tteam
07.10.2020 13:57:07
Remake ikkagi uus mäng. Soovitan võtta remake'i.
Kui nüüd võrrelda mõne muu uuema mänguga, siis ainukesena annab tunda see, et story pole nii polished kui näiteks Mafia 2 puhul (Mitte, et story pole hea, lihtsalt annab vanus tunda).
Tegin mängu 10h'ga läbi Classic raskusastmega. Väga fun ja paeluv oli. Vana versioon vaevalt, et seda enam on
28 |
Submob
08.10.2020 07:30:32
Esimene update:
New Content
Custom HUD Options – Use these new options to customize the in-game HUD if, for example, you want to make your explorations of Lost Heaven feel less guided or take a particularly pleasing screenshot:
- Switch the in-world main objective marker on/off.
- Switch mini-map enemy markers on/off on all difficulty settings. (Previously enemy markers were always on outside of Classic Mode.)
- Switch navigation features like turn-by-turn instructions and the mini-map GPS on/off.
- Enable the new Minimal HUD mode to hide HUD elements including the mini-map, the speedometer, and objective text while playing.
Noir Mode – Enable Noir Mode to enjoy Mafia: Definitive Edition‘s gameplay and cinematics with a vintage black-and-white look. Noir Mode can be toggled on and off via the game options screen.
Free Ride Content – Now that you’re off to the races and enjoying Free Ride mode, depending on which vehicle you’re driving and where you’re driving it, you might find one of a couple new gameplay features that we’ve added to the mode. We’ll leave the specifics for you to discover and hope you fare well in Lost Heaven.
Bug Fixes
- Addressed a reported issue that sometimes prevented the correct vehicles from unlocking in the player garage upon completion of the optional Lucas Bertone missions. Players who have completed these missions should find the correct vehicles in their garage the next time they start the game.
- Addressed a reported concern that a special assassination animation sometimes wasn’t triggering correctly during the mission “The Saint and The Sinner.”
- Addressed a reported concern that certain cinematics would occasionally show a black screen.
_________________ Disain |
| Kommentaarid: 47 loe/lisa |
44 |
X-Tream99
11.10.2020 10:09:34
| Submob kirjutas: |
Esimene update:
New Content
Bug Fixes
- Addressed a reported concern that certain cinematics would occasionally show a black screen. |
Tü** jumala saamatu on see kuradima 2K. Nad ei suuda esimese updatega parandada ära kõige olulisemat viga, mis mängus üldse on - menüüst on puudu "Restart chapter" funktsioon. Joptvõi... ma ei ole saanud kaks nädalat seda mängu mängida, sest Omerta missiooni alguses, pärast cut-scene, on mul mäng kinni kiilunud, maailm minu ümber liigub, aga karakter ei liigu ning on liikumatu ja midagi teha ei saa. Latest checkpoint ka ei toimi, sest ta laeb mind samasse kohta, kus ma olen juba kinni... Kuna ma ei saa end ka ära tappa, siis pole mul võimalik ka seda missiooni restartida, sest need plebid ei suuda sellist funktsiooni lisada. Loodetavasti on jaanipäevaks asi korras, siis proovin uuesti. Si**.
PS! Kui kellelgi juhtub olema Save game, kus on Omerta missiooni algus, siis oleksin faili eest tänulik. Tundub olevat hetkel ainus fix sellele jamale.
| Kommentaarid: 6 loe/lisa |
Dj-E
Aeg Maha 2a
11.10.2020 14:37:34
| X-Tream99 kirjutas: |
PS! Kui kellelgi juhtub olema Save game, kus on Omerta missiooni algus, siis oleksin faili eest tänulik. Tundub olevat hetkel ainus fix sellele jamale. |
Oled sa failide kontrollimise ära teinud steamis? Või sikuta mäng uuesti siis.
Endal oli küll 0 probleemi.
| Kommentaarid: 22 loe/lisa |
21 |
X-Tream99
11.10.2020 16:03:28
| Dj-E kirjutas: |
Endal oli küll 0 probleemi.  |
1. Ma olen cache ära puhastanud steamis.
2. Ma olen mängule reinstalli teinud.
3. Ma hakkasin kogu lugu otsast peale mängima, aga sinna samasse kohta jõudes jooksin vastu sama probleemi.
Seega ma olen teinud absoluutselt kõik, mis võimalik, aga see pa*k on ikka sama.
11.10.2020 17:55:39
Ma olen hetkel, kaks korda selle läbi teinud, null probleemi...
| Kommentaarid: 229 loe/lisa |
194 |
libe
kvaliteetne mees
11.10.2020 18:07:20
| Dj-E kirjutas: |
Seega ma olen teinud absoluutselt kõik, mis võimalik, aga see pa*k on ikka sama. |
restart chapter sind ju ei aitaks sel juhul?
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Vael
11.10.2020 18:09:43
| Etz kirjutas: |
Ma olen hetkel, kaks korda selle läbi teinud, null probleemi...  |
Ma mängisin orikat ja polnud ka ühtki probleemi, aga kuidas see kasutajat Xtreme aitab?
Isegi kui sama gpu ja draivud on, võib mõni muu kombo mängu lolliks ajada...
Siiski mõnikord aitab ram, gpu, prose stock sead3sse lükkamine...
Microsoft distributable c+++ reinstall ka harva...
| Kommentaarid: 17 loe/lisa |
16 |
Muhekas
12.10.2020 17:10:10
Natuke teemaväline, aga samas ka osaliselt mitte. Mis vahe on remake, remastered ja definite versioonidel?
_________________ Olenemata olukorrast, jää iseendaks ja samas lugupidavaks. |
| Kommentaarid: 20 loe/lisa |
17 |
Submob
12.10.2020 17:36:59
Remake - mäng on uuesti ülesse ehitatud nullist. Üldiselt kasutatud kaasaegset mootorit, graafikat, helisid jne
Remaster - mängu on natuke mukitud ilusamaks. Kõrgema kvaliteediga tekstuurid, parem reso tugi jne. Vahel uuendatakse ka 3d, 2d mudeleid.
Definitive Edition - põhimõtteliselt lihtsalt selline uhke termin. Selle all tavaliselt mõeldakse remastered või remake veriooni kus on ka mängu kõik lisapakid.
Mafia puhul siis jaguneks:
Kõik on nad nimetatud Definitive editioniks, sest need on uuendatud koos välja tulnud lisapakkide ja muu mudruga.
Mafia: Definitive Edition - remake. Täiesti nullist tehtud uus mäng. Kasutab ainult originaali sisu, karaktereid ja olustikku.
Mafia II: Definitive Edition - remaster. Üritatud natuke ilusamaks teha aga tulemus on kehva, näeb üsnagi jube välja ja jookseb kõvasti kehvemalt kui tavaline. Originaal tegelt näeb vägagi viisakas välja.
Mafia III: Definitive Edition - remaster. Põhimõtteliselt pole suuresti erinevusi näha. Lihtsalt kõik lisapakid on kaasas.
44 |
softis
13.10.2020 08:33:52
Remake - uue story, remaster - uued visuaalid.
| Kommentaarid: 21 loe/lisa |
21 |
Dj-E
Aeg Maha 2a
13.10.2020 09:15:46
| softis kirjutas: |
| Remake - uue story, remaster - uued visuaalid. |
Remake seda küll ei tähenda mida sina pakud.
Remake on ikka suurem visuaalne, tehniline ümbertegemine aga story jääb ikka samaks.
21 |
softis
13.10.2020 09:18:20
| Dj-E kirjutas: |
| softis kirjutas: |
Remake on ikka suurem visuaalne, tehniline ümbertegemine aga story jääb ikka samaks. |
Visuaalne ja tehniline uuendamine ongi remaster e üldise kvaliteedi parandamine.
Remake'i osas parandan ennast - algse stoori põhjal tehtud aga siiski paljuski erineva sisuga mäng. Modern Warfare on hea näide remakest.
21 |
rewer
13.10.2020 12:13:53
Remaster- parendatud pilt/heli või muud detailid aga mäng(story) on sama.
Remake- nullist tehtud uus mäng sama looga, storys väiksemaid erinevusi võib kindlasti olla aga üldplaanis sama.
Reboot- sama/sarnase maailma ja/või tegelastega aga teise storyga.
Modern Warfare on reboot mitte remake.
Reaalselt pole need terminid kuskil 100% täpsusega määratud ja mäng võib olla segu mitmest vms.
| Kommentaarid: 1303 loe/lisa |
919 |
lauri23
| Kommentaarid: 29 loe/lisa |
29 |
Dj-E
Aeg Maha 2a
13.10.2020 21:55:14
| rewer kirjutas: |
Reaalselt pole need terminid kuskil 100% täpsusega määratud ja mäng võib olla segu mitmest vms. |
Remake ei tähenda nullist tehtud mängu. Lihtsalt vahetatakse tekstuurid paremate vastu ja parandatakse tehnilisi aspekte jms. Nullist ei saa midagi alustada kui see eksisteerib juba 100%-sel kujul. Kindlasti võetakse vanast mingi alus baas ette mille peal alustatakse remake tegemist.
21 |
tteam
14.10.2020 00:17:30
| Dj-E, sa kirjeldad pigem remasterit. Mafia 1 puhul ikka võib öelda, et praktiliselt nullist üles ehitatud asi.
28 |
RustyZ
14.10.2020 09:49:59
Mafia 1 Definitive Editioni puhul võeti uuem mootor ja tehti mäng sinna peale nullist üles (pidades silma cutscenesid, missioone, vestlusi jms).
Dj-E, sa ei saaks elusees sellist tulemust kus tekstuuride vahetusega vana mootori peal saab sellise pela
_________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled) |
| Kommentaarid: 16 loe/lisa |
angel
16.10.2020 00:54:35
jeerum mida nad selle mänguga teinud on... seda peab võtma kui eraldi seisvat mängu mitte kui 1 osa uuesti loomist
Kes kuramus Sam'i nina kinni hoiab kui ta rääkida üritab
vanaga võrreldes:
kütusepaak ei tundu enam lekkivat kui kuuli saab
rattaid ei saa alt lasta
inimesed ei pilguta silmi (istus autos ja jõllitas vaid tuima pilguga )
kui kõmmutamine hakkab ei kerita enam auto akend alla, et tulistada
kui motelli missioonis AI autol rehvid labi torgata sõidab ikka täie rauaga edasi (originaal mängus AI jäi katkise auto tõttu seisma)
politsei ei sõida reaalselt kohale kui pahandust teed + tunduks et kui politsei kõrvaldada siis ei ole enam trahv kehtetu tingimusel, et keegi ei näe (Mafia 1 sai sedasi kenasti toimetada)
graafiliselt arenenud mäng aga originaal loomingule ja detailsusele eriti järgi ei ole tahetud jõuda.
157 |
Kustav
16.10.2020 05:30:27
angel, Proovisin samuti kütust otsa sõita, täitsa ära ei surnud, auto küll seiskus ja tegi koledaid hääli ja tõrkus.. aga lõputult.
_________________ Kogun protsessoreid  |
160 |
ECMadis
16.10.2020 19:20:25
Mulle miskipärast meeldis see mäng.
Missioonid on kõik erinevad ning huvitavad - vähemalt selline tunne jääb. Pole nagu Gearsis, et käid lähed ühest kohast teise ja teed täpselt ühte samat mõtetut zombi killimist, seda muidugi seina tagant koguaeg.
Tulistamine on imelik alguses aga kuidagi reaalsem. Vastane sureb kiiresti ja ise kah kui vigu teha.
Üldine heli ja muusika meeldib. Graafikast savi.
Mängu pikkus minujaoks norm, selline paar päeva. AC-s teed mingi 50 tundi ühte ja sama asja, igav ju.
Üldiselt on tunda, et varem tehti paremaid mänge aga on ka muidugi teatud asjad mis olid veidi iganenud.
| Kommentaarid: 10 loe/lisa |
10 |
rastaman
16.10.2020 19:51:49
nagu Scorsese filmis oleks sees tegi just ralli missiooni ära, et kuidas sellega probleeme saab olla, poole ringiga esimene
Dj-E
Aeg Maha 2a
16.10.2020 21:45:18
| rastaman kirjutas: |
nagu Scorsese filmis oleks sees tegi just ralli missiooni ära, et kuidas sellega probleeme saab olla, poole ringiga esimene  |
Kõik oleneb mis raskusastmega mängid. Mediumiga oli väga lihtne aga räägitakse, et Classicuga on raske.
21 |
lauri23
29 |
tteam
17.10.2020 18:11:00
Ma tegin võidusõidu ja üldse kogu mängu Classic raskusastmel. Suht sama case, et poole ringiga esimeseks ja siis pika puuga võit
28 |
