sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
Zonerman
![Zonerman Zonerman](https://foorum.hinnavaatlus.ee/images/avatars/upload/95c6a5b0d5d2c37a69b715a16aa08cf2.jpg)
15.01.2019 10:43:36
anubis kirjutas: |
Positiivne
Spoiler ![Spoiler](/images/exclamation.gif)
tsitaat: |
Nvidia, however, now supports FreeSync — although most of those monitors won’t work. The company said that it has already tested more than 400 FreeSync monitors, but only 12 of those passed its test:
Acer XFA240
Acer XZ321Q
Acer XG270HU
Acer XV273K
Agon AG241QG4
AOC G2590FX
Asus MG278Q
Asus XG248
Asus VG258Q
Asus XG258
Asus VG278Q
BenQ Xl2740
If you are running one of those displays, Nvidia’s software will automatically turn on adaptive sync. If you are running a different FreeSync monitor, however, you can still test it for yourself. You just need to go into the GeForce control panel and turn it on beginning January 15.
Maru vähe ikkagi 400'st. Lisaks ükski variant pole selline mida mina lootsin 27" IPS paneeliga 2k resol pole neist ükski. Eks peab edasi ootama vb mõni neist tekib tulevikus. Lihtsalt G-Sync pärast ei taha küll uut enam osta.
Kommentaarid: 63 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
62 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
![londiste londiste](https://foorum.hinnavaatlus.ee/images/avatars/upload/14e8b2a8ca7fc07a1be7f79f613c69f5.gif)
15.01.2019 12:32:56
reaalselt siiski umbes 200st.
lisaks on nüüd juttudest välja tulnud ka teine probleem vrr monitoridega - nvidia tahab ka adaptive/variable overdrive, mida freesync monitoridel on vähem kui üldse.
tn-monitoridel pole overdrive (nii) oluline, sellepärast ka need enne.
edit:
uued draiverid väljas, peaks nüüd saama proovida.
_________________ - londiste
Kommentaarid: 238 loe/lisa |
213 |
anubis
![anubis anubis](https://foorum.hinnavaatlus.ee/images/avatars/upload/0da2e7fa0ba90f4ae031b0d232b8a57a.gif)
Kommentaarid: 317 loe/lisa |
271 |
Vael
16.01.2019 18:00:05
trip, kasu(m)lik häkk, 70.- GTX1060;)
Kommentaarid: 17 loe/lisa |
16 |
trip
![trip trip](https://foorum.hinnavaatlus.ee/images/avatars/upload/7da7993d1249cb28b4e0c3e8524d15d2.gif)
16.01.2019 19:47:58
foorumis vahepeal olid mining 1060 isegi 45eur hinnaga müügil.
überbang for a buck
Kommentaarid: 405 loe/lisa |
302 |
KrikU
![KrikU KrikU](https://foorum.hinnavaatlus.ee/images/avatars/upload/771addac2676f354809f2d5605317c20.jpg)
Kommentaarid: 129 loe/lisa |
119 |
24.02.2019 11:15:41
1660Ti on jah pull kaart, eriti kui voolutarvet vaadata. Võiks järelturul Pascalite ja vanemate kaartide hindu alla suruda küll. Poes on olukord veel skisofreeniline, kus sama muskliga GTX1070 maksab pea soti rohkem kui GTX1660Ti.
Kommentaarid: 178 loe/lisa |
144 |
![Tomorrow Tomorrow](https://foorum.hinnavaatlus.ee/files/me3_667.jpg)
Kommentaarid: 89 loe/lisa |
79 |
mauro
![mauro mauro](https://foorum.hinnavaatlus.ee/images/avatars/upload/b134860b473ea4a20f923b7b990f34d5.gif)
05.03.2019 20:14:38
Graafiku järgi vaatan, et 1080ti oli detsembris 900+ eurot.
Kommentaarid: 7 loe/lisa |
Rauno266
07.03.2019 11:14:11
#StoryTime: Võtsin ühe foorumikasutaja käest ligi Kraken G12 + Kraken X31 kombo ja vesijahutasin oma Asus 1080Ti Turbo ära. Kaardi jahutust lahti keerates leidsin videokaardi PCB-lt mingeid läbipaistva õli laike ning paaril juhul oli seda õli ka termoteibi ja kiibi vahel. Kas tegemist võib olla mingi tootmisprotsessi käigus lekkinud/kaardile sattunud blower jahutilubrikandiga? Varasemad jäljed jahutuse eemaldamise kohta puudusid ning kahtlen sügavalt, et see õli sinna eelmise omaniku tegevuse tulemusena sattus.
Igatahes monteerimisprotsess oli võrdlemisi valutu kui välja arvata, et ideaalis teeks seda tööd keegi, kellel on 4 kätt. Kuna mul juba prose peal istus üks AIO, siis vana hea front-panel USB header plaadi peal oli kasutuses ning pidin kasutama Crosshair VII Hero ROG_EXT headerit. Siin-seal erinevaid arvamusi lugedes jäi mulje, et kui soovid kasutada vaid ühte seadet, siis sisuliselt võiks nagu kasutada seda teise USB headerina, aga midagi lõplikku selle kohta ei leidnud. Ons kellelgi kogemusi selle headeriga? Emaplaadi manualis mainitakse mingit adapterit selle ühenduse jaoks, mis tuleb eraldi juurde osta, aga see USB otsik AIO küljes istus sinna kenasti otsa. Küll aga ei õnnestunud mul oma AIO-t CAM-i abiga hiljem tuvastada (vist ikka ei tööta nii nagu võiks see lahendus).
Ventide kiirusi ei jõudnud veel reguleerida, aga power limit põhja keeratuna ning +200 GPU ja temperatuurid ei tõuse üle 54*C. See andis siis stabiilseks lõppsageduseks 2113MHz.
Tulemusi ka:
Fire Strike
Time Spy
Kommentaarid: 41 loe/lisa |
39 |
TheAnswer
![TheAnswer TheAnswer](https://foorum.hinnavaatlus.ee/images/avatars/upload/20637ec6f70305fe8224ec468cc8b95a.jpg)
07.03.2019 11:17:27
tsitaat: |
üsna levinud probleem. See õlilaadne toode tuleb thermalpadidest, mul oli oma evga kaardiga sama teema. Ei tohiks kuidagi negatiivselt mõjutada kaarti, aga kole on küll
Kommentaarid: 45 loe/lisa |
43 |
anubis
07.03.2019 11:31:02
Termopadjad higistavad vahel, jep.
271 |
Rauno266
07.03.2019 15:42:27
ot: |
Sain siis nii palju targemaks, et üldjuhul peaks see ROG_EXT header töötama emaplaadil, aga sõltub sellest, kuidas AIO pumba USB otsik kaabeldatud on. Kui ta peaks kasutama seda USB pesa, mis on seadistatud ROG_EXT NC pinnide peale, siis arvutiga teda ühendada ei õnnestugi, vähemalt headeri kaabeldust näppimata.
Käin korjan õhtul Arvutitargas ühe NZXT internal HUB-i üles ja lahendan nii selle tüütu headerite olukorra |
39 |
213 |
time123
![time123 time123](https://foorum.hinnavaatlus.ee/images/avatars/upload/598ba392de44a9f688adcba4c6a97a14.jpg)
10.10.2019 14:34:03
1080 jääb hätta 8K@60fps ja 4K@120fps videote paralleelse esitamisega. Video decode on 100% ja lag tuleb. Kas 1080ti võiks sellega toime tulla?
viimati muutis time123 10.10.2019 14:35:00, muudetud 2 korda |
Kommentaarid: 198 loe/lisa |
175 |
10.10.2019 14:38:36
pildi või video?
kui video, siis mis formaadis, mis mängijaga või mis tingimustel?
1080 ja 1080ti decoder on sama. ehk siis kõigi eelduste kohaselt on vastus ei.
tekita mingi demo-usecase ja keegi 1080ti-ga saab reaalselt öelda. või siis mõne muu põlvkonna kaardiga, et kas need on võimekamad.
213 |
10.10.2019 17:38:31
time123, See on suht karm use case. Olen üsna kindel, et jääb hätta ka 1080 Ti. Ise ei saa testida GTX 1080 peal, kuna netiühendus on pudelikael kuigi niipalju kui ettepuhverdamine lubab tundub kaart siiski ühe 8K 60fps videoga hakkama saama Youtubes.
Oleks hea teada jah mis tingimustel. Youtube või kettal olev fail?, meediamängija? jne.
79 |
anubis
271 |
olafsand
![olafsand olafsand](https://foorum.hinnavaatlus.ee/images/avatars/upload/a512983f8b1207720f4eddf2e6e5811a.jpg)
10.02.2020 22:17:43
msi 1070 ti ja Afterburner OSD näitab mängu ajal tihtilugu 1860MHZ core kellaks. Boost peaks tegelikult 1600+ olema. Mingi Afterburneri oma "kala" kuvamisel?
Kommentaarid: 60 loe/lisa |
57 |
10.02.2020 23:16:53
see on normaalne. nvidia boostib normaaloludes speci boost taktist kõrgemale.
213 |
olafsand
11.02.2020 10:04:51
londiste, a niipidi Suur tänu info eest! Kusjuures kui kuumaks hakkab minema näiteks, siis võtab jah alla 1840 või 1832 jne peale.
57 |
lopes39
![lopes39 lopes39](https://foorum.hinnavaatlus.ee/images/avatars/upload/9c11870976cbbf87388e6bea9e3d0fab.jpg)
18.03.2020 22:40:02
Huvitav kaua mul see graafika kaart vastu peab kui mul üks vent allles jääb.
Mul kaardil oli üks vent täiesti lahti ja loppendas. Krigises palju ja siis käis vastu radikat nagu õmblusmasina hääl.
Kommentaarid: 10 loe/lisa |
Aeg maha 1p
![rmc rmc](https://foorum.hinnavaatlus.ee/images/avatars/upload/860205b00a059d8d469d933b9d6f6416.jpeg)
18.03.2020 23:20:07
Aeg-ajalt tasub ikka masinat puhtaks ka tõmmata
![](https://foorum.hinnavaatlus.ee/images/200x40_HV.gif) |
Kommentaarid: 195 loe/lisa |
181 |
pots4t4j4
18.03.2020 23:20:19
Viska need mõttetud vendid mõlemad minema ja pane sinna üks 120mm vent asemele.
Kommentaarid: 488 loe/lisa |
396 |
19.03.2020 00:14:40
lopes39, Jep see on teada tuntud Zotaci probleem . Minu Zotac GTX 1080 peal esines täpselt sama asi. Hakkas vastu jahutust käima ja kohutavat müra tegema. Ajutiselt aitas ainult vendi kiiruse käsitsi 25% peale fikseerimine.
Nüüd pole enam vahet, kuna palju asjalikum jahutus koos 120mm ventidega on peal.
79 |
