praegune kellaaeg 02.11.2026 20:39:31
ummiq
02.04.2025 21:12:21
https://www.tiktok.com/legal/page/us/privacy-policy/en
Tasub lugeda ka TikToki privaatsuspoliitikat. Eks seal on suur osa sama, nagu Facebook ja Instagram jne. Aga no lihtsalt..:
| Device Information. We collect certain information about the device you use to access the Platform, such as your IP address, user agent, mobile carrier, time zone settings, identifiers for advertising purposes, model of your device, the device system, network type, device IDs, your screen resolution and operating system, app and file names and types, keystroke patterns or rhythms, battery state, audio settings and connected audio devices. We automatically assign you a device ID and user ID. Where you log-in from multiple devices, we will be able to use information such as your device ID and user ID to identify your activity across devices. We may also associate you with information collected from devices other than those you use to log-in to the Platform. |
_________________ --
Urmas |
Morana
Aeg Maha 2a
30.05.2025 15:23:55
| Mis mõte on selliste andmete edastamisel? Ja mis mõte on trahvil? Kellele see trahv määratakse?
30.05.2025 19:16:18
Hiina tulevane globaalne domineerimine
Brüsselile lisapappi ikka vaja
seda trahvi ei maksta suure tõenäosusega
