uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GeForce ForceWare Driverid märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 54, 55, 56, 57  järgmine
ccplazza
ccplazza
sõnum 16.01.2019 14:43:40 vasta tsitaadiga
londiste kirjutas:
https://forums.geforce.com/default/topic/1082681/geforce-drivers/is-it-possible-to-quot-port-quot-dithering-from-nvidia-x-server-to-geforce-driver-/post/5934577/#5934577
Proovisin ka seda. Panin 10 bit temporali key registrysse ja Lagomi gradient testis on tulemus palju parem. Rohkem pole hetkel testinud.
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 59
Anna tooli
sõnum 10.03.2019 14:55:12 vasta tsitaadiga
NVIDIA Is Officially Ending Driver Support for 3D Vision
https://nvidia.custhelp.com/app/answers/detail/a_id/4781
sõnum 22.03.2019 03:22:44 vasta tsitaadiga
NVIDIA Releases GeForce 419.67 Creator Ready Drivers
https://www.techpowerup.com/253926/nvidia-releases-geforce-419-67-creator-ready-drivers#comments
Nvidia has released the 419.67 CRD Creater Ready Drivers. This driver is for GeForce 1050 series and higher graphics cards under Windows 7 and 10. The CRD drivers are a new class of driver, alongside WHQL and Beta releases, that specifically improve performance and stability in creative applications such as Adobe Photoshop CC, Adobe Premiere Pro CC and Cinema 4D. Select Creator Ready Driver from the bottom drop-down box on the driver download page if you want to obtain these drivers.
sõnum 11.04.2019 16:06:42 vasta tsitaadiga
dxr draiverid:
https://www.techpowerup.com/254528/nvidia-extends-directx-raytracing-dxr-support-to-many-geforce-gtx-gpus
- londiste
Gap
Gap
sõnum 22.04.2019 12:51:44 vasta tsitaadiga
on keegi installinud ka omale,kellel on näiteks eelmise seeria kaart(pascal) need viimased 425.31 WHQL Raytracing toega driverid ? kuidas nad muidu käituvad ? on stabiilsed, mingeid jamasi ei esine ?
busta
busta
sõnum 23.04.2019 18:09:25 vasta tsitaadiga
Gap, Toimivad küll.
sõnum 01.05.2019 03:06:38 vasta tsitaadiga
https://www.techpowerup.com/255034/nvidia-releases-geforce-430-53-hotfix-driver-fixing-high-cpu-utilization-caused-by-telemetry
Driver number 430.53 addresses reported issues of high CPU utilization (due to NVDisplay.Container.exe) on NVIDIA's previous 430.39 WHQL driver
https://www.techpowerup.com/forums/threads/nvcleanstall-clean-installer-for-nvidia-drivers-alpha.249085/
sõnum 02.05.2019 12:11:23 vasta tsitaadiga
Shadowplay ilma GFE'ta ei toimi, ehk Telemeetria jne. tuleb juba ka kaasa?
sõnum 02.05.2019 12:52:48 vasta tsitaadiga
rmc, Neist on ehk abi:
https://github.com/NateShoffner/Disable-Nvidia-Telemetry
https://github.com/Moyster/BaiGfe
angel
angel
sõnum 17.06.2019 00:12:04 vasta tsitaadiga
Küsimus: kas nvidia on oma telemeetria viimastes driverites ära jätnud kui geforce experience'i peale ei pane? Vanasti sai autoruns jms softiga neid keys'id maha võetud, nüüd enam ei leiagi vasta softiga võtmeid icon_rolleyes.gif
sõnum 17.06.2019 02:33:41 vasta tsitaadiga
angel, Ei. Telemeetria on vaikimisi enabled sõltumata sellest mis komponendid sa peale lased. Installer ei lase isegi valida, et kas telemeertia on off või on.
Ainuke lahendus ongi kolmanda osapoole utiliitide kasutamine. Registrivõtmete mahalaskmine pole hea mõte, sest esiteks need muutuvad ja teiiseks on oht midagi vajalikku maha lasta.
Parem kasuta mõned postid ülevalpool väljatoodud utiliite.
angel
angel
sõnum 17.06.2019 23:24:42 vasta tsitaadiga
Ee seda ma just küsisingi, et autoruns ja disable nVidia telemetri ei leia miskit. Vanasti võtsin autoruns'iga võtmed maha ja nvidia telemetry disable tööriistaga vaatasin veel üle. Nüüd aga ei leia mitte muhvigi nende abil. icon_rolleyes.gif
sõnum 18.06.2019 07:48:38 vasta tsitaadiga
angel, Kaks võimalust: kas Nvidia on muutnud teenuste/registrivõtmete nimesid ja seetõttu ei leia need tööriistad enam midagi või siis paigaldasid juba moditud draiverid kust telemeetria välja korjatud. Või kui pole clean install, siis vb oled juba varem eemaldanud?
angel
angel
sõnum 21.06.2019 22:09:25 vasta tsitaadiga
Tomorrow kirjutas:
enne igat driveri installi lasen süsteemi DDU 'ga üle ehk siis täiesti puhas purk. Ja alati tõmban driverid nvidia enda kodukalt, igasugu mode'itud juraga ei hakka isegi jändama kui selline asi peaks olemas olema. Ise kasutasin autoruns vanakooli tarkvara ja otsisin nii telemetry kui nVidia key'sid ja miskit ei leia. Võimalik, et nüüdsest pannakse telemeetria ainult neile peale kes geforce experience'i kasutavad? Seda telemeetria jura on selle tarvis vaja minuteada. Ilma selleta see vähemalt ei tööta (geforce experience).
-edit-
Keegi veel sellise asja vastu on huvi tundnud ja märganud miskit muutust uuemate driveritega telemeetria osas?
Gap
Gap
sõnum 12.07.2019 12:06:05 vasta tsitaadiga
https://www.guru3d.com/files-details/nvidia-frameview-download.html
FrameView is NVIDIA's own benchmark software for graphic cards based on PresentMon and can measure frame rates, power consumption and frame times. The company offers the release as public beta of the software.
sõnum 26.07.2019 15:06:09 vasta tsitaadiga
https://www.techpowerup.com/257708/nvidia-rushes-out-geforce-hotfix-431-68-driver-to-address-broken-mouse-pointer
nägin ka seda probleemi korra peale draiverite installi. huvitaval kombel kadus see küll peale esimest restarti ära.
enda kogemusest - asja muutis mängust välja minek aga mitte suvalisest vaid windows store/äpp mängust. forza street minu puhul. töötas ka niipidi, et kursor lükati mõneks ajaks tööle tagasi. lisaks oli mingi seos multimonitoriga, ühel monitoril oli asi okei aga monitoride vahel liikudes kippusid katki minema.
- londiste
angel
angel
sõnum 26.07.2019 16:59:51 vasta tsitaadiga
See hiire jama tuleb tagasi pidevalt, ainuke viis lahendada on kas restart või siis korraks reso ära muuta ja tagasi panna. Esineb vist ainult RTX kaartidega thumbs_down.gif
Mõtlesin juba, et kaart pekkis aga meenus, et eelmise driveri versiooniga alates tekkis selline viga.
sõnum 20.08.2019 15:13:21 vasta tsitaadiga
elagu konkurents
https://www.techpowerup.com/258440/nvidia-prepares-geforce-436-02-gamescom-special-graphics-drivers
ehk siis ultra-low latency mode, integer scaling ja sharpen filter on üsna selgelt vasted amd ja inteli sarnastele featuretele.
- londiste
sõnum 21.08.2019 02:49:21 vasta tsitaadiga
Pole paha. Mõned agad siiski on. Max prerendered frames=1 juba annab enamus eeliseid. See uus Ultra säte on küll veidi parem aga iseasi kas enamus seda 10ms vahet märkab. Integer scaling on kahjuks Turing only featuur. Sharpen vajab Geforce Experience installi.
Pealegi kui Nvidial on nüüd oma sharpen filter mis point on siis üldse DLSS enam kasutada? Kas nad mitte iseendaga siin ei võistle?
EDIT:
https://www.nvidia.com/en-us/geforce/forums/game-ready-drivers/13/310429/geforce-game-ready-driver-43602-update/
NVIDIA has found a bug in our recent 436.02 driver posting, causing it to install GeForce Experience even if the user selects not to install it.
XeStAiSy
Aeg Maha 2a
sõnum 09.10.2019 11:23:25 vasta tsitaadiga
Mida mina olen 1070 kaarti pikemat kasutanud siis parimad diverid on windowsis endas olen kasutanud sellist trikki paigaldanud nõks vanema 10ne teinud kõik uuendused jas siis upgrade viimasele numbile ja unustanud igasugsed driveri uuendused. Tulemuseks sujuv voolav probleemivaba xp. Need uuemad driverid juba pidurdavad ja tulemuseks ikkagi meh iga uue driveriga vanema rauaga.
Renq
Renq
sõnum 20.11.2019 13:21:57 vasta tsitaadiga
Mul on selline mure, et alates eelmise kuu mingist driverist alates ei taha G-sync peale jääda. Valin, et nii full screenis kui windowed mode'is a siis lähen näiteks PUBGI ja vaatan, et G-sync on täitsa väljas või kui arvuti panen käima, siis on linnuke full screeni taga ainult. Monitoriks LG 34GK950F-B. Märkasin seda sellepärast, et järsku hakkasid mingi stuttering mängus pihta ja mingil hetkel kadus monitoril pilt lihtsalt ära või ei saanud ekraan signaali. Need viimased juhud on üksikud. Samas kui mängust välja minna, siis viskab korra ekraani pimedaks.
sõnum 20.11.2019 13:50:47 vasta tsitaadiga
Renq, Kindel, et monitor ise surema ei hakka? Tasub kontrollida monitori toiteadapterit (juhul kui on eraldi karbike).
Draiverite osas võib olla ka kasu DDU programmiga Nvidia asjade mahalaskmisest ja siis puhta (clean install) valikuga uuesti pealelaskmisest.
Renq
Renq
sõnum 20.11.2019 14:19:43 vasta tsitaadiga
Tomorrow kirjutas:
Monitor ma usun võiks nagu korras olla. Lükkasin DDU käima, kuidagi kaua võtab aega. 6 minutit on juba "Executing SetupApi remove Audio controller" juures. Olen seda varasemalt kasutanud ja ainult eelmine kord oli ka selline jama. Siis aitas hard reset. Või keeras mobo biosi uuendus midagi pekki. Ma ei oska midagi arvata enam.
edit: 14 minti sama koha peal
NATAS999
sõnum 30.12.2019 22:51:53 vasta tsitaadiga
kas sealt driveri installeri paketist midagi muud peale display.driver ja physx on vaja veel lahti pakkida? mul viskas see nvidinahhui paskperience sita ventikasse oma konto majandamisega ja otsustasin ddu'ga kogu pasa maha lasta ja ainult hädavajaliku installida.
e: ise küsin, ise vastan. peale farceware ikalduse täielikku eemaldamist ilmus installerisse maagiliselt valik driveri installiks ja driver koos paskperience installiks. mul enne ei õnnestund selle sittperience eest linnukest ära saada.
sõnum 30.12.2019 23:27:37 vasta tsitaadiga
Kas Windows 10 peal enam desktop programmina control panelit polegi, ainuke variant Windows Store-i äpp tirida lasta?
NATAS999
sõnum 30.12.2019 23:37:25 vasta tsitaadiga
rmc kirjutas:
windowsi enda control panelit mõtled, või nvidia oma? windowsi oma on olemas küll muidu, startmenüü lahti ja sinna kirjutad sisse control panel.
sõnum 30.12.2019 23:43:26 vasta tsitaadiga
rmc, On küll. Kui nad nüüd viimastes midagi muutnud pole. Ise hetkel 441.08 peal. Küll aga peab kontrollpaneeli jooksutamise jaoks jooksma NVIDIA Display Container LS teenus mis on veidi absurdne. Lisaks kui teenus ei jookse, siis pole kontekstimenüüs isegi Nvidia Control Panel valikut.
Endal on tehtud nii, et kui mul on vaja seda jooksutada, siis batch failiga tõmban teenuse käima ja pärast kinni. See ei pea kogu aeg jooksma. Kui kontrollpaneelist sätted paigas siis võib vabalt kinni panna. Alternatiiv oleks ehk Nvidia Inspector proge.
Uusim draiver on hetkel 441.66: http://us.download.nvidia.com/Windows/441.66/441.66-desktop-win10-64bit-international-whql.exe
Kasuks tuleb ka see: https://www.techpowerup.com/download/techpowerup-nvcleanstall/
sõnum 30.12.2019 23:47:29 vasta tsitaadiga
Värske Win10 + driverite install ja nvidia osas kodukalt uusim driveri 950M jaoks... sama versioon 441.66 ja viskab all paremal "NVIDIA Control Panel not found, click here to install ... from Microsoft store"
EDIT: tõenäoliselt DCH versioon? https://nvidia.custhelp.com/app/answers/detail/a_id/4733/~/nvidia-control-panel-windows-store-app
sõnum 30.12.2019 23:51:57 vasta tsitaadiga
rmc, Jep see läks meelest. Väldi DCH versioone kui vähegi võimalik. https://www.nvidia.com/en-us/geforce/forums/game-ready-drivers/13/300521/nvidia-dchstandard-display-drivers-for-windows-10-/
NATAS999
sõnum 31.12.2019 00:55:34 vasta tsitaadiga
tundub siis ikkagi see 441.66 vigane olema. mul sama jama mis rmc'l.
Tomorrow, kas sul ddu'ga safe modes kõik nvidia asjad maha lastud ja siis 441.66 peale pandud või lasid vanale selga? ma valisin game ready variandi. ma peast ei mäleta, mis lühend sellel oli.
sõnum 31.12.2019 03:15:40 vasta tsitaadiga
441.66 pärit NVIDIA kodulehelt, driverite valikus Win10 x64 ja viskab automaatselt siis DCH vast peale. Aga üldiselt tundus, et väga vahet polnud - kasutan selles masinas eniveis GFE-d.
Mis reaalne vahe ja vältimispõhjus on DCH vs. tavalised?
NATAS999
sõnum 31.12.2019 07:03:56 vasta tsitaadiga
rmc kirjutas:
nvidia ise ütleb, et ega muud vahet polegi, kui control panelit pole kaasa pandud ja driveri pakk väiksem ja installeerub kiiremini. link
e: siin saab valida, kas standard või dch. huvitav, miks nvidia kodulehelt kohe see tavaline driveri otsing sellist valikut ei paku vaid peab kuskilt faq'st mingit linki otsima?
xxlmaster
xxlmaster
sõnum 31.12.2019 15:07:12 vasta tsitaadiga
Mis gtx1080 kõige etem driver on hetkel?
sõnum 31.12.2019 15:13:21 vasta tsitaadiga
xxlmaster, Raske öelda. Ise pole oma kaardil küll mingit erilist vahet märganud. Selleks peaks paar päeva võtma, et testida nt 5 erinevat draiverit 5 erineva mootoriga mängus, et mingid tulemused saada.
NATAS999
sõnum 31.12.2019 16:01:11 vasta tsitaadiga
üldiselt ikka uusimad peaks parimad olema. ega kaart kiiremaks vaevalt läheb, värskematele mängudele mõne % jagu perfi juurde optimeeritud ja that's it.
xxlmaster
xxlmaster
sõnum 31.12.2019 16:43:48 vasta tsitaadiga
Seda küll. Lihtsalt sai selline kaart ligi võetud ja pole selle hingeeluga väga kursis.
sõnum 31.12.2019 17:31:03 vasta tsitaadiga
rmc kirjutas:
Testimise järg jõudis CS:GO-ni ja must screen launchil. DDU ja tavalised driverid selga - see Store-ist pärit Control Panel oli vaid ühe kategooria seadistusega ka, ala PhysX processor jmt.
EDIT: DDU-d hakkasin kasutama, kuivõrd tavarookimine pold piisav ja DDU ka ei saanud hakkama.
Uurin nüüd eelnevalt jagatud linke selles osas, kuidas tagasi minna.
EDIT2: Nvidia enda setup isegi sai hakkama, nagu siin öeldud: https://nvidia.custhelp.com/app/answers/detail/a_id/4777/
Inteli driveri jääb DCH vist igatahes.
EDIT3: CS:GO töötab nagu vaja - tundub, et kena M$ uuendus taaskord. Ajuvaba, et NVIDIA sellega tuimalt kaasa läheb.
Gap
Gap
sõnum 31.12.2019 19:50:54 vasta tsitaadiga
441.66 on väga head driverid .. Minuarvates pole tükk aega nii häid drvivereid nvidial olnud thumbs_up.gif endal ka need pikemat aega juba ja probleeme ei ole.
xxlmaster
xxlmaster
sõnum 04.01.2020 13:42:38 vasta tsitaadiga
Arvuti otse hdmiga pc järel ja iga kord kui teleka välja lülitan on ekraan scale-ist väljas.
Korraks reso vahetada ja scaleb ära uuesti aga niikui telekas sisse välja lülitada on jälle sama jama. Win7 sellist jama polnud, nüüd win 10 . Keegi oskab öelda milles võiks asi olla?
Reso 4k.
sõnum 04.01.2020 15:19:34 vasta tsitaadiga
Scaling on manuaalselt paika pandud või auto peal?
xxlmaster
xxlmaster
sõnum 04.01.2020 16:31:15 vasta tsitaadiga
rmc kirjutas:
Mida päris täpselt mõtled?
Siin reaalselt kõike näppinud
tulemus ikka sama. FH4 mängides 1440p resol jäävadki teleka servadesse mustad ääred, ainult 4k mängides on full screen.
tofay
sõnum 04.01.2020 17:49:15 vasta tsitaadiga
Ajad segamini 4k ja uhd, teler pane 3840 x 2160 (väga kahtlen, et 4k teler on, aga vabandan ette kui nii)
/edit pildi all kirjas native reso.
Kommentaarid: 12 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 10
xxlmaster
xxlmaster
sõnum 04.01.2020 21:52:18 vasta tsitaadiga
tofay kirjutas:
Telekas jah uhd aga see probleemi ei muuda. Tv käima ja ekraan on off scale. Muudan reso 4k v 2k siis korras... Kuniks järgmise teleri sisse /välja lülituseni.
Gap
Gap
sõnum 07.01.2020 14:22:25 vasta tsitaadiga
https://www.guru3d.com/news-story/nvidia-to-release-ces-2020-game-ready-driver.html
sõnum 08.01.2020 20:35:23 vasta tsitaadiga
NVIDIA Ends Quadro Driver Support for Windows 7 and Other OSes from Mid-January
https://www.techpowerup.com/262722/nvidia-ends-quadro-driver-support-for-windows-7-and-other-oses-from-mid-january
sõnum 15.03.2020 16:26:10 vasta tsitaadiga
keegi on kohanud sellist häda, et mitme monitoriga mängud ei hakka tööle või tahavad tööle hakata valel monitoril?
mul on võrdlemisi nõme monitoride konf - 1440p@165hz, 1440p@60hz ja pool aega on ka 2160@60hz telekas küljes - ja mängud viimasel ajal stabiilselt feilivad.
mu best guess on et see seondub saadavalolevate resode (pluss sagedus) nimekirjaga, mida mängud lihtsalt ei handle.
võimalik, et mingi nvidia draiverite pull aga paar hiljutist guugeldamist näitasid sarnaseid asju ka amd kaartidega nii et mingi windowsi update võib-olla?
- londiste
angel
angel
sõnum 15.03.2020 22:54:13 vasta tsitaadiga
londiste kirjutas:
Mul oli sarnane viga ikoonidega. Ikoonid olid teisel ekraanil ja pea ekraan oli puhas. Korda sain peale C:\Users\xxxx\AppData\Local IconCache.db kustutamist. Tunduks, et viga tekkis peale win 10 update'i kuna nvidi drivereid pole ammu viitsinud uuendada. Peale uute driverite peale panekut viga kordus kuniks mainitud faili ära kustutamist. Sama asi oli ka mängudega vahepeal. Mäng tahtis hakata sellel ekraanil tööle kus desktop ikoonid oli, vaatamata sellele, et see ei olnud primary.
Ekraanid on 1440p mõlemad aga erineva Hz'iga
sõnum 26.03.2020 16:45:28 vasta tsitaadiga
NVIDIA Announces DLSS 2.0 and New GeForce 445.75 Game Ready Drivers
https://www.techpowerup.com/265006/nvidia-announces-dlss-2-0-and-new-geforce-445-75-game-ready-drivers
Kas juhtub ime ja DLSS-st saab veel asja?
sõnum 26.03.2020 19:39:33 vasta tsitaadiga
näeb jätkuvalt välja nagu sharpen filter oleks peal :/
muus osas on sedapuhku võrdlusvideod üsna muljetavaldavad.
edit:
https://www.overclock3d.net/reviews/software/did_nvidia_fix_dlss_dlss_2_0_analysis_with_mechwarrior_5_mercenaries/1
- londiste
sõnum 24.06.2020 22:38:51 vasta tsitaadiga
https://www.nvidia.com/en-us/geforce/news/directx-12-ultimate-game-ready-driver/
Furthermore, in addition to introducing support for DirectX 12 Ultimate, the Windows 10 May 2020 Update also added a new feature called Hardware-accelerated GPU scheduling. This new feature can potentially improve performance and reduce latency by allowing the video card to directly manage its own memory.
To enable hardware scheduling, you can open “Graphics Settings: Change Default Graphics Settings”. Simply toggle the feature on and restart the system and you’ll reap the full benefits of the feature.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GeForce ForceWare Driverid mine lehele eelmine  1, 2, 3 ... 54, 55, 56, 57  järgmine
