13.05.2020 07:28:55
Pocophone F2 Pro |
Uus flagship killer siis.
https://www.poco.net/global/
https://www.gsmarena.com/xiaomi_poco_f2_pro-10220.php
Platform
Qualcomm® Snapdragon™ 865 flagship platform
Qualcomm® Kryo™ 585, 7 nm Process Technology
CPU frequency: Octa-core processor, up to 2.84 GHz
Qualcomm's trifecta design: 1 x 2.84GHz super large core + 3 x 2.42GHz large core + 4 x 1.80GHz small core
GPU: Adreno 650 GPU, up to 587MHz
AIE: 5th generation AIE processor
Storage and RAM
8GB + 256GB
LPDDR5 + UFS 3.1
6GB + 128GB
LPDDR4X + UFS 3.1
* The amount of available storage and RAM is less than the indicated memory,
as the operating system and pre-installed software are stored in the device.
Display
6.67" Dot Drop Full Screen Display
Corning® Gorilla® Glass 5 front and back
Resolution: 2400×1080 FHD+
Brightness: 500 nits (typ) / 800 nits (HBM)
Aspect ratio: 20:9 | 92.7% screen-to-body ratio
Contrast ratio: 500,000:1(typ) | Color range: NTSC 98%(typ)
60Hz refresh rate, 180Hz sample rate
TÜV Rheinland Full Care Display Certification
Support HDR10+ and Netflix HD streaming
* Xiaomi phones feature a curved design with gracefully rounded corners. When measuring the rectangle formed from the farthest ends of each corner, the screen has a diagonal length of 6.67 inches (actual display area may be slightly smaller).
Rear Camera
64MP quad rear camera
64MP main wide sensor
Sony IMX686, 1.6μm 4-in-1 Super Pixel, 1/1.7“ sensor size, ƒ/1.89 aperture
13MP ultra wide-angle sensor
123° FoV, ƒ/2.4 aperture
5MP macro sensor
1.12μm pixel size, ƒ/2.2 aperture, AF (3cm-10cm)
2MP depth sensor
1.75μm pixel size, ƒ/2.4 aperture
Rear camera photography features
64MP HD | AI camera | Pro mode | Night mode 2.0 | Document mode | Portrait mode background blurring | Panorama mode | Pro mode | Photo timer | Leveling | Burst mode | Face recognition | HDR | AI Beautify | AI smart slimming | Ultra wide-angle edge distortion correction | Group photo face correction | Custom watermark | Portrait mode background blur adjustment | AI light trails | AI Studio lighting | AI high resolution photos
Rear camera video features
AI 8K video | 4K recording | Video bokeh | Shootsteady video | Vlog mode | Video filters | Cinematic mode | Movie frame | Macro slow-motion video | 960 fps slow motion video | Rear Short video smart slimming | Rear video beautify
8K video recording 24fps/30fps
4K video recording 30fps/60fps
1080p video recording 30fps/60fps
720p video recording 30fps"
*8K 24fps feature will be added later via OTA update.
Slow-motion video
960fps 720P/1080P
240fps 720P/1080P
120fps 720P/1080P
Front Camera
20MP pop-up front camera
Front camera photography features
AI camera | Portrait mode | Panorama selfie | Full screen camera frame | Palm shutter | Front camera HDR | Front camera flash(via display) | Selfie timer | Eye light | AI Beautify | AI feature adjustment | AI makeup | AI scene detection | AI studio lighting
Front camera video features
AI Beautify | Short video mode | Short video filter
Slow-motion video
120fps 720P
Charging and battery
4700mAh(typ) / 4600mAh(min)*
Supports 30W fast charge
Built-in rechargeable battery
USB Type-C reversible connector port
Supports QC4.0+/ PD 3.0 quick charging protocol
33W charger included in-box , PD charging protocol
Network & Connectivity
Dual SIM card ① | Dual Nano-SIM slot
Supports 5G / 4G+ / 4G / 3G/ 2G ②
Supports VoLTE HD calling ③
① 5G requires the support of local telecom operator services, and may not be available in all regions
② Does not support TD-SCDMA
③ Only certain regions and telecom operators support VoLTE.
Supports network bands
5G: Sub6G: n77/n78
4G: FDD-LTE: 1/2/3/4/5/7/8/20/28
4G: TDD-LTE: 38/40/41
3G: WCDMA: 1/2/4/5/8
3G: EVDO: BC0
2G: GSM: B2/B3/B5/B8
Supports 4x4 MIMO | HPUE | HO RxD
Wireless network
Supports protocols: 802.11a/b/g/n/ac/ax
Supports 2.4G Wi-Fi / 5G Wi-Fi
Supports 2x2 MIMO, 8x8 Sounding for MU-MIMO, Wi-Fi Direct, Miracast,
Supports Bluetooth 5.1, Qualcomm TrueWireless™ Stereo Plus
Support AAC/ LDAC/ LHDC / aptX™/ aptX™ HD/ aptX™ -Adaptive
NFC
Supports Google Pay
Dimensions
Height: 163.3mm
Width: 75.4mm
hickness: 8.9mm
Weight: 219 g
* Data obtained from Xiaomi Laboratories. Results may vary depending on the method of measurement used.
Audio
1216 super-linear speaker
Dual smart PA high volume boost
Audio playback
Supports audio formats such as
MP3, FLAC, APE, DSF, M4A, AAC, OGG, WAV, WMA, AMR, AWB
Hi-Res Audio certification
Video playback
MP4丨M4V丨MKV丨AVI丨WMV丨WEBM丨3GP丨3G2丨ASF
Supports HDR display when playing HDR10 video content
Sensors
Proximity sensor | In-screen ambient light sensor | Accelerometer | Gyroscope | Electronic compass | Hall effect sensor | Linear motor | IR blaster | Barometer | Flicker sensor
Operating system
MIUI For POCO
Package contents
POCO F2 Pro | Power adapter | USB Type-C cable | Simple protective cover | SIM eject tool | User guide | Warranty card |
| Kommentaarid: 92 loe/lisa |
Oliverk
13.05.2020 07:58:20
| F1 omanikuna võivad omna 500 e telefoni sisse soolata. Peab jälle järgmist bang for bucki otsima hakkama.
| Kommentaarid: 27 loe/lisa |
26 |
13.05.2020 08:36:26
Oliverk, Kaeba Qualcommile. Nemad määravad Snapdragon SoC hinna. Lisaks peavad telefonitootjad ostma lisaks 865 SoC'le eraldi juurde ka X55 modemi, kuna 865 ei oma integreeritud modemit (erinevalt 855 ja 765/768 mudelitest), seega ilma X55-ta poleks isegi 4G võimalust rääkimata 5G-st. Selge see, et see tõstab hinda veelgi.
Muidugi see ei tähenda, et Xiaomi poleks saanud hinda allapoole tuua millegi muu arvelt. Näiteks arusaamatuks jääb miks oli vaja dual Gorilla Glass panna ette ja taha. Plastikkere nagu F1-l oleks tulnud odavam ja potentsiaalselt vastupidavam.
Teine kitsaskoht om MicroSD toe puudumine. See on seda kummalisem, et Dual-SIM tray on olemas ja poleks eriti keeruline lubada kahe SIM kaardi asemel kasutada ühte SIM ja ühte MicroSD kaarti seal trays nagu paljud tootjad teevad.
Veidi arusaamatu on ka 60Hz piiratud ekraan. Touch sample rate on küll 180Hz aga oleks siis võinud kasutada nt 90Hz ekraani vähemalt. Tabelis on seda võrreldud S20+ ja OP8-ga aga sujuvalt jäetud mainimata, et nood omavad 120Hz ekraani. Arvestades 4700mAh akut mis on suurem kui konkurentidel poleks ka aku vastupdavus 90-120Hz režiimi puhul probleem. Kummaline otsus lihtsalt.
Kommenteeritud on veel seda, et puudub kaamera OIS, juhtmevaba laadimine ja IP sertifikaat. Lisaks on USB-C port 2.0 kiirusega mitte 3.1
Lisaks isiklikult on kahju, et puudub musta värvi variant. Kõik on liiga heledad imo.
Mulle tundub, et märgatav osa telefoni eelarvest on kulutatud eri kaameratele. Kuigi pean tunnistama, et popup selfie kaamera on parim lahendus inimestele kes harva esikaamerat kasutavad ja isegi kõik eelnevat arvesse võttes on suudetud 500-600€ sisse see mahutada. Vähemalt kõrvaklapiväljund on olemas mis on tervitatav.
Ma lihtsalt kahtlustan, et hinnavahe teiste SD865 variantidega on seekord liiga väike. Eriti arvestades F2 puudujääke. Loodame, et aasta lõpuks kukub kuskile 350€ kanti. Siis võib soovitada küll.
C1rca
17.05.2020 13:18:30
Hetkel vist ühtegi reaalset reviewi ei ole? Endale nagu kõik muu meeldib, tahaks teada kas kaamera Oneplus 7T-ga võistleb.
Kui kaamera on samal tasemel, siis ekraani Hz vist elan üle, Poco võtaksin aku suuruse pärast aga kaamera peab tasemel olema selles hinnaklassis.
Ma ei saa aru, kui tootja hind on 499, miks siis meil jälle 549ga siin mõni edasimüüja pakub.
Ise ka F1 omanik, hetkel sellise hinnaga vist ei upgrade. Hetkel selles hinnaklassis/segmendis juba mitmed otsesed konkurendid ka tekkinud - Realme ja ega Redmi K30 Pro jms. ka samas hinnaklassis.
97 |
Delta
134 |
C1rca
22.05.2020 11:06:53
| Delta kirjutas: |
Ütleme nii, et hind pole soodne enam. Teisalt, omal ajal maksis f1 umbes pool tippude hinnast, selles mõttes on suhe enam-vähem paika jäänud.  |
Tõsi, täna ainuke põhjus keskmise kasutaja jaoks on flagshipi või flagship killeri ostmiseks kaamera. Mõned aastad tagasi olid keskklassi telefonid läggisid korralikult, täna on paremad keskklassi chipsetid SN845 tasemel ja mingit lagi ei ole.
Eks näis kuidas Poco F2 Pro kaamera on.
97 |
Delta
134 |
C1rca
16.08.2020 19:20:27
Soovitan jälgida ka Amazoni, seal on ka hinnad käinud alla 400€.
97 |
freddys
28.11.2020 00:45:15
Hetkel Euronicsis 360
_________________ Kui mees sööb, on ta tugev!
Kui mees joob, on ta julge! |
| Kommentaarid: 88 loe/lisa |
83 |
zaitz
07.01.2021 09:33:42
| On ostnud ka keegi? Rahul?
| Kommentaarid: 36 loe/lisa |
34 |
time123
31.01.2021 15:10:59
| Sõrmejälje tuvastamine on vääga aeglane ja 960fps video on interpolated ning kasutamiskõlbmatu. Kui neid funktsioone kasutate, soovitaks mujale vaadata.
| Kommentaarid: 205 loe/lisa |
180 |
zaitz
03.02.2021 16:56:37
(rant)Ja ongi kätte jõudnud aeg, kus kuni 450€ e 7000eek eest enam korralikku telefoni kätte ei saa Tuleks 800+ välja vist käia. (/rant)
34 |
zaitz
04.02.2021 10:35:48
| Tomorrow kirjutas: |
| zaitz, Defineeri "korralik" |
Üldiselt hea kooslus. St. korralik riistvara, koos hästitoimiva tarkvaraga.
Ma ise tugevalt kaldun praegu Poco F2 Pro peale. Samas loen, et sõrmejäljelugeja töötab halvasti (gsmarena reviewes oli ok), kaamera on parimal juhul keskpärane, 90Hz ekraani pole, kaal on 230g, siis tundub, et kuidagi palju kompromisse
Äkki Mi 10T, seal jälle IPS ekraan, tahaks OLED'i...
34 |
mz_est
04.02.2021 10:50:31
Omasin seda telefoni mõned kuud, siis vahetasin välja Pixel 4a vastu. Väga rahul valikuga. Sama hinnaklass, aga Pixel töökindluse osas mäekõrguselt üle.
Mis meeldis:
- aku vastupidavus ja laadimiskiirus
- ekraan
- UI
Ei meeldinud:
- Sõrmejäljelugeja. Töötas vaid siis, kui näpp just scannitud ja ekraan puhas. Igapäevane reaalsus oli, aga et pidi mitu korda scannima või tegi seda pikalt. Ka näotuvastus ei ole alternatiiv, kuna esikaamera on mehaaniline ja kogu protsess ka suhteliselt aeglane.
- Kaamera. Pildid tugevalt moonutatud, eriti inimesi pildistades. Loodust pildistada lainurgaga samas oli OK.
zaitz
05.02.2021 11:17:10
| Kuskil kirjutas, et viimase FW updatega addressiti FP readeri probleemi. Vaadates GSMArena videoreviewd, siis seal tüüp avab ekraani sõrmega x arv kordi ja töötab veatult. Tellisin ära, näis mis saab.
34 |
mikulaine
05.02.2021 17:13:40
Olen ka kuu aega omanik olnud. Hea telefon. Minu arust kaamera on aus ja viisakas, muidugi ma tulin ka mingi 5a vana Sony pealt.
Sõrmejäljelugeja, jah, sellega vahest ei saa hakkama. Muid häirivaid asju nagu polekski.
Kas kellelgi veel ei ole sellist asja, et näiteks mängides või telefoni kasutades mõnikord sõrmejäljealal puutetundlikus ei tööta? Või on mul kuivad käed?
zaitz
10.02.2021 12:20:14
Sain telefoni kätte ja muidugi updatesin esimese asjana viimase FW peale. Ehk siis MIUI12, ma pole nii toorest Official ROM'i veel näinud. Hetkel ajab kõige rohkem närvi kamm notificationitega, Telegram, Messenger. Tahan nii, et üleval Notification areas oleks vaikus aga chat head tuleks, no ei saa. Messengeri chat head on kujunduseta ruut, mida vahel saab ekraanil ringi liigutada, vahel mitte... Mitmeid pisiasju veel. Miks iga asja jaoks peab olema miljon settingut, tahad midagi sättida, 5min otsimist kuni lõpuks pead googeldama . Peab vist downgradema MIUI11 peale...
Ja see kaal, see ikka vajab harjumist
34 |
