uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 11 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 19, 20, 21 ... 186, 187, 188  järgmine
Hiid
Hiid
sõnum 06.09.2021 18:00:45 vasta tsitaadiga
Hapud viinamarjad
Killer85
sõnum 06.09.2021 18:05:53 vasta tsitaadiga
MS DOS oli Microsofti oma.
Eksisteeris ka muid, IBMi oma, DRDOS, jne.
sõnum 10.09.2021 11:54:07 vasta tsitaadiga
Microsoft Dives into the Internals of Windows 11
https://www.techpowerup.com/286502/microsoft-dives-into-the-internals-of-windows-11
Apps running in the foreground also automatically get a higher app priority. This is particularly useful when your CPU is bogged down with a heavy workload, and you're trying to open a new app. The OS automatically rations resources to ensure the app you just launched is prioritized, making the experience snappy.
reduces resume-from-sleep times by 25%. Microsoft also worked on improving the performance of Windows Hello (biometric login), reducing Hello user-authentication times by 30%.
Microsoft also worked to reduce the overall disk footprint of the operating system. Most in-built apps come as stubs, which are either loaded from over the web at first launch; or remain compressed. Unless accessed at least once, an in-built app never posts background activity, and doesn't line up for updates, either.
The Windows Update service model will also receive an overhaul. Rather than two feature-updates (typically Spring and Fall), the company will only release one feature-update per year, typically positioned in the second half. Windows Update has been overhauled to only fetch specific pieces of software that need updates, which translates to up to 40% reduction in bandwidth consumption.
XeStAiSy
Aeg Maha 2a
sõnum 16.09.2021 15:59:34 vasta tsitaadiga
Reliis polegi enam kaugel. Kolme nädala kanti ootamist veel.
Windows 11 available on October 5
Vael
sõnum 16.09.2021 20:46:18 vasta tsitaadiga
Sellepärast mängudes ongi aeglasem et pool aega veedab windows store tagataustal joonsutades...
sõnum 18.09.2021 06:25:00 vasta tsitaadiga
Windows 11 TPM 2.0 requirement leaves many virtual machines out in the cold
https://www.slashgear.com/windows-11-tpm-2-0-requirement-leaves-many-virtual-machines-out-in-the-cold-16691247/
Alates 22000.194 siis on Win11 enamus VM-is jooksutamine raskendatud. Ise sain Virtualboxis nii toimima, et pakkisin Win10 21H1 lahti ja siis Win11 22000.458-st võtsin välja ja asendasin ainult install.wim. Siis pakkisin uuesti ISO-ks kokku ja sain jooksma.
Vanemate kui 21H1 kasutamine pildus erinevaid erroreid. Ka appraiserss.dll asendamine ei toiminud.
XeStAiSy
Aeg Maha 2a
sõnum 18.09.2021 10:18:04 vasta tsitaadiga
Mis probleemseks saab win11 on CPU tuumade kasutamine kui win 10 suudab cput koomata mingi mänguga 100% sis win11 peal ainult peaegu 50% mina ei saanudki winn 11 peal sellepärast kaua veeta aega nendes mängudes on räme performance drop. Ennem mina wi11 peale ei lähe kui mängud on hakanud toimima.
Eriti hitti saavad cryengine lumberyard mootoriga mängud.
Räme kisa tekib kui new world mmo lastakse välja 28 september ja viiendal oktoobril on win 11 saadaval milles on 50% performance drop sest cpud ei kasutata niipalju kui seda oli win 10ne all sama teema on starcitizen.
Ennem kui need 2 asja toimima korralikult ei hakka ei toimu ka win11 peale kolimist.
Amazoni support vist läheb punaseks iseasi mismoodi nad kiiruga peaksid oma lumberyardi korda tegema.
Läbi aegade on uue windowsi versiooni peale joostud murdu.
Ma ikkagi vahest proovin 11 versiooni kuid alati on olnud tahtmine pressida restore nuppu DEV kanalis on see build mis reliisib. Beta kanalis ei ole väljalaskvat versioon nad ei saa ka hetkel prerelease kanalisse 11 lükata kuna seal istub windows 10.
Watermarkiga build on see mis hakkab reliisima kuna neid versioone on mitmeid siis kunagi ei tea milline neist. Ühest hetkest kaob watermark ära prerelease omadel.
Vael
sõnum 18.09.2021 10:22:29 vasta tsitaadiga
Kahju jah, et gamerite peale ei mõelda. Win 10 all oli küll mingi game mode, aga see ei täitnud eesmärki, vaid olukord läks pigem hullemaks. Lülitasin välja kohe.
Win11 all ei ole Game Mode enam? Oleks vaja mingit win versiooni, mis lükkaks välja power save ja muud jõudlust nudivad settingud.
MS võiks natuke olla motiveeritud, sest neil Game Pass PC peal ka toetatud...
firemark
firemark
sõnum 18.09.2021 10:33:37 vasta tsitaadiga
https://www.windowsfx.org/ Linuxi fännidele kes tahavad win11 kasutajaliidesega op süsteemi icon_biggrin.gif
XeStAiSy
Aeg Maha 2a
sõnum 18.09.2021 11:22:13 vasta tsitaadiga
Vaatan hetkel on 1 build beta kanalisse pidama pikemaks jäänud mis see ennast kujutab. Win 11 peal on game mode kuid too ei anna kogu proset mängule. Hakka või HT välja lülitama et 8 coret läheks kasutusse 16t kasutatakse ainult pool.
Kipun arvama ,et jällegi surutakes desktopi arvutisse Läptopi teemat
sõnum 18.09.2021 12:57:39 vasta tsitaadiga
Mis on sel mängujutul üldse windowsiga pistmist? Mis Redmond nüüd tegema peaks, teile kõigile Xbox seadmed ostma või?
Maailmas on tõesti märkimisväärne hulk mängusõltlasi, kuid neile sobiliku tarkvara peab ikka mängutootja looma vastavalt Mikrosofti poolt loodud raamistikule, mitte Redmondi tarkvaraarendajad ei pea windowsi mängu järgi arendama.
Seega on täiesti kohatu kiun, et isegi veel ametlikult arendusjärgus operatsioonisüsteem on sitt, kuna kellelgi mingi mäng ei jookse selles keskkonnas. Ning kuuldavasti see tarkvara, mis oktoobris välja lastakse, ei ole ka veel laiale kasutajaskonnale saadaval, nagu siin teemas ka juba viidati. Kuuldavasti 2022 algusepoole tuleb mängusõbrale uuem ja küpsem Windows 11, mille jaoks on mängutootjal aega küll kohandada oma mängu sobivaks.
Muidugi ametlik väljalase blokeerib tõenäoliselt ka kõik need mittesobivad testarvutid, millele me kuidagi oleme selle W11 praegu selga kuidagi ajanud.
Vael kirjutas:
Xbox on tõenäoliselt Microsofti motivatsioon, kui just mänguarendajad ei "tee koostööd" mikrosoftiga, et nene mängud jookseks windowsi peal. Motivatsioon on selline lai mõiste.
sõnum 18.09.2021 13:42:21 vasta tsitaadiga
Game Mode on ka Win11 peal olemas. Ise VM-is game perfi testida ei saa, aga hetkel tuubist videoid vaadates paistab perf enamvähem sama olevat. Muidugi kindlasti leidub erandeid kui mäng OS-iga läbi ei saa.
Esimesed muljed on siiski head. Keskel asuvad taskbar ikoonid meeldivad ja Windows Update on palju kiirem kui Win10 peal.
Küll aga ei meeldi paigaldusel see, et pole ühtset teemat. OOBE keskkonnas on osa paigaldusest valge, siis jälle must ekraan valge tekstiga. Siis jälle valge. Silmadele hakkab. Võiks ise saada selle kah dark mode peale lükata.
Azatris
Azatris
sõnum 18.09.2021 17:47:40 vasta tsitaadiga
Warzone'i puhul ei olnud W10 ja W11 minu jaoks vahet.
XeStAiSy
Aeg Maha 2a
sõnum 18.09.2021 18:36:54 vasta tsitaadiga
Enamuse mängudest on sama performance nagu 10nelgi probleemsemad on need mis cpud tahavad. Kuna see issue oli esimesest päevast mil win 11 avalikuks tuli siis rohkem ka seal midagi ei muudeta vaid saame selle mis on juba tehtud. Edasi saab ainult loota et arendajad teevad oma koodi toimivaks. Kui ei jookse ei tee ka MS midagi rohkem. 5 oktoobrini on maruvähe aega .et seal üldse hakata midagi muutma ,et cryengine jookseks. Samuti raud on toetatud win11 jaoks ei mingeid häkke ja trikke.
Minujaoks on win 11 piisavalt söödav et kasutada ei pange panemist ega veidruseid siis viies oktoober on igati paigas. Need kaks mängu on kah cryengine omad mis performivad kehvemini ülejäänutega probleeme pole.
Renq
Renq
sõnum 19.09.2021 20:38:46 vasta tsitaadiga
Kuda te teete "clean installi"? Mul annab mälupulga kohta võõra seadme errori ja edasi ei saa.
sõnum 01.10.2021 07:52:42 vasta tsitaadiga
Over 60% of PC users don't know about Windows 11
https://www.techspot.com/news/91496-over-60-pc-users-dont-know-about-windows.html
Tegu siiski ühe uuringu ja väikese valimiga aga eks uus versioon tuleb enamusele alati üllatusena.
olavsu1
külaline
sõnum 01.10.2021 08:25:00 vasta tsitaadiga
Renq kirjutas:
pead BIOS'i üle vaatama: https://www.dell.com/community/PowerEdge-HDD-SCSI-RAID/how-to-clear-a-foreign-state-from-a-replacement-sas-drive-on-a/td-p/3558875
win7ultimate plaadiga. sest mälupulkadelt mu praegune arvuti (DELL) keeldub bootimast.
sõnum 01.10.2021 08:40:06 vasta tsitaadiga
w7 plaadiga " repair" alt tõmbad wim i käima?
w11 l pole " taaste" all kohta, et "tõmba pilvest uus iso või tee kohalik "?
olavsu1
külaline
sõnum 01.10.2021 09:18:47 vasta tsitaadiga
w7 tuleb paigaldada alles siis saab distributsiooni uuenduse käima tõmmata.
kui originaal w10 plaat olema siis pole taolist jama vaja.
Muhekas
Muhekas
sõnum 01.10.2021 16:38:06 vasta tsitaadiga
Et kui mul on insaider praegu peal siis 5.okt tuleb format teha jah?
tofay
sõnum 01.10.2021 16:57:46 vasta tsitaadiga
Ei tule, lihtsalt lahku grupist.
Gap
Gap
sõnum 01.10.2021 21:53:05 vasta tsitaadiga
Tõmbasin huvi pärast selle viimase versiooni siis mikrosofti kodukalt ja näitab nüüd sellist asja ?
on siis 7700k toetatud või ei ole ?? Miks ta näitab prose on ok ? nad ei tohiks ju mingit udu ajada rahvale ? et kui kellelgi on kõik muud asjad ok ja siis tuleb välja et prose ei ole toetatud ? icon_rolleyes.gif Kas need boot meetodi on võimalik siis näiteks sellel kes asja tunneb ära muuta või on siiski uut proset ja emalplaati ja uut ssd ketast vaja ?
sõnum 01.10.2021 21:55:54 vasta tsitaadiga
Jah.
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Gap
Gap
sõnum 01.10.2021 21:56:53 vasta tsitaadiga
Betamax kirjutas:
Jah.
sõnum 01.10.2021 22:03:31 vasta tsitaadiga
Kuhu sul selle arvutivahetusega nii kiire on? Mitmendat kuud nagu munas kana oma 7700K-ga. Tahad nii väga uut arvutit osta? Enam halvemat aega selleks pole... Kasuta rahulikult Windows 10 kuni 2024. aastani ja ongi kõik. Või siis, kui raha kõrvetab nii väga näppude vahel, siis võid raske raha eest uue masina osta. Ma ei ole veel kordagi elus opsüsteemi pärast uut arvutit ostnud ega plaani ka seda teha. Eriti, kui veel olemasoleval tugi mitu aastat olemas.
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 11 mine lehele eelmine  1, 2, 3 ... 19, 20, 21 ... 186, 187, 188  järgmine
