 from WindowsXP Update download page! |
_____________________________________________________________________________|
3DMark2001Pro:Testid tehtud tänu Tanelile! |
Test konfiguratsioon: |
AmdXp1700 (1460MHz) |
GeForce3Ti200 64MbDDR Core:175Mhz & Memory:400Mhz |
196MbSDRAM CL3 (128,64Mb pc133) |
PcChips830LR (no AGP Fastwrites) |
40Gb 7200rpm SEAGATE Barracuda ATA IV |
Parim skoor: http://service.madonion.com/compare?2k1=4564404 |
Tulemused ja tweaked: |
All tests are @ DEFAULT:1024x768 32bit |
1.5204 with Detonator 28.32 AGP ApartureSize is 4Mb CAS4 memory settings |
2.5938 with Detonator 28.32 AGP ApartureSize is 64Mb CAS4 memory settings |
3.5949 with Detonator 28.32 AGP ApartureSize is 32Mb CAS4 memory settings |
4.6009 with Detonator 28.32 AGP ApartureSize is 128Mb CAS4 memory settings |
5.6047 with Detonator 28.32 AGP ApartureSize is 128Mb CAS3 memory settings |
6.6062 with Detonator 40.41 AGP ApartureSize is 128Mb CAS3 memory settings | 7.6701 with Detonator 40.41 AGP ApartureSize is 128Mb CAS3 memory settings OC|400@500 175@220 8.6719 with Detonator 40.41 AGP ApartureSize is 128Mb CAS3 memory settings OC|RivaTunerFastWrites 9.6959 with Detonator 40.41 AGP ApartureSize is 128Mb CAS3 memory settings OC|-/-LodBias+3
10.6904 with Detonator 40.41 AGP ApartureSize is 128Mb CAS3 memory settingsOC|400@520 175@230WOW! 11.6997 with Detonator 40.41 AGP ApartureSize is 128Mb CAS3 memory settingsOC|400@540 175@235WOW! http://service.madonion.com/compare?2k1=4573874 MINE piixI!!! krt 3punkti 7kst puudu! :grin:DDD
12.7085 with Detonator 40.41 AGP ApartureSize is 128Mb CAS3 memory settingsOC|400@539 175@238WOW!
yesssssssssssssss
Kopisin siia .txt faili nii,et kiri võib segane olla
Aga jah kas see 7kd on siis hea skoor siukesele arvutile???
Troll
26.09.2002 21:45:00
TO: Tanelusa
Sa oled ilmselt kaardist viimase välja pigistanud, aga väga hea tulemuse saamist takistab su emaplaat ja PC133 mälu. Sellise prose ja videokaardiga peaksid kuskil 1200-1300p rohkem saama.
121 |
Tanelusa
26.09.2002 21:49:00
tsitaat: |
26.09.2002 21:45 troll kirjutas:
TO: Tanelusa
Ja muide kui oleks selle mälu klokkinud 540peale siis tekkis kohe graafika viga ja resu!Sama asi oli COREga 240panna ei saanud!Jooxis max payne testi ajal kokku!
Tean juba ammu aega,et ema ja pc133 on SUUUUUUUUUREX takistusex kuid õnnex on pea synna tulemas ja sellega siis meibi DDR mälu :grin:fingers crossed!!
Ja ega ma siukest skoori siis ilma teie abita oleks saanudki,TÄNUD!
Eriti sulle TROLL!THXagain!
Ja praegu default COOLERIGA jooxeb arvuti ilusti clokil 400@520 ja 175@220!CASE on kinni!
[ Seda sõnumit muutis: Tanelusa on 26.09.2002 21:52 ]
Divxx
26.09.2002 22:00:00
Hm..Mul tuli 3dMark2001 ->> 3760 points
Arvuti:
Intel Pentium 3 800 Mhz
Kõvaketas Seagate Barracuda Ata IV 40gb
Videokaart Creative GeForce 3 Ti 200
192 Ram
Kommentaarid: 3 loe/lisa |
Troll
26.09.2002 22:08:00
tsitaat: |
26.09.2002 22:00 Divxx kirjutas:
Arvuti:
192 Ram
See on nüüd küll liiga vähe! Peaks ligi 1t rohkem saama. Mis emaplaat sul on, kas RAM on PC100 või 133, milliseid draivereid kasutad?
121 |
Tanelusa
26.09.2002 22:11:00
tsitaat: |
26.09.2002 22:08 troll kirjutas:
tsitaat: |
Arvuti:
192 Ram
Ei tohiks olla!
Tegin sõbrapool enda kaardiga ja tal oli 256Mb mälu ning AMdDuron850 ning sai 3850
Anc
Kommentaarid: 53 loe/lisa |
31 |
don
26.09.2002 22:37:00
Prose: AMD XP 1600 - 1400 MHz
Emaplaat: Chaintech 7VJD2
Video: ASUS Geforce 2 GTS @ Engine: 230 Mhz; Mem: 390 Mhz
HDD: Seagate Barracuda IV 60 gb + Quantum Firebird 15 gb
Mälu: 512 Mb SDRAM
Opsys: Win XP Pro
3DMark 2001 SE: 4110
Kas norm või vähe?
Kommentaarid: 59 loe/lisa |
53 |
Mägiaivar
26.09.2002 23:14:00
AMD Athlon XP 2000+. 256 MB DDRAM 266 MHz. IBM 60 GB vint 7200 rpm.Emane mingi Innoboard BD-7300D. Geforce4 mx440 64MB.Midagi pole(veel) kellatud.
3DMark 2001 SE - 6325 punni.
Kommentaarid: 4 loe/lisa |
Troll
26.09.2002 23:16:00
Proovige uusimaid Detonator draivereid vers.40.71, leiate siit.
121 |
Tanelusa
27.09.2002 00:05:00
tsitaat: |
26.09.2002 23:16 troll kirjutas:
Irw küll
Alles tirisin sinu lingilt 40.52 ja nüüd juba jälle uued (ca 2tundi tagasi)
NVIDIA yks hull driver firma ytlen! :grin:
[ Seda sõnumit muutis: Tanelusa on 27.09.2002 00:06 ]
Troll
27.09.2002 00:14:00
Ennastki üllatas! Aga samas ei saagi aru, kelle draiverid need on, sest NVidia pole neid ju tunnustanud!?
121 |
Tanelusa
27.09.2002 00:15:00
klge kas aint minul näitab nii või äkki lisati mingi pisi proge drivudega kaasa?????
40.52 9mb
uued 40.71 15mb
On keegi neid proovinud kah ve??
Endal sai download just valmis ja läen panen peale!
[ Seda sõnumit muutis: Tanelusa on 27.09.2002 00:19 ]
Mawrec
27.09.2002 01:03:00
tsitaat: |
27.09.2002 00:15 Tanelusa kirjutas:
40.52 9mb
uued 40.71 15mb
Vähemalt GF2 Ti omanikel ei soovita 40.71 küll proovida, sest mul võttis kohe 200 punkti vähemaks 4381 -> 4169
Kommentaarid: 42 loe/lisa |
37 |
Tanelusa
27.09.2002 01:08:00
Nii proovisin siis!
3Dmark2001:ilma OCta oli HEA 6158 enne oli 6058(100punni juurde)
siis OCga 400@520 175@230(töötab arvuti koguaeg selle cloki peal!TULEMUS:6959 ehk siis umbes sama kui kasutasin 40.41!
40.52 andis skoorix 6858
Zorg
Batareimees
Kommentaarid: 140 loe/lisa |
126 |
DigeBeni
27.09.2002 06:59:00
link :: ja siin tiba ingliskeelset juttu
tsitaat: |
27.09.2002 02:16 Zorg kirjutas:
Mis vahe on Detonator draiveritel ja tavalistel kui neil üldse mingit vahte on
... nuh praktikas polegi neil mingit vahet st. nVida'le ilmselt
lihtsalt mainekujunduslikult meeldis selline ahvatlev nimi
aga iseenesest kujutab see lihtsalt universaalset draiverite
pakki/kogumit, mis sisaldab draivereid kõigile win'based
op.sys'iddele ja nVidia kiibiga videokaartidele ...
[ Seda sõnumit muutis: DigeBeni on 27.09.2002 13:59 ]
160 |
Divxx
27.09.2002 13:58:00
[quote]
tsitaat: |
Arvuti:
192 Ram
Tegeliklt peaks jah rohkem tulema....Emaplaat Acorp 6bx/via83 ja Ram 192 Pc133
Sugulane ütles ka et vähe on punkte tulnud...
Kas need detonaator driverid lähevad ka Creative GF3 Ti 200 ka we?
Troll
27.09.2002 14:05:00
Need Detonator draiverid on sellised universaalsed asjad, et sobivad pea kõigile NVidia kaartidele, proovi kindlasti mõne uuema versiooniga.
121 |
Nu
27.09.2002 16:08:00
tsitaat: |
millised need tavalised veel on?
157 |
