| Mitu tolli on sinu peamine igapäevases kasutuses olev monitor? |
| 10-15" |
0% |
[ 3 ] |
| 15-20" |
2% |
[ 7 ] |
| 20-25" |
17% |
[ 56 ] |
| 25-30" |
41% |
[ 132 ] |
| 30-35" |
25% |
[ 81 ] |
| 35" või suurem |
12% |
[ 40 ] |
| hääli kokku : 319 |
von Wu
22.11.2019 13:33:51
| londiste kirjutas: |
| mingi sharpness setting monitoril? |
Endal kogemus, et keegi oli monitoril "Gaming" režiimi sisse lülitanud. Tegi tekstid rõvedalt karvaseks ja varjud taga.
_________________ Müüa elektriroller
Müüa igasugu asju |
| Kommentaarid: 907 loe/lisa |
681 |
29.11.2019 16:59:16
NVIDIA to Open G-Sync Monitors to VRR Support, Enabling AMD Graphics Cards Support
https://www.techpowerup.com/261494/nvidia-to-open-g-sync-monitors-to-vrr-support-enabling-amd-graphics-cards-support?
| confirmed by NVIDIA, the company will enable VRR support for next releases of monitors equipped with the company's G-Sync module. This will essentially enable AMD graphics cards to work with NVIDIA-branded G-Sync monitors. |
| This move will only work for future monitor releases, mind you - a firmware update which will be distributed amongst monitor makers will enable the next releases of G-Sync to support VESA's VRR standard. This will not, apparently, be happening with already-released G-Sync modules, whether carrying NVIDIA's first take on the technology, nor the v2 G-Sync modules. It's not a perfect solution, and current adapters of G-Sync are still locked-in to NVIDIA graphics cards for VRR support on their monitors. |
Seega kahjuks ainult uutele G-Sync mooduliga mudelitele. Ehk siis väga väike hulk potentsiaalseid tooteid. Tootjad vaevalt, et lähevad tagasi ja hakkavad vanematele mudelitele püsivara uuendust tegema, kuigi tehniliselt oleks see võimalik.
EDIT:
Veidi huvitavat statistikat kah:
https://levvvel.com/gaming-monitor-study/
TL;DR:
65% Freesync, 17% G-Sync, 5,8% Freesync 2 ja 3,3% G-Sync Ultimate.
91,3% omab VRR tuge
27" @ 45% ja 24" @ 32%
1080p @ 53% ja 1440p @ 35%
45% VA, 40% TN ja 14% IPS
74% 144Hz, 7% 240Hz
| Kommentaarid: 92 loe/lisa |
karts3
| Kommentaarid: 63 loe/lisa |
62 |
pots4t4j4
02.12.2019 17:50:00
| 1k eest tahaks küll
401 |
heretic666
02.12.2019 17:54:26
| Nkn maksab see mingi 2 ja pool kilo
| Kommentaarid: 73 loe/lisa |
pots4t4j4
02.12.2019 18:16:27
| vaevalt, lg oma on 2k, sama tootega aasta aega hiljem turule tulla kallima hinnaga natuke nonsens pole? Kui Lg omalegi paneelide tootmisega hakkama ei saa siis kustkohast see acer neid võtab?
401 |
karts3
02.12.2019 19:46:53
| Ootan juba pikemat aega 38GL950G-B monitori , sama paneeliga mis Aceril, kuid LG lükkab järjest välja tuleku aega edasi. Paistab et mul jääbki monitor ostmata.
62 |
pots4t4j4
02.12.2019 20:11:50
| See juba aasta aega "väljas" lihtsalt saadavus kehva?
401 |
heretic666
02.12.2019 20:12:58
| pots4t4j4 kirjutas: |
| vaevalt, lg oma on 2k, sama tootega aasta aega hiljem turule tulla kallima hinnaga natuke nonsens pole? Kui Lg omalegi paneelide tootmisega hakkama ei saa siis kustkohast see acer neid võtab? |
Uurisin ja on jah väidetavalt 2K eur LG isend, samas ma ei saa aru miks sa eeldad kohe odavamat hinda? Aceri disain ju "ägedam".
denis28
| Kommentaarid: 67 loe/lisa |
22.12.2019 17:33:34
LG.Display Latest Panel Development Plans – Dec 2019
https://www.tftcentral.co.uk/blog/lg-display-latest-panel-development-plans-dec-2019/
AU Optronics Latest Panel Development Plans – Dec 2019
https://www.tftcentral.co.uk/blog/au-optronics-latest-panel-development-plans-dec-2019/
LG'l päris huvitavad paneelid arenduses. Kahjuks kaugel. Enne 2021 ilmselt lettidel neid ei näe.
Overall focus areas for LG.Display are:
Improved design with new thinner profiles and “real borderless” design
Use of Mini LED backlights for improved local dimming and HDR performance
Extending colour spaces for more vivid and lifelike colours
Faster IPS gaming panels
More low blue light filter developments |
One looks like it will be the 27″ UltraHD (3840 x 2160 res) panel with 144Hz refresh rate that we’ve talked about before. This will have a 4-side borderless design and offers a 98% DCI-P3 colour gamut and HDR600 support. That is penciled in at this stage for Q3 2020 production.
The other planned option with this Oxide design is a 27″ module with 2560 x 1440 resolution and a 240Hz refresh rate. This too has a 98% DCI-P3 gamut and HDR600 support, but is penciled in for Q4 2020 production. |
Ehk siis mõlemad tootjad liiguvad FALD pealt edasi Mini-LED peale mis on vahesamm enne Micro-LED kasutuselevõtmist järgmisel kümnendil. Kahjuks OLED pole desktop monitorides eriti realiseerunud, seega lootus on, et Micro-LED seda suudab.
Ühtlasi 240Hz IPS variandid 1440p peal ja 4K IPS 144Hz koos DP 1.4 ja DSC-ga+Mini-LED ehk 1000+ tsooni ja puudub vajadus chroma subsampling teha, et 144Hz edastada üle DP 1.4 (tänu Display Stream Compression featuurile).
Siiski kui hetkel panna kirja mis võiks olla realistlik ja mida ise tahaks ütleme 5 aasta pärast näha hiljemalt:
27-32" 1440p @ 240Hz-480Hz või 35-37" 4K @ 144Hz-240Hz
IPS, Mini-LED, HDR 1000-1400
HDMI 2.1, DP 2.0
GSync & Freesync ühilduv
ULMB & Sync tugi samaaegselt
22.12.2019 17:42:20
4k 144hz mini-led mõitsliku hinnaga tahaks, 2k pole mõistlik
22.12.2019 18:06:29
No ühel on fan probleem, kogu aeg töötab ja teisel oli mingi muu kamm
pots4t4j4
22.12.2019 18:36:53
| Millega te seda 4k 144hz asja jooksutada tahate ? Tavaline rtx 2080 ei saa isegi 3440x1440 resul hakkama 120hz paneeliga, 2080ti teid ka ei pääasta 4k ja 144hz juures kahjuks.
401 |
22.12.2019 20:22:54
pots4t4j4, ei osta aastaks molli ju. Tuimalt pakun, et uus monitor jääb 5+ aastaks lauale
Küll lõpuks ka videod järgi jõuavad
pots4t4j4
22.12.2019 20:31:40
| Ja kui ükskord jõuavad siis on ammu 4k 144hz monitorid 500€ tk ja paremad ka veel
401 |
22.12.2019 21:00:52
Paar aastat möödas ja pole kusagile jõudnud selles segmendis
Vael
23.12.2019 08:07:11
Lülita monitor 30Hz peale kui Vstnc vaja jookautada. Sama häda jätkub, siis tootjad ei panustagi enam 60Hz+ moniroridele "bc ur PC wii blow up if 144Hd=|=FPS".
Jah kõrgem FPS on alati parem, aga midagi ei juhtu kui 144HZ monitor silub <144FPS, vastypidi, alla 60FPS tyleb 120Hz+ monitori kasutegur veel paremini välja.
Sama hea väide nagu, "u cant see more than 60FPS". Silm ei rwgistreeri jah väiksemaid vahesid, aga monitor ei väljasta sul 60FPS ühtlast pilti- alustades ülalt alla skaneerimise ja lõpetades 0.1% low-ga.
Ma ei taha paari aasta pärast tagasi kolida 60Hz peale sest osa rahvast arvab, et nagunii GPU-d järgi ei tyle, siis pole 144Hz monitoril ka mõtet.
EDIT: https://www.blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/, 2a vana artikkel tegelikult juba olemas, siin küll VSYNC ka mängus, aga point jääb ikka samaks:
60FPS@144HZ 2x parem kui 300FPS@60Hz. Ja kui ülejäänud artiklit vaadata, siis pigem 144FPS@144Hz on kehvem kui 10FPS alla monitor HZ.
Võrdluseks 142FPS@144Hz
| Kommentaarid: 17 loe/lisa |
16 |
SirAskAlot
04.01.2020 16:47:52
| Millega te seda 4k 144hz asja jooksutada tahate ? Tavaline rtx 2080 ei saa isegi 3440x1440 resul hakkama 120hz paneeliga, 2080ti teid ka ei pääasta 4k ja 144hz juures kahjuks. |
Äkki ta tahab 1080p ja 144hz peal vahel mõnda shooterit mängida ? Sa ei hakka ju selleks eraldi monitori ostma
Gap
| Kommentaarid: 21 loe/lisa |
17 |
Renq
kuccu
05.01.2020 00:12:06
| See samsa G9 võib juba päris viisakas alternatiiv olla kolmikutele auto simudes kui VRi ei kannata. R1000 raadiusega piisavalt lähedale nina saad peaks päris hea olema juba.
06.01.2020 10:49:58
Tomorrow, njah, esimese hinnalipik hakkab arvatavasti number kolmega
Launger
06.01.2020 13:11:36
Kas tehniliselt sobiks iga Dell standi otsa iga Dell monitor? Mehaanism tundub sama.
Ja kui ekraani kaal on sama, siis tehniliselt töötaks kõrguse muutmine ka normaalselt?
(Oman P2417H jalga ja tahan külge osta U2518D)
_________________ https://store.simracing.ee/eval-lounge-simulaatori-rent |
109 |
06.01.2020 20:39:51
| jeesus188 kirjutas: |
| Tomorrow, njah, esimese hinnalipik hakkab arvatavasti number kolmega |
Ainuke hea asi on see, et diagonaali on suurendatud 4K 27" pealt 4K 32" peale
loox
07.01.2020 00:06:21
Dell tunnistab ametlikult, et nende UHD monitorid ei ole sisuliselt Windowsiga DisplayPort-i taga kasutatavad: https://www.dell.com/support/article/us/en/19/sln295708/display-windows-move-resize-after-resuming-from-sleep-state?lang=en
Lühidalt on asi selline, et "kui kasutate 3840x2160 resolutsiooni ja 60Hz", siis pärast monitori magamast ärkamist on Windowsi aknad ülemises vasakus nurgas hunnikus, kõik 640x480.
U3219Q kuulub ka sellesse klubisse.
"Lahenduseks" pakutakse 30 Hz refresh rate peale sundimist.
Pisut arusaamatuks jääb, kuidas sellist saasta üldse müüa saab.
Mul veel vedas, sest saan enne väljalülitamist monitori KVM-ga Linuxi masina külge lülitada.
Alari A.
07.01.2020 00:13:22
| loox, Dell on Linux only. Macidel Thunderbolt->Displayport kaudu on Delli monitoridel samuti probleeme.
| Kommentaarid: 681 loe/lisa |
554 |
08.01.2020 13:57:10
27GL850 mudelist tehti 27gn950-b, peaks normaalsema hinnalipikuga tulema kui üleval mainitud asus
https://www.lg.com/us/monitors/lg-27gn950-b-gaming-monitor
Killer85
08.01.2020 14:53:11
Küll alles tuleb neid pisikesi ekraane.
30"+ segmenti võiks ka miskit huvitavat rohkem tekkida.
| Kommentaarid: 69 loe/lisa |
67 |
Killhoven
OC`er
08.01.2020 15:25:59
Tõsiselt kahju, et neid 4k 27" ekraane veel edasi vorbitakse. 27" on liiga väike et 4k korralikult välja tuua; 32" oleks omajagu parem kuid neid ei tehta nii palju
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 410 loe/lisa |
352 |
Auron
08.01.2020 20:41:37
| Jap, 32" 16:9 ja 42" ultrawide võiks suht uus levind standard olla.
133 |
09.01.2020 00:22:02
Muarust võiks lihtsalt mõnusaid standardseid asju toota:
24" 1080p ja seda aina parendada
27" 1440p ja seda aina parendada
32" 4k ja üles ning seda aina parendada...
ja igast UW jne. kurvid-gimmickid ka, kel tarvis.
Allosas peaks juba olema head paneelid ning kiire reaktsioonikiirus + lisad (vastavalt kihtidele siis hinnad).
Aga millegipärast toodetakse enamuses ikkagi üpris naljakaid asju.
182 |
pots4t4j4
13.01.2020 17:27:29
| aceri nitro 4k 144 oli Eu amazonis vahepeal 700 midagi postiga, ei paista nagu mingi eriline diil see nixeus, vahepeal mõtlesin isegi proovida aga ei viitsi ausalt ips loteriid mängida.
401 |
NATAS999
17.01.2020 06:55:30
kui on siit juba läbi käind, võib kustutada.
prillideta 3D monitorid leiutatud .
| Kommentaarid: 41 loe/lisa |
39 |
loox
17.01.2020 18:17:28
U3219Q puhul esines kirjeldatud viga ainult Windows 7-ga. Pärast Windows 10-le uuendamist kadus see jama ära.
Anna tooli
300 |
Auron
26.01.2020 09:34:47
Pole hinnal häda midagi - kui on ostetud paar 800.- maksvat molli mida veavad miskid 2080Ti'd sli's siis 110.- on nohu
133 |
time123
26.01.2020 23:38:20
| Kalibreerisin kõik oma 4 (odavama otsa) monitori fotoluksist renditud SpyderPro kalibraatoriga ära ja tegi kõikidel värvid oluliselt lillakamaks (tint-i peab nüüd fotodel oluliselt vähendama, et silmaga vaadates hea oleks). Kas monitorid kipuvadki liialt rohelist pilti näitama by default?
| Kommentaarid: 205 loe/lisa |
180 |
erko
27.01.2020 00:10:26
| time123 kirjutas: |
| Kalibreerisin kõik oma 4 (odavama otsa) monitori fotoluksist renditud SpyderPro kalibraatoriga ära ja tegi kõikidel värvid oluliselt lillakamaks (tint-i peab nüüd fotodel oluliselt vähendama, et silmaga vaadates hea oleks). Kas monitorid kipuvadki liialt rohelist pilti näitama by default? |
Sõltub, millise võimekusega on monitorid ning milliseks sa kalibreerimise targeti (profiili) seadsid ja mis nuppe kuhu suunas sa monitoride peal keerasid. Kui päris täpselt ei tea mida teha siis annab tulemuse üsna pekki keerata. Samas mõnda monitori ei saagi kalibreerida, nii kehv on paneel.
| Kommentaarid: 26 loe/lisa |
26 |
time123
27.01.2020 00:14:33
| Kalibraator tegi monitoridele õiged(?) värviprofiilid, mida saab siis enableda-disableda.
180 |
erko
27.01.2020 00:47:56
| Oled sa kindel, et kõik monitorid said ikka oma individuaalse profiili? Ma pole küll ekspert kuid nelja samaaegse monitori kalibreerimine ei pruugi üldse nii lihtne olla. Mis kaardi küljes need on? Kas kõik ühe väljundi taga (nt DP)? Mis op.süs.? Kuidas sul kalibreerimise protsess välja nägi?
26 |
pots4t4j4
27.01.2020 12:28:39
| Millal vg259qm ja vg279qm reaalselt müüki tulevad, on kellelgi kuskilt silma jäänud?
401 |
Rauno266
28.01.2020 01:22:29
Eve avalikustas täna oma kolm uut Spectrum monitori, mis tulevad Q3 müüki. Hinnad paistavad ulmeliselt head, kui keegi tahab midagi nii kallis üle poole aasta ette broneerida.
https://evedevices.com/pages/full-specs
1440p 144Hz - 359€
1440p 240Hz - 499€
4k 144Hz - 599€
Kui on vaja jalga monitorile, siis see on 99€ lisaks.
| Kommentaarid: 45 loe/lisa |
41 |
28.01.2020 05:22:12
Miks see 4k nii odav on?
Kahtlaselt liiga odab.....
NATAS999
28.01.2020 06:55:00
Kahtlaselt liiga odab..... |
odavad 43" 4k hdr telekad c.a. 350€ koos jalaga. 27" non hdr eest 700€ ei ole kuskilt otsast odav.
39 |
