praegune kellaaeg 10.02.2026 05:26:53
07.02.2026 12:29:30
M: 8TB HDD WD Red Plus :: Asukoht: Tallinn |
Müüki läheb siis üks WD Red Plus 8TB ketas WD80EFAX-68KNBN0
Ketas on kontrollitud ja testitud, SMART on puhas:
smartctl 7.5 2025-04-30 r5714 [Darwin 25.2.0 arm64] (CircleCI)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red Plus
Device Model: WDC WD80EFAX-68KNBN0
Serial Number: VDJ10R9K
LU WWN Device Id: 5 000cca 0bbdca614
Firmware Version: 81.00A81
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.5/5706
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Feb 6 21:11:16 2026 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 87) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 908) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0004 127 127 054 Old_age Offline - 112
3 Spin_Up_Time 0x0007 152 152 024 Pre-fail Always - 536 (Average 533)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 80
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0
8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18
9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 49804
10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 77
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 1912
193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 1912
194 Temperature_Celsius 0x0002 203 203 000 Old_age Always - 32 (Min/Max 21/48)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 49695 -
# 2 Extended offline Completed without error 00% 49614 -
# 3 Short offline Completed without error 00% 49527 -
# 4 Short offline Completed without error 00% 49359 -
# 5 Short offline Completed without error 00% 49191 -
# 6 Short offline Completed without error 00% 49023 -
# 7 Extended offline Completed without error 00% 48860 -
# 8 Short offline Completed without error 00% 48687 -
# 9 Short offline Completed without error 00% 48519 -
#10 Short offline Completed without error 00% 48351 -
#11 Short offline Completed without error 00% 48183 -
#12 Extended offline Completed without error 00% 48138 -
#13 Short offline Completed without error 00% 48015 -
#14 Short offline Completed without error 00% 47847 -
#15 Short offline Completed without error 00% 47679 -
#16 Short offline Completed without error 00% 47511 -
#17 Extended offline Completed without error 00% 47393 -
#18 Short offline Completed without error 00% 47343 -
#19 Short offline Completed without error 00% 47174 -
#20 Short offline Completed without error 00% 47006 -
#21 Short offline Completed without error 00% 46838 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay. |
Käimamineku garantii saab minu poolt kaasa.
OK: 99€ tk.
Asub Põhja-Tallinnas, eelistatud on käest-kätte tehing.
Mujale liigub ainult ostja kulul ning vastutusel ja ettemaksuga.
196 |
commer
| Kommentaarid: 920 loe/lisa |
709 |
07.02.2026 12:32:34
Vaatame seda asja, mõned päevad.
196 |
Hailer
09.02.2026 13:01:49
| 85€
| Kommentaarid: 36 loe/lisa |
34 |
09.02.2026 16:29:25
Juba parem
196 |
