Beanladen
28.09.2004 20:24:12
19 tundi veel siis ootamist...
Rajareits
28.09.2004 20:28:17
| Beanladen, vähe vähem peaks olema nagu ju..
| Kommentaarid: 74 loe/lisa |
69 |
olc
28.09.2004 22:27:36
noh, homme mingi 15-16 ajal jooxevad servud kokku siis
130 |
28.09.2004 22:33:49
ei... enne tuleb uus lugemine
201 |
corvette
28.09.2004 22:36:08
| Magic kirjutas: |
ei... enne tuleb uus lugemine  |
ma olen ka selles 100% veendunud
| Kommentaarid: 49 loe/lisa |
48 |
28.09.2004 22:56:51
täna käisin koolist korra kodus ja siis vaatasin, et ohh jess 180 sekki veel... tutkit
201 |
28.09.2004 23:36:54
pakun, et suurust tal kuskil 0,7-1,4GB
installituna tahab ju 1,5GB
| Kommentaarid: 85 loe/lisa |
olc
28.09.2004 23:47:22
| mikk36 kirjutas: |
installituna tahab ju 1,5GB |
jeh, kuhu me küll nii jõuame. 3dmark99 oli 18.1MB, sellestki pool on vist directx6
130 |
Beanladen
28.09.2004 23:51:45
natuke infi:
3Dmark 05 scores revealed
WE HAVE SOME numbers that we would like to share with you before Futuremark finally introduces this long awaited test.
With current drivers, Nvidia will score 5000 points with the 6800 Ultra while the X800XT PR will score only 4500 with 4.9 drivers. With the new ATI driver codenamed 8.07, ATI score will jump to an incredible 5800. All these scores are on a 3.4GHz Pentium 4 machine. The ATI driver will be introduced as the Catalyst 4.10 and we learned it should get its WHQL very soon.
The Geforce FX 5950 Ultra will score a modest 1270 while the Radeon 9600XT will provide 1570 marks. The mainstream card kicks the former high end in its performance nuts.
The Geforce 6800 GT will score 4500.
You will be able to see many more scores on the 29th of this month at 3PM CET when Futuremark lifts the non disclosure agreement (NDA) veil. µ
Siit siis saate kinnitust et homme kell 17 meie aja järgi (vist ) tõmmatakse eesriie...
28.09.2004 23:54:49
| Beanladen kirjutas: |
natuke infi:
bla-bla-bla
The Geforce FX 5950 Ultra will score a modest 1270 while the Radeon 9600XT will provide 1570 marks. The mainstream card kicks the former high end in its performance nuts. |
woohoooooo.......... 8) 8)
29.09.2004 00:09:37
how come!?
313 |
redenergy
29.09.2004 00:11:17
natuke infi:
See küll normaalne nüüd pole
Nüüd said küll käkiga hakkama ma arvan
| Kommentaarid: 30 loe/lisa |
9 |
29.09.2004 00:13:59
| redenergy kirjutas: |
natuke infi:
Nüüd said küll käkiga hakkama ma arvan |
eks näeb. kust see info üldse pärineb? ametlik?
313 |
29.09.2004 00:49:01
| Fast&Furious kirjutas: |
natuke infi:
eks näeb. kust see info üldse pärineb? ametlik? |
futuremarki väida
HDTanel
Overclocker
29.09.2004 02:08:40
Noh olge õnnelikud vähemalt mina olen asi on 283Mb suur:)
irwww naera või puruks ennast omastarust üks vend kirjutas ilgema koomilt Teemas oli jutt, et kurat nad sedasi teevad, et venitavad nagu teine sellepeale kohe vastas
Poxy5
(Member)
09/28/04 08:20 PM
Re: Last countdown!!!
Prob got advice from gabe on how to delay stuff!
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Beanladen
29.09.2004 09:07:23
Pealkirja võik nüüd muuta ära: 3dmark05
erick
29.09.2004 10:14:29
Säärane madal tulemus võib olla seletatav nVidia uute draiverite madala kvaliteediga. TheInquirer avaldas just eile sellise jutu (WHQL on siis test, mille eesmärgiks IMAGE QUALITY testmine):
Our snitch sent us complete report on WHQL test finished at Nvidiai Geforce 5950 card with 61.77. they are failing each and part of WHQL test. They are failing in all fourteen tests including, D3Dlines, Multisampling, Non power 2 conditional RenderTarget, Pixel Shader Precision, Pixel Shader Ver. 1.1, Pixel Shader Ver. 1.2, Pixel Shader Ver. 1.3, Pixel Shader Ver. 1.4, Pixel Shader Ver. 2.0, Point Sprites, Texture address, Texture stage, Update surface and YUV Bit test.
Kui asjalood tõepoolest nii hullud on, siis pole midagi imestada, et osad testid jäävad lihtsalt tegemata, või loeb Futuremarki enda cheat-kaitse need kehtetuks.
Teine huvitav märkus, millest kõik siin kuidagi mugavalt mööda vaatasid, on see:
| With current drivers, Nvidia will score 5000 points with the 6800 Ultra while the X800XT PR will score only 4500 with 4.9 drivers. With the new ATI driver codenamed 8.07, ATI score will jump to an incredible 5800. |
Ajad on tõepoolest muutumas. nVidia kaardid failivad uute driveritega igas WHQL IMAGE QUALITY testis, samas kui ATI kaardid teevad uute draiveritega täiesti legaalselt 3DMark 2005-s ligi 25% perfoormantsihüppe.
Kes oleks eales arvanud?
Edit: Nägin et seltsimees Scart müüb oma X800 Pro-d... äkki mõtleb seda uudist nähes veel ümber??
viimati muutis erick 29.09.2004 10:39:21, muudetud 1 kord |
96 |
29.09.2004 10:28:53
karm boost ati poolt
201 |
aise
29.09.2004 11:12:40
ilus, esmaspäev või teisipäev peaks saama oma vivo´kese kätte saab vahelduseks mõnda teist testi peale 03´e ka jooksutada
| Kommentaarid: 189 loe/lisa |
172 |
Mirage
29.09.2004 11:49:17
in reply to erick...
Jaa, püha futuremark tunnistab, et nvidia kaardid ei kõlba kuhugi. Mina isiklikult benchmark'e ei mängi niiet I don't give a flying eff mingisuguse benchmarki nö. pildi kvaliteedi testide kohta. Peaasi, et ma ise näen ilusat pilti mängudes, mida ma mängin.
Ja ega sedasi arvavadki ainult need, kes peavad futuremark'i üllitisi vankumatult tõepärasteks. Õnneks mina seda ei tee
Hmm... tõepoolest, kes mõtleb ümber pärast seda uudist. Tõenäoliselt need, kes hakkavad seda 3dmark'i sekundis korra päevas jooksutama. Mina mõtleks ainult siis ümber (juhul näiteks, kui ma oleks ühe või teise kasuks juba otsustanud), kui hinnavahe oleks suurem, kui ta praegu on.
ATi ühed ( ) draiverid teevad midagi sellist... hehe nvidia "ühed" draiverid tegid täpselt samamoodi ju kange isu tekib paralleele tõmmata.
See uusim 3dmark peaks ju samamoodi sünteetiline olema. Sellele tuginedes võiks väita, et see ei pruugi näidata üldse mitte seda, mida kaardid mängudes teevad
| Kommentaarid: 81 loe/lisa |
74 |
Auron
29.09.2004 11:54:41
| Mirage kirjutas: |
in reply to erick...ATi ühed ( ) draiverid teevad midagi sellist... hehe nvidia "ühed" draiverid tegid täpselt samamoodi ju kange isu tekib paralleele tõmmata. |
Seda küll aga igast optimisatsiooni suhtes on tal anticheat sisse ehitaud nagu kirjas oli, sel ajal kui 03'es tüssati polnud ju sellist asja.
133 |
Scart
29.09.2004 12:02:37
ma ei näe mingit mõtet ymber mõelda, kui Richard Burns Rally ei tööta, Full Spectrum Warrior ei tööta, Rome loobib desktopi, Nexuse demo ei tööta jne jne jne.
ootame ehk asja ära, enne, kui kilkama paneme?
erick, sa vist kipud unustama, et 9600 oli omal ajal võrreldes 5950'ga ka igatepidi parem kaart pildikvaliteedis? vana "hea" FXi arhitektuur siiski uue testi puhul võrdleme ikka 6800 vs 800 ja 6600 vs 700
101 |
stepzter
29.09.2004 15:28:04
natuke infi:
See küll normaalne nüüd pole :-?
Siin ei ole minuarust midagi imelikku. NVidia FX seeria kaartide arhitektuur on enamvähem sobiv vanemate mängude jaoks, aga keerulisemate pixelshaderite puhul on tegu suhteliselt jama arhitektuuriga.
| Kommentaarid: 26 loe/lisa |
26 |
SCREAMER
29.09.2004 15:33:24
| Kommentaarid: 441 loe/lisa |
393 |
olc
29.09.2004 15:52:42
counter on igatahes nullile lähedal
sikutage nüüd
viimati muutis olc 29.09.2004 16:07:05, muudetud 1 kord |
130 |
Scart
29.09.2004 16:02:46
kohe- kohe
101 |
Tbit
29.09.2004 16:04:41
0
|OSTAN|-> T43 pikk jahutus |
230 |
High-Q
29.09.2004 16:05:50
25% juba laetud, 2,5 minti umbes veel tõmmata
speed ~1,3MB/s
97 |
aise
29.09.2004 16:06:34
õhtul ka tirima panema, kui võimalik megaumbes kindlasti
172 |
TNS
29.09.2004 16:08:04
Sikutan praegu 200, varsti peaks teada saama mitu sada punkti saan.
| Kommentaarid: 25 loe/lisa |
24 |
High-Q
29.09.2004 16:09:13
niih, olemas, viskan kohe pumpa ja datasse kah, et saaks kõik tõmmata
ise kohe kontrollida ei saa, tööarvuti seda ei võimalda
97 |
redenergy
29.09.2004 16:11:32
Kellel käes laske palun datasse või torru ka
jöuti juba kirjutada
9 |
HDTanel
Overclocker
29.09.2004 16:12:29
tirin ka siis juba maksimumiga. MInu uber 1337 maximum
496 |
m1
29.09.2004 16:14:02
www.gameland.ee
Saab eestist tirida
(üllatavalt lõdvalt sai kätte, üle MB/s pidevalt)
| Kommentaarid: 31 loe/lisa |
30 |
HDTanel
Overclocker
496 |
olc
29.09.2004 16:19:20
nad võiks yhe nulli tagant ära korjata
130 |
aise
29.09.2004 16:22:48
default kellaga oli tehtud ka see test, aga jah 16fps eks nüüd hakkab see ralli pihta jälle
172 |
ppg
29.09.2004 16:26:11
mida kuradit ta seal näitab küll siis et fps üle 30 pole kuskil
138 |
olc
29.09.2004 16:33:04
| paras aeg vist võitlustandrisse teema teha 3dmark05 skooride kohta?
130 |
HDTanel
Overclocker
29.09.2004 16:33:48
Noh üks foorumis ütles küsimusele vastates, et kuda see demo on siis
The demo made me shiet me pants
496 |
TNS
29.09.2004 16:43:19
Nii kas ma nüüd HV rekordi omanik praegult 1296 punkti , profiilis oleva masinaga, ilma kellamata, cat 4.9
24 |
keegi-Hannes
29.09.2004 17:21:06
[quote="PlatoonSgtElias"]irw ma ei tea kes see oli aga keegi juba helistas mulel ja küsis kas tasub tirida esimest korda elus
Fenomenaalne telefonis hääle kaudu "pool" nime ära tunda!!! Ma jah küsisin et kas proffikaardile ehk QuadroFX 2000 jaoks asjal mõtet on aga nüüd ei saa enam seda kuskilt kätte kõik ftp-d ja lingid umbes ehk annate mõne koha kust õnne proovida (guru3D) on umbes.
| Kommentaarid: 42 loe/lisa |
38 |
tomz
29.09.2004 17:29:42
| kel käes uppiga kuhugile. kõik kohad absull umbes...
| Kommentaarid: 68 loe/lisa |
olc
29.09.2004 17:31:33
| tomz kirjutas: |
| kel käes uppiga kuhugile. kõik kohad absull umbes... |
see www.gameland.ee kah umbes? ega see enne omkut rahune
130 |
rene p
29.09.2004 17:31:57
| tomz kirjutas: |
ma tõmban gamelandist, tuleb küll ilusti minuarust...
68 |
29.09.2004 17:44:41
mul tõmbab ka suht aeglaselt
201 |
tomz
29.09.2004 17:46:20
| olc kirjutas: |
| tomz kirjutas: |
see www.gameland.ee kah umbes? ega see enne omkut rahune  |
hehe tänud. 45 minti ja siis ounin kõik ära
corvette
29.09.2004 17:49:57
gamelandist tuleb jah hea kiirusega
48 |
rene p
29.09.2004 17:52:18
| niih olemas, varsti siis näeb palju punne saab kah...
68 |
PHT
29.09.2004 17:56:41
| mul 25 minni pärast olemas, kiirusega 115 kb/s tuleb
| Kommentaarid: 7 loe/lisa |
