mine lehele eelmine  1, 2, 3 ... 388, 389, 390 ... 486, 487, 488  järgmine
sõnum 02.06.2022 06:22:07 vasta tsitaadiga
Mõni isegi ei teadnud enne üleeilset, et tavapäraselt kiired google jms. teenused on kiired just ipv6 pärast.
Kogu selle pika perioodi jooksul on vast olnud 3 suuremat IPv6 tõrget.
Aga on olnud ka IPv4 tõrkeid, suurematest tuleb meelde vist see globaalne DNS serverite probleem mis mingilt "saarelt" pihta hakkas.
jaakjaak22
sõnum 02.06.2022 08:44:30 vasta tsitaadiga
indrpo kirjutas:
Paar linki vastuseks küsimustele "MIKS IPv6?":
https://www.reddit.com/r/ipv6/comments/sjbzjh/business_and_customer_case_for_ipv6/
IPv6 has on average 10%-40% lower latency than IPv4 (RTT, TTFB). This will have noticeable improvements in gaming, VR, video calls, web surfing and more.
In 2020 Apple told its app developers to use IPv6 as it's 40% faster than IPv4 [Link] [NewsLink]
Facebook in 2016 said IPv6 is 30-40% faster than IPv4 [Link]
In 2016 Linked in demonstrated that IPv6 was 10-40% faster than IPv4. [Link]
In 2016, Akamai's independent research concluded a 5-15% speed increase on IPv6. [Link]. Research paper [Link]
In 2018 Facebook claimed 15-35% improved speed in v6. "We actually saw very significant, in some cases dramatic improvements on performance in v6". [Link]
APNIC has advanced stats that show IPv6 in North America is more than 10ms faster than IPv4. [Link]
Google notes in North America that IPv6 is 10ms faster than IPv4. [Link]
ARIN notes that IPv6 has 10ms lower latency [Link]
https://developer.apple.com/videos/play/wwdc2020/10111/
If you look at the last month of connections made worldwide by Apple devices, we see that IPv6 now accounts for 26% of all connections made. Twenty percent of the time, the connection could have used IPv6, but the server didn't have it enabled. And when IPv6 is in use, the median connection setup is 1.4 times faster than IPv4. This is primarily due to reduced NAT usage and improved routing.
sõnum 02.06.2022 09:17:53 vasta tsitaadiga
jaakjaak22 kirjutas:
alles posti lugedes oli järjest rohkem küsimus, et tulemused on toredad küll aga miks ipv6 kiirem on. vähem nati ja ilmselt otsapidi seotult parem ruutimine vastab sellele miks küsimusele icon_biggrin.gif
- londiste
jaakjaak22
sõnum 02.06.2022 09:31:17 vasta tsitaadiga
londiste kirjutas:
Kui juba üldfilosofeerimiseks läks, siis ärge nõudke Telialt jämedamat toru madalama hinnaga vaid targemaid ruutereid, mis oskavad reaalsete igapäevaste tegevuste (videokõned ja striimingteenused) bufferbloatiga paremini toime tulla: https://www.waveform.com/tools/bufferbloat
A.S.
sõnum 02.06.2022 13:55:30 vasta tsitaadiga
Kas Telia pakub VDSL peal ka ADSL kiiruseid? Varem justkui ei pakkunud.
Läks siis jaam mingi aeg tagasi VDSL peale, pordi kiirus läks 16/1 pealt 30/3.x peale (X2 DGA4330 ruuter), aga neti kiirust pakub endiselt vaid 5/1 või 12/1.
Helistasin, 10/2 ei pakuta, kuna liin ei kannatavat niipalju. 12 kannatab, 10 ei kannata, tore, sellest ei osatud midagi arvata. Ongi nii või oli klienditeeninduse tibi lolliks läinud?
Kellelgi kogemusi?
napoleon
Unknown virus
napoleon
sõnum 02.06.2022 14:06:52 vasta tsitaadiga
Kas seal see teema pole, et hoopis uploadi 2M ei vea välja? ADSL ja VDSL on ju asümmeetrilised.
A.S.
sõnum 02.06.2022 14:14:46 vasta tsitaadiga
Vot ei tea, ruuter näitab, justkui 3.x läheks üles. Proovida paraku ju ei saa.
Aga eks ma kontakteerun nendega järgmisel nädalal jälle. Kunagi läks 3 nädalat, et teise vaatajakoha tellides pordi kiirus 16/1 peale saada, mingi "automaatika" polevat neil töötanud ja minu jutust nad varem aru ei saanud.
Aga nüüd vähemalt 3 HD kanalit mahuvad probleemideta läbi, hea seegi. Enne oli vaid 1 HD + 1 SD võimalik.
kaabakas
kaabakas
sõnum 02.06.2022 15:24:17 vasta tsitaadiga
A.S.,
sõnum 02.06.2022 16:18:04 vasta tsitaadiga
A.S. kirjutas:
Kellelgi kogemusi?
See on veidi toores teema kuna alles sellega tegeletakse kuid kuna sina kui klient seda näed, ja võibolla mõni veel. siis lühike vastus on:
Testitakse pisut pikema liini peal kui 1200 meetrit ka vdsl parameetreid. Kui see on OK, siis see aktiveeritakse. Telepilt multicastiga kohe tõenäoliselt muretum. Hiljem on vaja aga ka HLSi jaoks piisavalt internetti.
Need kellel oli enne VDSL võibolla saavad siis ka suuremat kiirust aktiviseerida.
Kellel oli seal piiri peal ADSL, veel ei pruugi veel VDSL saada sest kiirusepiirangud tulenevad hetkel ikkagi liini pikkustest.
Varasemal näitel siis ADSL 12M kuni 2,5km, VDSL 20M kuni 1,2km, seal veel allapoole siis ADSL alla 1,5km siis 16M pordiprofiiliga kuid siiski nett 12M, VDSL alla 800M sõltuvalt liinist, 40 või 60Mbit/s jne.
Vectoring tegi selle asja veel lühemaks, kuni 400meetrit 200Mbit/s, kuni 600 vms meetrit saab 100Mbit/s ja kuni 800meetrit siis mingi kuni 50Mbit/s Umbes nii, peast ei mäleta neid aga sõltub ka veel lisaks kaablitüübist mis vahemaid märgib.
Igal juhul veidi timmitakse, kas annab veel midagi ADSLi suretamiseks teha, ja kui liin ikka ei võimalda, siis 4G/5G lahendus.
Isegi kui sul VDSL hetkel püsti, see ei tähenda, et pikal liinil veel kõik stabiilne on, kui vigu jooksma hakkab, on ikkagi vaja teist lahendust, seega ei ole veel protsess lõppenud ja teenindaja näeb ainult seda, mida on sulle võimalik müüa, see mida tehnoloogia/võrgu pool on selleks määranud. See pole nii lihtne, et kraan lahti keerata ja pärast portsu otsas istuda. Vähemalt see pole Telia stiil.
A.S.
sõnum 02.06.2022 16:29:21 vasta tsitaadiga
No selge, eks ma siis ootan ja vaatan, tänud.
Edgar
sõnum 03.06.2022 06:35:47 vasta tsitaadiga
Aega võttis, aga asja sai.
Võtsime kätte ja viisime korteriühistu jõul Tallinna kortermaja fiiberoptikaga ühendades kiirema ja kvaliteetsema interneti maalima.
Sellega seotult on mul teema jälgijatele tähelepanek ja küsimus.
Kui Elisa puhul pole lisapurki enne ruuterit vaja, siis on see täna vajalik Telia puhul.
Kas keegi tark oskab öelda, on see lähiajal muutumas ehk kas Telia on oma ruuterivalikut uuendamas ja eraldi ONT seadet kaotamas?
(Mõtleme roheliselt ja vähendame oma CO2 jalajälge.)
KillFrenzy
KillFrenzy
sõnum 03.06.2022 07:55:41 vasta tsitaadiga
Edgar, ei.
Kommentaarid: 152 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 134
sõnum 03.06.2022 08:08:19 vasta tsitaadiga
Elisa puhul on kuuldavasti erinevaid lahendusi, tellis nokia kilpi ja ruuter eraldi elutoas. Mingi lahendus ka ühe seadmega aga siis pead selle korterite puhul kusagile fiibri otsa juurde sättima. Telial jah pisike ont vahel, jalajälge mõjutab pigem vähem, siis saad ruuteri paremaase kohta sättida ja vajadusel ka ruuterit vahetada või enda seadet kasutada. Elektroonika puhul on taaskasutus ja ringlus pigem hea.
mannie
sõnum 08.07.2022 19:28:04 telia x2 DMZ vasta tsitaadiga
Ahoi!
Oskab keegi seletada mis asi on Telia X2 ruuteri DMZ ja kuidas see täpsemalt toimib?
KillFrenzy
KillFrenzy
sõnum 08.07.2022 19:31:51 vasta tsitaadiga
Kõik pordid suunatakse sinna ip peale mis valid.
https://en.wikipedia.org/wiki/DMZ_(computing)#DMZ_host
sõnum 08.07.2022 19:43:56 vasta tsitaadiga
Kõikidel Telia ruuteritel uus soft väljas. X2 omal on dns muutmine korda tehtud, wifi osa veidi parendatud, teistel mudelitel pigem turvauuendusi. Saad algatada resetiga või Telia Online Abi kaudu.
dex
dex
sõnum 18.07.2022 09:52:42 vasta tsitaadiga
Mul siis telia 4g ja see juba tükimat aega õhtuti ja nädalavahetustel nöögib. Telia klienditoest sain küll igasugu soodustusi ja ümmargust juttu, et kohe kohe hakkab Kambjas tööle uus mast ja siis koormus hajutub, aga see mind hetkel väga ei lohuta. Mul on väline 4G ruuter, mis on suunatud praeguse kambja masti poole. Vaatasin, et hiljuti on lähedale paigaldatud, mingi pisike tugijaam, millel ilmselt ei ole kuigi palju kasutajaid. Huvitav, kas ma võiksin ise oma välise ruuteri selle poole keerata?
Süümi, juumi, makkami ja kui tüüle nakkami...
viimati muutis dex 18.07.2022 21:58:36, muudetud 1 kord
Kommentaarid: 98 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 87
Inspiro
sõnum 18.07.2022 10:10:17 vasta tsitaadiga
dex kirjutas:
Huvitav, kas sellest proovimisest võib mingit jama tulla?
Ise teed, ise vastutad. Võid ju proovida, alati saad endisele positsioonile tagasi keerata.
KillFrenzy
KillFrenzy
sõnum 18.07.2022 10:24:00 vasta tsitaadiga
dex, mobiilse koduneti teema on siin -> https://foorum.hinnavaatlus.ee/viewtopic.php?t=665358
dex
dex
sõnum 18.07.2022 10:26:07 vasta tsitaadiga
Kas ehk keegi oskab valgustada, et kas need välised ruuterid on lukustatud mingile kindlale mastile või räägivad nii nagu mobiiltelefonid lihtsalt sellega, kes kõvemini karjub?
avrn
sõnum 18.07.2022 10:42:56 vasta tsitaadiga
Kas see väliruuter on see nn. termos või miski muu?
Termos vist suundantenne ei oma. Kindlale tugijaamale laitarbe ruutereid vaevalt tarkvaraliselt lukustada saab, olenevalt tarkvarast mõnele sagedusele küll.
Konkreetse tugijaama püüdmiseks on parem suundantennidega lahendus.
Paikselt mobiilset netti püüdes tasub katsetada erinevaid kombinatsioone, alati ei pruugi lähim tugijaam olla parim.
sõnum 18.07.2022 10:59:28 vasta tsitaadiga
Zyxel lukus ei ole, võid antenni keeramist proovida kuid kas väike katusetugijaam mis on tiheasustusele suunatud ka tuleb, sõltub maastiku eripäradest jms. Katsetada võid.
dex
dex
sõnum 18.07.2022 11:44:14 vasta tsitaadiga
Paneel, mitte termos. Proovin õhtul ära. Igasuguste antennidega on nooruses mürgeldatud küll.
Minu poolest võib mu postid siit teemast üle tõsta või kustutada.
pois11
sõnum 18.07.2022 12:04:46 vasta tsitaadiga
Inspiro kirjutas:
dex kirjutas:
Lukustasin ka paar aastat tagasi ühele linnas asuvale mastile, ehk jätsin kohaliku masti vahele. Mingi nädala pärast helistas Elisa tehnik ja pidas loengu, et miks nii ei tehta. Ma ütlesin siis, et tulgu ja korjaku siis oma seaded kokku aga kohaliku mastiga ei kannatanud isegi TV vaadata.
Mul oli muidugi katusel ilgelt suur suundantenn ja siiamaani on kogu süsteem lukustatud ühe masti ja sageduse külge. 0 probleemi.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 110
pppd
sõnum 18.07.2022 13:32:21 vasta tsitaadiga
pois11 kirjutas:
Huviga kuulaks, et miks siis nii ei tehta (eeldusel et klient teab mida teeb). Ruuteri majas ümberpaigutamine või suundantenni panemine on OK, aga mastide blacklistimine/whitelistimine on paha-paha? Või oli tehnikul lihtsalt lõvikonservi päev?
taavi
sõnum 18.07.2022 14:34:47 vasta tsitaadiga
tundub jah põnev. miks nii ei tehta?
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
pois11
sõnum 18.07.2022 14:50:43 vasta tsitaadiga
pppd kirjutas:
pois11 kirjutas:
Tegelikku põhjust ei tea aga mulle jahuti, et teenus ei tööta nii korralikult. Näiteks kui mast läheb hooldusesse, siis ei ole internetti ja TV. Igatahes kõik põhjendused oli jaburad. Huvitav oli see, et kui pakkusin asjad kokku korjata, siis tehnik pidi midagi uurima ja tagasi helistama. Sirka 30min. pärast helistaski ja ütles, et las siis jääb aga omal vastutusel. Et kui mul on mingi jama, siis nad jutule ei võta, sest olen ise süüdi kuna ei kasuta standardset seadistust. Midagi nad hüvitama ei hakka ja ühesõnaga kõikide probleemidega olen üksi.
olafsand
olafsand
sõnum 18.07.2022 15:50:26 vasta tsitaadiga
https://www.telia.ee/uudised/telia-hinnakirja-muudatused
Nõme, et 500/500 ära kaob thumbs_down.gif
sõnum 18.07.2022 16:03:09 vasta tsitaadiga
olafsand kirjutas:
Ühtlasi lihtsustab Telia oma eraklientide tooteportfelli, mis muudab uutel klientidel enda igapäevase internetikiiruse valiku tegemise lihtsamaks. Selleks ei müü Telia alates 01.09.2022 enam koduinterneti kiiruseid 50/50 Mbit/s ja 500/500 Mbit/s. Kliendid, kellel on kõnealuste kiirustega ühendused varasemalt kasutuses, saavad nende kasutamist jätkata.
Telli enne ära, saad jätkata ja hoida 500
Uutele ei müüda enam seda.
pois11
sõnum 18.07.2022 16:25:52 vasta tsitaadiga
Hea teada, et ka Telias hakkavad ka hinnad tõusma. Just mõtlesin, et peaks Teliasse minema, et Elisa kergitab vaikselt hinda. Aga nüüd pole pointi. Sama raha eest saab jätkuvalt Elisast rohkem internetti.
Aga Telia paketti peaks küll jagama hakkama nagu spotify famili pakette.
yerba
yerba
sõnum 18.07.2022 16:26:41 vasta tsitaadiga
pois11, vaata 1000se ühenduse hinda.
www.lapik.ee - parima hinnaga patareid!
ja lisaks ERYONE filamendid ( küsige HVs ): www.eryone.ee
Kommentaarid: 1239 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 910
pois11
sõnum 18.07.2022 16:34:00 vasta tsitaadiga
yerba kirjutas:
nujah.. ma vaatan oma mätta otsast
Elisa: 150/20 26.99€
Telia 100/100 27€
Ei ole erilist vahet, pealegi allalaadimis kiirus vajangi rohkem, üles polegi midagi eriti laadida.
sõnum 18.07.2022 16:53:31 vasta tsitaadiga
Vase hindu ei tõstetudki? icon_eek.gif Kust see ime tuleb. Tavaliselt on vase peal istujad olnud Telia peksupoisid.
50/50 ja 500/500 kaotamine on ilmselgelt selleks, et utsitada tellijaid valima kallimaid pakette. 1000/1000 hinnalangus 72€ peale on ilmselgelt selleks, et meelitada 300/300 asemel võtma 1000/1000
Kummaline, et lingil olevas hinnakirjas on kirjas 50/50 hind alates 01.09 aga mitte 500/500 hind alates 01.09 (eksisteerivatele tellijatele).
Oli ka aeg, et 1000/1000 hind langeks lõpuks. Aru saamatu lihtsalt miks tõusevad väiksemate kiiruste paketid. Kas valgus mis läbi kaabli liigub on kallimaks läinud või? icon_lol.gif
sõnum 18.07.2022 17:07:46 vasta tsitaadiga
Tomorrow kirjutas:
Eestis on valgus ja kõik kallim icon_lol.gif 100/100 peaks alla 20€ kätte tulema juba ammu mitte rühkima kuhugi 30€ suunas. Lõunanaabritel vähe inimlikumad hinnad
sõnum 18.07.2022 17:25:55 vasta tsitaadiga
salatoimik, Kohe tuleb indpro rääkima kuidas meil on ikka väike turg ja sada muud vabandust miks meil on euroopa ühed kallimad hinnad.
Ja kuna Telia hinnad on nii kallid, siis pole põhjust ka teistel madalamaid hindu eriti pakkuda. Eriti kui nad rendivad telia kaablit.
sõnum 18.07.2022 17:44:11 vasta tsitaadiga
Tomorrow, jaja, kõvasti väiksem rahvaaarv võrreldes lätiga ning meil on ju keskmine palk niipalju kõrgem, et võib seeõttu kordi kõrgemat hinda küsida jne. Mis need sissekulunud vabandused kõik on icon_biggrin.gif
KillFrenzy
KillFrenzy
sõnum 18.07.2022 17:57:16 vasta tsitaadiga
Tomorrow kirjutas:
pppd
sõnum 18.07.2022 18:38:11 vasta tsitaadiga
ärge unustage, et meil ongi kliendid harjunud kõrgemat hinda maksma icon_exclaim.gif
Renq
Renq
sõnum 18.07.2022 19:00:52 vasta tsitaadiga
indrpo kirjutas:
olafsand kirjutas:
Kuidas see Telia1 pakette mõjutab, kes praegu 300'se neti asemel 500 saavad?
kevku
sõnum 18.07.2022 19:07:36 vasta tsitaadiga
Selliste hindade peale võib kohe minna ja võtta tele2 mobiilne piiramatu 20€ eest, isegi kui telia kaabel toas on.
KillFrenzy
KillFrenzy
sõnum 18.07.2022 19:25:28 vasta tsitaadiga
Renq kirjutas:
Praegune telia1 pakkumine kestab kuu lõpuni, eks siis ole näha.
kevku kirjutas:
Just, tahanteada käest nagi antenn ka ja elu lill.
Renq
Renq
sõnum 18.07.2022 19:40:40 vasta tsitaadiga
KillFrenzy kirjutas:
Renq kirjutas:
kevku kirjutas:
A näed täitsa olemas info https://www.telia.ee/images/documents/kampaaniad/telia1/Telia1_kampaania_tingimused_01092022.pdf
Ma peaks ennast ikka väga vihkama, kui Telia kaabli Tele 2 mobiilse vastu vahetaks... ennem vihkaks vist raha... samas see 35 vs 20 ei kaalu mitte midagi üle.
prtv
sõnum 18.07.2022 19:48:14 vasta tsitaadiga
Võite mind tänada, reedel tegin taotlused ära, et Elisast Teliasse kolida, tõusvate hindade valguses.
olafsand
olafsand
sõnum 18.07.2022 20:13:50 vasta tsitaadiga
indrpo kirjutas:
olafsand kirjutas:
Ma mõtlen seda, et aeg-ajalt tellin selle 1000/1000 nädalavahetuseks näiteks. Kui peale esimest septembrit seda teen, siis 1000 pealt tagasi muutes on hoopis 300 valikus, mitte 500.
Ja kui näiteks seadmetega uuele aadressile kolin, siis kas saan selle 500/500 kaasa või peab vahepeal lepingu lõpetama ja uues kohas uue tegema?
KillFrenzy
KillFrenzy
sõnum 18.07.2022 20:14:30 vasta tsitaadiga
Renq kirjutas:
Renq kirjutas:
kevku kirjutas:
Heh, ma trükkisin aadressi ribale telia1 üks siis pakkus praegu kehtivat linki, mida hiljuti vaatasin.
Ehk 500 jääb edasi telia1 klientidele ainult ja 2 eur läheb hinnale otsa.
Vahur
Vahur
sõnum 18.07.2022 20:23:03 vasta tsitaadiga
1 Gbps ei saagi mingit soodustust selle kampaaniaga kiiruse/hinna osas icon_rolleyes.gif
olafsand, uusi tingimusi vaadates pead lihtsalt 300/300 Mbps võtma ja saad ikkagi 500/500 Telia 1 raames.
olafsand
olafsand
sõnum 18.07.2022 20:23:50 vasta tsitaadiga
Vahur, kui see nii on, siis on ok õnneks. Tänud!
pois11
sõnum 18.07.2022 20:43:34 vasta tsitaadiga
Diili numbrid Telia1 arvesse ei lähe, mis siis, et neid on terve pinu?
KillFrenzy
KillFrenzy
sõnum 18.07.2022 20:47:01 vasta tsitaadiga
pois11, ei.
RCC
RCC
sõnum 19.07.2022 07:30:04 vasta tsitaadiga
hinnatõus, see on väga hea uudis! aga ma ei saa nüüd aru, 50/50 on ju hinnakirjas edasi, kuidas see siis ära kaob? vbl mõtlesivad et 10/10 kaob ära
ohh ma võtaks hajaasustuspiirkonnas, valgel alal, koos indropro ja nagi antenniga mistahes hinna eest mistahes KAABLIneti, paraku seda eestis ei pakuta
uus teema   vasta Hinnavaatlus »  Andmeside ja kõnelevi »  Telia Koduinternet mine lehele eelmine  1, 2, 3 ... 388, 389, 390 ... 486, 487, 488  järgmine
