excalibur
26.08.2004 12:29:02
radeon 9800pro 128mb |
Arvuti on P4 2,8HT 512ram
tegin kohe 3dmark03 sain 5000p siis vaatasin et driverid on kole vanad panin uuemad peale ja sain 5600p peale seda. Sattusin siis foorumi ja nägin et üksmees on lõpuks 7000 välja pigistanud.
andke nõu kuidas saaksin oma olukorda parandada
Intel(R) Pentium(R) 4 CPU 2.80GHz 2.8 GHz
Manufacturer Intel
Family Intel(R) Pentium(R) 4 CPU 2.80GHz
Internal Clock 2.8 GHz
Internal Clock Maximum 3.1 GHz
External Clock 200.0 MHz
Socket Designation Socket 478
Upgrade ZIF Socket
HyperThreadingTechnology Available - 2 Logical Processors
Capabilities MMX, CMov, RDTSC, SSE, SSE2
Version Intel(R) Pentium(R) 4 CPU 2.80GHz
Caches
Level 1 32 KB
Level 2 1 MB
RADEON 9800 PRO Driver 6.14.10.6476
Description RADEON 9800 PRO
Manufacturer ATI Technologies Inc.
Total Local Video Memory 128 MB
Total Local Texture Memory 128 MB
Total AGP Memory 0 B
Driver File ati2dvag.dll
Driver Version 6.14.10.6476
Driver Details 8.05-040727a-017086E-ATI
Driver Date 7-27-2004
Driver WHQL Certified false
Max Texture Width 2048 px
Max Texture Height 2048 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 2.0
Pixel Shader Version 2.0
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
VGA Memory Clock 337.5 MHz
VGA Core Clock 378.0 MHz
PCI
Name RADEON 9800 PRO
Vendor ID 0x1002
Device ID 0x4e48
SubSystem ID 0x2068148c
Revision ID 0x00
viimati muutis excalibur 26.08.2004 12:34:27, muudetud 1 kord |
Kommentaarid: 316 loe/lisa |
262 |
Troll
26.08.2004 12:34:03
Mul umbes sama tulemus R9800Pro-ga, seega pole sul paanikaks põhjust. Kindlasti saadi see 7000p proset ja videokaarti klokkides.
_________________ TÜMPA, TÜMPA...EEST ÄRA, TROLL TULEB!!! |
Kommentaarid: 125 loe/lisa |
121 |
Mirage
26.08.2004 12:58:01
5600 ju täiesti tasemel tulemus
Kommentaarid: 79 loe/lisa |
73 |
excalibur
26.08.2004 13:20:57
aga doom 3 ikka katkub
262 |
26.08.2004 13:22:55
excalibur kirjutas: |
aga doom 3 ikka katkub  |
profiili ei taha ära täita ?
palju mälu on ? 256 ?
Kommentaarid: 85 loe/lisa |
excalibur
26.08.2004 14:04:06
üleval ju kirjas
kuidas see clockimine käib üldse
262 |
26.08.2004 16:12:56
üleval ju kirjas
kuidas see clockimine käib üldse |
sry ei pannud tähele seda
nii, klokkimine: CPU, mälud - BIOS'ist tavaliselt
VGA - windowsist, ise kasutan AtiTooli...
kui videokaart liiga üle kellata, siis võib ka jõnkse tekitama hakata...
tomz
26.08.2004 17:01:55
üksmees sai 8kp kah õhkjahutusega
prose lase üks 3.4ghz peale. ei tohiks probleeme olla. ehk siis tõsta fsb'd.
video lase vähemalt 9800xt kelladele kui kannatab.
siis oledgi omadega mäel
Kommentaarid: 68 loe/lisa |
margusser
26.08.2004 17:05:27
üleval ju kirjas
ei ole sul vahemälu üleval kirjas
Kommentaarid: 215 loe/lisa |
167 |
Terror
26.08.2004 17:37:59
Seda tahaks küll näha, et 3dmark 2k3's saab 9600 seeria kaardiga 7000 punni
Kommentaarid: 100 loe/lisa |
91 |
tomz
26.08.2004 17:54:58
Terror kirjutas: |
Seda tahaks küll näha, et 3dmark 2k3's saab 9600 seeria kaardiga 7000 punni  |
mh. vennal on 9800pro.
Mirage
26.08.2004 18:39:52
Resolutsioon 1024x768, detailid High või Medium ja ei haki ta sul midagi samas, kui sul ainult operatiivmälu 256MB on siis võib ta seda vabalt teha mul 512 ja täheldan teinekord "swappimist"
73 |
aise
26.08.2004 18:41:54
sellise masinaga peaks def skoor olema 03es ~6500 ja up
Kommentaarid: 189 loe/lisa |
172 |
Troll
26.08.2004 20:44:42
margusser kirjutas: |
üleval ju kirjas
ei ole sul vahemälu üleval kirjas |
121 |
Mirage
26.08.2004 22:24:07
aise kirjutas: |
sellise masinaga peaks def skoor olema 03es ~6500 ja up  |
eip, selline on selle inimese skoor, kes tegeleb klokkimisega
73 |
aise
26.08.2004 22:57:13
ega ma päris n00b nüüd ka ei ole, mul oli sama masin ja ma ikka mäletan, mis ma sain def skooriks eks
172 |
excalibur
26.08.2004 23:04:09
mul on see jama et ma ei ole ise niis spetsialist et hakata clockima nii et ma midagi maha ei põletaks. peab kusagilt spetsialisti leidam
262 |
Mirage
27.08.2004 09:54:46
aise kirjutas: |
ega ma päris n00b nüüd ka ei ole, mul oli sama masin ja ma ikka mäletan, mis ma sain def skooriks eks  |
Mina samuti mitte, aga miks ma enda aparaadiga siis kusagil 5700 sain ainult?
73 |
merk14
27.08.2004 13:46:23
Kas te ostate kaart selleks et 3d mark skoore saada ja siis kekutada siin vaata kui palju mina sain 3d margis punkt. See skoor ju nii mõttetu teema. 3d mark testist tasuks vaadata ainult seda mitu kaadrit ta sekundis annab ja see ka kõik. kas te siis tõesti ei tea muud testi kui 3d mark ?
Kommentaarid: 99 loe/lisa |
rodi
01.09.2004 20:01:25
5917p
mingi alles installid xp mingi twiiki ei ole
asus k8v se deluxe
amd athlon 64 3200+ 2200mhz
club3d radeon 9800pro
2 x 256 kingston cl 2.5 m'a'lu
klokkimata k6ik :d
Kommentaarid: 25 loe/lisa |
23 |
wazaa
01.09.2004 20:08:39
merk14 kirjutas: |
Kas te ostate kaart selleks et 3d mark skoore saada ja siis kekutada siin vaata kui palju mina sain 3d margis punkt. See skoor ju nii (<font size=-1><i>tegelikult tahtsin kirjutada</font></i> =>)<b>mõ<font color=red>tt</font>etu</b> teema. 3d mark testist tasuks vaadata ainult seda mitu kaadrit ta sekundis annab ja see ka kõik. kas te siis tõesti ei tea muud testi kui 3d mark ? |
loe kogu teemat
Kommentaarid: 53 loe/lisa |
40 |
eXiter
08.09.2004 21:11:42
6547p.
xp 2500+ @3200+ 1,6v
2,5cl ddr 400 1GB (2x512) @2,7v
Excalibur 9800pro def 378/675 @ 411,75/729
_________________ okse RÖÖTS |
