uus teema   vasta Ärifoorumid »  Arvutitehnika ja tarkvara müük/vahetus »  M: 8TB HDD WD Red Plus :: Asukoht: Tallinn märgi kõik teemad loetuks
sõnum 07.02.2026 12:29:30 M: 8TB HDD WD Red Plus :: Asukoht: Tallinn vasta tsitaadiga
Müüki läheb siis üks WD Red Plus 8TB ketas WD80EFAX-68KNBN0
Ketas on kontrollitud ja testitud, SMART on puhas:
smartctl 7.5 2025-04-30 r5714 [Darwin 25.2.0 arm64] (CircleCI)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red Plus
Device Model:     WDC WD80EFAX-68KNBN0
Serial Number:    VDJ10R9K
LU WWN Device Id: 5 000cca 0bbdca614
Firmware Version: 81.00A81
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.5/5706
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Feb  6 21:11:16 2026 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84)   Offline data collection activity
               was suspended by an interrupting command from host.
               Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)   The previous self-test routine completed
               without error or no self-test has ever
               been run.
Total time to complete Offline
data collection:       (   87) seconds.
capabilities:           (0x5b) SMART execute Offline immediate.
               Auto Offline data collection on/off support.
               Suspend Offline collection upon new
               command.
               Offline surface scan supported.
               Self-test supported.
               No Conveyance Self-test supported.
               Selective Self-test supported.
SMART capabilities:            (0x0003)   Saves SMART data before entering
               power-saving mode.
               Supports SMART auto save timer.
Error logging capability:        (0x01)   Error logging supported.
               General Purpose Logging supported.
Short self-test routine
recommended polling time:     (   2) minutes.
Extended self-test routine
recommended polling time:     ( 908) minutes.
SCT capabilities:           (0x003d)   SCT Status supported.
                  SCT Error Recovery Control supported.
               SCT Feature Control supported.
               SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   127   127   054    Old_age   Offline      -       112
  3 Spin_Up_Time            0x0007   152   152   024    Pre-fail  Always       -       536 (Average 533)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       80
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   093   093   000    Old_age   Always       -       49804
10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       77
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1912
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1912
194 Temperature_Celsius     0x0002   203   203   000    Old_age   Always       -       32 (Min/Max 21/48)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     49695         -
# 2  Extended offline    Completed without error       00%     49614         -
# 3  Short offline       Completed without error       00%     49527         -
# 4  Short offline       Completed without error       00%     49359         -
# 5  Short offline       Completed without error       00%     49191         -
# 6  Short offline       Completed without error       00%     49023         -
# 7  Extended offline    Completed without error       00%     48860         -
# 8  Short offline       Completed without error       00%     48687         -
# 9  Short offline       Completed without error       00%     48519         -
#10  Short offline       Completed without error       00%     48351         -
#11  Short offline       Completed without error       00%     48183         -
#12  Extended offline    Completed without error       00%     48138         -
#13  Short offline       Completed without error       00%     48015         -
#14  Short offline       Completed without error       00%     47847         -
#15  Short offline       Completed without error       00%     47679         -
#16  Short offline       Completed without error       00%     47511         -
#17  Extended offline    Completed without error       00%     47393         -
#18  Short offline       Completed without error       00%     47343         -
#19  Short offline       Completed without error       00%     47174         -
#20  Short offline       Completed without error       00%     47006         -
#21  Short offline       Completed without error       00%     46838         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Käimamineku garantii saab minu poolt kaasa.
OK: 99€ tk.
Asub Põhja-Tallinnas, eelistatud on käest-kätte tehing.
Mujale liigub ainult ostja kulul ning vastutusel ja ettemaksuga.
Kommentaarid: 234 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 196
commer
commer
sõnum 07.02.2026 12:30:34 vasta tsitaadiga
80.- Tallinnas
Kommentaarid: 920 loe/lisa Kasutajad arvavad:  :: 4 :: 2 :: 709
sõnum 07.02.2026 12:32:34 vasta tsitaadiga
Hailer
sõnum 09.02.2026 13:01:49 vasta tsitaadiga
85€
sõnum 09.02.2026 16:29:25 vasta tsitaadiga
Hailer kirjutas:
85€
