HDD
24.03.2004 21:57:48
auk P4 cores |
Tekkis siis kysimus ,et milleks see auk prose core peal hea on ...
Võtmehoida panemise auk vee ??
_________________ The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it  |
| Kommentaarid: 62 loe/lisa |
57 |
pealuu
24.03.2004 22:07:30
| hmm... kui kindel sa oled et see auk on core peal? ma pakuks küll et tegemist on heat spreader'iga.. ja core on selel all varjus.
| Kommentaarid: 211 loe/lisa |
170 |
HDD
24.03.2004 22:09:38
pealuu, ära nori nüüd .. tean ise ka ,et core seal all on ...
57 |
pealuu
24.03.2004 22:16:01
okkei
The hole is for pressure relief. When the IHS is epoxied to the Organic Land Grid Array, or "OLGA" for short, it releases gas as it cures. If Intel did not provide the hole, the pressure would build up and eventually blow out the still wet epoxy. This would cause mechanical stresses due to the incomplete epoxy line around the IHS to OLGA bond line. Once the epoxy has cured (before it leaves the factory) it is not an issue. So, Intel put in a hole. If it gets plugged up with thermal grease or something it is OK. I would not suggest filling it with anything that conducts electricity though."
170 |
lamp
24.03.2004 22:38:13
samas sinna võib sulatina ka lasta, midagi seal pole, mis lyhisesse läheks..
a64 ihs puudus jällegi on just selle augu puudus.. ja lyhisetundlikud komponendid seal all.
niiet kui tahad proset pakasesse lasta, pead ihs eemaldama..
| Kommentaarid: 191 loe/lisa |
168 |
Henrik
25.03.2004 00:45:28
| Hmmm.... Kust sa konfidentsiaalse protsessori said?
lamp
25.03.2004 02:49:04
tal tomshardwares käpp sees, sealt sai.
| Henrik kirjutas: |
| Hmmm.... Kust sa konfidentsiaalse protsessori said? |
168 |
