Azatris
25.06.2021 14:46:00
See TPM moodul maksab ise mingi kümnekas, võib-olla kakskümmend. Ei ole hullu.
Mida ma ise siiralt vajan Windows 11st: parem multi-display haldamine, parem SSD kasutus mängudes ning Android äppid (nt Kindle, mille desktop app ei toimi samasuguselt nagu telefonil). Lisaks ma ei ole kunagi flat designi talunud ja kuna me liigume sellest veits kaugemale jälle, siis see on teretulnud.
Muhekas
25.06.2021 15:34:54
| Mis asi see tpm on ja milleks seda vaja?
Azatris
25.06.2021 15:40:50
Trusted Platform Module provides
A hardware random number generator[4][5]
Facilities for the secure generation of cryptographic keys for limited uses.
Remote attestation: Creates a nearly unforgeable hash key summary of the hardware and software configuration. The software in charge of hashing the configuration data determines the extent of the summary. This allows a third party to verify that the software has not been changed.
Binding: Encrypts data using the TPM bind key, a unique RSA key descended from a storage key[clarification needed].[6]
Sealing: Similar to binding, but in addition, specifies the TPM state[7] for the data to be decrypted (unsealed).[8]
Other Trusted Computing functions for the data to be decrypted (unsealed).[9]
Computer programs can use a TPM to authenticate hardware devices, since each TPM chip has a unique and secret Endorsement Key (EK) burned in as it is produced. Pushing the security down to the hardware level provides more protection than a software-only solution.[10]
Lühidalt, Bitlocker toimib veits paremini sellega (kõvaketta krüpteerimine). Kahtlustan, et MS tahab seda kõigile, et lõpuks seda ära kasutada piraatluse vastu. Tegelikult ei tundu olevat otsest põhjust miks W11 ei võiks joosta ilma selleta. Ja kusjuures hetkel saabki paari häkiga neid leaked ISO-delt selliselt installida.
25.06.2021 17:37:30
| Azatris kirjutas: |
Kusjuures vaatasin HP G1 840 jaoks seda TPM1.2 moodulit ja no ei leidnud. Vähemalt pole kinnitatud, et sobib antud arvutiga.
Muus osas tuli sobivuskontrolli osas kindel ei.
The_Boss
25.06.2021 17:41:19
jägaja, jutt on lauakatest. 840 G1 ju läppar.
Muhekas
25.06.2021 17:44:03
| Mis moodulitest te jaurate, tahaks ka aru saada millest ma ilma olen jäänud
25.06.2021 17:48:48
| The_Boss kirjutas: |
| jägaja, jutt on lauakatest. 840 G1 ju läppar. |
Mis siis, sellel nõutakse ka TPMi olemasolu.
Muhekas, vaata mõned postitused eespoolt.
Bunny
LKits
Azatris
25.06.2021 18:07:58
Sain ka siiski oma 7700K peal TPM enabled. Aga ma ei saa aru, mis versioon see siis lõpuks on. See ei teinud PC Health Checkis valiidseks Windows 11 jaoks.
Windows Security -> Device security -> Security processor details -> Specifications
Specification version 2.0
PPI specification version 1.2
TPM specification sub/version 1.16
PC client spec version 1.0
Ma ei tea, mis versioon nüüd siin oluline on.
Muhekas
25.06.2021 18:11:18
| Kas ma pean ka kuskilt selle TPM enablema kui kunagi win11 peale yle lähen? Miks need asjad nii keeruliseks aetakse
Azatris
25.06.2021 18:33:37
Sain teada miks ta ütleb, et ma W11 ei saa: From the looks of it, major Intel Core processors such as i3, i5, i7, i9, etc., are supported, but you must be running an 8th-Gen (released in 2018) or above CPU to install Windows 11, which is a shocker. Basically, if you have an Intel processor below 8th-gen, you won’t pass the Windows 11 compatibility test. https://beebom.com/this-pc-cant-run-windows-11-fix/
Nii et kui Sul on 5GhZ overclocked 7700K, siis see ei ole piisavalt võimas, et jooksutada ümardatud nurki.
Gap
25.06.2021 19:14:10
Seda ma ka enne küsisin et kui tahan seda win 11 siis mina ei saa pean uue prose ja emalplaadi ka ostma kuna seda 7700k socketit ju ka enam ei eksisteeri ... täiesti haigemaja ... see prose on ikka tegleikult võimas veel isegi mängude jaoks 3 aastat kindlasti kui mõni jooksutab veel praeguis mänge 2600k või 4k prosega ja windowsile nüüd äkki ei kõlba .,.. krdi nasa arvutit jälle vaja.
von Wu
olavsu1
külaline
25.06.2021 19:32:23
karl80038, siiski on üks koht, kus neid võib vaja minna. klient-server süsteemid.
üks selleks, et kindlustada klient seadmel õige softi jooksmine ja teine selleks et krüptida kliendi ja serveri infovahetus.
Azatris
25.06.2021 19:59:30
| Ma usun, et nii hiilitakse requirementsidest kõrvale häkkidega kui ka Microsoft ise alandab neid nõudeid ühel hetkel.
napoleon
Unknown virus
25.06.2021 20:25:43
| ot: |
| IMHO on see secure boot suht mõttetu asi. Vähemalt kodukasutaja ja töökoha arvuti jaoks. See kaitseb vaid selle eest, kui keegi tõesti bootloaderit häkkima hakkab, aga pakun et see oleks juba suht suunatud rünnak ehk tavaline botnet, ransomware ja muud paharetid nii madalal tasemel ei toimeta |
Ramones
25.06.2021 20:46:19
Gap, midagi ei pea ostma. Jookseb Win11 ka Sinu raual. Toetatud CPU-de nimekiri on pigem soovituslikku laadi. W10 21H1 ei tohiks sama loogika järgi ühegi vanema Inteli prose, kui 6gen peal joosta, kuid töötab vägagi hästi ka vanade C2D prosedega, mis on tänaseks juba 16a vanad.
Tundub suht mõttetu paanika TPM ja eriti CPU generatsioonide üle, mis suurele enamusele ei ole tegelikult mitte mingiks probleemiks.
The_Boss
25.06.2021 22:23:34
| jägaja kirjutas: |
Mis siis, sellel nõutakse ka TPMi olemasolu. |
No ma parandan oma sõnastust siis. TPM mooduli ostuvõimaluse jutt käib lauakate, mitte läpparite kohta.
Läpparitel on neid mooduleid harva võimalik juurde osta. Fujitsul tean peast ainult seda võimalust.
25.06.2021 23:15:02
Microsoft DirectStorage Walled Off from Windows 10, Now Needs Windows 11 and DirectX 12 Ultimate GPU
https://www.techpowerup.com/283777/microsoft-directstorage-walled-off-from-windows-10-now-needs-windows-11-and-directx-12-ultimate-gpu
Üsna segane värk. Algul oli, et peab olema 1TB PCI 3.0 SSD ja DX12 Ultimate GPU. Nüüd on 1TB nõue eemaldatud ja jutt käib DX12 GPU'st.
Ühtlasi arusaamatu kas see SSD peab olema see kuhu OS paigaldatud või see kuhu mängud on paigaldatud? Või peavad mõlemad nõuetele vastama?
MS nagu tavaliselt oma ülisegase kommunikatsiooniga.
Ühtlasi dick move limiteerida see Win11 peale kui pole mingit tehnilist põhjust miks Win10 ei saaks seda toetada.
Meenutab DX12 limiteerimist Win10 peale kuiugi üksikute eranditega lubati hiljem DX12 kasutada Win7 all.
Ja ennetades teatud kasutajate küsimust, siis DirectStorage võimaldab SSD ja GPU otsesuhtlust ja peaks tulevikus tooma mängude ülikiire laadimise.
Hetkel käib suhtlus läbi CPU mis on lisasamm.
s4nder
26.06.2021 14:11:06
| Ürgsete Inteli emaplaatide omanikel tasub uuendada BIOS ja aktiveerida seal turvaseadete alt PTT, mul hakkas TPM 2.0 nii tööle. Kontrollida saab Start menüüst run -> tpm.msc.
XeStAiSy
Aeg Maha 2a
26.06.2021 14:31:06
Ma ka enablesin PTT biosis 2.0 tuli külge. Kui poleks Rbar enabled siis oleks biosi saamine lihtsam kui vaja peab cmos tegema ,et sinna saada kuigi igapäev ei lähe vaja.
_________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
viimati muutis XeStAiSy 26.06.2021 14:33:15, muudetud 1 kord |
XeStAiSy
Aeg Maha 2a
26.06.2021 15:16:37
Pigem ostma kukuvad need kes ei tea biosist midagi ise olin kah veits sassis kuna sellist settingut nagu PTT ei olnud kunagi ennem vaja. Amd peal on teine nimetus. By default need settingud on disabled. See on veider selle leakiga digilitsents on küljes peale installi kui upgrade teha. Siis järelikult oli too ametlik muidu poleks ma saanud digilitsensi win 11 jaoks järelikult need serverid toimetavad rahulikult. Peab win 11 insideri kah ära ootama.
lopes39
26.06.2021 16:12:10
Ma oma emme MSI B85M-E45 biosist ei leidnud seda kohta kus ptt sisse lülitada
Samas mul 4s generatsioon prose kas üldse saab seda W11-st.
Väga absurdne vajadus op süsteemi uuendusel. Loodetavasti saab pisipehme piisavalt meedia kära ja nad kaotavad ära selle absurdse vajaduse.
Samas mul bios-is näitas et mu windows on 8/8.1 ehk siis kunagi sai ostetud W8
Muhekas
26.06.2021 19:50:36
Ühesõnaga kuna minu jaoks on asi sassis nagu puder ja kapsad siis küsimus on lühike. Kas ma pean ka hakkama mingeid PTT-sid ja TPM-e või saan tulevikus sujuvalt win11 peale ümber kolida ilma mingisuguste jamadeta?
Tänan!
26.06.2021 20:15:40
Muhekas, Pead BIOS-st PTT siiski sisse lülitama. Muus osas on sinu raud Win11 kõlbulik seega midagi juurde ostma ei pea.
Hetkel on see muidugi akadeemiline argument, kuna Win11 pole veel väljaski ja seega pole vaja praegu BIOS-i minnagi.
Hiid
26.06.2021 20:25:26
mis see on? Miks ta seni väljas on?
NATAS999
26.06.2021 20:27:33
Hiid, kõvaketta krüpteerimise süsteem. sest nii on.
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
Muhekas
26.06.2021 21:36:43
Kuda krt peaks kodukasutaja seda koike teadma kui ükskord win10 enam uusi uuendusi ei saa? Täis kosmos see tänapäeva elu. Tomorrow mul on üks vana isend ka kodus veel lisaks uuele. Ja kui poleks kõlbulik olnud siis oleks midagi lisaks tulnud veel osta? Kuhu me jõudnud küll oleme eluga ometi
Vondur
26.06.2021 22:15:42
Muhekas, Microsoftil on lahendus olemas. Win11 tutvustuslehel teatab ta, et kui vana arvuti parameetrid ei sobi, osta uus ja annab sulle lingid Amazoni, Walmarti, Best Buy või Microsofti enda poodi uut arvutit ostma... Siiani on Win 11 esitlus olnud suur PR ämber. Saab näha mis edasi tuleb.
_________________ Lugupeetud AHV, enne kui vaidlema hakkad, mõtle hästi järgi, kas see ikka on tark mõte... |
26.06.2021 22:17:27
Kodukasutaja läheb poodi ja ostab uue arvuti kui olemasolev enam uuemat tarkvara vastu võtta ei taha. Või viib arvuti spetsialisti juurde kes asjad ringi seadistab. Kodukasutajad üldjuhul ei käi HV foorumis omi muresid kurtmas.
Muhekas
26.06.2021 22:44:56
Tutkisin biosis ja ma seda ptm kohta ei leidnud
trükkisin tpm.msc ja sain sellise teate
a ok sain kätte see oli biosis security seadete all ja see oli väljas mul
LKits
Killer85
26.06.2021 23:35:15
| Vondur kirjutas: |
Järjekordne HV foorumi teema kus vanad peerud saavad Windows Seitset taga nutmas käia ning uusi ja arusaamatuid asju kiruda... Mina ise ootan uut Windowsit rahuliku huviga. |
| Vondur kirjutas: |
| Siiani on Win 11 esitlus olnud suur PR ämber. Saab näha mis edasi tuleb. |
that aged well
Vondur
27.06.2021 01:11:04
Millal MS on suutnud head PR-i teha?
Enamus esitlusi enamus firmade poolt on tänapäeval täielik ajaraisk. Mõned üksikud suudavad veel enamvähem teha lühikese, informatiivse ja huvitava esitluse mitte jahuda tundide kaupa võrdõiguslikkusest või millestki muust mis otseselt toodetega ei seostu. Rääkimata tehnilistest probleemidest. See oli päris piinlik kui suurim tarkvarafirma maailmas ei suuda teha livestreami, mida suvaline inimene oma telefonist tänavanurgal teha suudab.
Win11 on strech ilmselgelt. Samahästi võiks olla 10.1
Oraff
Vondur
27.06.2021 02:01:34
Tomorrow, Microsofti võikis ju vähemalt üritada, aga Win11 sattus kohe esimesel päeval "spekulatsioonide veskisse". Inimesed on ärevil, sest nõudmised on nende jaoks täiesti arusaamatud, scalperid hakkasid TPM mooduleid kokku ostma ja lisaks tekkis paanika, et üle 90 protsendi maailma prosedest ei jaksa "uut" Windowsit jooksutada. Mille eest saavad palka Microsofti PR tüübid, jääb selgusetuks. Tootest endast nagu eriti midagi ei mainitagi, peale selle, et akende nurgad on nüüd ümarad ja OS ise nõuab FBI tasemel turvakaitsega NASA arvutit.
Hiid
27.06.2021 09:49:38
Leidsin oma ürgesest HP arvutist TPMi
PTTd, siiski ei paistnud
Bilderberg
27.06.2021 10:46:42
Piisab ühe faili "appraiserres.dll" asendamisest.
Vael
27.06.2021 11:26:14
Tekkis juba väike lootus, et win11 tuleb lõpuks nagu win7. Lased RC versiooni peale, otsib ise uusimad draiverid ja elu lill.
Nüdd tuleb välja et kui dual boot jooksutada, siis hakka kogu majandust ümber häälestama?
Jääb siis ära see nali.
Kui TPM tekitab turvalise HWID, siis võib arvata,et kood MS kontoga nõudega kolitakse täielikult CD key pealt.
Kui HWID olemas, siis peab uue GPU/CPU vahetamiseks pappi hakkama köhima?
NATAS999
27.06.2021 11:30:40
leidsin oma kiviaegse arvuti biosist ka lõpuks selle ptt/tpm asja üles. asus prime z390-p siis nimelt (bios ver. 2820), kui kedagi huvitab. tuleb minna advanced mode (f7), ülevalt advanced, pch-fw configuration ja seal intel platform trust technology ilusti olemas.
pc health check on igatahes rahul ja väidab mu raali win11 kõlbulikuks olevat.
27.06.2021 12:43:33
Huvitav, kuidas nad plaanivad selle massiivse online kontode tegemise ja haldamisega toime tulla? Ega kõigil pole ju Hotmaili, Outlooki või mis iganes Microsofti derivaatkontot. See tähendab ju miljoneid uusi e-maili kontosid, mis on igapäevaselt aktiivsed ja sünkroonivad-varundavad ning teevad veel teab mida.
M: HP Elitedesk 800 G3 SFF
27.06.2021 12:52:48
Betamax, see kõik pole tegelikult üldse nii keeruline, kui sa arvad…
