uus teema   vasta Tarkvara »  Arvutimängude foorum »  Mafia märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... , 28, 29, 30  järgmine
tteam
tteam
sõnum 07.10.2020 13:57:07 vasta tsitaadiga
Remake ikkagi uus mäng. Soovitan võtta remake'i.
Kui nüüd võrrelda mõne muu uuema mänguga, siis ainukesena annab tunda see, et story pole nii polished kui näiteks Mafia 2 puhul (Mitte, et story pole hea, lihtsalt annab vanus tunda).
Tegin mängu 10h'ga läbi Classic raskusastmega. Väga fun ja paeluv oli. Vana versioon vaevalt, et seda enam on icon_smile.gif
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 28
Submob
Submob
sõnum 08.10.2020 07:30:32 vasta tsitaadiga
Esimene update:
New Content
Custom HUD Options – Use these new options to customize the in-game HUD if, for example, you want to make your explorations of Lost Heaven feel less guided or take a particularly pleasing screenshot:
- Switch the in-world main objective marker on/off.
- Switch mini-map enemy markers on/off on all difficulty settings. (Previously enemy markers were always on outside of Classic Mode.)
- Switch navigation features like turn-by-turn instructions and the mini-map GPS on/off.
- Enable the new Minimal HUD mode to hide HUD elements including the mini-map, the speedometer, and objective text while playing.
Noir Mode – Enable Noir Mode to enjoy Mafia: Definitive Edition‘s gameplay and cinematics with a vintage black-and-white look. Noir Mode can be toggled on and off via the game options screen.
Free Ride Content – Now that you’re off to the races and enjoying Free Ride mode, depending on which vehicle you’re driving and where you’re driving it, you might find one of a couple new gameplay features that we’ve added to the mode. We’ll leave the specifics for you to discover and hope you fare well in Lost Heaven.
Bug Fixes
- Addressed a reported issue that sometimes prevented the correct vehicles from unlocking in the player garage upon completion of the optional Lucas Bertone missions. Players who have completed these missions should find the correct vehicles in their garage the next time they start the game.
- Addressed a reported concern that a special assassination animation sometimes wasn’t triggering correctly during the mission “The Saint and The Sinner.”
- Addressed a reported concern that certain cinematics would occasionally show a black screen.
Disain
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 44
X-Tream99
sõnum 11.10.2020 10:09:34 vasta tsitaadiga
Submob kirjutas:
Esimene update:
New Content
Bug Fixes
Tü** jumala saamatu on see kuradima 2K. Nad ei suuda esimese updatega parandada ära kõige olulisemat viga, mis mängus üldse on - menüüst on puudu "Restart chapter" funktsioon. Joptvõi... ma ei ole saanud kaks nädalat seda mängu mängida, sest Omerta missiooni alguses, pärast cut-scene, on mul mäng kinni kiilunud, maailm minu ümber liigub, aga karakter ei liigu ning on liikumatu ja midagi teha ei saa. Latest checkpoint ka ei toimi, sest ta laeb mind samasse kohta, kus ma olen juba kinni... Kuna ma ei saa end ka ära tappa, siis pole mul võimalik ka seda missiooni restartida, sest need plebid ei suuda sellist funktsiooni lisada. Loodetavasti on jaanipäevaks asi korras, siis proovin uuesti. Si**.
PS! Kui kellelgi juhtub olema Save game, kus on Omerta missiooni algus, siis oleksin faili eest tänulik. Tundub olevat hetkel ainus fix sellele jamale.
Dj-E
Aeg Maha 2a
Dj-E
sõnum 11.10.2020 14:37:34 vasta tsitaadiga
X-Tream99 kirjutas:
Oled sa failide kontrollimise ära teinud steamis? Või sikuta mäng uuesti siis.
X-Tream99
sõnum 11.10.2020 16:03:28 vasta tsitaadiga
Dj-E kirjutas:
X-Tream99 kirjutas:
1. Ma olen cache ära puhastanud steamis.
2. Ma olen mängule reinstalli teinud.
3. Ma hakkasin kogu lugu otsast peale mängima, aga sinna samasse kohta jõudes jooksin vastu sama probleemi.
Seega ma olen teinud absoluutselt kõik, mis võimalik, aga see pa*k on ikka sama.
sõnum 11.10.2020 17:55:39 vasta tsitaadiga
Ma olen hetkel, kaks korda selle läbi teinud, null probleemi... icon_rolleyes.gif
Vaata kasutaja äripakkumisi
M: NVMe SSD Samsung 970 Evo Plus 500GB 4464
M: 8TB HDD WD Red Plus 2110
Kommentaarid: 234 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 196
libe
kvaliteetne mees
libe
sõnum 11.10.2020 18:07:20 vasta tsitaadiga
X-Tream99 kirjutas:
Dj-E kirjutas:
X-Tream99 kirjutas:
restart chapter sind ju ei aitaks sel juhul?
Vael
sõnum 11.10.2020 18:09:43 vasta tsitaadiga
Etz kirjutas:
Ma mängisin orikat ja polnud ka ühtki probleemi, aga kuidas see kasutajat Xtreme aitab? monkey.gif
Isegi kui sama gpu ja draivud on, võib mõni muu kombo mängu lolliks ajada...
Siiski mõnikord aitab ram, gpu, prose stock sead3sse lükkamine...
Microsoft distributable c+++ reinstall ka harva...
Muhekas
Muhekas
sõnum 12.10.2020 17:10:10 vasta tsitaadiga
Natuke teemaväline, aga samas ka osaliselt mitte. Mis vahe on remake, remastered ja definite versioonidel?
Submob
Submob
sõnum 12.10.2020 17:36:59 vasta tsitaadiga
Remake - mäng on uuesti ülesse ehitatud nullist. Üldiselt kasutatud kaasaegset mootorit, graafikat, helisid jne
Remaster - mängu on natuke mukitud ilusamaks. Kõrgema kvaliteediga tekstuurid, parem reso tugi jne. Vahel uuendatakse ka 3d, 2d mudeleid.
Definitive Edition - põhimõtteliselt lihtsalt selline uhke termin. Selle all tavaliselt mõeldakse remastered või remake veriooni kus on ka mängu kõik lisapakid.
Mafia puhul siis jaguneks:
Kõik on nad nimetatud Definitive editioniks, sest need on uuendatud koos välja tulnud lisapakkide ja muu mudruga.
Mafia: Definitive Edition - remake. Täiesti nullist tehtud uus mäng. Kasutab ainult originaali sisu, karaktereid ja olustikku.
Mafia II: Definitive Edition - remaster. Üritatud natuke ilusamaks teha aga tulemus on kehva, näeb üsnagi jube välja ja jookseb kõvasti kehvemalt kui tavaline. Originaal tegelt näeb vägagi viisakas välja.
Mafia III: Definitive Edition - remaster. Põhimõtteliselt pole suuresti erinevusi näha. Lihtsalt kõik lisapakid on kaasas.
Disain
softis
softis
sõnum 13.10.2020 08:33:52 vasta tsitaadiga
Remake - uue story, remaster - uued visuaalid.
Dj-E
Aeg Maha 2a
Dj-E
sõnum 13.10.2020 09:15:46 vasta tsitaadiga
softis kirjutas:
Remake seda küll ei tähenda mida sina pakud.
Remake on ikka suurem visuaalne, tehniline ümbertegemine aga story jääb ikka samaks.
softis
softis
sõnum 13.10.2020 09:18:20 vasta tsitaadiga
Dj-E kirjutas:
softis kirjutas:
Visuaalne ja tehniline uuendamine ongi remaster e üldise kvaliteedi parandamine.
Remake'i osas parandan ennast - algse stoori põhjal tehtud aga siiski paljuski erineva sisuga mäng. Modern Warfare on hea näide remakest.
rewer
rewer
sõnum 13.10.2020 12:13:53 vasta tsitaadiga
Remaster- parendatud pilt/heli või muud detailid aga mäng(story) on sama.
Remake- nullist tehtud uus mäng sama looga, storys väiksemaid erinevusi võib kindlasti olla aga üldplaanis sama.
Reboot- sama/sarnase maailma ja/või tegelastega aga teise storyga.
Modern Warfare on reboot mitte remake.
Reaalselt pole need terminid kuskil 100% täpsusega määratud ja mäng võib olla segu mitmest vms.
Kommentaarid: 1306 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 920
lauri23
lauri23
sõnum 13.10.2020 19:50:42 vasta tsitaadiga
Ega tegelt vahet ei ole ju kuidas ingliskeeles seda nimetada. Hea asi on igatahes, võtsin ligi. 18a tagused missioonid kaasaaegse graafikaga oma aja lemmik mängus tekitab paraja nostalgia tunde.
Tasuta 50$pokkeri kontole. Registreeri, õpi strateegiat ja vasta küsimustele. Saad valitud pokkerituppa 50$+veel boonust, kui mängida oskad. Isiklikult saanud 285$ sealt.
Dj-E
Aeg Maha 2a
Dj-E
sõnum 13.10.2020 21:55:14 vasta tsitaadiga
rewer kirjutas:
Remake ei tähenda nullist tehtud mängu. Lihtsalt vahetatakse tekstuurid paremate vastu ja parandatakse tehnilisi aspekte jms. Nullist ei saa midagi alustada kui see eksisteerib juba 100%-sel kujul. Kindlasti võetakse vanast mingi alus baas ette mille peal alustatakse remake tegemist.
tteam
tteam
sõnum 14.10.2020 00:17:30 vasta tsitaadiga
Dj-E, sa kirjeldad pigem remasterit. Mafia 1 puhul ikka võib öelda, et praktiliselt nullist üles ehitatud asi.
RustyZ
RustyZ
sõnum 14.10.2020 09:49:59 vasta tsitaadiga
Mafia 1 Definitive Editioni puhul võeti uuem mootor ja tehti mäng sinna peale nullist üles (pidades silma cutscenesid, missioone, vestlusi jms).
Dj-E, sa ei saaks elusees sellist tulemust kus tekstuuride vahetusega vana mootori peal saab sellise pela icon_lol.gif
angel
angel
sõnum 16.10.2020 00:54:35 vasta tsitaadiga
jeerum mida nad selle mänguga teinud on... seda peab võtma kui eraldi seisvat mängu mitte kui 1 osa uuesti loomist beer_yum.gif
vanaga võrreldes:
kütusepaak ei tundu enam lekkivat kui kuuli saab
rattaid ei saa alt lasta
inimesed ei pilguta silmi (istus autos ja jõllitas vaid tuima pilguga icon_biggrin.gif )
kui kõmmutamine hakkab ei kerita enam auto akend alla, et tulistada
kui motelli missioonis AI autol rehvid labi torgata sõidab ikka täie rauaga edasi (originaal mängus AI jäi katkise auto tõttu seisma)
politsei ei sõida reaalselt kohale kui pahandust teed + tunduks et kui politsei kõrvaldada siis ei ole enam trahv kehtetu tingimusel, et keegi ei näe (Mafia 1 sai sedasi kenasti toimetada)
graafiliselt arenenud mäng aga originaal loomingule ja detailsusele eriti järgi ei ole tahetud jõuda. thumbs_up.gif
Kustav
Kustav
sõnum 16.10.2020 05:30:27 vasta tsitaadiga
angel, Proovisin samuti kütust otsa sõita, täitsa ära ei surnud, auto küll seiskus ja tegi koledaid hääli ja tõrkus.. aga lõputult.
Kommentaarid: 175 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 160
ECMadis
ECMadis
sõnum 16.10.2020 19:20:25 vasta tsitaadiga
Mulle miskipärast meeldis see mäng.
Missioonid on kõik erinevad ning huvitavad - vähemalt selline tunne jääb. Pole nagu Gearsis, et käid lähed ühest kohast teise ja teed täpselt ühte samat mõtetut zombi killimist, seda muidugi seina tagant koguaeg.
Tulistamine on imelik alguses aga kuidagi reaalsem. Vastane sureb kiiresti ja ise kah kui vigu teha.
Üldine heli ja muusika meeldib. Graafikast savi.
Mängu pikkus minujaoks norm, selline paar päeva. AC-s teed mingi 50 tundi ühte ja sama asja, igav ju.
Üldiselt on tunda, et varem tehti paremaid mänge aga on ka muidugi teatud asjad mis olid veidi iganenud.
rastaman
rastaman
sõnum 16.10.2020 19:51:49 vasta tsitaadiga
nagu Scorsese filmis oleks sees thumbs_up.gif tegi just ralli missiooni ära, et kuidas sellega probleeme saab olla, poole ringiga esimene icon_biggrin.gif
Dj-E
Aeg Maha 2a
Dj-E
sõnum 16.10.2020 21:45:18 vasta tsitaadiga
rastaman kirjutas:
Kõik oleneb mis raskusastmega mängid. Mediumiga oli väga lihtne aga räägitakse, et Classicuga on raske.
lauri23
lauri23
sõnum 17.10.2020 12:58:05 vasta tsitaadiga
Ma andsin Classicuga alla peale viiendat katset icon_biggrin.gif , mediumiga sain poole ringiga esimeseks ja tuli võit ära. Mäng on väärt oma hinda.
tteam
tteam
sõnum 17.10.2020 18:11:00 vasta tsitaadiga
Ma tegin võidusõidu ja üldse kogu mängu Classic raskusastmel. Suht sama case, et poole ringiga esimeseks ja siis pika puuga võit icon_biggrin.gif
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Mafia mine lehele eelmine  1, 2, 3 ... , 28, 29, 30  järgmine
