praegune kellaaeg 16.11.2026 12:03:12
dropp
22.04.2004 14:16:15
TFT ja XGA monitoride erinevused |
| Mis vahe neil on?
Plin500
HV piljardihai
26.04.2004 13:11:43
Short for extended graphics array, a high-resolution graphics standard introduced by IBM in 1990. XGA was designed to replace the older 8514/A video standard. It provides the same resolutions (640 by 480 or 1024 by 768 pixels), but supports more simultaneous colors (65 thousand compared to 8514/A's 256 colors). In addition, XGA allows monitors to be non-interlaced.
Short for thin film transistor, a type of LCD flat-panel display screen, in which each pixel is controlled by from one to four transistors. The TFT technology provides the best resolution of all the flat-panel techniques, but it is also the most expensive. TFT screens are sometimes called active-matrix LCDs.
minu teada ongi nii, et ekraan ongi TFT XGA, mitte et need kaks eri asja oleks et siis TFT kuvari tüüp ning XGA reso
| Kommentaarid: 79 loe/lisa |
77 |
dot4
27.04.2004 08:41:18
Kas TFT siis üle 1024x768 pikseli ei lähe?
| It provides the same resolutions (640 by 480 or 1024 by 768 pixels), but supports more simultaneous colors (65 thousand compared to 8514/A's 256 colors). |
| Kommentaarid: 81 loe/lisa |
73 |
