mine lehele eelmine  1, 2, 3 ... 375, 376, 377 ... 636, 637, 638  järgmine
sõnum 06.07.2020 09:40:12 vasta tsitaadiga
AMD Ryzen 7 4700G Flagship Renoir 8 Core Desktop APU Benchmarked, Matches The Ryzen 7 3800X 95W CPU
https://wccftech.com/amd-ryzen-7-4700g-flagship-renoir-8-core-desktop-apu-benchmarked-matches-95w-ryzen-7-3800x/
Viilutaja
Viilutaja
sõnum 06.07.2020 20:32:16 vasta tsitaadiga
Link
AMD Ryzen 4600H + 5600M vs Ryzen 4800H + 5600M
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11768241#11768241
rene p
sõnum 07.07.2020 15:30:26 vasta tsitaadiga
https://wccftech.com/amd-ryzen-4000-renoir-desktop-apu-21st-july-official-launch-lineup-full-specs-detailed/
AMD Ryzen 4000 Renoir Desktop APUs Launching on 21st July
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
sõnum 07.07.2020 15:49:55 vasta tsitaadiga
Saab huvitav olema. Iseasi mis hinnad tulevad. Kui jõudlus on 3800X ja latentsus on madalam + iGPU kah kaasas siis kahtlen, et 4750G alla 300€ maksma hakkab. Muidugi oleks hea aga kes siis ostaks 3800X enam 350+ eest kui 4750G saab parema jõudluse ja iGPU kaasa? Jah cache ja baaskell on madalam.
EDIT:
Ühtlasi potentsiaalselt halb uudis:
AMD is prioritizing its APUs to System Integrator and the OEM market. The reason AMD wants to push APUs to the SI market is because they can affect the sales of Ryzen 3000 Matisse APUs which offer higher margins compared to the Ryzen 4000 series APUs. We have seen retailers list down several PRO variants and about that, we also confirmed that AMD Ryzen PRO 4000 series has replaced the standard Ryzen 4000 Renoir SKUs. Both PRO & non-PRO variants are virtually the same but AMD has decided to go with PRO series branding officially.
viimati muutis Tomorrow 07.07.2020 15:54:26, muudetud 1 kord
anubis
anubis
sõnum 07.07.2020 15:53:59 vasta tsitaadiga
3800x on €309 ja 3700x on €285, äkki saavad EOL.
sõnum 07.07.2020 16:10:32 vasta tsitaadiga
XT ülevaated:
https://www.anandtech.com/show/15897/new-amd-ryzen-3000xt-processors-available-today
https://www.techpowerup.com/review/amd-ryzen-5-3600xt/
https://www.techpowerup.com/review/amd-ryzen-5-3800xt/
https://www.techpowerup.com/review/amd-ryzen-9-3900xt/
Link
Link
Viilutaja
Viilutaja
sõnum 07.07.2020 16:32:16 vasta tsitaadiga
Link
Pointless prosed. Oleks siis praeguste X prosede hindadega.
Natuke positiivsem ülevaade @3600XT'st.
4.6Ghz @1.36v! All-core.
Link
viimati muutis Viilutaja 07.07.2020 16:38:18, muudetud 1 kord
sõnum 07.07.2020 16:38:08 vasta tsitaadiga
Viilutaja, Üsna pointless jah. Oleks siis tulnud nt 4.6Ghz allcore sagedusega 3800XT vms.
Hetkel pole veel näinud kas Infinity Fabric läheb üle 1900Mhz või mitte ja kuidas latentsus on. Ei usu erilist edasiminekut. 4750G pidi olema võimeline tegema 2100Mhz IF mis on päris hea.
One
sõnum 07.07.2020 16:38:43 vasta tsitaadiga
Imelik, et suuremast klokist reaalselt mingit kasu ei ole.
Viilutaja
Viilutaja
sõnum 07.07.2020 16:50:45 vasta tsitaadiga
Winterwind kirjutas:
Sünteetilistes testides ja renderdamises on, kuid jah mängdes 0 % kasu.
sõnum 07.07.2020 17:21:45 vasta tsitaadiga
Viilutaja kirjutas:
5Ghz 3800X test näitas, et pudelikael on kuskil mujal. potentsiaalselt IF klokis.
Viilutaja
Viilutaja
sõnum 07.07.2020 19:07:41 vasta tsitaadiga
Tomorrow kirjutas:
Viilutaja kirjutas:
Ja mitte ühises vahemälus. Sellepärast need uued 4X00G'd APU'd ongi parimad Zen2'd mängimiseks.
Bssldr
sõnum 07.07.2020 19:47:27 vasta tsitaadiga
Tomorrow kirjutas:
Ulme. Minu 9900KS teeb olenevalt BIOSi versioonist Cinebench R20 skoori vahemikus 5130-5200.
Kolin arvatavasti AMD 4000 seeria desktop CPU peale, kui need välja tulevad. Aga loodaks, et flagship tuleb kohe alguses, mitte nagu oli 3950X'ga. AMD teeb uusi CPU mudeleid nii kiiresti, et mingi kindla seeria flagshipi tahaks kätte saada võimalikult vara.
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 8
bush
bush
sõnum 08.07.2020 10:29:54 vasta tsitaadiga
anubis kirjutas:
Kust need hinnad võetud on? HV järgi on pigem 3800x 400€ ja 3700x 315€
>50$ pokkeri bankroll
anubis
anubis
sõnum 08.07.2020 10:32:05 vasta tsitaadiga
bush kirjutas:
anubis kirjutas:
Geizhals, Saksamaalt/EUst saab kiirelt kätte asja.Neid mis meil kohapeal olemas pole saab sama kiirelt (mõnel juhul isegi kiiremini) kui Eesti poest tellides.
sõnum 08.07.2020 20:44:06 vasta tsitaadiga
AMD Ryzen Threadripper PRO 3995WX Processor Pictured: 8-channel DDR4
https://www.techpowerup.com/269557/amd-ryzen-threadripper-pro-3995wx-processor-pictured-8-channel-ddr4
AMD Ryzen 7 4700G Flagship Renoir APU Overclocked To 4.75 GHz Across All 8 Zen 2 Cores on Standard Cooling
https://wccftech.com/amd-ryzen-7-4700g-8-core-renoir-apu-overclocked-4-75-GHz-standard-cooling/
Paistab tulevat midagi erilist thumbs_up.gif . Ilmselt kiireim Zen2 kivi üldse. Oleks väga huvitav näha tulemusi mängudes. Paar nädalat veel aega ülevaadeteni.
Lisaks kui see nii hea tuleb, siis võib hakata ohustama praegu turul olevaid X ja XT mudelid oma hinna/perf suhtega.
Lisaks äärmiselt kehv saadavus kui kõik kukuvad neid krabama.
Ainsad miinused on väiksem L3 cache hulk ja vist ka PCIe 4.0 puudumine (mis desktopil on kummaline).
IceUul
Sinu Ema
IceUul
sõnum 08.07.2020 23:12:24 vasta tsitaadiga
3800XT ja 3900XT jõudsid ka HV-sse müüki.
Hinnad tunduvad ebamõistlikult kõrged.
3900XT maksab 600€ ja 3800XT 450€
Võrdluseks 3900X ja 3800X maksavad
vastavalt 450 ja 335€
Hinnad on ümardatult!
Kommentaarid: 218 loe/lisa Kasutajad arvavad:  :: 1 :: 4 :: 187
sõnum 08.07.2020 23:17:00 vasta tsitaadiga
IceUul, Need hinnad on enamvähem X mudelite eelmise aasta omad. Need olid kõrged eelmine aasta ja on kõrged selle aasta XT mudelitel.
Arvestades seda, et XT oluliselt üle ei saa kiirendada (isegi mitte IF klokki) ja vanemate mudelite hindu, siis kahjuks üsna mõttetud.
Parem oodata ära 4000 APU seeria kahe nädala pärast või Zen3 Q3-Q4.
Anna tooli
sõnum 09.07.2020 07:20:32 vasta tsitaadiga
täpsustuseks, et HV ise ei müü midagi
ja lisasin just ka 3900XT box versiooni
https://www.hinnavaatlus.ee/products/Arvutikomponendid/Protsessorid/f8be5ed55ba3974583a875f68f991379/?sort=-add_date
pots4t4j4
sõnum 09.07.2020 07:45:46 vasta tsitaadiga
selle hinnaga on tegu täiesti pointless prosedega, amd hakkab intelit tegema...
sõnum 09.07.2020 09:02:17 vasta tsitaadiga
pots4t4j4, Vaikselt hiilib sinnapoole jah. Minu kommentaarid sellele teises foorumis Threadripperi näol:
It was a major dissapointment that they broke TR1000 and TR2000 compatibility with the new socket yet somehow managed to retain it on AM4 across generations. And if this CPU is real then again a new socket for 8 channel memory configuration. sWRX80 was also rumored before TR3000 launch. Also problably a new socket after 4000 series TR comes out likely next year.
AMD specificly stated that the TR3000 socket change was to enable longer support but that's blatantly false if sTR40 receives only two generations of CPU's like TR4 socket did.
When Threadripper first came out it was great but AMD broke compatibility and significantly upped the prices with TR3000 once they saw that Intel was unable to complete (in terms of performance, energy efficiency and even availability).
This is why we need competition. I have no doubt that AMD would do the same on desktop with AM5 if Intel is unable to compete. Raise prices and limit AM5 to two generations of CPU's.
That's not the future im looking forward to. And as much as i love my 3800X and AM4 and as much as i dislike Intel - AMD is not above criticism for me.
https://www.reddit.com/r/Amd/comments/dsy4kw/performance_preview_3rd_gen_amd_ryzen/
1. We wanted to drive maximum performance for the 3rd Gen AMD Ryzen Threadripper processors and sTRX4 helps us do exactly that. The 3rd Gen Threadripper will have 88 total PCIe Gen 4 lanes with 72 usable (CPU+motherboard). The net of total versus usable is because we’re also increasing the CPU<->chipset link from 4x Gen4 to 8x Gen4—quadruple the bandwidth vs. 2nd Gen TR. Extra data pins between the chipset and CPU make this possible, so you’ll be able to hang more I/O off the motherboard at full performance.
2. The socket change also sets us up nicely for future development and scalability of the Threadripper platform, both on a near- and long-term basis.
Yet despite this EPYC CPU's retained compatiblity without a socket change while still introducing PCIe 4.0
So AMD's arguments are pretty hollow. And now with sWRX80 platform and DDR5 based platform coming in 2022 i fail to see where this long term support and scalability exists when users can expect barely ~2 years of support with sTRX40 still needing a replacement to run WRX CPU's. AMD should have enabled TR4/X399 compatibility even if it meant losing some features like wider CPU-Chipset uplink and then gone all out with unified DDR5 based 8 channel system in 2022. Instead we got 2 intermediate sockets that are not compatible with each other nor backwards or forwards. Great job AMD...
IceUul
Sinu Ema
IceUul
sõnum 09.07.2020 09:10:50 vasta tsitaadiga
pots4t4j4 kirjutas:
Täiesti nõus. 3900XT peaks nagu 10900k konkurent olema, aga hind seda nagu ei näita.
TallMan
sõnum 09.07.2020 19:15:20 vasta tsitaadiga
anubis kirjutas:
bush kirjutas:
anubis kirjutas:
Kas keegi on proovinud seal Geizhalsist firma nimele (y-number olemas) ilma käibekata ka tellida? Sellisel juhul oleks osad hinnad suht naeruväärsed seal. (Sorry kui teema on juba läbi arutatud, iga päev ei loe siin)
Anna tooli
sõnum 09.07.2020 21:13:50 vasta tsitaadiga
Geizhals on saksa HinnaVaatlus ega ise ei müü midagi
TallMan
sõnum 09.07.2020 21:26:11 vasta tsitaadiga
No sellest ma sain aru, et see sakslaste HV on, aga pidasin silmas mõne seal listitud suurema poe kaudu tellimist. Kui mõnesse Eesti firmasse helistasin, et kas Soomes olevale firmale saaks ilma käibekata, siis enamus saatsid kohe pikalt, et ei hakka sebima, aga üks ütles, et on korduvalt saatnud Soome pakiautomaati.
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 375, 376, 377 ... 636, 637, 638  järgmine
