Ta ei saa aru, et Trump müüks ilma pikema kaalumiseta osa või kõik Ida-Euroopa venelastele, sõltub ainult hinnast. Just nende väärtushinnangute järgi, mida ta takka kiidab.
See on huupi pakkumine. Kui sa päriselt seda usuks, siis peaks olema kas Kaitseliidus (võib-olla oledki) või Eestist lahkuma, sest läheb sõjaks.
Kunagi siin küsisin 2 korda, et kas siit keegi mees ka nõus rindele minema olukorra tekkimisel. Vastuseid ei tulnud. Soomes sama küsimusega vastaks tugev enamus jaa
Pole varem seda küsimust näinud, aga kui võimalik, siis tuleks kindlasti Eestisse appi. Elatud omajagu juba
Muuhulgas siis selline näkkusülitamine liitlastele:
Trump wrong that the U.S. never benefitted from NATO
Trump said "we've never gotten anything" from NATO.
That’s wrong.
According to the Defense Department in 2024, “The only time NATO invoked Article 5 of the Washington Treaty was when terrorists attacked the U.S. on Sept. 11, 2001. NATO personnel fought and died alongside American forces in Afghanistan.”’
Article 5’s key text says that "an armed attack against one or more" NATO members "shall be considered an attack against them all" with NATO members agreeing to assist the parties that have been attacked with "such action as it deems necessary, including the use of armed force."
PolitiFact found in 2013 that the NATO-led International Security Assistance Force was tasked with preventing Afghanistan "from once again becoming a haven for terrorists, to help provide security, and to contribute to a better future for the Afghan people."
Six months after President Barack Obama took office, NATO forces in Afghanistan numbered 64,495. As a result of the “surge" supported by Obama, the number of allied troops more than doubled by June 2011, to 132,457.
According to historian David Murphy of Ireland’s Maynooth University, Danish troops were among the NATO nations supporting the U.S. effort in Afghanistan. Danish troops suffered 44 fatal casualties, Murphy said — the highest per capita death rate among coalition members. Another eight Danish soldiers died in Iraq, he said.
Mõni ikka veel arvab, et tema jaoks on faktid tähtsad või? Ta lihtsalt ütleb, mida tahab. Kui härra suvatseb ignoreerida kõike, mida liitlased on USA heaks teinud, siis ta lihtsalt teeb seda. Ja jutuga, et härra te eksite, ennast talle armsamaks ei tee.
Kui inimene käitub nagu idioot ja räägib nagu idioot ja üleüldse pole kunagi midagi muud olnud kui idioot...siis ta mängib hoopis geniaalset 4d malet vms.
Keegi seda ei arva, aga tõde on vastukaaluks vajalik.
Mitte keegi peale sinu ei arva siin, et ta 4d malet mängib. Tal on lihtsalt võim pähe löönud, ja ta teeb mida tahab, sest ta saab. Selleks ei pea väga intelligentne olema.
Jah.
See on väga tõenäoline. /s
Praegu võiks vabalt öelda ka et sa räägid endast
Biden ei küündinud isegi idioodi tasemeni, nii frukt lihtsalt
Bidenil olid vast arukad inimesed toeks. Trump otsa peaks ühte või teistpidi saama või tagasi astub siis on natukese vähem hull järtsus. Nagu puutjaga.
Lähiaastatel midagi head ikka ei paista
Või natukese rohkem hull. Praegu üks asi mida me Trumpi kohta saame statistilise tõenäosusega öelda, et TACO. Ma ei tea, kas me saaks sama Vance kohta öleda näiteks ja noh seal kulisside taga on veel igasugu friike varuks.
Mida oligi oodata, siin on osa seltskonda liialt pöördes. Taaskord - Trump ei ole jumal, USA-s kehtib veel endine riigikord. _________________ Tsensuur HinnaVaatluse foorumis
USA-l on juba praegu lubatud rajada Gröönimaale sõjaväebaase. Teoreetiliselt peaks kavandatav lepingu raamistik võimaldama USA-l kontrollida teatud Gröönimaa osi, sealhulgas alasid, kus asuvad maavarad. See tähendaks, et USA ei peaks enam näiteks ka ehituslube taotlema. Samuti oleks USA-l seal lihtsam arendada oma Kuldse Kupliga (USA kavandatav raketitõrjesüsteem– toim) seotud projekti.
Maavarad USA-le, tühjad pihud Euroopale. Kuidas see parem on?
Näed Taanit palju Gröönimaal kaevandamas? Ehk siis mida me kaotame? Gröönimaa elanikuna oleks ehk sellepärast mures, eestlasena küll mitte. USA pakub Euroopale julgeolekut, sest ise me seda endale pakkuda ei suuda. Kas need just tühjad pihud on...
Ei näe Taanit praegu kaevandamas praegu ja nagu selgus - ka tulevikus mitte. USA pakub Euroopale julgeolekut? Kui kindel sa selles viimasel ajal oled? Sa oled üks nendest naiivitaridest? _________________ M: Intel i5 4590 protsessorid: 10€/tk M: HP Elitedesk 800 G3 SFF: 90€/tk M: HP Elitedesk 800 G2 Mini 35W: 90€/tk
Ja täpselt selline kõne oligi? Hakkiv, kontekstist välja lõigatud? Endal ei ole imelik või?
Järjest enam hakkab tunduma et ta lihtsalt trollib teid leftiluusereid
Trump ju toetab üsna oluliselt... EU ühtsus paraneb _________________ PORTFOLIO
Milline ühtsus? Asjad on p*rses, et Kaja tahab jooma hakata.
Kas see Kallase ütlus (mitte avalik, vaid kollegid omavahel) on tõesti nii hull ja laastav, et väärib sellist hüsteerilist tähelepanu? Nagu päriselt, mis selles ütluses nii pahasti ja hullusti oli, et osad väänlevad nüüd lausa agoonias ja ei suuda ära halada oma hingevalu ja sügavaid haavu, mide see lause nende vaimse tervise sisse tekitas? _________________ Psychologists usually attribute belief in conspiracy theories to a number of psychopathological conditions such as paranoia, schizotypy, narcissism, and insecure attachment, or to a form of cognitive bias called "illusory pattern perception".
Kaja minu meelest täpustas intervjuus, et see oli öeldud uusaasta eel kolleegidele, soovides head pidu. Meedia nagu ikka krabas selle üles ja ehitas oma narratiivi külge
USA surve pärast tõmmati ju koosolek käima. Promilliga või ilma - vähemalt räägitakse autonoomiast rohkem. _________________ PORTFOLIO
Euroopas muudkui räägitakse jah, Venemaa ei ole Eestile kallale tulnud seetõttu, et USA saab veidi rohkem ka teha kui rääkida. _________________ Tsensuur HinnaVaatluse foorumis
Ühtsus
Trumpi kontekstis on prostituudil rohkem segroogu, kui sellel majandusühendusel, keda vanamees siin viimased paar nädalat ette ja taha kottinud on. _________________ All it took was for a lot of seemingly decent people to put the wrong person in power, and then pay for their innocent choice.
Mina ei näe seal mingit vahet "Kaja tahab jooma hakata" vs "Mis lipp lehvib Hermann'i tornis... jne" mõlemad olid kontekstist välja rebitud ja iga täiemõistusega inimene kel veel arutossu pealuu sees järel on saab ellest aru, aga samasugune ümberväänatud hüsteeria tehti teisest ütlusest missugune.
Nüüd ma saan omale muidugi kohe siin Tibla, Fritsu jne kõikmõeldavad ja veel väljamõtlemata tiitlid, aga mul savi . _________________ Win ISO'd ja uuendused Artiklid jagatud
Selle võimaluse eest hoiatati juba kunagi ammu, et kui te oma rahvast piisavalt nu**ite siis nii võib minna. Nüüd on see olukord käes... ja kõike seda tänu riigi eesotsas olevatele rahaahnetele huiaritele, just täpselt huiaritele, sest poliitikud nad kohe kindlasti pole. _________________ Win ISO'd ja uuendused Artiklid jagatud
viimati muutis Longero 22.01.2026 18:52:37, muudetud 1 kord
Üks on ikkagi rahvusringhäälingu väljaanne ja teine kollane prügikast
Võibolla, ilmselt pole eestis teistmoodi kui mujal. Kui vaja maailmas mingi uudis lahti lasta siis on see kohe kõigis BBC, Bloomberg jne pasaladudes. See väga kedagi ei huvita kes uudise "treial" on ja sageli on seal mittemidagiütlev info v pole üldse midagi . _________________ Win ISO'd ja uuendused Artiklid jagatud
Helmedel on alati õigus isegi siis, kui neil vale on, vähemalt osade arvates
Esimeses stuudios sai ilusti kuulata, mis sorti "mehega" tegemist on.
Siis on küll ikka pahasti kui vahet ei näe, saan aru mentaliteedist, et omadel on aalati õigus, aga no kui siin ikka vahet ei näe, siis on päris pahasti.
Tekst ise oli selline. Pane sinna kõrvale nüüd Kallase lause, et olukord ajab jooma, täpselt sama?
Järvi: Aga ikkagi, isamaa huvid kaaluvad üles igasugused muud asjad. Jah, et, kui nüüd Putin tuleb, et siis on kõikidele hea selline testiküsimus, et kui palju te olete valmis sellise riigi eest omaenda verd valama? Kuidas teil on kodanikud?
Vooglaid: Ei noh, mina olen seda varem ka öelnud ja ma ei häbene seda ütelda ka uuesti, et vaata, kui Venemaa tegutseks sellisel viisil, et ta tagaks inimestele päriselt põhiseaduslikud õigused, ei suruks peale seda ... ei teostaks vaktsiinisundi, ei teostaks apartheidi, jätaks inimestele võimaluse elada ja kasvatada oma lapsi vastavalt oma veendumustele, ei hakka ähvardama siin vangistusega, sellepärast et sa ei ole nõus, ma ei tea...
Järvi: Homotorti tegema...
Vooglaid: Jaa, pidev selline kiusamine lollide väikeste asjadega nagu. Ei taha sind relvituks teha, eks ole. Ei taha su vanemlikke õigusi piirata. Ei taha sinu lapsi süstida sinu selja taga niimoodi. Siis tekiks väga kiiresti väga tõsine küsimus, et nagu, ma ei tea, mina tahan lõppude lõpuks elada normaalset elu, eks ole. Nimetage seda Eesti Vabariigiks või nimetage seda mingiks Eestimaa kubermanguks või millekski muuks, eks ole. Kes iganes tagab inimestele võimaluse siin normaalselt elada, selle poole siis inimesed hoiavad, eks. Et sa ei saa nagu lõputult ka mingi emotsionaalse argumendiga, et meil peab siin tornis olema sinimustvalge, eks ole, mis siis, et selle sinimustvalge all sa tegeled nagu inimeste ahistamise ja kiusamise ja mahasurumisega, eks.
Järvi: Mina ütlen lihtsalt seda, et esimest korda Eesti Vabariigi sünnipäeval, 24. veebruaril, minul on selline tunne, et see lipp ei esinda mind. See lipp ei ole see, mille eest ma tahaksin elada ja surra. See ei ole mingi riik, mis on minu riik. See ei ole mingi Eesti, mis on minu Eesti. Meil on kaks Eestit täiesti omavahel lõhki. Üks on nomeklatuurne Eesti ja teine on nii-öelda kõrvaletõrjutud Eesti. See nomenklatuurne Eesti on valmis astuma kõrvaletõrjutud Eesti õigustel, valmis trampima nende õigustel. Ja ma pean tunnistama, et esimest korda võib-olla, et vabariigi aastapäeval mul on selline tunne, et mind ei huvita see asi. Mind ei huvita üldse see asi. Mulle meeldib Vabadussõda, mulle meeldib vaba rahvas. Mulle meeldib see, mis on eesti kultuur, aga see süsteem, mis praegu sinimustvalge lipu taha varjub - see ei ole minu Eesti.
Vooglaid: Minu Eesti see ka ei ole. Ma ka ei tunne mitte mingisugust ühisosa selle seltskonnaga, kes seal Stenbocki majas pesitseb ja ministeeriumides ja mujal. Pidage ise oma pidu ja olge õnnelikud eksole. Eriti veel olukorras, kus te ei ole nõus isegi neid piiranguid tühistama vabariigi aastapäevaks. Te jätate sajad tuhanded inimesed apartheidirežiimi alla, avalikust elust kõrvaldatuks eksole. Sa teed sellise olukorra, kus isegi vabariigi aastapäeval ei saa inimesed minna näiteks perega restorani, et tähistada vabariigi aastapäeva. Sõitke seenele oma pidustustega ja tõesti, noh, pidutsege nii palju kui tahate, eks ole. Ja siis tõstke maksusid, et järgmine aasta saaks veel rohkem pidu pidada teiste inimeste raha eest, keda te represseerite samal ajal. Mul ei ole ka mitte mingisugust huvi selle seltskonnaga mingit ühist pidu pidada siin. _________________ Psychologists usually attribute belief in conspiracy theories to a number of psychopathological conditions such as paranoia, schizotypy, narcissism, and insecure attachment, or to a form of cognitive bias called "illusory pattern perception".
Võibolla tulekski tõesti kinni panna.
1. Kui arhiivi sirvida siis on võetud maha paljud siiani vabalt kättesaadavad vanad filmid nö "Eesti kullafond".
2. Vanadest intervjuudest on "VALIKULINE" kättesaadavus. Ma ei usu, et nii olulised asjad "kadunud" on See näitab selgelt, et propamasin töötab kellegi heaks ja lool lõpp.
