mine lehele eelmine  1, 2, 3 ... 177, 178, 179 ... 319, 320, 321  järgmine
sõnum 25.04.2020 14:31:35 vasta tsitaadiga
Ootabki aega kuna need ryzen4000 prosed kommihinnaga kättesaadavad on ning saab mõnusa boosti icon_cool.gif
sõnum 25.04.2020 15:35:40 vasta tsitaadiga
AMD AGESA 1.0.0.5 BIOS Firmware Rolls Out
https://wccftech.com/amd-agesa-1-0-0-5-bios-firmware-rolls-out-with-improved-ddr4-dram-compatibility-system-reliability/
AMD's board partners have started rolling out the latest AGESA 1.0.0.5 BIOS firmware which adds improved compatibility with upcoming processors
Improving DRAM, USB devices compatibility.
Improving system reliability.
AGESA 1.0.0.5 firmware also fixes an issue where the HDMI audio was lost when using the Radeon RX 570 graphics card.
X570 BETA BIOS adds some improved support for DDR4 memory such as A-XMP Mode 1 and XMP Mode 2, there are plans of two major firmware updates for X570 boards to be introduced before June of this year. Our sources also mentioned that there's a high chance of X570 being kept on the BETA BIOS and moved to the new AGESA 1.0.0.6 version that comes later
Viilutaja
Viilutaja
sõnum 25.04.2020 15:38:01 vasta tsitaadiga
Parim x570 emaplaat vahemikus 150-350. Hinnaga 200.
Link
Parim kodukino projektor müügis: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11790090#11790090
sõnum 27.04.2020 09:31:38 vasta tsitaadiga
https://www.techpowerup.com/266287/amd-matisse-and-rome-io-controller-dies-mapped-out
io dies: https://twitter.com/GPUsAreMagic/status/1254443191115415552
raven ridge: https://twitter.com/GPUsAreMagic/status/1246081008522452992
- londiste
Vael
sõnum 28.04.2020 06:09:30 vasta tsitaadiga
Viilutaja kirjutas:
VRm tempide järgi, mitte ainult 200$ eest parim vaid üldse parim...(peaaegu) Hämmastav, kehvast seeriast parimaks. Ei tea kas over engineered, et mainet tagasi saada?
sõnum 28.04.2020 11:31:20 vasta tsitaadiga
MSI mobod on praegu üldse parimad vist, vähemalt AMD osas...
Viilutaja
Viilutaja
sõnum 28.04.2020 13:11:52 vasta tsitaadiga
rmc kirjutas:
Ootaks ära MSI Tomahawk B550 emaplaadi ja siis võrdleks X570 Tomahawkiga.
Kui sellel B550'l on ka Wifi6 olemas, korralik VRM jms, siis võtaks selle. Kui pole, siis läheb ikkagi X570 loosi.
Vael
sõnum 28.04.2020 15:53:42 vasta tsitaadiga
rmc kirjutas:
Carbon jms odavam ots oli täielik saast ju, Tomahawk ülevaavaates ju ka näha. 100c+ ja osad andsid üldse alla.(mingi3600 jaoks ilma oc käivad ka, aga milleks kui kvaliteetsem valikus olemas)
Teine laine MSIlt parem juba, pärast armutuid ülevaateid võtsid end käsile.
angel
angel
sõnum 01.05.2020 11:12:06 vasta tsitaadiga
Vael kirjutas:
rmc kirjutas:
Kas mitte MSI emaplaate kõige rohkem ei kritiseeritud X570 valdkonnas? Prose toite osa vist küpses väga kuumalt koormuse all.
sõnum 01.05.2020 12:03:34 vasta tsitaadiga
angel, Nii oli jah aga see sõltub kõik seeriast. Samal tootjal võib olla mõni seeria väga õnnestunud samas kui teine seeeria on päris halb. Mobode puhul on see eriti nii, et ei saa võtta aluseks eelnevaid seeriaid ja teha selle põhjal järeldusi tuleviku kohta.
Viilutaja
Viilutaja
sõnum 01.05.2020 12:08:22 vasta tsitaadiga
Esialgsed odavama otsa MSI X570 emaplaadid ACE'st allapoole, olid kõik kasutuskõlbmatud. ACE'st ülessepoole olid OK.
Siis tuli UNIFI, mis oli täitsa hea juba oma hinnaklassis, kuid nüüd tuli välja X570 Tomahawk, mis minumeelest muudab Unifi ja ACE pointless tooteks...
jt234
jt234
sõnum 02.05.2020 00:23:44 vasta tsitaadiga
Kasutuskõlbmatu ei saa just öelda - mul 3700x-ga toimetab täitsa edukalt. Muidugi suurt OC-d peale ei lükka, aga ei ole ette ka jäänud.
Ostuvalu muidugi vähendab kõvasti see, et umbes kohe sai MSI-lt tasuta 60€-se AIO, mille turul rahaks sai teha icon_lol.gif
Dima oli siin
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 124
Viilutaja
Viilutaja
sõnum 02.05.2020 01:36:59 vasta tsitaadiga
jt234 kirjutas:
Miks tasuta AIO said?
sõnum 02.05.2020 02:09:52 vasta tsitaadiga
Viilutaja, MSI'l oli kampaania, et teatud X570 platedega sai kaasa "tasuta" AIO. Või oli kõigi X570 omadega? Ma ei mäleta enam. Launchi ajal mingi kampaania igatahes oli.
Imo pole see siiski piisab põhjus mingit emaplaati eelistada sõltumata sellest mida sealt kaasa antakse. Lisaks kui antakse midagi kaasa siis minul tekib õigustatud küsimus, et kas siis toode pole piisavalt hea, et peab midagi lisama?
Vael
sõnum 02.05.2020 09:46:33 vasta tsitaadiga
Aio ei puhu üldse õhku üle VRM, vastupidiselt tornidele. Seega tegi MSI endale karuteene;)
4700u teste lekib juba vaikselt: Techepiphany toimetab kõige usinamalt. 17w pealAPU üle 2.4GHz ei kiirenda, mulle tundub, et 8 aeglast tuuma jäävad 80% üeal jalgu?
Kuigi samas H seeria ka palju kiirem polnud?
Renq
Renq
sõnum 02.05.2020 10:24:18 vasta tsitaadiga
https://wccftech.com/amd-ceo-ryzen-cpus-now-account-to-more-than-50-premium-processor-sales-globally-strong-demand-for-ryzen-3000-ryzen-2000-cpus/ ilusad numbrid AMD jaoks.
jt234
jt234
sõnum 02.05.2020 11:50:42 vasta tsitaadiga
Tomorrow kirjutas:
Tomorrow kirjutas:
Ma arvan küll, et nad hakkasid kartma
Dima oli siin
Viilutaja
Viilutaja
sõnum 04.05.2020 11:19:53 vasta tsitaadiga
AMD R7 3800X@5Ghz vs Intel i9-9900K@5Ghz
Link
angel
angel
sõnum 04.05.2020 18:47:10 vasta tsitaadiga
Viilutaja kirjutas:
Link
Minuteada alguses juba räägiti, et Ryzen 'it on suht mõttetu ülekiirendada. Üks kasu, mida saad on suuremad temperatuurid ja voolutarve. Ja kübeke jõudlust.
Parem juba kiiremad mälud panna.
anubis
anubis
sõnum 04.05.2020 18:56:17 vasta tsitaadiga
Jep.
sõnum 04.05.2020 22:01:07 vasta tsitaadiga
angel, Sõltub workloadist. Pikematel kõiki tuumasid kasutavates asjades nagu renderdamine vms on kindlasti kasu allcore OC'st. Lühikestes burst loadides nagu CB20, mängud jne see eriti juurte ei anna. Võib isegi jõudlust vähendada.
Aga tõsi see on, et suurima jõudluselisa saab 3600-3800Mhz mälude jooksutamisest mis on 1:1 Infinity Fabric kellaga (enamus prosed teevad 1800Mhz, paljud 1866 ja parimad 1900). Seda siis veel koos timmitud subtaimingutega.
Aga see test oli päris huvitav. Olin seni arvanud, et Inteli eelis on ainult suurem Mhz aga tundub, et AMD'l on vaja veel teha tööd L1, L2 suurendamise ja latentsuse langetamisega. L3 on juba praegu piisav ja seda on ka miinimumidest näha. Seega kui me oleks ka saanud 3950X mis suudab õhuga teha 5Ghz, siis selle testi järgi poleks see olnud piisav.
angel
angel
sõnum 04.05.2020 23:41:38 vasta tsitaadiga
Endal on Asuse emaplaadiga vaikimisi seadistus peal, et kõik tuumad jookseks 4.2-4.3 GHz vahemikus. Mingit erilist jõudluse kasvu peale cinebenchi ei ole märganud mängudes, võrreldes stock kelladega. Ainuke erinevus on kõrgem pinge suurema GHz'i juures ja sellest tingitud ka suurem voolutarve ja protsessori temperatuurid.
Kui prose boostimise maha võtsin siis muutus asi väga jahedaks. Tundub, nagu eelmise põlvkonnaga, et 4Ghz altates on AMD rohkem särtsu vaja ning temperatuur tõuseb ka kolinal. Sama kogemus on vanema Ryzen 1600'ga.
Asus nagunii trikkitab prose kelladega ja näitajatega seega kasutan seda "ülekiirendamist" mida ta vaikimisi pakub. Ehk siis kõik tuumad kiirendavad ühtemoodi ja korraga. Võimalik, et kui vaeva näeks saaks pinget maha võtta ja temperatuuri paremaks aga Noctua NHD15S eriti ei kurda ja temperatuurid väga krõbedaks ei lähe. Kuigi Asuse viimased bios uuendused võtsid seda automaat "OC" agressiivsust maha. Ennem oli Level 1 sama mis nüüd on Level 3.
anubis
anubis
sõnum 05.05.2020 23:30:37 vasta tsitaadiga
Link
Mnjaa, päris hull muutus.
Vael
sõnum 06.05.2020 15:47:50 vasta tsitaadiga
anubis, ma ei viitsind lõpunigi vaadata, 10gen<9gen kohati. (AMDst ei hakka rääkimagi...)
Seda 5GHz lugu pole ka veel näinud, aga hetkel on U-seeria palju huvitavam. TechEpyphanyl tilgub 4700u ja4500u teste juba pikemat aega. Peale energiatarbimise suurt erinevust polegi. 18W isend perfib ka hästi, huvitav on seejuures raportweritav prose kell, mis kõigub seal default lähedal ehk üle 1400MHz ei lähegi. Ja samas mängudes on tulemused ühes augus. efektiivsus on ikka meeletu ja\või iGPU pudelikaelaks.
Ananyechil ka lugu väljas 4700u kohta.
degreal
sõnum 06.05.2020 19:01:29 vasta tsitaadiga
Vanasti naerdi igaaastase 5% IPC kasvu üle. Nüüd võib 5% IPC kasvust ainult und näha.
Kommentaarid: 28 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 26
Auron
Auron
sõnum 07.05.2020 08:47:07 vasta tsitaadiga
degreal kirjutas:
Eks tegelt samalaadse tehnoloogiaga tulebki üheltmaalt piir suht ette kui juba tükkaega olemas olnud ja suurt hüpet pole enam kuskilt võtta. Ei saa juurde suurt IPC kasvu, ei saa juurde taktsagedust jne. või nohh - nö. mikroskoopilised vahed mida ei tunneta mingitmoodi.
anubis
anubis
sõnum 07.05.2020 08:49:51 vasta tsitaadiga
Zen -> Zen+ -> Zen2 on kokkuvõttes rohkem kui 5% kasv aastas olnud
Auron
Auron
sõnum 07.05.2020 10:34:41 vasta tsitaadiga
anubis, jahh aga kui tuumade ralli välja arvata siis AMD on nüüd intelile järgi võtnud per tuum perfis aga sellest punktist mingit korralikku +25-30% hüpet ei ole vast niipea tulemas.
sõnum 07.05.2020 15:43:42 vasta tsitaadiga
Auron,
Zen3 2020: +10%
Zen4 2021/2022: +10%
Need on veel konservatiivsed numbrid. Reaalsed saavad olema mõnevõrra suuremad. Eriti kui rääkida spetsiifilisest workloadist. Nt Zen3 toob kuni +50% floting point perf lisa ja Zen4 lisab AVX-512, et kiirendada AVX. See on mõistagi kinnitamata AMD enda poolt, aga mineviku lekked on IPC osas üsna täpseks osutunud.
Ega Intel ise kah lõputult 14nm peal paigal istuda ei saa. Rocket Lake-S peaks tooma mingi IPC kasvu, kuna tegu 10nm backportiga ja Alder Lake-S peaks olema esimene kombinatsioon 10nm++ ja "uuest" arhitektuurist.
Samas selge see, et erinevalt RISC'st ei suuda x86 iga aasta teha +25% IPC. Seega korfraga pole kummaltki poolt sellist suurt hüõpet tulemas aga paigal keegi ka ei tammu. Seetõttu ei näegi ise põhjust iga paari aasta tagant uuendada. Umbes 5-6 aastat on selline mõistlik, et saada hea perf hüpe järjekordselt.
anubis
anubis
sõnum 07.05.2020 15:46:52 vasta tsitaadiga
Ma ei usu Inteli 10nm elujõulisusse. Pigem jääb see üheks Itaniumiks nende ajajoonel.
Mõju loomulikult suurem kuid Intel on nii krdi suur firma ja nende rahavarud on suht põhjatud. Elavad üle.
AWsander
AWsander
sõnum 07.05.2020 16:14:19 vasta tsitaadiga
Ryzen 3100 ja 3300x reviewid väljas.
Huvitav millal ja mis hinnaga meie kandis müügile tulevad.
sõnum 07.05.2020 16:43:22 vasta tsitaadiga
zen3 ainult 500-seeria chipsetiga?
ja 550 chipset toetab hetkel ainult 3000-seeria cpu-sid (ja mitte zen+ 3000 seeria apusid).
- londiste
sõnum 07.05.2020 16:47:18 vasta tsitaadiga
londiste, Jep just tahtsin postitada. Not good. Not good at all. Ok saan aru, et X370 ja B350 ei toetaks Zen3, sest slaidi järgi ei toetanud nad ka Zen2 aga see, et X470 ja eriti B450 seda ei toeta on suur üllatus. Isegi bombshell ütleks selle peale icon_eek.gif
Muidugi lõppude lõpuks sõltub kõik konkreetsest mudelist ja tootjast. Usun, et see võib olla rohkem aja ja ressursi küsimus emaplaaditootjate poolel mitte niivõrd tehniline piirang. Lisaks isegi kui nt B450 ei toeta Zen3, siis tulevikus saab B450 omanik ikka osta odavamalt omale 3900X või isegi 3950X kui need on alla hinnatud Zen3 tõttu.
sõnum 07.05.2020 16:58:31 vasta tsitaadiga
3100 ja 3300x on sellised nii ja naa. ühest küljest tapavad edukalt vanade inteli ddr3 platvormide järelturgu. teisest küljest on ennetav löök i3-10100 pihta.
tulemused on üsna pettumust valmistavad tegelikult. 7700k-st küll kiiremad aga vaevu-vaevu ja ainus boonus on am4 platvorm.
- londiste
sõnum 07.05.2020 17:37:30 vasta tsitaadiga
londiste, RIP: 7700K, 9100F ja 9400F. Viimane on veel 6c/6t seega AMD 4c/8t on sellest kiirem omades vähem füüsilisi tuumasid. Eks näis kuidas 10400 asja muudab tänu HT lisamisele.
Igati asjalikud. Eriti 3300X. Ainuke pettumus on see, et R5 1600AF on 150€ thumbs_down.gif
Reaper
Reaper
sõnum 07.05.2020 21:39:44 vasta tsitaadiga
Ryzen 3700X töötab mul edukalt X370 plate peal, pärast BIOS-i uuendamist. Nii et see pilt vigane.
Kaalusin just X470 platet osta Ryzen 4xxx jaoks.
X570 üldse ei meeldi, kuna aktiivjahutus. Seda põhiliselt kasutu PCIe 4 tõttu.
PS. Järelturust rääkides: ostsin just endale paar uut 1155 platet H61 chipsetiga. Prosed ja mälud ju olemas!
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 27
virx
sõnum 07.05.2020 21:41:43 vasta tsitaadiga
Küsimus kas Gigabyte B450 AORUS M veab 2700X ära edukalt ilma OC'ta?
https://arvutitark.ee/est/tootekataloog/Arvutikomponendid-Emaplaadid-Socket-AM4-emaplaadid/Gigabyte-B450-AORUS-M-AM4-DDR4-3200-USB-31-DVI-D-HDMI-mATX-372961
Või mida soovitate ~150€ kandis?
Kommentaarid: 365 loe/lisa Kasutajad arvavad:  :: 5 :: 1 :: 309
anubis
anubis
sõnum 07.05.2020 21:48:57 vasta tsitaadiga
Veab. Veab ka OCga.
Pole väga mõtet OC'l, v.a. väga kitsa kasutusmudeli (kus vaja kõiki ruumi püsikoormatult hoida) korral.
sõnum 07.05.2020 23:15:36 vasta tsitaadiga
virx kirjutas:
Miks nii kallis B450 osta? Kui tahad parimat B450 plaati, siis MSI Tomahawk MAX ~125€ ja ei pea isegi BIOS uuendust tegema teise prosega. Või kui juurde paned, siis ~200€ eest saad X570 Tomahawk. See pole küll vist veel saadaval aga 200 kandis on teisigi valikuid.
Viilutaja
Viilutaja
sõnum 08.05.2020 00:43:33 vasta tsitaadiga
Ma pakun välja, et B450'd millel on see 64MB biose kivi ei toeta Zen3, kuid kõik need 128MB biose'ga emaplaadid toetavad. Just nagu praegu on ju Zen2'ga. Osad B350 said toe ja kõik mitte.
Renq
Renq
sõnum 08.05.2020 07:48:12 vasta tsitaadiga
https://wccftech.com/amd-confirms-ryzen-4000-zen-3-cpu-compatibility-x570-b550-chipset-motherboards/
Anna tooli
sõnum 08.05.2020 08:36:01 vasta tsitaadiga
AWsander kirjutas:
saksas hinnad jämedalt 110 ja 130
Kohalike pakkumisi veel pole
pots4t4j4
sõnum 08.05.2020 09:48:25 vasta tsitaadiga
3600 hinda arvestades ei saa öelda et mingi super hea diil oleks.
anubis
anubis
sõnum 08.05.2020 09:52:17 vasta tsitaadiga
Kui eelarve seal ~€400 kanti siis iga euro arvel.
degreal
sõnum 08.05.2020 12:17:53 vasta tsitaadiga
Huvitav kui ürgvana 7700k maha müüa kas siis saab piisavalt raha, et osta tutikas 3300x, tutikas B450 emaplaat ja kast õlut.
sõnum 08.05.2020 12:20:50 vasta tsitaadiga
Oleneb kas orikat või midagi Põhjalalt.
sõnum 08.05.2020 12:26:38 vasta tsitaadiga
AMD has highlighted the main reason as to why they don't plan on adding support for Zen 3 Ryzen CPUs on pre-500-series chipsets to be the flash memory limitation. As per AMD, the flash memory chips that store the BIOS have capacity limitations, and not all AM4 boards feature dual-BIOS chip design (usually found on more expensive and high-end boards).
Q: What about (X pre-500 Series chipset)?
A: AMD has no plans to introduce “Zen 3” architecture support for older chipsets. While we wish could enable full support for every processor on every chipset, the flash memory chips that store BIOS settings and support have capacity limitations. Given these limitations, and the unprecedented longevity of the AM4 socket, there will inevitably be a time and place where a transition to free up space is necessary—the AMD 500 Series chipsets are that time.
Q: How long will Socket AM4 last from here?
A: This will depend on the schedule of industry I/O technologies. Such technology changes typically require adjustments to the pin count or layout of a processor package, which would necessitate a new socket. We have no specific details to share concerning this roadmap or timing right now, but we know it’s important to keep you updated—and we will.
sõnum 08.05.2020 14:36:43 vasta tsitaadiga
Renq kirjutas:
"AMD has highlighted the main reason as to why they don't plan on adding support for Zen 3 Ryzen CPUs on pre-500-series chipsets to be the flash memory limitation. As per AMD, the flash memory chips that store the BIOS have capacity limitations, and not all AM4 boards feature dual-BIOS chip design (usually found on more expensive and high-end boards)."
Kui asi on BIOS kiipides, siis võiks ju MAX mobodel tugi tulla... lisaks võiks mobode tootjad ise vaadata, kas pakuvad BIOS uuendust või ei.. st. tegelt saaks ju vanu asju välja flashida ka.
"Notebook maker, XMG, confirmed that they will enable AMD Ryzen 4000 series compatibility with B450 chipset through a microcode update."
Seega võiks nagu tulla, ilmselt siis ongi tootjates kinni tugi pigem.
degreal, julgen arvata, et hetkel veel pigem saab.
kaspar737
sõnum 08.05.2020 15:05:43 vasta tsitaadiga
On X570 mobosid millel 128Mb kiip, on B450 mobosid millel 256Mb kiip. AMDlt jama põhjendus, raudselt tahavad rohkem chipsete müüa.
anubis
anubis
sõnum 08.05.2020 15:39:43 vasta tsitaadiga
AMD ei ehita emaplaate.
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 177, 178, 179 ... 319, 320, 321  järgmine
