| Kas see on Inteli lõpp? |
| Jah |
33% |
[ 52 ] |
| Ei |
43% |
[ 67 ] |
| Intelil on mingi salarelv, millest keegi midagi ei tea veel |
20% |
[ 32 ] |
| AMD teeb ise endale kahju üritades 65 nm tehnoloogiat arendada |
1% |
[ 3 ] |
| hääli kokku : 154 |
Lorien
15.10.2004 13:16:51
AMD Athlon 64 4000+ ja FX-55 testitud |
Praeguseks peaks need mõlemad protsessorid olema juba avalikkusele teatatavaks tehtud olema. Testtulemused, mis siia kirja panen on tehtud järgmise masinakonfiguratsiooniga: MSI K8T Neo 2 (MS-6702E) emaplaat, 2 x 512 MB Corsair PC3200 2-2-2 TwinX, EVGA Nvidia FX6800 Ultra graafikakaart, 2 x WD740 10,000 RPM SATA HDD Raid 9-s ja OS oli Win XP SP2 koos kõikide updateidega ja DX 9c.
Testide tulemused siis sellised:
-------------------------------------------------------------------Athlon 64 4000+-------------------------------------Athlon FX-55
Sysmark 2004 Overall Productivity----------------------------------204-------------------------------------------------- 213.7
Business Winstone 2004----------------------------------------------28.6---------------------------------------------------29.5
Sysmark 2004 ICC overall------------------------------------------222.7--------------------------------------------------239.3
Content Creation Winstone 2004------------------------------------34.9----------------------------------------------------36.6
3Dmark2003 Patch 340 (hardware)-------------------------------12365-------------------------------------------------12531.7
3Dmark2003 Patch 340 (software)---------------------------------3623.3------------------------------------------------3846.7
AquaMark3 FPS---------------------------------------------------------69-----------------------------------------------------70.9
QuakeIII Demo2 (1024x768x32)------------------------------------472.1--------------------------------------------------500.2
RTCW Enemy Territory------------------------------------------------88.2----------------------------------------------------93.7
UnrealTournment 2003 Flyby (v2206)------------------------------340.3----------------------------------------------------358
Unreal Tournment 2003 Botmatch (v2206)-------------------------123.9---------------------------------------------------131.1
Splinter Cell (1_1_1)-------------------------------------------------115.9---------------------------------------------------122
Splinter Cell (1_1_2)-------------------------------------------------109-----------------------------------------------------113.8
Doom3------------------------------------------------------------------85.7----------------------------------------------------88.6
Sciencemark 2.0 Mem BW MB/s------------------------------------5678.7-------------------------------------------------5718.7
Panorama Factory----------------------------------------------------128.293------------------------------------------------120.82
nagu näha on Athlon FX 55 igas testis üle. Huvitav ainult, mis hinnavahe tuleb nendel kahel
_________________ Live and let die.
viimati muutis Lorien 15.10.2004 19:27:33, muudetud 1 kord |
| Kommentaarid: 9 loe/lisa |
Lorien
15.10.2004 14:21:58
Tundub, et peale tänaseid uudiseid, mil Intel teatas oma 4GHz-se prose cancellimisest, on saabunud siis mõneks ajaks AMD "happy hour time"!
Dominus
15.10.2004 20:14:08
| QuakeIII Demo2 (1024x768x32)------------------------------------472.1--------------------------------------------------500.2 |
kas need on fps-id või?
76 |
One
15.10.2004 20:25:26
| Mafka kirjutas: |
kas need on fps-id või?  |
jap
728 |
Dominus
15.10.2004 20:27:35
omfg...need lausa maagilised nr ju
sellist superb asja annab ikka kokku klopsida
76 |
Tbit
15.10.2004 20:29:48
et nagu aasta tagasi aretati siin mingi 700fps q3, siis peab küll millegi väga magedaga tegu olema
|OSTAN|-> T43 pikk jahutus |
230 |
Dominus
15.10.2004 20:34:19
700 fps? eino...kust sellised numbrid tulevad?
76 |
One
15.10.2004 20:35:48
| Mafka kirjutas: |
700 fps? eino...kust sellised numbrid tulevad?  |
eino kloki videot ka ja skoor kohe tõuseb...
q3 mootor juba nii vana, et selline fps pole nii üllatav midagi...
728 |
Dominus
15.10.2004 20:37:12
jah...saan aru ...aga ikkagi
OC on kellegi mõnus eluviis
76 |
Elof
15.10.2004 20:49:40
Samas kes ootas, et FX-55 on hea CPU kontoriarvutisse, peab pettuma
Vaadates Anandtech'i "toolimärke" saab selgeks, et AMD tugevus on vaid mängudes - http://anandtech.com/printarticle.html?i=2065
(üllatus-üllatus...)
Olgu märgitud, et toolimärgid on jooksutatud mitte vabriku FX-55'ga vaid FX-55' kelladel jooksva FX-53 'ga
175 |
15.10.2004 22:12:14
| päris kobedad tulemused, aga hind tuleb neil prosedel ka sinna 12K kanti nii et pole midagi hõisata... rõõmustav on see, et AMD omab peaagu kõiges Intelit, aga hindadele see küll head ei tee...
200 |
leits
16.10.2004 01:06:13
wuhu, ootame nüüd intelit siis midagi
| Kommentaarid: 28 loe/lisa |
23 |
16.10.2004 01:10:32
kse see Doom 3 FPS on maksimum graafikaga ve?
_________________ MÜÜA: Xbox 360 E 250GB (UUS) |
313 |
Oraff
16.10.2004 01:16:22
jube kohe m6elda, et ise istun miske duroni rondi otsas hetkel... j22b siis vaid oodata inteli vastul88ki, muidu jah, hinnad meile kasuks ei tule
| Kommentaarid: 92 loe/lisa |
84 |
Lorien
16.10.2004 01:22:06
| (S.i.C.) kirjutas: |
j22b siis vaid oodata inteli vastul88ki, muidu jah, hinnad meile kasuks ei tule  |
Nagu ma mainisin, siis Intelilt esialgu sellises klassi protsessori vastulööki esialgu ei tule kahjuks. Nad lasevad lähiajal 3.8GHz prose välja ja sellega siis esialgu kõik. 4GHz jäeti esialgu mängust täiesti välja
Drake
16.10.2004 01:49:09
kas teile ei tundu et midagi on väga peetis
kui q3 fps on ~450-500
ja samal mootoril moditud mäng Enemy territory on 88fps ??
like .. see 2004 videokaartide testis .. esimestena rokkisid ti4600 ti4400 ja ti4200 ... talse
seda siis wolfET (kirjas oli küll return to castle wolfenstein, kuid imo oli see siiski ET , sest rtcw oli oluliselt fpsi leebem)
ilmselgelt pole enemy territory oma default 1024x768 configa hea võrdlus.
tõsi .. r9700 alates jne on kõrgetel resodel + AA + AF meeletult hea pref,.
kuid benchimiseks pole see mäng küll loodud ... ilusaid numbreid ta ei lao ..
eksponentsiaalset kiirusekasvu uute kaartidega lihtsalt EI SAA,.
d.
_________________ On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel- |
| Kommentaarid: 89 loe/lisa |
84 |
Dumb(_;_)
16.10.2004 07:53:19
"Kas see on Inteli lõpp"
No on teil alles küsimused
Kes viitsib, lugegu Stroligot
| Kommentaarid: 60 loe/lisa |
55 |
16.10.2004 08:11:46
lugesin läbi ja kuigi tegu oli väga üldistava tekstiga, siis eks seal oli midagi huvitavat ka... samas kõike seda on juba varem välja öeldud...
samas tegelt on intel üsna imelikus seisus... oletame, et see 4GHz prose tuleb välja, aga see üsna lähedal mõtekale tootmispiirile ja nüüd oleks sammu edasi võimalik teha kas dual core põhimõttel või kasutusele võttes AMD strateegia... st intel tooks enda MHz võib-olla isegi AMD'st madalamale, samas see viimane lööks marketingi valusalt, sest olgem ausad ikka liialt paljud inimesed vaatavad MHz'i Aga jah nagu seal artiklis öeldi - ees on huvitavad ajad
200 |
Auron
16.10.2004 10:02:22
| Mnjah praegu kärab praegune prose veel küll, kui 4200+ välja lastakse siis nähtavasti toimub ka kolimine(eeldusel, et meie poodides ka vastav emme saada on).
132 |
lamp
16.10.2004 10:21:30
Re: AMD Athlon 64 4000+ ja FX-55 testitud |
testiti fx55 ja 4000+ ning leiti et fx55 on yle? Ei teagi juhuseid kus 200mhz suurem klokk
on kahjuks
ja kui sa ei tea veel, siis 4000+ ja fx53 vahe on siis täielikult lahtise kordaja puudumine.
muidu mhz ja cache samad.
kysitlusest ka aru ei saand ästi, on vast mingit suuremat pankrotti oodata peale testide
ametlikuks tulemist?
| Lorien kirjutas: |
nagu näha on Athlon FX 55 igas testis üle. Huvitav ainult, mis hinnavahe tuleb nendel kahel  |
| Kommentaarid: 191 loe/lisa |
168 |
A-Circus.
16.10.2004 10:38:42
| Inrl ei hääbu niipea, AMD on jõudluse poolest intelist kordades mhajäänud, kuid elas edasi...
| Kommentaarid: 50 loe/lisa |
48 |
Lorien
16.10.2004 12:09:52
Eks see küsitlus sai rohkem ka irooniapoole pealt tehtud Muidugi oleks võinud jah küsimused natuke teistviisi teha...N: et kas AMD võtab lähiajal suure turuosa endale vms
tomson
16.10.2004 13:14:54
| Mafka kirjutas: |
| QuakeIII Demo2 (1024x768x32)---472.1---500.2 |
No vaata Quake III Arena miinimum nõudeid (Linux Quake III Arena Point Release 1.32b).
Pentium MMX 233 MHz + 3Dfx 8MB graphics adapter
või Pentium II 266 MHz + 3Dfx 4MB graphics adapter
või AMD K6-2 350 MHz + 3Dfx 4MB graphics adapter
64MB RAM
Quake III Arena kasutab DirectX 7't. Nii et siin pole midagi imestada. Mingi 1GB RAM'i juures paned /com_hunkmegs 600, mis on rohkem kui küll, et terve mäng laadida RAM'i (mäng on installituna kuskil 500MB) ning kui seal on taga veel protsessor, mille Front Side Bus juba on mitu korda kiirem kui min. nõuetes core speed ning isegi graafika kaardi VPU on kiirem kui min. nõuetes CPU siis vabalt tulevad sellised FPS'id.
28 |
lamp
16.10.2004 13:20:44
amd tootmisvõimalustest jaguks teoreetiliselt 30% ylemaailmse x86 turuosa täitmiseks,
niiet kui intel mitte kottigi 1-2aastat ette ei võtaks, suudaks amd teoorias oma turuosa
kahekordistada, ehk siis 30% peale.
ma ei hakanud kahekordistama ette panema "ainult" kuna paberil on see vb väike number,
amd jaoks tähendaks see massiivset kasvu.
see oli siis yks laenatud ja tõlgitud quote
aga nüüd teema juurde tagasi minnes - siiski on mul kysimus huulel, et millal suudab
amd teha yle 2.2ghz 90nm prosesi.
fx-55 on mitteplaneeritud 130nm. mitte 90nm.
| Lorien kirjutas: |
Eks see küsitlus sai rohkem ka irooniapoole pealt tehtud Muidugi oleks võinud jah küsimused natuke teistviisi teha...N: et kas AMD võtab lähiajal suure turuosa endale vms  |
168 |
One
16.10.2004 15:13:11
| Dumb(_;_) kirjutas: |
Kes viitsib, lugegu Stroligot |
just eelmisest pc formatist lugesin, et intel pani mingile uuele tehnoloogiale käpa peale
mis lubab minna sinna 10+ GHz-i juurde...
nüüd siis selline artikkel? ei tea kumb on bs? või on intel bs?
iga uus päev toob uue idee? kuna pressikott kütab nagu loom?
peale selle on see jutt sinu antud lingil 100% intelit pooldav.
ning see, et intel lõpuks ometi aru on saanud, et GHz ei loe on tore.
amd sai sellest juba ammu aru ja seetõttu nüüd nn lammutabki
728 |
