sõnum |
02.06.2022 07:22:07
Mõni isegi ei teadnud enne üleeilset, et tavapäraselt kiired google jms. teenused on kiired just ipv6 pärast.
Kogu selle pika perioodi jooksul on vast olnud 3 suuremat IPv6 tõrget.
Aga on olnud ka IPv4 tõrkeid, suurematest tuleb meelde vist see globaalne DNS serverite probleem mis mingilt "saarelt" pihta hakkas.
Kommentaarid: 255 loe/lisa |
223 |
jaakjaak22
02.06.2022 09:44:30
indrpo kirjutas: |
Mõni isegi ei teadnud enne üleeilset, et tavapäraselt kiired google jms. teenused on kiired just ipv6 pärast. |
Paar linki vastuseks küsimustele "MIKS IPv6?":
https://www.reddit.com/r/ipv6/comments/sjbzjh/business_and_customer_case_for_ipv6/
IPv6 has on average 10%-40% lower latency than IPv4 (RTT, TTFB). This will have noticeable improvements in gaming, VR, video calls, web surfing and more.
In 2020 Apple told its app developers to use IPv6 as it's 40% faster than IPv4 [Link] [NewsLink]
Facebook in 2016 said IPv6 is 30-40% faster than IPv4 [Link]
In 2016 Linked in demonstrated that IPv6 was 10-40% faster than IPv4. [Link]
In 2016, Akamai's independent research concluded a 5-15% speed increase on IPv6. [Link]. Research paper [Link]
In 2018 Facebook claimed 15-35% improved speed in v6. "We actually saw very significant, in some cases dramatic improvements on performance in v6". [Link]
APNIC has advanced stats that show IPv6 in North America is more than 10ms faster than IPv4. [Link]
Google notes in North America that IPv6 is 10ms faster than IPv4. [Link]
ARIN notes that IPv6 has 10ms lower latency [Link]
https://developer.apple.com/videos/play/wwdc2020/10111/
If you look at the last month of connections made worldwide by Apple devices, we see that IPv6 now accounts for 26% of all connections made. Twenty percent of the time, the connection could have used IPv6, but the server didn't have it enabled. And when IPv6 is in use, the median connection setup is 1.4 times faster than IPv4. This is primarily due to reduced NAT usage and improved routing.
02.06.2022 10:17:53
jaakjaak22 kirjutas: |
And when IPv6 is in use, the median connection setup is 1.4 times faster than IPv4. This is primarily due to reduced NAT usage and improved routing. |
alles posti lugedes oli järjest rohkem küsimus, et tulemused on toredad küll aga miks ipv6 kiirem on. vähem nati ja ilmselt otsapidi seotult parem ruutimine vastab sellele miks küsimusele
_________________ - londiste
Kommentaarid: 238 loe/lisa |
213 |
jaakjaak22
02.06.2022 10:31:17
londiste kirjutas: |
alles posti lugedes oli järjest rohkem küsimus, et tulemused on toredad küll aga miks ipv6 kiirem on. vähem nati ja ilmselt otsapidi seotult parem ruutimine vastab sellele miks küsimusele |
Kui juba üldfilosofeerimiseks läks, siis ärge nõudke Telialt jämedamat toru madalama hinnaga vaid targemaid ruutereid, mis oskavad reaalsete igapäevaste tegevuste (videokõned ja striimingteenused) bufferbloatiga paremini toime tulla: https://www.waveform.com/tools/bufferbloat
A.S.
02.06.2022 14:55:30
Kas Telia pakub VDSL peal ka ADSL kiiruseid? Varem justkui ei pakkunud.
Läks siis jaam mingi aeg tagasi VDSL peale, pordi kiirus läks 16/1 pealt 30/3.x peale (X2 DGA4330 ruuter), aga neti kiirust pakub endiselt vaid 5/1 või 12/1.
Helistasin, 10/2 ei pakuta, kuna liin ei kannatavat niipalju. 12 kannatab, 10 ei kannata, tore, sellest ei osatud midagi arvata. Ongi nii või oli klienditeeninduse tibi lolliks läinud?
Kellelgi kogemusi?
Kommentaarid: 33 loe/lisa |
33 |
napoleon
Unknown virus
02.06.2022 15:06:52
Kas seal see teema pole, et hoopis uploadi 2M ei vea välja? ADSL ja VDSL on ju asümmeetrilised.
Kommentaarid: 76 loe/lisa |
59 |
A.S.
02.06.2022 15:14:46
Vot ei tea, ruuter näitab, justkui 3.x läheks üles. Proovida paraku ju ei saa.
Aga eks ma kontakteerun nendega järgmisel nädalal jälle. Kunagi läks 3 nädalat, et teise vaatajakoha tellides pordi kiirus 16/1 peale saada, mingi "automaatika" polevat neil töötanud ja minu jutust nad varem aru ei saanud.
Aga nüüd vähemalt 3 HD kanalit mahuvad probleemideta läbi, hea seegi. Enne oli vaid 1 HD + 1 SD võimalik.
33 |
kaabakas
02.06.2022 16:24:17
A.S.,
Kommentaarid: 103 loe/lisa |
93 |
02.06.2022 17:18:04
A.S. kirjutas: |
Kellelgi kogemusi?
See on veidi toores teema kuna alles sellega tegeletakse kuid kuna sina kui klient seda näed, ja võibolla mõni veel. siis lühike vastus on:
Testitakse pisut pikema liini peal kui 1200 meetrit ka vdsl parameetreid. Kui see on OK, siis see aktiveeritakse. Telepilt multicastiga kohe tõenäoliselt muretum. Hiljem on vaja aga ka HLSi jaoks piisavalt internetti.
Need kellel oli enne VDSL võibolla saavad siis ka suuremat kiirust aktiviseerida.
Kellel oli seal piiri peal ADSL, veel ei pruugi veel VDSL saada sest kiirusepiirangud tulenevad hetkel ikkagi liini pikkustest.
Varasemal näitel siis ADSL 12M kuni 2,5km, VDSL 20M kuni 1,2km, seal veel allapoole siis ADSL alla 1,5km siis 16M pordiprofiiliga kuid siiski nett 12M, VDSL alla 800M sõltuvalt liinist, 40 või 60Mbit/s jne.
Vectoring tegi selle asja veel lühemaks, kuni 400meetrit 200Mbit/s, kuni 600 vms meetrit saab 100Mbit/s ja kuni 800meetrit siis mingi kuni 50Mbit/s Umbes nii, peast ei mäleta neid aga sõltub ka veel lisaks kaablitüübist mis vahemaid märgib.
Igal juhul veidi timmitakse, kas annab veel midagi ADSLi suretamiseks teha, ja kui liin ikka ei võimalda, siis 4G/5G lahendus.
Isegi kui sul VDSL hetkel püsti, see ei tähenda, et pikal liinil veel kõik stabiilne on, kui vigu jooksma hakkab, on ikkagi vaja teist lahendust, seega ei ole veel protsess lõppenud ja teenindaja näeb ainult seda, mida on sulle võimalik müüa, see mida tehnoloogia/võrgu pool on selleks määranud. See pole nii lihtne, et kraan lahti keerata ja pärast portsu otsas istuda. Vähemalt see pole Telia stiil.
223 |
A.S.
02.06.2022 17:29:21
No selge, eks ma siis ootan ja vaatan, tänud.
33 |
Edgar
03.06.2022 07:35:47
Aega võttis, aga asja sai.
Võtsime kätte ja viisime korteriühistu jõul Tallinna kortermaja fiiberoptikaga ühendades kiirema ja kvaliteetsema interneti maalima.
Sellega seotult on mul teema jälgijatele tähelepanek ja küsimus.
Kui Elisa puhul pole lisapurki enne ruuterit vaja, siis on see täna vajalik Telia puhul.
Kas keegi tark oskab öelda, on see lähiajal muutumas ehk kas Telia on oma ruuterivalikut uuendamas ja eraldi ONT seadet kaotamas?
(Mõtleme roheliselt ja vähendame oma CO2 jalajälge.)
_________________ -_- |
Kommentaarid: 20 loe/lisa |
20 |
KillFrenzy
03.06.2022 08:55:41
Edgar, ei.
_________________ M: SFP Telia GPON võrgu jaoks - 40€ |
Kommentaarid: 151 loe/lisa |
133 |
03.06.2022 09:08:19
Elisa puhul on kuuldavasti erinevaid lahendusi, tellis nokia kilpi ja ruuter eraldi elutoas. Mingi lahendus ka ühe seadmega aga siis pead selle korterite puhul kusagile fiibri otsa juurde sättima. Telial jah pisike ont vahel, jalajälge mõjutab pigem vähem, siis saad ruuteri paremaase kohta sättida ja vajadusel ka ruuterit vahetada või enda seadet kasutada. Elektroonika puhul on taaskasutus ja ringlus pigem hea.
223 |
mannie
08.07.2022 20:28:04
telia x2 DMZ |
Ahoi!
Oskab keegi seletada mis asi on Telia X2 ruuteri DMZ ja kuidas see täpsemalt toimib?
Kommentaarid: 4 loe/lisa |
KillFrenzy
133 |
08.07.2022 20:43:56
Kõikidel Telia ruuteritel uus soft väljas. X2 omal on dns muutmine korda tehtud, wifi osa veidi parendatud, teistel mudelitel pigem turvauuendusi. Saad algatada resetiga või Telia Online Abi kaudu.
223 |
dex
18.07.2022 10:52:42
Mul siis telia 4g ja see juba tükimat aega õhtuti ja nädalavahetustel nöögib. Telia klienditoest sain küll igasugu soodustusi ja ümmargust juttu, et kohe kohe hakkab Kambjas tööle uus mast ja siis koormus hajutub, aga see mind hetkel väga ei lohuta. Mul on väline 4G ruuter, mis on suunatud praeguse kambja masti poole. Vaatasin, et hiljuti on lähedale paigaldatud, mingi pisike tugijaam, millel ilmselt ei ole kuigi palju kasutajaid. Huvitav, kas ma võiksin ise oma välise ruuteri selle poole keerata?
_________________ Süümi, juumi, makkami ja kui tüüle nakkami...
viimati muutis dex 18.07.2022 22:58:36, muudetud 1 kord |
Kommentaarid: 91 loe/lisa |
81 |
Inspiro
18.07.2022 11:10:17
dex kirjutas: |
Huvitav, kas sellest proovimisest võib mingit jama tulla? |
Ise teed, ise vastutad. Võid ju proovida, alati saad endisele positsioonile tagasi keerata.
KillFrenzy
133 |
dex
18.07.2022 11:26:07
Kas ehk keegi oskab valgustada, et kas need välised ruuterid on lukustatud mingile kindlale mastile või räägivad nii nagu mobiiltelefonid lihtsalt sellega, kes kõvemini karjub?
_________________ Süümi, juumi, makkami ja kui tüüle nakkami... |
81 |
avrn
18.07.2022 11:42:56
Kas see väliruuter on see nn. termos või miski muu?
Termos vist suundantenne ei oma. Kindlale tugijaamale laitarbe ruutereid vaevalt tarkvaraliselt lukustada saab, olenevalt tarkvarast mõnele sagedusele küll.
Konkreetse tugijaama püüdmiseks on parem suundantennidega lahendus.
Paikselt mobiilset netti püüdes tasub katsetada erinevaid kombinatsioone, alati ei pruugi lähim tugijaam olla parim.
Kommentaarid: 5 loe/lisa |
18.07.2022 11:59:28
Zyxel lukus ei ole, võid antenni keeramist proovida kuid kas väike katusetugijaam mis on tiheasustusele suunatud ka tuleb, sõltub maastiku eripäradest jms. Katsetada võid.
223 |
dex
18.07.2022 12:44:14
Paneel, mitte termos. Proovin õhtul ära. Igasuguste antennidega on nooruses mürgeldatud küll.
Minu poolest võib mu postid siit teemast üle tõsta või kustutada.
81 |
pois11
18.07.2022 13:04:46
Inspiro kirjutas: |
dex kirjutas: |
Ise teed, ise vastutad. Võid ju proovida, alati saad endisele positsioonile tagasi keerata. |
Lukustasin ka paar aastat tagasi ühele linnas asuvale mastile, ehk jätsin kohaliku masti vahele. Mingi nädala pärast helistas Elisa tehnik ja pidas loengu, et miks nii ei tehta. Ma ütlesin siis, et tulgu ja korjaku siis oma seaded kokku aga kohaliku mastiga ei kannatanud isegi TV vaadata.
Mul oli muidugi katusel ilgelt suur suundantenn ja siiamaani on kogu süsteem lukustatud ühe masti ja sageduse külge. 0 probleemi.
Kommentaarid: 104 loe/lisa |
101 |
pppd
18.07.2022 14:32:21
pois11 kirjutas: |
Lukustasin ka paar aastat tagasi ühele linnas asuvale mastile, ehk jätsin kohaliku masti vahele. Mingi nädala pärast helistas Elisa tehnik ja pidas loengu, et miks nii ei tehta. |
Huviga kuulaks, et miks siis nii ei tehta (eeldusel et klient teab mida teeb). Ruuteri majas ümberpaigutamine või suundantenni panemine on OK, aga mastide blacklistimine/whitelistimine on paha-paha? Või oli tehnikul lihtsalt lõvikonservi päev?
Kommentaarid: 3 loe/lisa |
