snap3
22.06.2004 10:27:05
| Nganasan kirjutas: |
| mul kaotasid 4.6 originaalid battlefieldi iseärasused ära, kui AF kasutada ja pilt ilus |
mis AF?
66 |
volts333
22.06.2004 10:33:38
| snap3 kirjutas: |
mis AF?  |
anistropic filtering
_________________ don't click this link... |
| Kommentaarid: 81 loe/lisa |
73 |
haldz
22.06.2004 10:39:03
endal kõige uuemad driverid peal ja kõik töötab ilusti mingeid probleeme pole
Kaardiks club 3d Ati Radeon 9600 pro 400/400Mhz
| Kommentaarid: 153 loe/lisa |
138 |
snap3
22.06.2004 13:27:36
| snap3 kirjutas: |
installisin täna viimased omega driverid (cat. 4.6) ja BAttelfield Vietnam'is on nüüd mingid artifaktid, üldiselt pilt on s*tt.
endal on Sapphire 9200... |
::PILT::
66 |
SCREAMER
08.07.2004 07:08:19
Cat.4.7 väljas, ootame omegat
Resolved CATALYST Driver Issues
This section provides information on CATALYST driver issues that have been resolved in the latest release of CATALYST. These include the following:
Enabling both the CRT and DVI connectors and setting the CRT to primary no longer results in display corruption being seen on the display connected to the DVI when running 3D Labs applications and disabling the display on the DVI connector
The mouse pointer no longer flashes or becomes corrupted when setting the display mode to 1080i and launching Windows MCE
DVD playback hesitation at the beginning of a movie is no longer noticed when using the ATI DVD Player under Windows XP with an ATI 8500 ALL-IN-WONDER installed
The Windows XP operating system no longer fails to respond when a D3D application generates a floating-point exception error
The BIOS Version information is now stated correctly in the Details found in the ATI Options tab. Further, the correct DAC and ASIC information is now displayed in the Adapter tab found in the advanced setting of the display properties
The Overlay Theater Mode table has now been extended to support 1080i and 720p
Launching EVE Online under Windows XP with an ATI RADEON 8500, 9100, or 9200 series no longer results in a VPU recover error before the terms and conditions is displayed
Resolved Game Issues
This section provides information on game issues that have been resolved in the latest release of CATALYST. These include the following:
Setting the D3D option to Optimal Quality and configuring the game Freedom Fighters to 1280x1024 no longer results in display corruption being seen on the test resolution window. This issue occurred under Windows XP with an ALL-IN-WONDER 9200 installed
The water that surrounds Death Island in the game Halo: Combat evolved is now seen as blue in colour. This issues was known to occur under Windows XP with an ATI RADEON 8500 installed
Image rendering issues in the Truform room found in Serious Sam are no longer noticed when increasing the Truform level to maximum under the Advanced Rendering Option
Flashing textures in the water are no longer noticed when running Splinter Cell Pandora Tomorrow under Windows XP with an ATI RADEON X800 XT installed
Playing the game TOCA Race Driver under Windows XP no longer results in the shadows being missing under the car when the shadow quality is set to high |
driver xp/w2k:
http://www2.ati.com/drivers/wxp-w2k-8-03-040610a-016126c.exe
Control Panel:
http://www2.ati.com/drivers/control-panel-8-03-040610a-016126c.exe
| Kommentaarid: 440 loe/lisa |
392 |
margusser
08.07.2004 08:56:25
| on keegi neid 4.7 proovind?
167 |
KENWOOD
08.07.2004 10:59:46
Lehmad söövad heinamaal.Mina ka,mina ka!
99 |
siLc
08.07.2004 11:28:08
Ex vaatame kas nad parandasin seekord Splinter Cell PT vead ära või taas lubati aga sittagi ei teind. Ex ootame siis Omegaid
186 |
rogue
08.07.2004 17:23:54
sai siis proovitud neid ja 3dmark 03 skoor tuli 13128 eelmine oli midagi 12700
ah ja siis see tore asi veel temporal anti-aliasing mida varem pidi mujalt nibima
_________________ Life sucks sellega oleks nigu kõik öeldud |
| Kommentaarid: 21 loe/lisa |
19 |
amd2500
10.07.2004 19:14:25
nuh väga vinge, tõmbasin need driverid,3dmark2k01 tegi ainult selle esimese testi ära ja seal oli fps väga palju suurem kui tavaliselt. aga probla selles et rohkem teste üldse ei teegi ja morrowindis topib kah mängu kinni nagu 3dmargiski milles kala oN?
edit: kusjuures ut2004 läks pilt paremaks ja cmrd4 kah aga osasi mänge pikemalt mängida ei saa
_________________ powerd by: AMD&ATI
[b] |
volts333
11.07.2004 10:39:26
3dmarki pole küll teinud aga siiamaani on colin 4 ilusti jooksnud
73 |
question
11.07.2004 12:26:39
Kaarti ise on PowerColor ATI Radeon 9600XT VIVO 128MB driver hetkel catalyst 4.6
Jama nimelt selles et TV-OUT-i kasutades kumab tv pilt läbi (etv või ms. tekst ja kontuurid) probleem kaob kui antenni kaabli välja võtan.Ok see polegi kõige suurem mure,aga VIDEO-IN-i kasutades (kasutan nii wIN-DVDR3 kui ka ATV2000 või VDUB-i) jooksevad üle pildi vertikkalsed triibud ja pilt pole üldse normaalne).
Enne kasutasin Geforce 4200 TI VIVO kaarti ja sellega sellist probleemi polnud.
Panin arvuti korpusele lisa-maanduse aga see ka ei lahendanud probleemi.Sai vahepeal ostetud korralikud kaablid (profigold)ikka sama seis.Nüüd on mõistus otsas.Kas on driveris viga või kaart defektiga.Väljas on ka cat 4.7 kas tasuks seda proovida???
Kõik ettepanekud on teretulnud
11.07.2004 12:55:47
need läbikumamised on ikka kehvade kaartide viga...
milleks on siis eraldi VIVO kaardid ja AIW kaardid ???
ikka selle pärast, et kvaliteedi vahe on...
AIW puhul on IN pesa kaitstud karbikesega magnetlainete eest, VIVO kaardid aga pole...
ju siis sulle natuke kehv isend sattunud ja siis lööb eriti tugevalt läbi need...
see teleka jama on sellest, et sul vist odav telekas (eeldan nii, kuna kallimad ei tohiks lasta eri sisenditel endast läbi kumada)
endal muidu selline imelik asi:
mul tuleb teleka koksiaalkaabel läbi VCR'i ja sealt jätkub siis RCA'dega SCART'i
kui võtan VCR'ilt toite ära, siis muutub telekas pilt väga sahisevaks, umbes nagu oleks antenn paigast liigutatud, aga mul ju kaabelTV
see on täpselt sama asi, mis sinul TVOUT'i ja TV signaali sisenditega toimub...
| Kommentaarid: 85 loe/lisa |
libe
kvaliteetne mees
11.07.2004 15:27:08
| question kirjutas: |
Kõik ettepanekud on teretulnud |
m22ra ati multimedia center'i video in proges 2ra PAL B v6i pane country estonia vms, igatahes mulle j22b mulje, et see on selle viga
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
amd2500
11.07.2004 19:51:18
kas keegi oskab soovitada cat 4,7 drivereid millega tuleks r9600 clokimine lahti,praegu cat 4,7 ja need panevad natuke näkku, kuigi jah max fps yhes testis tõusis koguni 30
[b] |
11.07.2004 20:00:56
mis mõttes clokkimine lahti ???
kiiruseid on saanud alati mõelda, kui sa seda mõtled...näiteks AtiTool'iga...
amd2500
11.07.2004 20:23:20
| mikk36 kirjutas: |
kiiruseid on saanud alati mõelda, kui sa seda mõtled...näiteks AtiTool'iga... |
osade seerjate ati kaarte ei saa orig driveritea OCida, kuna r9600,r9550(midagi oli veel) neid lihtsalt ei saa ja vaja on modded drivereid et saaks, näiteks kui atitooliga määrad clokid siis, kui käivitad 3dprogra/mängu siis kohe aut. def. clokide peal. praegu on modded cat 4,7 peal aga nendega ei saa 3dmark2k01 tehtud(paneb kinni ise), mängudes muidu enam problasi ei ole.
[b] |
Spacefly
11.07.2004 20:34:08
oma r9600-t piinasin just
fastwrites on nii bioses kui driveritel (muidu hakkas kaart segast panema), orikatega ei last klokata, omegatega kenasti toimis
http://service.futuremark.com/compare?2k1=7964697
omegatest kasutan 2.5.36b kuna uuematega on tv-out peetis
_________________ Parim tegevus, kui und ei tule, on lambaid ja nende postitusi lugeda. |
| Kommentaarid: 63 loe/lisa |
60 |
SCREAMER
392 |
EvilMick007
20.07.2004 00:27:49
Hmm pole küll originaale proovinud, kuid omegatega on EnemyTerritory-s Fuel Dumpis koobastes mõned kohad põrandal läbipaistvad.. Muudes mängudes pole probleeme täheldanud.
_________________ Pentestimise ja küberturbe konsultatsiooni soovi korral võib kirjutada.. |
| Kommentaarid: 46 loe/lisa |
41 |
siLc
20.07.2004 07:44:44
Viimax ometi parandati räiged bugid Splinter Cell PTs ära 3DMark03 sai kah 100 punni otsa
186 |
DigeBeni
20.07.2004 07:59:05
... BT:Veitnam'is ei kao enam osad tekstuurid ära, kui kasutada AA ja AF, ning pilt tundub ka muidu ilusam ...
163 |
pokk
21.07.2004 19:51:04
| proovisin DNA 2.7.4.7, 3d Mark 2001se: 7130, 3d Mark 03: 1147. Natuke paremad kui omegad, dna-del on ka olemas fps mode
| Kommentaarid: 89 loe/lisa |
69 |
SCREAMER
21.07.2004 20:28:49
| pokk kirjutas: |
mode |
sinu jareldus 3d marki põhjal või kõik kokku (3d mark, bugid jne)
392 |
Chaze
24.07.2004 22:41:46
Mul need omegad võtsid 3Dmark2001 skoori 1000 võrra maha Ei teagi milles asi.
| Kommentaarid: 99 loe/lisa |
92 |
