sõnum |
kjaups
MeesKesTuliMetsast
27.08.2021 09:42:18
Margus, jama on pigem siis, kui vaja UC teha ja ventidel põõrdeid eemaldada, et tavakasutus või vanemate mängudega ennast lärmama ei aja.
_________________ SNAP pildipank
Mul võivad mõned asjad viitega tulla, prioriteedid paigas.
M: Nodi ja privas 3D Touch V3.2 15€ + varu nõelad 1€ tk |
Kommentaarid: 160 loe/lisa |
130 |
XeStAiSy
27.08.2021 12:34:32
See oleneb täitsa kaardist ilmselt Kuigi MSI trio gaming x või z on üldse täitsa vaiksed ei lärma seal midagi kui 144hz screen on siis tahadki ,et 144 ikka ära tuleks. Igasugune alla 144ja on jama.
Kommentaarid: 12 loe/lisa |
13.09.2021 20:44:52
AMD Radeon Software Adrenalin 21.9.1 Released with Auto-Overclock, SAM for RX 5000 Series
https://www.techpowerup.com/286658/amd-radeon-software-adrenalin-21-9-1-released-with-auto-overclock-sam-for-rx-5000-series
tsitaat: |
Support For
Deathloop
Call of Duty Vanguard Open Beta
AMD Smart Access Memory on Radeon RX 5000 Series Graphics
Added Vulkan Support
VK_KHR_zero_initialize_workgroup_memory: This extension allows implementations to use the null constant initializer on shader workgroup memory variables. This in turn allows applications that run untrusted content to defeat memory-scraping attacks.
VK_KHR_shader_integer_dot_product: This extension adds support for the integer dot product SPIR-V instructions defined in SPV_KHR_integer_dot_product. The SPV_KHR_integer_dot_product extension allows dot product operations on integer vectors with optional accumulation. In addition to allowing dot product operations for all input vector types, it also allows integer dot product for 4-component vectors of 8-bit integers that are packed into 32-bit integers.
VK_EXT_shader_atomic_float2: This extension provides shaders with the capability to perform 16-bit floating-point atomic operations on buffer and workgroup memory. It additionally allows floating-point atomic minimum and maximum operations on buffer, workgroup, and image memory.
VK_EXT_load_store_op_none: This extension allows an application to specify the contents within the render area that will not modified or can be expected to be undefined after rendering.
Fixed Issues
Visual artifacts in PAYDAY 2 may be observed during gameplay on some AMD Graphics products such as Radeon RX 6800 XT.
Connecting two displays with large differences in resolution/refresh rates may cause flickering on Radeon RX Vega series graphics products.
On Radeon RX 5500 XT Graphics, higher than expected memory clock speed and power consumption may be experienced when idle and the display's resolution and refresh rate are set to specific values such as 1080p @ 60 Hz.
While playing Assassin's Creed Odyssey, driver timeouts or black screens may be experienced on some AMD Graphics products such as Radeon RX 480 Graphics when the user quickly navigates through the game menus or swiftly looks around an environment with their character.
Known Issues
Open Broadcaster Software may continue to run in the background after a user ends a recording session and closes the application.
Driver timeouts may be experienced while playing a game & streaming a video simultaneously on some AMD Graphics products such as Radeon RX 500 Series Graphics.
AMD Radeon Software may crash or become unresponsive while playing some DirectX 11 games such as PlayerUnknown's Battlegrounds with multiple displays connected in extended mode.
Playing Horizon Zero Dawn for an extended period may lead to a driver timeout or game crash on some AMD Graphics products such as Radeon RX 6700 XT.
Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
Radeon performance metrics and logging features may intermittently report extremely high and incorrect memory clock values. |
Tubli. See, et 5000 seeriale ReBAR-i ei lisatud oli algusest peale vastumeelt mulle. Ja see on ka kasutajasõbralik erinevalt Nvidiast kes pole samast ajast pärit 20 seeriale ReBAR lisanud ja väheusutav, et kunagi lisabki. Vaatamata sellele, et neil on palju rohkem tarkvarainsenere paigal kes draivereid teevad.
Auto OC on kah huvitav. Ühtlasi ametlik Windows 11 tugi nüüd olemas.
Kommentaarid: 89 loe/lisa |
79 |
XeStAiSy
22.09.2021 20:13:01
AMD Radeon Software Adrenalin 21.9.2 on väljas
New world mmo tugi
AlvinL
24.09.2021 12:37:39
Ei saa aru, mis kala selle Adrenaliniga on. Kaart on Asrock rx 6800 PGD, nii kui adrenalin peale läheb, hakkavad mingid anomaaliad pihta. Ekraan virvendab niisama ringi brausideski, driver time out, system hard crash jne jne. Selline tunne nagu kaart tahaks RMA. Samas, kui ainult display driver peale panna, siis on kõik täiesti stabiilne. Stress testi tundide viisi, mitte midagi halba ei juhtu.
_________________ Võimatu on teha midagi lollikindlaks, sest lollid on haruldaselt leidlikud. |
Kommentaarid: 16 loe/lisa |
15 |
Vael
24.09.2021 14:26:56
Vb ehanced sync, Freesync ja muu jura maha kakkuda igaltpoolt?
Samuti igaks petteks CLEAR CMOS, eriti kui all oli Nvidia.
Aga jah, kui AMD enda draiverid peal siis hakkab gpu koormust saama.
Tempid korras?
Ise uue kaardi, cpu puhul teen alati Tomb Raider vms koormava mängu, kus temp ja muud näitajad taustal jooksmas....
PS OCCT hea proge üldkoormuse testimiseks
Kommentaarid: 17 loe/lisa |
16 |
AlvinL
24.09.2021 14:48:42
Kui ma ei eksi siis display driveril on vaikimisi freesync sees. St, kui monitor seda toetab, siis ta on aktiveeritud.
Kunagi oli nvidia tõesti all, clear cmos on tehtud, ka sellest oli abi.
Tempid on korras, panin korraliku pasta - hotspot läheb stressates kõige rohkem 80 peale, see on täiesti normaalne.
15 |
Vael
24.09.2021 15:58:45
Vigade välistamisems võiks ebavajaliku välja lülitada, st igasugused syncid. Algselt on nad jqh ON...
16 |
XeStAiSy
24.09.2021 16:37:19
syncist rohkem kahju kui kasu.
aff
24.09.2021 17:11:15
Vahemärkuseks, et mul oli vaikimisi freesynck off ja automaatselt see peale ei läinud kui monitorist selle aktiveerisin. Kindluse mõttes paneks ma varukettale puhta windowsi peale ja prooviks sellega. Kui jama edasi esineb, siis kaart garantiisse.
Vaevalt viga monitoris on.
Kommentaarid: 63 loe/lisa |
56 |
AlvinL
24.09.2021 17:13:22
Kaart on korras. Soft kalab.
15 |
24.09.2021 17:52:54
AlvinL kirjutas: |
Ei saa aru, mis kala selle Adrenaliniga on. Kaart on Asrock rx 6800 PGD, nii kui adrenalin peale läheb, hakkavad mingid anomaaliad pihta. Ekraan virvendab niisama ringi brausideski, driver time out, system hard crash jne jne. Selline tunne nagu kaart tahaks RMA. Samas, kui ainult display driver peale panna, siis on kõik täiesti stabiilne. Stress testi tundide viisi, mitte midagi halba ei juhtu. |
Jep, mul sama. Arvuti restardib, appid crashivad, mingid imelikud anomaaliad. Hakkas peale viimast uuendust ehk siis 21.8.2 versiooniga, mis peaks ise veel WHQL draiver olema Beetasid ma ei kasuta.
Krt, oleks pidanud ignoreerima kui uuendust pakkus. Järjekordne kinnitus, et ei tasu töötavat asja näppida
_________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..." |
Kommentaarid: 373 loe/lisa |
313 |
AlvinL
24.09.2021 18:04:54
Kasutan ise 21.9.1. Pole 21.8.2 proovinudki, tõenäoliselt on need ka ok. Igatahes DDUga plats puhtaks, paki amd installikas lahti ja cancel install. Installi device manageri kaudu ainult display driver. Minu jaoks lahendas see probleemi. Afterburneriga saab propellereid kontrollida, OC suhtes on mul savi, kaardil jõudu jagub ilma kellatagi.
15 |
XeStAiSy
24.09.2021 19:22:54
Minul on nad kõik toiminud esimesest päevast mõni driver on natuke imelikum kuid midagi pole ka tegemata jäänud. Mingid ime arvutid teil ,et ei funka. Ma olean alates kevadest juba kaarti hoindud ja driverid on ka toiminud ei mingeid ddu vm uninstalle lihtsalt lasen otsa ja kõik toimib.
Pigem on siin windowsi kala midagi seal hapu
sfc
DISM
Kas need olete unustanud teha.
AlvinL
24.09.2021 19:25:37
Sõltub vist kaardist. Netist leida hulgi teemasid, kus 6800 (xt) inimesed hädas konkreetselt Adrenalini pärast. Väga ei taha uskuda, et massiliselt on defektseid kaarte toodetud. Samas, mine sa kurat tea..
Windows on kombes, selle olen üle kontrollinud.
15 |
XeStAiSy
24.09.2021 19:51:25
Minul on ka 6800xt ja see viimane beta peal ei kala kuskilt samas too on igav kaart mingeid probleeme pole mida saaks koinida.
Aeg maha 1p
14.10.2022 23:23:16
Kolisin täna GPUvahetusega taas AMD peale üle pika aja. WOW. Väga rahul olen. Meelega tahtsin AMD peale tagasi tulla ja seni olen väga rahul.
Kogu tarkvara toimimine +seadistamine, jne., kõik on väga palju mõnusam ning mängu ajal väga ulatusliku seadistuse ligipääs on ideaalne. Kõik seni toimib väga mõnusalt ja on täpselt see, mida igatsenud olen.
Kahjuks ei võimaldata native Hz peal mängude salvestamist, though :]
Teema nime võiks ka vast ära muuta, kuivõrd "AMD Software" nüüd.
Kommentaarid: 195 loe/lisa |
181 |
marxveix
Kommentaarid: 306 loe/lisa |
267 |
79 |
Aeg maha 1p
16.02.2023 13:37:25
Arusaamatu, miks peaks üks OS-is olev tarkvara seda vaikimisi üldse saama teha
Õnneks ise BETA-sid ei installi.
181 |
Vael
16.02.2023 16:53:54
rmc kirjutas: |
Õnneks ise BETA-sid ei installi. |
Sest AMD toodab ise emaplaafid ja chipset draiverid ka, BIOS sätete muutmine seega no problemo. Vb sattuski pakki ka chipseti draiver?
16 |
16.02.2023 17:46:43
Vael, Ma olen eraldi chipset draivereid paigaldanud hulgim (nvidia kaardi ja amd kiibistiku emaplaadiga). Seni pole need bios sätteid näppinud ja selleks pole ka mingit vajadust. BIOS sätteid muudetakse ikka BIOS uuendusega mis tuleb läbi AGESA ja emaplaaditootjate.
79 |
16.02.2023 17:49:05
kust see biose sätete muutmise jutt üldse pärit on?
buutimise lõhkumine ei eelda biosi sätete muutmist.
_________________ - londiste
Kommentaarid: 238 loe/lisa |
213 |
Vael
17.02.2023 17:02:56
UEFI puhul näitab uue draiveri installiga, et pole GPU UEFI sobiv? Samas see eeldaks juba GPU FW ümberkirjutamist?
Buutimsjrk muutmine on kõige lihtsam teema, UBUNTU teeb mul seda iga kord. Muudab BIOS ülestulekul Win->Ubuntu esimeseksb järbekorras. Samuti keerab kella UTC peale, kuigi Ubuntus 3ndas kl õige.
Seega kõik on võimalik.
EDIT. Nüüd tuli meelde, et see pole esimene kord AMDl Adrenaline Installer Package segamini ajada.
Mul oli ka ükskord jama, omast arust installisin Gpu, aga kuidagi kirjutas hoopis cvipseti draiverid üle. Saatsin bug reporti ja paari päeva pärast oli parandatud.
Nad kasutavad sisuliselt sama installerit mõlema draiveri paigaldamiseks...
16 |
dwert123
Kommentaarid: 2 loe/lisa |
