Zonerman
| Kommentaarid: 68 loe/lisa |
67 |
10.06.2024 18:56:53
Arrow Lake tuleb väidetavalt Oktoobris, seega poleks üllatav.
| Kommentaarid: 92 loe/lisa |
Auron
10.06.2024 19:43:26
| Tomorrow kirjutas: |
Arrow Lake tuleb väidetavalt Oktoobris, seega poleks üllatav. |
Arrow Lake on surnult sündinud üritus - sellepärast ei pea küll AMD kuhugi kiirustama.
133 |
Optimist
12.06.2024 14:49:04
Single core CPU-Z pole power limited aga 5% takti lisamist annab 11% jõudlust juurde ? Pakun RAM on ka OC'd saanud.
E: AMDi marketingu tegelane Anandtechile: ".."Zen 5" microarchitecture won't beat the Ryzen 7000X3D series at gaming workloads, said Donny Woligroski, the company's senior technical marketing manager, in an interview with Tom's Hardware. The new "Zen 5" chips, such as the Ryzen 7 9700X and Ryzen 9 9950X, will come close to the gaming performance of the 7800X3D and 7950X3D, but won't quite beat it"
https://www.techpowerup.com/323529/amd-says-ryzen-9000-series-wont-beat-7000x3d-series-at-gaming
| Kommentaarid: 10 loe/lisa |
12.06.2024 22:10:25
| Optimist kirjutas: |
| Single core CPU-Z pole power limited aga 5% takti lisamist annab 11% jõudlust juurde ? Pakun RAM on ka OC'd saanud. |
5.05 > 5.7 on +12.8%
775,9 > 871,4 on +12,3%
source ja asjad räägivad, et es ja seega pole baseline mitte spec 5.4 vaid 5.05. ja siis keerutatakse uudispealkirju üles.
zen4 > zen5 vahe cpuz testis per takt tuleb kuskile +7% kanti.
https://www.techpowerup.com/323529/amd-says-ryzen-9000-series-wont-beat-7000x3d-series-at-gaming |
kas keegi on selle üle üllatunud?
_________________ - londiste
217 |
13.06.2024 15:07:50
B650 Chipset and Micro-ATX Form-factor Dominate Socket AM5 Motherboard Sales: Research
https://www.techpowerup.com/323559/b650-chipset-and-micro-atx-form-factor-dominate-socket-am5-motherboard-sales-research
| A market research of AMD Socket AM5 motherboards sold in South Korea by Danawa, provide some interesting insights on how gamers approach the platform. This research is confined to Korea, but can be extrapolated to other similar markets. |
Pole üllatav, et B650 on kõige populaarsem ja et X670E on populaarsemad kui B650E ja X670. Viimased kaks on suht mõttetud ja võiks olemata olla. Viis kiibistikku samale socketile on liiga palju. Eriti kui erinevused on nii väikesed.
A620 on kõige mõttetum. A seeria hind on alati olnud nii lähedal B seeriale, et pole mingit reaalset põhjust olnud seda soovitada isegi budget ostjatele.
Üllatav, et ATX on nii väikse osaga vs mATX aga see võib ka olla Korea eripära, sest kui vaadata Geizhalist seda jagunemist on ATX ja mATX pea sama arv plaate saadaval: Mini-ITX (9) µATX (63) ATX (58) E-ATX (SSI CEB) (4) E-ATX (SSI EEB) (4).
Optimist
13.06.2024 15:11:17
| londiste kirjutas: |
OK see ES 5,05 GHz seletab asja kenasti ära, ei olnud sellest teadlik.
Kuna ise eriline mängur pole, siis 5,5 GHz 9700X huvitab rohkem kui 5 GHz 7800X3D. Rohkem jõudlust per takt, rohkem takti ja tõenäoliselt suurem OC potentsiaal + tehasest enamvähem sama AMD 65W TDP tänu 4nm compute die'le. Ilmselt suurem osa mängureid aga ootavad ostuga 9800X3D tulekuni.
Zonerman
13.06.2024 15:31:21
The new "Zen 5" chips, such as the Ryzen 7 9700X and Ryzen 9 9950X, will come close to the gaming performance of the 7800X3D and 7950X3D, but won't quite beat it. The new processors, however, will offer significant generational performance uplifts in productivity workloads, particularly multithreaded workloads that use vector extensions such as VNNI and AVX512. The Ryzen 7 7800X3D remains the fastest gaming desktop processor you can buy.
Nii ma algusest peale arvasingi. Kellel mängimine ei ole peamine eesmärk, siis on mõtet upgrade teha, muul juhul mitte.
_________________ Sõim ja räuskamine läheb SIIA |
67 |
Optimist
13.06.2024 15:49:50
| 65W on ikka tänu madalamale baaskellale (vs nt 105W 7700X), mitte tänu 4nm'le. |
Ma arvan see on tänu mõlemale.
13.06.2024 15:56:33
ilmselt tänu mõlemale. 5nm > 4nm vahe on väike aga midagi sealt ikka saab.
suurem osa tuleb pigem taktist. tsmc 5nm perekonna taktsagedused seal 5ghz peal lähevad tarbekõvera osas väga valusaks.
217 |
marxveix
| Kommentaarid: 310 loe/lisa |
270 |
Optimist
19.06.2024 14:40:41
tundub samad msrp, mis kaks viimast põlvkonda, võib-olla 9950x 50 raha odavamat?
217 |
1dumbpcuser
97 |
Optimist
19.06.2024 15:05:42
| Samas 7950X3D on 495€ Eestist ostes ja vbla augustis langeb veelgi.
Arx07
19.06.2024 15:09:37
1dumbpcuser, 7600X oli ka algul 350+eur(ja EU MSRP 334eur), aga juba 3 kuu pärast liikus 250 euriga.
Ise ootan X3D, aga reliis on hiljem ja lisaks nende hinnad püsivad kirved pikemalt... 7800X3D hinnagraafiku järgi ca 5 kuud peale reliisi juba selline enam vähem hea hind. Aga eeldatavasti enamik 7800X3D omanikke ei plaani upgradeda, et 9800X3D hind äkki loksub veidi kiiremini paika.
1dumbpcuser
19.06.2024 15:29:25
Kas AMD strateegia on ikka chipletide baasil, see tähendab, et loota mingit spetsiaalset "gaming" CPU-d, mis olekski ainult üks homogeenne 8-tuumaline suure L3-ga on suhteliselt välistatud?
_________________ M: MSI B660M MORTAR
M: Dell RTX 2060
O: AM5 ITX emaplaat |
97 |
Optimist
19.06.2024 15:35:41
| 1dumbpcuser kirjutas: |
Kas AMD strateegia on ikka chipletide baasil, see tähendab, et loota mingit spetsiaalset "gaming" CPU-d, mis olekski ainult üks homogeenne 8-tuumaline suure L3-ga on suhteliselt välistatud?  |
Pakun 9800X3D tuleb jõuluks müüki.
19.06.2024 15:56:03
Need on mingi konkreetse edasimüüja enda hinnad. Pealegi ei ole loogiline, et 9900X on ainult $ 51 odavam kui 9950X. Sellisel juhul ostaks enamus 9950X.
7000 seeria hinnad olid:
Ryzen 9 7950X: $699
Ryzen 9 7900X: $549
Ryzen 7 7700X: $399
Ryzen 5 7600X: $299
Kui AMD on seekord suurendanud 9900X MSRP $599 peale ja 9950X oma vähendanud $50 võrra, siis see vähendab 9900X müüginumbreid veelgi vs eelmised 12c/24t mudelid mis niigi olid palju vähem populaarsed.
Otsene vastus sinu küsimusele on ei.
Ei tule monoliitset kivi millel nt 8c/16t ja suur hulk L3. 9800X3D on ikkagi eraldi IO ja Compute chipletitega. Isiklikult mina probleemi ei näe niikaua kuni jõudlus on Inteliga konkurentsivõimeline ja voolutarve/hind on kontrolli all.
Strix Point variant on monoliitne aga L3 on siiski kaugelt vähem kui X3D mudelitel (24MB vs 96MB 9800X3D/128MB 9950X3D).
Strix Halo on 64MB L3 aga see on MCM nagu desktop prosed ja selle eesmärk on pakkuda dGPU asendust.
Vael
20.06.2024 07:44:26
APUd on, aga ega need x3D CPUst kiiremad pole, seepärast et monoliitsed on.
N 5800x3d on isegi tänasel päeval täitsa viisakas veel, samal ajal kui Intel otsib taga bug 7ma prosas ja vähendab kiirusi arvatavasti veel tulevikus. 1 FW lapp juba tuli...
AM4 platvorm nagu Sandy Bridge oli, toda ka 10a polnud erilist vajadust uuendada.
ainult et AM4 peal saand juba 2x perf boosti uute prosede näol, ja nüüd 5800x3d pole plaanis ka veel 2 põlvkonda vajadust olnud uuendada, vb zen6 pakub juba pinget...
| Kommentaarid: 17 loe/lisa |
16 |
20.06.2024 22:55:36
näe, i3-12100 on sama kiire kui 7800x3d. vastavalt amd testimisele
tunnistan, et kerisin diagonaalis läbi - aga miks 7900xt, mitte xtx või 4090?
teksti kujul sama asi ka: https://www.techspot.com/article/2853-amd-bad-cpu-benchmarks/
217 |
1dumbpcuser
21.06.2024 00:21:02
Ju AMD arvas, et "no such thing as bad press"
Ühelt poolt on tore, et AM4 ikka elab
Samas wtf numeratsioon?
Ryzen 9 5900 - 12c/24t
Ryzen 9 5900X - 12c/24t
Ryzen 9 5900XT - 16c/24T
Ryzen 9 5950X - 16c/32T
Miks ei võinud see olla 5950 non-X või 5940X vms?
M: Dell RTX 2060
97 |
anubis
283 |
1dumbpcuser
21.06.2024 10:59:26
XT oli varasemalt ju kõrgema taktiga mudel (umbes nagu KS mudel Inteli ), 5900xt on 5950x miinus 100mhz (3.3/4.8ghz vs 3.4/4.9ghz), seega 5950xt tekitaks teistpidi segadust.
Kahju, et am5-le pole mingit 90-100€ CPUs saada.
M: Dell RTX 2060
97 |
c4v6
21.06.2024 11:14:33
7500F maksab siin alates 170 ja mujal maailmas 150+
See on küll rohkem kui see 100 aga tegemist on ju ka väga võimeka asjaga. Endal jookseb 5350mhz all-core hetkel ja R23 tuli mingi 15200 äkki. Mul ainult 240mm aio ka. Ilmselt hea jahutuse, emaplaadi, mälude timmimisega teeks kuni 5,5ghz vähemalt osade tuumadega ja mingi 16k+.
Mängudes pigem võrdväärne 14600k prosega
Tõenäoliselt varsti hind kukub veidi ning mingi black week raames võibki ala natuke üle saja saada.
_________________ Emotsionaalne suruja
https://hwbot.org/users/tannu013/ C'mos, Simmo... Pole hullu, ma klokin esimest korda
https://discord.gg/4CKG5Vnqc - PC huviliste discord |
| Kommentaarid: 72 loe/lisa |
68 |
22.06.2024 16:46:13
CUDIMM Standard Set to Make Desktop Memory a Bit Smarter and a Lot More Robust
https://www.anandtech.com/show/21455/making-desktop-ddr5-even-faster-cudimms-debut-at-computex
CUDIMMs tweak the traditional unbuffered DIMM by adding a clock driver (CKD) to the DIMM itself, with the tiny IC responsible for regenerating the clock signal driving the actual memory chips. By generating a clean clock locally on the DIMM (rather than directly using the clock from the CPU, as is the case today), CUDIMMs are designed to offer improved stability and reliability at high memory speeds, combating the electrical issues that would otherwise cause reliability issues at faster memory speeds. In other words, adding a clock driver is the key to keeping DDR5 operating reliably at high clockspeeds.
All told, JEDEC is proposing that CUDIMMs be used for DDR5-6400 speeds and higher, with the first version of the specification covering speeds up to DDR5-7200. The new DIMMs will also be drop-in compatible with existing platforms (at least on paper), using the same 288-pin connector as today's standard DDR5 UDIMM and allowing for a relatively smooth transition towards higher DDR5 clockspeeds. |
26.06.2024 13:02:57
https://www.nextplatform.com/2024/06/24/the-appetite-for-datacenter-compute-capacity-is-ravenous/
| I really like our chances with TSMC. I think they are an amazing partner and an amazing execution machine, and we’re going to keep using their most advanced process for each generation. I like our chances of staying at the bleeding edge of process with that. |
zen5 on n3, right... right?
in all fairness, zen5c vist on n3 peal.
217 |
rene p
68 |
Optimist
27.06.2024 10:31:24
Loodetavasti säilib võimalus TDP 65W peale tagasi keerata, muidu mul selle CPU vastu huvi pole
27.06.2024 12:27:39
amd on inteli urundamise playbooki ikka väga ette võtnud
217 |
c4v6
27.06.2024 15:56:59
Kas see TDP peab siis üldse seda tähendama, et nii ongi? See võib ju vabalt mängudes mingi X korda väiksema numbriga hästi perfoormida
68 |
27.06.2024 17:20:22
ainukene loogiline kahtlus on, et muutuse taga on konkurents 7800x3d-ga. sel juhul asi lihtsalt peab mängudes olema. ka suure cachega võistlemiseks on vaja kõrgeid takte, mis ka amd puhul lähevad efektiivsuskõveral juba väga järsku üles. nii et ka mängudes võib sealt tõsiseid tarbimisnumbreid tulla, mis selle 90w vms sisse ära ei mahuks.
hetkel on see muidugi kõlaka tasemel asi.
217 |
1dumbpcuser
97 |
Arx07
30.06.2024 10:42:44
Kuna EA WRC on väga CPU heavy mäng siis otsustasin ikkagi 5800X3D pealt 7800X3D peale upgradeda.
Seda siis 3440x1440 resol:
FPS cap oli 162 peal, et jäi veel varu ka
viimati muutis Arx07 30.06.2024 11:52:09, muudetud 1 kord |
Zonerman
30.06.2024 10:59:17
78003D kasuks räägib ka suur min fps tõus lisaks.
67 |
Arx07
30.06.2024 12:22:27
Zonerman, see kõige tähtsam smoothiks gaminguks jah.
Muutsin enda jagatud pildi ära ühe teise katse benchmarki vastu, kus 7000 seeria mudel konkreetselt 2x parem.
1dumbpcuser
97 |
c4v6
68 |
Optimist
Arx07
01.07.2024 13:14:04
| RAMist tundub väga palju perf ei olene. Mu Hynix 6000mhz CL30 EXPO profiil oli suht juust, timmisin ta ära - RAM benchmarki tulemused(ja latency) 10-20% paremad, aga WRC mängus tuli suht sama tulemus(õrnalt kõrgem average fps ja low 0,1%, aga õrnalt kehvem 1% low fps)
C1rca
01.07.2024 13:40:56
Ise ühte Ryzen 7600 kasti panin tuimalt 5200mhz ja cl40 mälud, väidetavalt see mälukiiruse teema ikka ülepaisutatud mängudes. Osad youtube videod screamivad ka, et stop wasting your money on expensive RAM.
Kui aus olla, siis ma ise väga palju sellesse teemasse süübinud ei ole aga mõned videod olen läbi ketranud ja sellepõhjal otsuse teinud, et mälu kiirust ja timingut taga ei aja.
97 |
tshw900
01.07.2024 13:51:56
Kas 9000 seeria cpu kasutamiseks peaks uued 9000 seeria jaoks toodetud emaplaadid ka ära oootama ja soetama või saab 7000 seeriaga kasutatud emaplaatidega kohe kasutusse võtta, ilma et peaks tootja poolseid BIOS uuendusi ootama?
viimati muutis tshw900 01.07.2024 14:11:00, muudetud 1 kord |
| Kommentaarid: 66 loe/lisa |
56 |
01.07.2024 13:59:49
| C1rca kirjutas: |
Kui aus olla, siis ma ise väga palju sellesse teemasse süübinud ei ole aga mõned videod olen läbi ketranud ja sellepõhjal otsuse teinud, et mälu kiirust ja timingut taga ei aja. |
Üldiselt on hinnavahe nii väike, et madalama kiirusega mälu ostmine pole teab mis mõttekas.
| tshw900 kirjutas: |
| Kas 8000 seeria cpu kasutamiseks peaks uued 8000 seeria jaoks toodetud emaplaadid ka ära oootama ja soetama või saab 7000 seeriaga kasutatud emaplaatidega kohe kasutusse võtta, ilma et peaks tootja poolseid BIOS uuendusi ootama? |
8000 seeria on Zen 4 põhised APU mudelid. Mingeid spetsiaalseid emaplaate selle jaoks ei ole ega tule.
Kui sa just 9000 seeria Zen 5'ga nüüd segi ei aja.
BIOS uuendus uue CPU kasutamisekson ALATI vajalik. Sa ei saa võtta eksisteerivat 600 seeria emaplaati ja istutada sinna 9000 seeria prose ilma BIOS uuenduseta.
600 seeria emaplaadid juba kas on või saavad enne selle kuu lõppu vastava uuenduse, et toetada 9000 seeriat.
800 seeria emaplaate on mõistlik oodata ainult siis kui sa tahad USB 4, Wi-Fi 7 ja veel mõningaid pisemaid asju. Suurt muud need juurde ei anna.
tshw900
01.07.2024 14:29:04
| C1rca kirjutas: |
| tshw900 kirjutas: |
800 seeria emaplaate on mõistlik oodata ainult siis kui sa tahad USB 4, Wi-Fi 7 ja veel mõningaid pisemaid asju. Suurt muud need juurde ei anna. |
Jah, 9000 seeria cpu'sid ja 800 seeria emaplaate pidasin silmas, parandasin ära postituses.
800-seeria emaplaate kaalun kuna 5Gbit port on uus default, 2.5Gbit asemel.
56 |
