| Kui vana on sinu igapäevaselt enimkasutatav teler? |
| Alla 1 aasta |
11% |
[ 50 ] |
| 1-3 aastat |
31% |
[ 141 ] |
| 4-6 aastat |
25% |
[ 114 ] |
| 7-10 aastat |
18% |
[ 83 ] |
| 11-13 aastat |
7% |
[ 33 ] |
| 14-16 aastat |
3% |
[ 15 ] |
| 17-20 aastat |
0% |
[ 4 ] |
| Üle 20 aasta |
1% |
[ 5 ] |
| hääli kokku : 445 |
pots4t4j4
20.03.2019 14:09:48
| jeesus188 kirjutas: |
Tundub, et selle aasta LG OLED´i hinnad on samas suurusjärgus, mis eelmine aasta
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1552901822
LG 2019 OLED TVs – pricing & availability
C9 LG OLED TVs
55" OLED55C9 - $2,499 (available in April)
65" OLED65C9 - $3,499 (available in April)
77" OLED77C9 - $6,999 (available in May)
E9 LG OLED TVs (glass)
55" OLED55E9 - $3,299 (available in June)
65" OLED65E9 - $4,299 (available in April)
W9 LG SIGNATURE OLED TVs (wallpaper)
65" OLED65W9 - $6,999 (available in June)
77" OLED77W9 - $12,999 (available in June)
Ja samsugi hinnad ka enamvähem olemas tippmudelitele
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1552924662
Samsung Q90R (US / UK / DE)
55” Q90R - - / £2,799 / €2.899
65” Q90R - $3,499.99 / £3,799 / €3.799
75” Q90R - $4,999.99 / £4,999 / €5.999
82” Q90R - $6,499.99 / -
Samsung Q80R (US / UK)
55” Q80R - $1,999.99 / £1,999
65” Q80R - $2,799.99 / £2,499
75” Q80R - $3,999.99 / -
Samsung Q70R (US / UK / DE)
49” Q70R - $1,249.99 / £1,499 / €1.499
55” Q70R - $1,499.99 / £1,699 / €1.899
65” Q70R - $2,199.99 / £2,199 / -
75” Q70R - $3,299.99 / £3,499 / €3.899
82” Q70R - $4,499.99 / £4,799 / -
Samsung Q60R (US / UK / DE)
49” Q60R – $999.99 / £1,099 / €1.149
55” Q60R - $1,199.99 / £1,299 / €1.349
65” Q60R - $1,799.99 / £1,799 / €1.999
75” Q60R - $2,999.99 / £2,799 / €2.899
82” Q60R - $3,799.99 / £3,999 / €-
65c8 on juba 2k tea kas veel odavamaks ka läheb peale c9 tulekut?
401 |
20.03.2019 14:14:58
pots4t4j4, ega ma selgeltnägija pole
Aga kui sa vaatad C7 hinna kujunemist, siis see piir kusagil seal kandis ole. vb 10% veel venitab alla. Rohkem küll ei julge ennustada.
Müüakse laod tyhjaks ja juurde enam neid ei tule.
raigo
| Kommentaarid: 15 loe/lisa |
14 |
7 :: |
360 |
muhvits
22.03.2019 01:32:11
Kui ma ei eksi siis see pill on edge light ja mitte FALD. Ehk idee poolest peaks "blooming" efekt näha olema. Samuti võiks qled nõrgaks kohaks olla külje pealt vaatamine.
Teiselt poolt kui vaadata võrdluseid (seal küll on tavaliselt Q8F või Q9F) siis qled kipub värve soojemas toonides kuvama. Kumb erksam värvide mõttes - see on minu arust vaataja maitse asi.
Samas tundub et OLED suudab paremini väikeseid detaile välja tuua.
Qled eelis tundub (luumeneid võrreldes) olevad ka see et ta on "heledam" (samas poes ise kiigates oled ei tundu oluliselt "tuhmim").
iguaan
23.03.2019 14:45:27
Kellelgi kokkupuuteid Hisense H55U7A?
Euronicsis hetkel 600.- välismaised foorumid kohati soovitavad seda üle Samsungi NU7400 seeria.
Nagu aru sain, siis samsungiga oht heli osas, kui tahta striimida nas kettalt?
Ja kuidas selle OS olemuselt? Oluliselt kehvem WebOs'st?
| Kommentaarid: 83 loe/lisa |
71 |
pots4t4j4
23.03.2019 14:47:30
Mis kasutajaliidese sa nende hisensede jms kahtlastega kaasa saad pole minuarust seda säästu väärt, samas kui smart osa üldse tähtis pole siis pole väga oluline.
Näiteks mingit philipsi UI näppida oli tahtmine peast kinni võtta ja appi karjuda, kes küll sellise jama valmis tegi,ükski asi polnud loogiliselt üles ehitatud.
401 |
C1rca
23.03.2019 16:18:04
| iguaan kirjutas: |
Ja kuidas selle OS olemuselt? Oluliselt kehvem WebOs'st? |
Kaalusin ka Hisense U7A ja Samsungi. Hisense miinus ikka päris kitsas vaatenurk. Sammu keskelt kõrvale teed siis praktiliselt kohe värvid muutuvad.
Kuna minu jaoks smart funktsioonid mingid megatähtsad ei ole siis lõpuks ostsin pimesi Philipsi.
https://www.hinnavaatlus.ee/1230771/philips-55-55pus6803/
Pole veel küll kätte saanud aga vahepeal oli see Hansapostis 499 ja netist uurides sai 6703 mudel päris palju kiita. See 6803 peaks suht sama paneel olema ma eeldan, et selle hinna eest peaks päris hea olema.
Eks kui kätte saan siis muljetan.
97 |
nunnu
25.03.2019 14:48:21
Kirjutagu see, kellel on võimalust ära mõõta kui pikk HDMI pulk mahub nende mudelite tagaküljel olevasse HDMI pessa. Amazoni 4K pulk on 110mm pikk. Kas mahub ära? Samuti mis on jala mõõt. Manuaalis sügavus 318.7mm. Kapp on 300mm.
65SK8500
UE65NU8002
_________________ Pooldan igareedeseid kondoomivastaseid ühiskogunemisi vabaduse väljakul. |
| Kommentaarid: 19 loe/lisa |
18 |
04.04.2019 14:31:26
link :: LG acquires DuPont's OLED tech to inkjet-print OLED displays
Hinnad võivad veel odavneda ja pilt veel paremaks minna
kyrvas
agox57
05.04.2019 12:10:49
| Küsimus kas telekat mis on ostetud poest, originaal pakendis võib transportida ka pikali asendis või ainult püsti.
05.04.2019 12:12:56
Iseenesest on nad normaalselt pakitud, lühema otsa puhul ei näe küll probleemi (kui mõtled poest koju sõitu vms.)
lalalalala
05.04.2019 12:24:04
| iguaan kirjutas: |
Ostsin selle enne jalka MMi juunis või juulis. Minul oli valikus veel miskine TCL millel olid front-firing kõlarid.
Kõlarid on sellel hisensel täielik jama muidugi aga see ei saanud määravaks, sest teadsin juba kohe et ükskõik kui hea see teleka heli ka ei ole, tuleb tõenäoliselt soundbar + woofer ligi võtta. Pilt oli hisensel kuidagi... sujuvam, eks see 120hz paneelist vahe tuleb. Kui TCL ja hisense kõrvuti pandi siis oli paari sekundiga otsus tehtud. Värvid jne, minuarust olid neil suht samad ja eks seda annab ise ka näppida endale meeldivaks.
Keegi kirjutas et UI ja smart osa on jama. WebOS-ga ei oska võrrelda aga jama küll ei ole. Kui sa veebi tahad brausida siis vb küll aga selle jaoks on arvuti ja telefon. Netflixi ja youtubesse saab ühe nupuvajutusega, mida muud tahta. Menüüd ka mõistlikud. Netflixi äpis menüüdes ringi kolamine on vahel veidi aeglane aga mitte nii aeglane, et oleks oluliselt häirima hakanud. Paned filmi peale siis kõik okk.
Teler kokku pole jooksnud, ainus viga et vahel ei leia wifit üles. siis korra juhe välja ja uuesti tagasi. Juhtub max korra kuus. Eile vedasin kaabli telekasse ja äkki nüüd sellega ka rahu majas.
| Kommentaarid: 43 loe/lisa |
40 |
agox57
05.04.2019 15:34:09
| Kas keegi oskab öelda sellise teleka kohta midagi head vōi halba.55'' LED-TELER SONY XF80
oliver.
05.04.2019 16:12:45
| agox57 kirjutas: |
| Küsimus kas telekat mis on ostetud poest, originaal pakendis võib transportida ka pikali asendis või ainult püsti. |
Oleneb mõõdust. Mingi 43" puhul pole vahet, aga 65-tollist lapiti ei paneks - ekraani pindala on nii suur, et on oht ämblikuks.
| Kommentaarid: 280 loe/lisa |
239 |
C1rca
07.04.2019 17:54:18
| lalalalala kirjutas: |
| iguaan kirjutas: |
Teler kokku pole jooksnud, ainus viga et vahel ei leia wifit üles. siis korra juhe välja ja uuesti tagasi. Juhtub max korra kuus. Eile vedasin kaabli telekasse ja äkki nüüd sellega ka rahu majas. |
Selle Hisense kõige suurem mure pidi vaatenurk olema, nii kui tsentrist natuke kõrvale kaldud siis kohe pilt hall või ma eksin selles osas?
97 |
oliver.
07.04.2019 20:49:05
| 55-tollisel on tõesti vaatenurk nõrgavõitu, nagu paljudel selle hinnaklassi teleritel. Aga sama teler, kuid 65" on sellest murest prii. Kusjuures see kehtib ka teiste Hisense mudelite kohta - alates 60" paneelidest pole vaatenurk enam teemaks.
239 |
tumbuser
08.04.2019 15:33:59
edit, võtsin vogeli seinakinnituse ja rahul
_________________ "The computer says I need to upgrade my brain to be compatible with the new software."
viimati muutis tumbuser 16.04.2019 14:26:35, muudetud 1 kord |
| Kommentaarid: 4 loe/lisa |
raxz
| Kommentaarid: 46 loe/lisa |
45 |
anubis
08.04.2019 18:24:48
| Päris hea hind.
283 |
08.04.2019 19:45:03
| anubis kirjutas: |
| Päris hea hind. |
Jõuad oled-i osta jõuad ka kinnituse
| Kommentaarid: 39 loe/lisa |
Anti
08.04.2019 19:57:48
| 65" max nadi ju.
240 |
08.04.2019 20:49:26
| salatoimik kirjutas: |
| anubis kirjutas: |
| Päris hea hind. |
Jõuad oled-i osta jõuad ka kinnituse  |
Minu rahakott selle peale ei avane......mõttetu
pots4t4j4
08.04.2019 20:53:13
| Miks see 7x parem on kui miski 100€ keerutatav mount ?
401 |
