Üldiselt need artiklid ja uuringud mulle tunduvad nagu sigri-migri, sest nendest ma suurt midagi aru ei saa, küll aga võin jagada järgnevat:
Ingliskeelne tehniline mudru:
“The Lilly Wave called a balanced bidirectional pulse pair invented by John Cunningham Lilly is a carrier waveform that bypasses the mind’s subconscious defense systems. It has been monitored via oscilloscopes connected to homes A/C ground and neutral of powerlines. It can be used to transmit mind control via ultrasonic (1 – 10MHz) and electromagnetic wavelengths (600m to 1e-15m). •Electromagnetic wavelengths transmit long/short/FM wavelength radio waves, and TV/telephone/wireless signals or energies. They are also responsible for transmitting energy in the form of microwaves, infrared radiation (IR), visible light (VIS), ultraviolet light (UV), X-rays, and gamma rays (1996) • The Lilly wave can be neutralized via pink or white noise generators connecting to the non-voltage A/C ground and neutral of the homes power grid.
The goal was to find an electric current waveform with which animals could be stimulated through implanted electrodes for several hours per day for several months without causing irreversible changes in threshold by the passage of current through the tissue.
Many waveforms, including 60-cps. sine-wave current could apparently be used safely for these limited schedules of stimulation. They could not be used for the intensive, long-term schedule of chronic stimulation. Electric current passed through the brain can cause at least two distinct types of injury: thermal and electrolytic.
The technical problem in chronic brain stimulation is to stay above the excitatory threshold and below the injury threshold in the neuronal system under consideration. This result can be achieved most easily by the proper choice of waveforms and their time courses; and less easily by the choice of the range of repetition frequencies and train durations.
The previous wave forms used in neurophysiology and in neurosurgery injured the neurons when unidirectional current passed through the brain. Dr. Lilly developed a new electrical wave form to balance the current, first in one direction and then, after a brief interval, in the other. Thus ions moving in the neurons would first be pushed one way and then quickly the other way, stimulating the neurons and leaving the ions in their former positions within the neurons. This new wave form was called a balanced bidirectional pulse pair, or the Lilly Wave. Microscopic studies of brains stimulated with this balanced pulse pair showed that there was no injury of the neuronai networks from this kind Waveform of stimulating current: pulse pairs of current resulting from quasi-differentiation, with passive electrical elements, of a rectangular pulse. Measured at 2 percent of the peak, the duration of the positive pulse (upward) is 34 µsec, and the duration of the negative pulse (downward) is 28 µsec. stimulation.
Lühikokkuvõttes pidi üle maailma elektrivõrkude alajaamades, või kus iganes, olema nn. "must kast", mis seda toodab.
Kuidas muu signaal vahele pannakse, ei tea. Äkki polegi vaja ja piisab teleka vaatamisest ja mõnest väikesest "suunavast võnkest" mõjuks. Kes oskab, mõõdab.
Ja midagi ainult herr tahanteada-le kommenteerimiseks, juhuks, kui AM millalgi lubab ja kaasfoorumlased enne ära ei söö.
John C. Lilly tehtud psühhedeelsetesse uuringutesse tuleks ettevaatlikult suhtuda. See mees ammutas inspiratsiooni ka LSD-st ja ketamiinist.
Oot mismoodi saab keegi mu maandusesse ja neutraaljuhti mingit sagedust saata? Palun nüüd tehniliselt ära seletada, mitte kopeerida mingi narkomaani fantaasiaid.
See ei ole tehniliselt võimalik isegi kui keegi seda keerulisi sõnu kasutades kirjeldab.
Palun hoiame luulud ja vandenõuteooriad tehnilisest teemast eemal. Vandenõuteooriate jaoks on oma teema, mõni mode võiks teemat ilmselgetest vandenõumaigulistest postitustest puhastada ja need õigesse teemasse suunata.
See spektogramm näitab ju, et keegi on lihtsalt müra võimendanud. Mida seal kommenteerida?
Üldiselt spektogramm oli möeldud ainult härra tahanteadale kommenteerimiseks, siiski.
LSD kohta nii palju, et selleks ajaks kui ta sinna maani jõudis, oli härra juba vähemalt 50, perioodil, mil see oli lubatud, selle testimise eest sai rahvusliku vaimse tervise instituudi käest (NIMH) palka, pluss aastaid kõikvõimalikke (tipp)koole läbitud ja kraade omandatud nii füsioloogia kui ka elektroonika valdkonnas ammu enne seda.
Häbi hakkab lugeda, mis kaasfoorumlased kirjutavad. Parem sellise suhtumise tõttu üldse enam mitte.
Umbes nagu mu telefon 4G võrgus tipptunnil rongis ära häkiti. Kui CERT-RIA ka selle peale midagi öelda ei oska (nii on),
siis tundub, et on aeg asjad kokku pakkida ja 5G aegu isegi mitte ootama jääda, ennetava meetmena.
Ära nüüd lärma ja selgita kuidas keegi mind maanduse ja neutraali kaudu kontrollib. Kuidas sa saad mulle maanduse kaudu midagi saata kui see signaal läheb enne minuni jõudmist maha?
Kui mees nii tark on, siis peaks ta suvalise pläusti asemel tehnilist juttu kirjutama. Sellist ümmargust pläusti oskab iga kirjanik välja mõelda.
Kas sa oled üks nendest, keda “keegi” pidevalt jälgib ja kelle telefoni sisu on kindlasti kellelgi vaja? Hahaa. Unista edasi.
Tõesti hakkab häbi mõne kaasfoorumlase postitusi lugedes!
Hea veel, et telefon elektrirongis ära häkiti, saab Elroni süüdistada. Oleks sitamajas juhtunud, käiks nähtavasti ristiretk Tallinna Vee vastu!
Edaspidi tasuks ikka põhikooli füüsikatunnid läbida. Siis saad teada, et "digitaalselt tehtud" siinus on kogu aeg - oma 100 aastat - täpselt selline olnud.
Isegi NSVL-is toodeti juba nii a 40-50 (või ka kauemgi) aastat tagasi elektroonikaseadmeid kus olid samuti elektroonilised toiteplokid kasutusel.
Ning oli samamoodi olemas probleem, et need toitegeneraatorid tekitavad elektrihäireid.
See on ikka kohutav kui lühike on eestlastel Tehnika-ajaloo mälu.
Laulude-tantsude korral võiks ikka ka muud mäletada mis varem olnud on.
Huvitav, kas see on organiseeritud tegevus siin, et mingi kõrvalise infoga teemalt tähelepanu kõrvale juhtida?
Jah, harmoonilised elektrivõrkudes on tänapäeval tõsine probleem, aga selle kohta võiks eraldi teema teha. Mobiilivõrke selles süüdistada ei saa.
Eks kõik sõltub sellest, kui suure portsu saad korraga. Võib olla nõrk kiirgus 24/7 tõesti midagi ei tee või mõju ilmneb alles pikema aja möödudes. 80-ndatel oli siinkandis üks eruohvitser, ostis suvila ja harrastas tervislikku eluviisi ja värskes õhus viibida. Ütles, et tänu sellele veel elus on, kolleeg olevat juba ammu teises ilmas. Oli juhtunud õnnetus, olid midagi teinud töötava lokaatori juures. Saatja antennikaabel oli pistikust lahti tulnud ja enne kui ruumist välja said, said juba piisavalt kiiritada. Radari sagedus seal 5G sageduse kandis või rohkem, täpselt ei tea. Olin Paldiskis õhutõrjes partisaniks, seal ka hoiatati, et sihtimisradari ette ei tohi jääda, kui see töötab.
Kuskile mujale postitasin ühe video, kus üks härra väidab, et suure vooluga kiirgus pidi nende sageduste juures turvalisem olema.
Samamoodi eruohvitser. Äkki mitte selles videos isegi, aga mujal siis. Huvitav miks?
100 aastat digitaalset siinust
Ma tean väga hästi, et seda põhjustavad igasugused impulsstoiteplokid ja muu jura. Räägiti siin ajuhalvavatest signaalidest, mida edastatakse elektrivõrgu kaudu. Tõin lihtsalt näite, milline see siinus praegult on. Milline tipp seal kellegi aju mõjutab, on iseasi. Ja elektrivõrku on kasutatud sidepidamiseks juba siis, kui polnud veel mingeid tänapäeva mõistes arvuteid ega midagi. Järelikult seal siis liiguvad kahtlased signaalid.
Kui on tõesti soov rohkem teada saada, pole eestikeelne ekspertarvamus isegi klikivääriline. Sorri.
sama hästi võib võtta mõne lapiku maa lehe pealt mingi uurimustöö ja siis seletada et maa ei olegi ümar ja gravitatsiooni pole olemas ja asjad on maa küljes sest tihedus.
Üldiselt: kui inimene usub, et miski teda mõjutab, siis nii ka juhtubki.
Kui probleeme mitte välja mõelda ja tervet mõistust kasutada, elad rõõmsana kaua. _________________ Albert Einstein: "Vaid kaks asja on lõpmatud, universum ja inimlik rumalus, ja selles esimeses pole ma nii kindel."
perseas: Sugulased ehitasid uues majas kogemata Faraday puuri. Ilma akendeta ruum, betooni terasarmatuur varjestab igasuguse mobiililevi.
Üldiselt tegelikult remont käib küll elukohas, leviprobleemid tõesti mingi karkassi tõttu, aga pilt on palju koledam, kui siin kirjeldatud.
NATAS999 kirjutas:
Ise selle lapiku maa fanaatik pole, aga saan aru, et need inimesed miskipärast usuvad sellist absurdset asja.
Tuleb arvestada, et enamus ehitustöid tehakse nn. lapiku maa parameetrite järgi. Maa tasapindsus ja muud tegurid.
Kui vaja kooli rajada, näiteks. Maa peab lapik olema ju vundamendi rajamise jaoks, kui pole, siis tuleb ju siluda
Mul praegune üürimaja mingi spetsialisti poolt katuseplekiga kaetud. Esineb ka mõningaid leviprobleeme... _________________ Tahad autovaruosi hea hinnaga? Kirjuta mulle ja saad mu kaudu suurema soodustusega konto ühes tuntumas veebipoes.
Selle kohta tekib küsimusi, muuseas. Üldiselt kui telefon käima panna levialas, siis saan helistatud nii oma toas, kui ka köögis, aga kui mingil põhjusel ühendus ära peaks kaduma korteri sees siis ei aita ei taaskäivitamine ega ka lennurežiimi näppimine, ühendust miskipärast ei saa.
Õue minna ja levi kätte saan, siis saab toas jälle helistada määramata ajani. Äkki keegi levispetsialist oskab kommenteerida?
TT, äkki aitab juba selle sinu ulmepõhikooli füüsika nämmutamisest igas postis Põhikooli füüsika ainekava, loe.
Digitaalselt tehtud siinus põhikooli füüsika õppekavas!? Digitaalselt tehtud siinus 100 aastat!? Mäh
Minu käesoleva teemavälise posti võivad moded ära kustutada, aga no ei suutnud TT järjekordse pläusti kohta vaiki olla.
Mis siin ikka kosta, Teie kui kõrgema eksperdi arvamusele pole mul midagi lisada.
Üldiselt antud juhul tegu minu isikliku eelistusega. Selle kommentaari peale tegin küll lahti,
tekst korralik, aga minu jaoks kõlbaks ainult plagiaraadiks ehk copy-pasteks, kui kedagi tõesti huvitab.
Liiga tehniline valdkond emakeele jaoks...Inglise-vene keeles leiab ehk veel midagi teemakohast...spämmi seest, võib-olla
Kui sinu tehniline baas on suur null, mida on siin teemas ülihästi näha, siis ei ole sa absoluutselt mitte keegi sellist dokumenti kommenteerima.
Füüsika kehtib olenemata kas sa usud seda või mitte. Loodusseadusi ei koti kellegi arvamus või isiklik eelistus.
lugesin ka vähe seda kirjatükki. see selline puhtalt väidetest kubisev mõnus jutuke. lisaks siis et ühes kohas räägib et 1GHz on mikrolaine, teises kohas, et 180GHz on 5mm. eriti meeldis algusest see koht, kus kirjutab, et igast uurimusi ja värke on tehtud ja pole leitud et miskit mõju organismidele avaldab, aga näe mina neid tulemusi vot mitte kohe ei usu.
üsna selline "keegi pole maakerast pilti teind ja need pildid, mis on tehtud, on võltsing, maa on tegelikult lapik" jutt.
