Henrive
20.11.2004 15:01:13
High-Q kirjutas: |
saad selle gravity guni siis kui saad mängu lõpus saad veel selle modifitseeritud ultrakiller variandi. |
gravity gun on ikka liiga möllukas .. mängule annab see palju juurde.. wicked!!!
Kommentaarid: 34 loe/lisa |
29 |
neros
20.11.2004 15:11:31
Eriti veel lõpu oma võiks juba alguses olla ma sellega käiksingi siis kogu aeg ringi... kurat kui ikka vendi saab gravity guniga lükata ja tõugata ja suuremaid asju enda poole tirida... deem
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
Kommentaarid: 48 loe/lisa |
40 |
corvette
20.11.2004 15:12:05
link :: Missing Texture Solution
Kui kellelgi esineb samasuguseid probleeme tekstuuridega, nagu minul, siis lahendus on siin:
Intructions:
1. Turn off any programs using the internet, including Steam.
2. Navigate to Drive:\Program Files\Valve\Steam\SteamApps
3. Delete the file source materials.gcf
4. Reconnect to Steam.
5. From the main menu of Steam, select Play Games
6. Right Click on Half-Life 2 and select launch game. Steam will launch the update manager and begin to redownload the source materials.gcf.
7. This step is important. Do not use the actual "Ready to play in : blank amount of time" window that comes up. Im refering to the window that will pop up when you attempt to launch Half-Life 2, and it will show a progress bar. This window is not important and can be very misleading.
8. Close all Steam windows, and in your taskbar, right click on the Steam logo, and select Monitor. This will show the actual progress of your download.
9. Once the download is complete at 100%, exit steam and restart your computer.
10. Once your computer reboots, launch Steam and launch Half-Life 2
Kommentaarid: 49 loe/lisa |
48 |
siLc
20.11.2004 15:23:42
See viis on ilus ja hea küll aga aeglase ühendusega vennal oleks väga raske giga jagu tekstuure uuesti tirida
Kommentaarid: 197 loe/lisa |
186 |
System
20.11.2004 15:29:40
Mängu alustades saan mingi kahtlase "errori" . AI disabled. Kõik vastased seisavad kohapeal ja ei liiguta.
_________________ Tuli vaikselt, tuli tasa. Varjud jättis seintele ja maha. |
Kommentaarid: 14 loe/lisa |
DigeBeni
20.11.2004 15:42:16
... polegi midagi rohkemat ülivõrdes lisada, kui juba siin korduvalt öeldud - mäng ongi täpselt see, mida oodata oli ja vähemalt mina, ei suutnud esmapilgul midagi pettumustvalmistavat leida, kõik on täpselt omal kohal nii nagu lubati ja videodest varemalt näha võis. Minu konf veab mängu suuremate slow-down'ideta 1280x1024 max. seadetega, ilma AA & AF'ta täiesti mängitavalt välja. Millegagi pole üle pingutatud, kõik on tasakaalus ja igavust tunda ei jõua, pidevalt tirib miski sind üha edasi. Palju äratundmisrõõmu nii vana taasnägemises kui ka keskkonna tuttavlikkuses, kohati tekib tunne, nagu oleksid juba ammu seda mängu mänginud Füüsika ja üldse keskkonnaefektid on tasemel ja kohe näha, et selle mängu mootoril on kindlasti tulevikku ja potentsiaali rohkem, kui esmapilgul isegi paista laseb. Sisu on nagu HL ikka, kõik koorub lahti käigupealt ja mingit pikka seletamist ega ettevalmistust ei toimu, oled kohe, kui tundmatus kohas vettevisatu ja vaata ise, kuidas välja rabeled. Kogu kulgemine on küll suht lineaarne ja valikuvõimalusi eriti pole, kuid siiski on jäetud osavalt mulje, et sa just tahadki sinna minna, kuhu minema pead, seega ei tunne ennast eriti piiratult. Taustahelid ja muusika tunduvad üsna tagasihoidlikud, kuid seda mitte, et oleksid kehvad vms., pigem nad on keskkonda üpris hästi sobitaud ja tunduvad loomulikud nii, et ei oska neile eraldi tähelepanu pööratagi. AI pole midagi ennenägematut, kui siiski tasemel, et muljet avaldada - ilmselt piirab AI'd vaid tegijate fantaasia ja arvuti võimekus, ning seega saab tulevikus palju huvitavaid mod'isid näha, kus panustatud just AI võimekusele. Kas tegemist on aasta mänguga ? Minuarust küll !
Kommentaarid: 194 loe/lisa |
160 |
Ra*
20.11.2004 15:52:58
DigeBeni kirjutas: |
Kas tegemist on aasta mänguga ? Minuarust küll ! |
kes üldse võiks lähim konkurent olla-
ma küll ei tea,
NFSU2 -kahtlen
Doom3 - heh EI
Kommentaarid: 135 loe/lisa |
123 |
MarekSäde
20.11.2004 16:00:17
olen kusagil lõpu poole jõudmas ja tõesti on tasemel mäng. Aasta mäng raudselt ja minu poolt 10-st 9,5 palli nagu laksti. Doom3 sai minult 7 ja FarCry 8 palli. Olen alati uskund PCGameri reviewidesse ning nad ei valeta ka seekord. Huvitav, et olen mänginud iga päev, mediumiga ja mul nagu küll see otsa ei saa. Ei ole ju mõtet tormata läbi hea mängumaailma nägemata selle võlu ja hirmusid. Aega on rahulikult, luurates, uurides, vaadates ja nautides Suurepärane.
Kommentaarid: 68 loe/lisa |
66 |
tomz
20.11.2004 16:01:53
System kirjutas: |
Mängu alustades saan mingi kahtlase "errori" . AI disabled. Kõik vastased seisavad kohapeal ja ei liiguta.  |
see on see kui pira versiooni "ostad".
ise hetkel 7 chapteri lõpus. kui igal pool chillida ja kõik kohad läbi käia on suht pikk mäng.
tsitaat: |
täpselt
viimati muutis tomz 20.11.2004 16:03:18, muudetud 1 kord |
2III7
20.11.2004 16:03:09
mul on selles kohas kus bugbaiti saab mingi jama, nimelt kui ma selle saan siis ma uksest sisse minna ei saa kuna see ühesilmne seisab ees ja eest ära ei lähe
Kommentaarid: 159 loe/lisa |
144 |
Kaivo
20.11.2004 16:04:06
Füüsika jne on tasemel.
Far Cry oli põnevam kuidagi.
_________________ Tracker------------------->-Dra[EST]coN-<------------------- |
Kommentaarid: 2 loe/lisa |
MarekSäde
20.11.2004 16:08:23
2III7 kirjutas: |
mul on selles kohas kus bugbaiti saab mingi jama, nimelt kui ma selle saan siis ma uksest sisse minna ei saa kuna see ühesilmne seisab ees ja eest ära ei lähe  |
pane talle laks gravity guniga
66 |
cybro
20.11.2004 16:44:46
hei!! Unable to init shader system.
AARRRGHGH mida P***, see mäng maksis palju raha ja ega uus arvuti ka odav pold, mismõttes ei lähe käima?? krt
(vanaisa arvutil läks kusjuures)
2III7
20.11.2004 16:46:35
cybro kirjutas: |
(vanaisa arvutil läks kusjuures) |
meil on sind lihtsam aidata ´kui sa ütled oma confi või paned selle oma profiili
144 |
Vananematu
20.11.2004 16:56:25
siis mõtle parem mis arvutil võiks olla viga, kui vanaisa arvutil läks käima ! ei tasu siis kohe mängu hakata süüdistama!
to Cybro
Kommentaarid: 31 loe/lisa |
28 |
rene p
20.11.2004 17:07:58
läbi sai krt. hea oli küll, kuid paar miinust minupoolt (väga pisikesed miinused). kogu arvuti peab ikka suht kiire ja hea olema, et seda nautida saaks. vahelaadimised olid üks väga tüütu 20+ sekki ootamine näiteks. vahel tekkis ka selline tunne, et kuhu edasi minema peab? siis sai tükk aega otsitud ja mõeldud, enne kui väljapääsu leidsin. fps langes ka aeg-ajalt (eriti viimaste levelite ajal) vahepeal isegi 0-13. üldiselt ikkagi andsin oma hääle HL2-le http://www.spiketv.com/events/vga2004/
seda et chaptereid oli ju 14, 15-s oli credits juba...
Kommentaarid: 71 loe/lisa |
68 |
tomz
20.11.2004 17:20:50
tsitaat: |
vahel tekkis ka selline tunne, et kuhu edasi minema peab? siis sai tükk aega otsitud ja mõeldud, enne kui väljapääsu leidsin. |
see on ainult positiivne imo. ei sõida niisama läbi nagu d3 või farcry, vaid pead ka oma aju liigutama pisut.
senimaani olen ise kõigega hakkama saanud, kuigi seal silla peal mõtlesin päris jupp aega, ei tulnud selle pealegi,et gravity gun ajab asja ära , lõpuks enamvähem kogemata sain jagu.
CnZ
20.11.2004 17:34:30
woohoo..
tundub, et 256 sdr pc -133 sucks half-life2'te <: [viskas korra pelist välja: Virtual Memory Too Low]
r9100 peal muidu graafiliselt ei jõnksuta.
der hammer
20.11.2004 17:52:34
mikk36 kirjutas: |
TD@ kirjutas: |
Tegelikult suht jama, et HL-is on ainult 15 chapterit..nii hea asi saab kähku otsa. Valve oleks võind veel natike mett moka peale määrida .. Võiks olla sama palju chaptereid kui Doom 3-s |
suht raske on ju nii pikka stoorit veel kütkevaks jätta...
Doom3'e viga oli just ühetaolisus ja ülipikk rassimine... |
Half Life1 oli väga pikk mäng ,aga ära küll ei tüüdanud..
Kommentaarid: 148 loe/lisa |
130 |
TD@
20.11.2004 17:56:15
HL1 lõppu ma vist ei näinudki, aga HL2 lõppu tahan näha kindlasti...Samas jah Doom 3 on tõesti üksluine kollihordi tapmine
_________________ If i start murdering people...there would be none of you left.
-Charles Manson |
Kommentaarid: 1 loe/lisa |
gamer
20.11.2004 18:08:01
loll küsimus, aga kas HL2'l ka võrgumängu tugi on?
Kommentaarid: 36 loe/lisa |
36 |
486
20.11.2004 18:11:48
Ma küll ei mõelnud eriti kaua keeruliste kohtade juures.Aga üks koht käis retsilt pinda, see seal vanglas kus oli 3 automaatsed kuulipildujat ja pidi end mingi armee vastu kaitsma, rsk kuidas kuidas käisid pinda oma granaatidega.
EDIT: stoory oli nõrk ja lõpp oli nõrgem kui HL1.
_________________ zero |
Kommentaarid: 46 loe/lisa |
39 |
corvette
20.11.2004 18:14:39
See on jah siga vinge, et gravitygun'iga tuleb igasugu ülesandeid lahendada, lihtsalt pöörane asi see
CnZ kirjutas: |
woohoo..
r9100 peal muidu graafiliselt ei jõnksuta. |
Keera aga virtuaal mälu juurde siis...
48 |
der hammer
20.11.2004 18:39:40
Mul teiste mängudega palju nii teinud ,et virtual memory too low ,aga panen ignore ja siis mingi 10 minuti pärast ütleb out of virtual memory ja viskab välja..
Mis seal siis nii hullu on 18+ ??
_________________ Tere. |
130 |
CnZ
20.11.2004 18:48:58
corvette kirjutas: |
CnZ kirjutas: |
woohoo..
Keera aga virtuaal mälu juurde siis... |
nii, aga mille peale ma keeran?
Inital Size (MB): 384
Maximum Size (MB): 768
või panen üldse System managed size?
korrutan, endal 256 sdr pc -133 :p
