uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 11 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 13, 14, 15 ... 96, 97, 98  järgmine
sõnum 13.10.2021 08:30:37 vasta tsitaadiga
Ei näe enam mingi püsilitsentsi ostmisel mõtet. Isegi eraisikuna. Kuu/aastatasuline värk on ikka ülimugav ja alati uusim versioon.
Bilderberg kirjutas:
Muhekas kirjutas:
Kas nüüd ongi ainult office kuumakse ja aastamakse põhiselt ainult saada?
Office 2021 tasud ainult ostes ja üks kord. Office 365 on pideva tasuga.
Muide hea uudis on see, et tasuta ja iidne IBM Lotus Symphony avab ka täna vabalt Office 2021 või 365 failid.
LibreOffice ja OpenOffice on samuti tasuta ning märksa kaasaegsemad.
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
sõnum 13.10.2021 10:12:18 vasta tsitaadiga
AMD Ryzen CPU’s L3 Latency Performance Fix To Be Resolved By Microsoft Through Windows 11 Update on 19th October, CPPC Driver on 21st
https://wccftech.com/amd-ryzen-cpus-l3-latency-performance-fix-to-be-resolved-by-microsoft-through-windows-11-update-on-19th-october-cppc-driver-on-21st/
- The CPPC issue has been resolved. The AMD driver power profile is in the release process and targeted for GA release on 10/21. If it is needed before GA, AMD can share the driver directly with customers upon request.
‒ The L3 cache latency issue has been resolved by Microsoft. Microsoft plans to release the fix in their 10C Windows Update which is targeted for 10/19.
First Windows 11 Patch Tuesday Makes Ryzen L3 Cache Latency Worse, AMD Puts Out Fix Dates
https://www.techpowerup.com/287786/first-windows-11-patch-tuesday-makes-ryzen-l3-cache-latency-worse-amd-puts-out-fix-dates
You Aren’t Alone – Over 50% of Enterprise Machines Unable to Upgrade to Windows 11
https://wccftech.com/over-50-of-enterprise-machines-cant-upgrade-to-windows-11/
Now a study of over 30 million devices in over 60,000 companies has revealed that things look bleak in the enterprise segment, as well.
Virtual machines fared even worse, as only 0.23% currently pass Windows 11's TPM-enabled requirement.
First Windows 11 Cumulative Update Drops!
https://wccftech.com/first-windows-11-cumulative-update-drops-kb5006674-build-22000-258/
Addresses known compatibility issues between some Intel “Killer” and “SmartByte” networking software and Windows 11 (original release). Devices with the affected software might drop User Datagram Protocol (UDP) packets under certain conditions. This creates performance and other issues for protocols based on UDP. For example, some websites might load slower than others on the affected devices, which might cause videos to stream slower in certain resolutions. VPN solutions based on UDP might also be slower.
sõnum 13.10.2021 10:14:43 vasta tsitaadiga
kes täna w10 masinad kolmeks aastaks renti võtavad, saavad need aasta enne w11 lavale astumist tagasi anda. ma ei muretseks. ATM ides ja asjades võib veel xp d ki tiksuda. metsatööstuses olen ka dos 6.2 pealt käivaid asju näinud viimase aasta jooksul. (maxi)
sõnum 13.10.2021 11:24:01 vasta tsitaadiga
Betamax kirjutas:
Muhekas kirjutas:
Sõltub tarkvarast ja kasutajast ikkagi. Eraisikul oleks absurdne maksta kuu või aaastatasu ühe litsentsi eest ühele masinale a'la Windows. uusi Windowsi versioone ei tule niii tihti, et see end ära tasuks. Ainult Vistaga oleks ehk plussi jäänud (2006-2009). Win7-ga enam mitte: 2009-2015. Sama ka Win10-ga 2015-2021. Win8 parem üritame unustada...
Kui selline 6 aasta graafik paika peab tuleb Win12 aastal 2027 ehk enne kümnendi lõppu võime saada veel ühe nuhtluse.
Samas on kohti kus kuutasuline asi toimib. Näiteks teenusepakkuja ruuterid vahetuvad piisavalt tihedalt, et kuutasuga rentimine on rahaliselt mõistlikum kui iga mudeli väljaostmine.
Office osas ei tea. Kasutan LibreOffice ja enne seda OpenOffice ja ei tunne puudust millestki. Võibolla firmades Office õigustab ennast aga eraisikul ühel arvutil ma arvan, et mitte.
Muide panin täna hommiku VM käima ja paistab, et Microsoft hirmutab hetkel niisama, et nõuetele mittevastavale rauale paigaldatud (või nn häkitud) installid uuendusi ei saa justkui. Saab küll:
Ühtlasi lasin huvi pärast Home versiooni installi käima. Paistab, et installi alguses on internetiühendus vajalik. Vastasel korral edasi ei saa. Kui aga enne kasutaja loomist võrk eemaldada, siis saab ka Home versiooniga edukalt lokaalse konto teha. Tuiasin ka veidi ringi ja hetkel vähemalt VM-is näägutama ei hakatud, et miks ei ole MS kontot. Seega mingeid lisapiiranguid silma ei hakanud võrreldes Pro versiooni lokaalse kontoga.
Juhul kui võrk on olemas, siis saate sellise pildi ja Sign-in options all on lisavalikud ainult turvavõtmega sisselogimiseks või MS konto salasõna taastamiseks kui olete unustanud. Pro versioonil saab Sign-in options alt ka lokaalse konto teha:
Ühtlasi peale Editioni valimist registrifaili laadimine toimib kah väga kergesti. Valite oma Home/Pro vms. SHIFT+F10 ja sisestada regedit. Sealt import ja vastav registrifail importida läheb install kenasti edasi sõltumata sellest kui halvasti raud nõuetele vastab. Virtuaalmasinasse paigaldamiseks on see hetkel pmst ainus viis. Siin on täpsemalt kirjas: https://www.techpowerup.com/287584/windows-11-tpm-requirement-bypass-it-in-5-minutes
Bilderberg
Bilderberg
sõnum 13.10.2021 15:09:27 vasta tsitaadiga
Betamax kirjutas:
Muhekas kirjutas:
Kuidagi ära harjunud teisega, võib-olla sellepärast, et töö juures Lotus Notes
Jälle tuli üks Win11 uuendus:
October 12, 2021—KB5006674 (OS Build 22000.258)
https://support.microsoft.com/en-gb/topic/october-12-2021-kb5006674-os-build-22000-258-32255bb8-6b25-4265-934c-74fdb25f4d35
Muhekas
Muhekas
sõnum 13.10.2021 18:00:09 vasta tsitaadiga
Betamax kirjutas:
Muhekas kirjutas:
Ma officit pigem tahtnud just seda outlooki pärast
sõnum 13.10.2021 18:03:31 vasta tsitaadiga
ja mis tulilinnul viga? kontor on hea pigem domeenis. kalendrid jutud.
Muhekas
Muhekas
sõnum 13.10.2021 18:39:56 vasta tsitaadiga
laurx kirjutas:
Ma ei suutnud tulilinnuga sinasõbraks saada kuidagi
sõnum 13.10.2021 18:48:06 vasta tsitaadiga
Tulilinnul on omad probleemid mistõttu eksisteerib betterbird fork: https://www.betterbird.eu/#featuretable
Aga no outlooki kasutamine meilide jaoks on umbes nagu adobe readeri kasutamine PDF vaatamiseks kui sama töö suudavavad ära teha isegi brauserid juba rääkimata siis väikestest progedest a'la sumatra pdf. Piltlikult öeldes kärbse jahtimine kahuriga.
Võibolla firmades jah kus päevas liigub sadu või tuhandeid meile Outlook õigustab ennast aga tavainimesel ma küll pointi ei näe.
Muhekas
Muhekas
sõnum 13.10.2021 19:09:55 vasta tsitaadiga
Tomorrow kirjutas:
Tavainimene siis käib brauseriga sees?
bettertbird is blocked because it could harm your device a sain selle peale
ressi
sõnum 13.10.2021 19:24:38 vasta tsitaadiga
Millised on riistvara nõuded W11 jaoks?
Kui mul praegu lauaarvutis on Windows 10 peal ja kõik on korras,
kas on võimalik siis W11 peale lasta ilma probleemideta?
Mul sinna uuenduste juurde tekkis küll kiri, et " Teie arvuti ei pruugi olla
W11 nõuetele vastav "...
See hoiatus on vist pigem tarkvaraliste mittesobimiste kohta, näiteks
mõned draiverid või midagi sellist...
Kas on mõtet pigem oodata w11 paigaldusega - tehakse draiveritele
automaatsed uuendused jne.? Või selline hoiatus jääbki kehtima?
sõnum 13.10.2021 20:42:28 vasta tsitaadiga
Ametlikult tahab tpm 2.0, 7700k prose, gpt mbr asemele ja uefibooti.
NATAS999
sõnum 13.10.2021 21:41:45 vasta tsitaadiga
Muhekas kirjutas:
mitte ei käi sees, vaid avab/loeb. pole samuti viimased clean installid mingit readerit paigaldand ja chromet pdf lugemiseks kasutand. adobe readeril masendavalt bloated gui, võrreldav sajandi alguse IE'ga millele kõikvõimalikud tol ajal hüpermoodsad toolbarid paigaldatud.
"Kuidas on see hea?"
-Auto kirurgia kliinik
Bilderberg
Bilderberg
sõnum 13.10.2021 23:31:58 vasta tsitaadiga
Muhekas kirjutas:
Kui sellised soovid, siis ega see summa ära ka ei tapa:
https://www.windowscentral.com/office-2021
Ise kasutan Windows 10/11 tarkvaraga kaasasolevat maili ja kõik värgid töötavad:
https://support.microsoft.com/en-us/office/set-up-email-in-the-mail-app-for-windows-10-7ff79e8b-439b-4b47-8ff9-3f9a33166c60
Outlooki võib ka nii kasutada:
https://outlook.live.com/owa/
sõnum 13.10.2021 23:48:50 vasta tsitaadiga
Muhekas kirjutas:
Just. Gmaili veebiliides on väga korralik. Meiliklient on ikka selleks kui on soov samaaegselt hallata mitmeid meiliaadresse. Neil kellel üks (või isegi paar tükki aga suunatud ühele) ei ole erilist mõtet eraldi programmi kasutada.
Muhekas kirjutas:
Ma ei tea mis brauseriga sina üritasid alla laadida aga Firefox mingit hoiatust ei anna.
madis888, https://support.microsoft.com/et-ee/windows/windows-11-s%C3%BCsteemin%C3%B5uded-86c11283-ea52-4782-9efd-7674389a7ba3
Bilderberg, Jep meilihalduseks on mustmiljon viisi. Täis Office ostmine ja Outloooki kasutamine on kõik lisasammud mida füüsilisel isikul teha ei ole vaja. Kuigi ega mul sellest sisseehitatud UWP meilikliendist head muljet pole.
NATAS999
sõnum 15.10.2021 05:39:17 vasta tsitaadiga
Renq
Renq
sõnum 15.10.2021 10:41:11 vasta tsitaadiga
Kas päriselt Ka 11's on mingi aasta aega vanad Nvidia driverid? mul näitas kuupäevaks 30.09.20 ja uuendust ei pakkunud.
sõnum 15.10.2021 11:21:01 vasta tsitaadiga
Renq, Vaatasin ja vähemalt eestikeelses .194 buildis ei näe et oleks kaasas ühtegi Nvidia draiverit.
Ja aasta vana ei saagi olla, kuna Nvidia lisas Win11 toe alles eelmine kuu ja aasta tagasi ei teadnud keegi veel, et Win11 üldse tuleb.
Läbi mille sa seda vaatasid ja mis sulle näitas, et uuendusi pole? Hetkel kahtlustaks selle programmi bugi millega sa vaatad.
olafsand
olafsand
sõnum 15.10.2021 16:20:36 vasta tsitaadiga
sain ka 4790k peal tööle ilusti ja pakub ka uuendusi, seega täitsa tehtav ja kasutatav see win11 icon_smile.gif
Osiris
Osiris
sõnum 15.10.2021 18:47:40 vasta tsitaadiga
Lasin just win 11-e masinale milles i3-5010U (Zotaci Zbox mini aastast 2015). Töötab nii nagu vaja ja uuendused ka paigaldas ära.
See reg faili kohendus toimis küll.
olafsand
olafsand
sõnum 15.10.2021 20:37:14 vasta tsitaadiga
ma kasutasin win11 iso ja rufus beta2 varianti, ilusti töötab jah. Äge värk ikka. MS progejad püüavad asja ää rikkuda ja Rufuse tüübid teevad asja korda. On ikka elu selles it maailmas icon_biggrin.gif
sõnum 15.10.2021 21:25:23 vasta tsitaadiga
olafsand kirjutas:
Indeed:
olafsand
olafsand
sõnum 16.10.2021 00:02:42 vasta tsitaadiga
sõnum 16.10.2021 00:25:20 vasta tsitaadiga
Windows Insiders get fix for AMD performance issues on Windows 11
https://www.xda-developers.com/windows-11-fix-amd-performance-beta-channel-insiders/
noxton
noxton
sõnum 16.10.2021 22:48:30 vasta tsitaadiga
kas keegi teab, kust saab hibernationi sisse lülitada?
ei aita ka : cmd-st "powercfg.exe /hibernate on"
Proovitud kõik võtted läbi : https://digitaldopes.com/how-to-enable-hibernate-on-windows-11/
registris pole üldse sellist
sõnum 16.10.2021 22:53:12 vasta tsitaadiga
Driverid puudu. Arvatavasti chipset või videokaart. Ilma driveriteta on Windowsil ainult Sleep võimalik.
sõnum 16.10.2021 23:20:21 vasta tsitaadiga
Ugradesin 10 pealt 11 peale e8400, ddr2, 9400gt.. näib töötavat.
A-Circus.
A-Circus.
sõnum 16.10.2021 23:25:11 vasta tsitaadiga
Vaja arvutile puhas OS install teha varsti ja nüüd dilemma- kas win 10 või 11. AMD jõudlusprobleemiga olen kursis ning saan aru, et oktoobri jooksul see arvatavasti lahendatakse. On veel põhjuseid miks seda mitte teha?
Teine küsimus, et kui lasen win11 esimest korda peale otse USB pulgalt, kas siis aktiveerib automaatselt või on mingit jamamist vaja läbi viia (kasutan Windowsi kontot). Ehk on kogemusi kellelgi.
Hiid
Hiid
sõnum 17.10.2021 08:55:29 vasta tsitaadiga
Osiris kirjutas:
olafsand kirjutas:
Rääkige lähemalt.
Poisil Intel 7600 prose ja 1070 videokaart.
Leiab, et peaks Win 11 peale ajama.
Hapud viinamarjad
sõnum 17.10.2021 09:50:57 vasta tsitaadiga
Hiid, Googeldada ei oska või?
https://rufus.ie/en/
https://www.microsoft.com/en-us/software-download/windows11
USB pulk peab endal olema.
sõnum 17.10.2021 10:09:08 vasta tsitaadiga
https://www.youtube.com/watch?v=u1FmfJpJsKw Hiid pole seda tpm i ja muu huinjaa nõuet + üle ei pea ka masinat installima kui ei taha programmidega jaurama hakata. e8400 sai selliselt selga ja i3-2100
Bilderberg
Bilderberg
sõnum 17.10.2021 10:46:15 vasta tsitaadiga
noxton kirjutas:
Admini õigustega CMD:powercfg -h on+ restart ja siis tekib valik:
sõnum 17.10.2021 10:53:21 vasta tsitaadiga
algatuseks vaadake dev. manager üle, tuleb ehk ajureid paigaldada siiski.
Hiid
Hiid
sõnum 17.10.2021 12:25:09 vasta tsitaadiga
laurx kirjutas:
kas mänguarvutile seda selga ajada on üldse mõistlik?
Hapud viinamarjad
sõnum 17.10.2021 12:25:11 vasta tsitaadiga
Vahet pole, kas käivitad adminiõigustes või ilma. Ilma adminiõigusteta on seal aknas lihtsalt valikud hallid ja pead adminiõiguseid kasutama. Kui vastavaid drivereid pole (või on genericud), siis pole sul ka Hibernate'i valikut.
sõnum 17.10.2021 13:01:22 vasta tsitaadiga
Hiid, seda ma ei tea.
sõnum 17.10.2021 13:02:40 vasta tsitaadiga
Hiid kirjutas:
Mängib mingeid iidseid mänge? Kaasaaja mängud ei toimi XP peal.
sõnum 17.10.2021 13:04:14 vasta tsitaadiga
Dx12 vajab w10 t.
Hiid
Hiid
sõnum 17.10.2021 14:36:36 vasta tsitaadiga
Hapud viinamarjad
Dijital
Dijital
sõnum 17.10.2021 14:43:15 vasta tsitaadiga
Mikisofti enda poolt kah RegEdit lahendus neile, kes W11 tahavad, kui raud pole sobiv:
https://support.microsoft.com/en-us/windows/ways-to-install-windows-11-e0edbbfb-cfc5-4011-868b-2ce77ac7c70e
Telex
Telex
sõnum 17.10.2021 21:21:37 vasta tsitaadiga
laurx kirjutas:
sõnum 17.10.2021 21:47:01 vasta tsitaadiga
Vana x-fi pci, millele juba w7 mitteametlik oli, jäi tööle. W11=w10.1
E8400 sai, q6600 sai, i3-2100 sai.. boot on tatisem natuke.
renx09
renx09
sõnum 17.10.2021 21:47:13 vasta tsitaadiga
null pole number
LKits
LKits
sõnum 18.10.2021 05:36:00 vasta tsitaadiga
laurx kirjutas:
Ehk siis peab sul olema:
1) Windows10 installimeedia
2) Windows11 installimeedia
Kopeerid Win10 kõik installimeedia failid ühte kausta (või kui soovid USB pulgaga teha, siis pead Win10 installika USB pulgale laskma).
Kopeerid "sources\install.wim" faili Win11 installimeediast ning asendad selle seal ühes kaustas sources kaustas Win10 install.wim failiga.
sõnum 18.10.2021 08:33:06 vasta tsitaadiga
LKits, Ei ole enam vaja käsitsi hakkida. Rufus teeb USB pulga booditavaks tehes vajalikud muudatused ja piisab ainult Win11 ISO-st.
Vondur
Vondur
sõnum 18.10.2021 10:20:54 vasta tsitaadiga
Misasja te seal häkite oma Rufustega? Kinnitan et "mittetoetava" protsessoriga masinale ametliku Microsofti installikaga Win kümnele selga aetud Win 11 ja Microsofti poolt pakutud ja registrisse lisatud
[HKEY_LOCAL_MACHINE\SYSTEM\Setup\MoSetup]
"AllowUpgradesWithUnsupportedTPMOrCPU"=dword:00000001
toimib ja kui vana starti, toolbari, menüüsid jne tagasi tahad, siis lisaks veel selline pisike programm nagu Startallback ja kõik, laseb Win 10 pealt Win 11 peale uuendada ja töötab iga normaalse protsessoroga. TPM peab aga olema vähemalt 1.2, aga see on ju igal vähegi arvestataval protsessoril juba rauas.
Lugupeetud AHV, enne kui vaidlema hakkad, mõtle hästi järgi, kas see ikka on tark mõte...
olafsand
olafsand
sõnum 18.10.2021 10:58:36 vasta tsitaadiga
Vondur, minul aitaski ainult Rufus, sest TPM on üldse puudu 4790k prosel.
Vondur
Vondur
sõnum 18.10.2021 11:06:58 vasta tsitaadiga
olafsand, nojah, sel juhul on asi õigustatud... aga kas poleks põnevam kasutada uue Windowsi puhul veidi värskemat protsessorit? Las vanake müttab kümnenda Windowsi peal edasi.
sõnum 18.10.2021 11:15:16 vasta tsitaadiga
Vondur kirjutas:
Booditava USB pulga pead ju niikuinii tegema. Rufuse variant on kõige kiirem ja ei nõua kasutajalt ise käsitsi registri muutmist/importimist või muid häkke. Ma saaks aru kui Rufus oleks eraldi programm millega peaks häkkima aga ise kasutan seda nii või naa booditava meedia tegemiseks. Rääkimata platvormidest mis TPM üldse ei toeta ja kus sinu mainitud registrisäte pole piisav.
NATAS999
sõnum 18.10.2021 11:45:45 vasta tsitaadiga
Vondur kirjutas:
mida põnevat veidi värskem protsessor endaga kaasa toob kah peale rahakotti tekkinud vaakumi?
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 11 mine lehele eelmine  1, 2, 3 ... 13, 14, 15 ... 96, 97, 98  järgmine
