c4v6
26.03.2019 18:25:08
Huawei P30 (Pro) |
No wow,
https://www.gsmarena.com/compare.php3?idPhone1=9635&idPhone2=9106
Mind häirib ennast see Samsungi välimus ja rõve notch (tavaline notch on palju normaalsem). Olgu siis see punch hole vähemalt või kuidas nad nimetavad, selline lehmanisa on ikka täitsa tobe.
Coming soon. Exp. release 2019, April
158 x 73.4 x 8.4 mm (6.22 x 2.89 x 0.33 in)
192 g (6.77 oz)
IP68 dust/water resistant (up to 2m for 30 mins)
OLED capacitive touchscreen, 16M colors
6.47 inches, 102.8 cm2 (~88.6% screen-to-body ratio)
1080 x 2340 pixels, 19.5:9 ratio (~398 ppi density)DCI-P3
Android 9.0 (Pie); EMUI 9.1
HiSilicon Kirin 980 (7 nm)
Octa-core (2x2.6 GHz Cortex-A76 & 2x1.92 GHz Cortex-A76 & 4x1.8 GHz Cortex-A55)
Mali-G76 MP10
NM (Nano Memory), up to 256GB (uses SIM 2)
128/256/512 GB, 8 GB RAM or 128 GB, 6 GB RAM
40 MP, f/1.6, 27mm (wide), 1/1.7", PDAF, OIS
20 MP, f/2.2, 16mm (ultrawide), 1/2.7", PDAF
Periscope 8 MP, f/3.4, 125mm (telephoto), 1/4", 5x optical zoom, OIS, PDAF
TOF 3D camera
Leica optics, dual-LED dual-tone flash, panorama, HDR
2160p@30fps, 1080p@60fps, 1080p@30fps (gyro-EIS), 720p@960fps
SELFIE CAMERA Single 32 MP, f/2.0, (wide)
HDR
1080p@30fps
Loudspeaker Yes
3.5mm jack No
NFC Yes
Infrared port Yes
Radio No
USB 3.1, Type-C 1.0 reversible connector
FEATURES Sensors Fingerprint (under display), accelerometer, gyro, proximity, compass, color spectrum
Non-removable Li-Po 4200 mAh battery
Fast battery charging 40W (70% in 30 min)
Fast wireless charging 15W
Endurance rating 100h
Aga just kaamera tundub jälle täiesti next level olema, eriti see 5x optiline zoom.
https://www.gsmarena.com/huawei_p30_pro-review-1910p7.php
| Kommentaarid: 67 loe/lisa |
63 |
Fuz
26.03.2019 18:34:57
| Jälg maha. Huvitav mis hinnaga tavaline P30 tuleb? Sama mis S10?
| Kommentaarid: 57 loe/lisa |
56 |
7 :: |
360 |
c4v6
63 |
Fuz
26.03.2019 21:17:32
Hind päris krõbe jah, sama nagu mate 20 pro.
Panin tähele, et elisa annab eeltellijatele huawei nutikella kaasa.
56 |
c4v6
26.03.2019 21:24:41
Krõbe ? See on ju odav võrreldes praeguste lipulaevadega mis müügile tulevad. Tonn on ju regulaarne taks olnud. Hetkel lõhnab see pigem -20% järgi mis on ju soodne.
Ja milleks seda telefoni üldse Mate20 pro'ga võrrelda kui see on mate20 pro'st parem ?
63 |
hkurujo88r
26.03.2019 21:25:44
| c4v6 kirjutas: |
Ja milleks seda telefoni üldse Mate20 pro'ga võrrelda kui see on mate20 pro'st parem ? |
Vana protsessor jne, võtad mälu rohkem läheb kallimaks. Ega ei saagi rohkem ka küsida ju. Kaamera ainus hea asi huaweil.
120 |
c4v6
26.03.2019 21:31:57
Ausaltöeldes praegu ju saabki lipulaeval kaamera ja disaini peale mängida. Kõik muu on ju niigi topnotch....
Palju reaalses elus kasutades on vahet mingil top10 benchmark telefonidel jõudluse poolest ? Keegi päriselt pimetestis saaks aru ka või ?
Mida see juurde annaks kui prose oleks mingi uuem-võimsam ? Filmiks kiiremini ? Angrybirds laeks 0,02 sekundit kiiremini ära ?
63 |
hkurujo88r
26.03.2019 21:35:26
Etem on ju splitscreeni kasutada jne. Ajaga annab tunda, kellel alles poole aasta pärast kellel 2.a pärast.
Aga suht sarnane hind ikkagi mis praegustel lipulaevadel, no okei tõrts odavam. 5x zoom on muidugi väga vinge
120 |
flake
27.03.2019 10:00:19
| hkurujo88r kirjutas: |
| c4v6 kirjutas: |
Vana protsessor jne, võtad mälu rohkem läheb kallimaks. Ega ei saagi rohkem ka küsida ju. Kaamera ainus hea asi huaweil. |
kakoi vana protsessor? Mate 20 Pro ka Kirin 980ga nagu ka P30 Pro
https://www.digitaltrends.com/mobile/huawei-p30-pro-vs-p20-pro-vs-mate-20-pro/
_________________ ..||.. |
| Kommentaarid: 63 loe/lisa |
60 |
7 :: |
360 |
flake
27.03.2019 10:15:26
mul Mate 20 Pro ja ei kiirusta upgradema
60 |
c4v6
27.03.2019 10:35:36
| Tanel kirjutas: |
P30 Pro on väga hea, aga ootaks Mate 30 Pro ära  |
Ma loodan, et nad selle nisanotchiga midagi teevad. Kui kaamera reaalselt õigustab ennast nii hästi nagu praegustest testidest on selgunud, siis ilmselt suudavad nad ennast mulle maha müüa.
Muidugi ma passiks vast pool aastakest veel, et see enamvähem mõistliku hindega soetada.
63 |
flake
27.03.2019 10:38:48
Huaweil so far see teema olnud et kogu ülemise status riba saab mustaks muuta niiet notchi näha pole.
60 |
eddvin
27.03.2019 12:50:40
Käisin hommikul vaatamas ja Kristiine Telias oli mõlemad mudelid väljas näppimiseks
Praegu mõtlen küll, äkki peaks ostma ühe neist, hetkel saab lisaks ka Huawei Watch GT.
| Kommentaarid: 62 loe/lisa |
59 |
cuda
27.03.2019 13:36:27
| Tele2 ka just saatis sõnumi, et annavad kella kaasa
| Kommentaarid: 6 loe/lisa |
7 :: |
360 |
hans
Nii ränk on olla.
27.03.2019 13:53:54
Kõrvaklapi pesa pole?
_________________ ------ |
81 |
7 :: |
360 |
eddvin
27.03.2019 14:57:10
| hans kirjutas: |
| Kõrvaklapi pesa pole? |
Täpsutsan, et PRO mudelil ei ole, tavalisel P30'l on kõrvaklapipesa täiesti olemas.
59 |
NATAS999
27.03.2019 15:00:55
noh, samas väga hull pole, kui paari sotaga kell maha müüa, pro siis 600 ja tavaline 500€
tele2 saatis sõnumi jah, ehmatasin ära et pole uudist ega midagi tulnd selle kohta.
kutsun üles rahvast pro'd boikoteerima ja tavaline p30 võtta. lõpetagu see kõrvaklapikasutajate pedereerimine ära ükskord.
| Kommentaarid: 41 loe/lisa |
39 |
Teip
27.03.2019 18:47:35
| NATAS999 kirjutas: |
| noh, samas väga hull pole, kui paari sotaga kell maha müüa, pro siis 600 ja tavaline 500€ |
Kahjuks elu nii ilus pole, see kell maksab poes paar sotti mitte mahamüües.
| Kommentaarid: 201 loe/lisa |
184 |
NATAS999
27.03.2019 18:50:41
Teip, poes 249 ja uuena pakendist lahti võtmata müüd 25'ga?
rtx 2080 ti võtaks isegi 130 euriga ära.
39 |
Anna tooli
27.03.2019 18:56:11
| Võta HV lahti ja võrdle hindu. Kas just identne, kuid hõbedase korpusega kella hinnad algavad 185-st
| Kommentaarid: 364 loe/lisa |
300 |
Mõttetumees
27.03.2019 20:59:27
Võtsin omale ühe P30 pro näppimiseks. Oleks mitteprol samad kaamerad olnud, oleks selle ostnud.
Esmamuljed kümne minuti järel. Meeldisid kohe karbist võttes lömmi vajutatud otsad. Vähemalt minu kätte istub suts paremini, kui s10 plus. Samas lisagrammid on tunda. Kõlar selge ja vali, kahjuks mitte stereo. S10 plussi kõlarid suts valjemad. Aga väga suts. Ekraan kena, nagu arvata võis. S10 plussi omaga eriti suurt vahet ei tee. Jõllitasin küll igatepidi peenikest teksti, aga ei saanud vahele pihta. S10 plussil reso põhja pandud.
Ronisin pea pimedasse tuppa ja tegin pildi ööreziimis ja mitteööreziimis. Mõlemad tulid paremad S10 plussi ööreziimi omast. Võiks öelda, et oluliselt paremad. Nauditavad vaadata. S10 plussi oma oli hägune mäsu.
Juhtmeta kõrvaklappide kasutamine hakkas meeldima ja seega isiklikult erilist kadu selle pesa puudumises ei näe. Alati saab ju adapterit kasutada.
Oki-toki, näpin edasi.
| Kommentaarid: 656 loe/lisa |
533 |
