praegune kellaaeg 03.08.2026 18:47:59
08.01.2004 19:28:45
Inimestele kellel on NAV 2003 ja Win98 |
| Täna juhtus peale NAV 2003 update selline asi (mul ja paljudel tuttavatel), et peale LiveUpdate'i tegemist jooksis NAV kinni ja peale restarti ei tulnud üldse enam lahti. Lisaks sellele ei olnud võimalik lahti teha Word XP (avanes lõpuks siiski peale 5 minutilist ooteaega), kuigi teised Office XP komponendid läksid normaalselt tööle. Kuna mul ja teistel juhtus see peale LiveUpdate, siis on põhjust kahtlustada, et asi oli viimases Update'is. Probleem lahenes NAV' uninstalliga.Kodulehel sellest mingeid teateid polnud ja NAV'i pole samuti julenud uuesti installida. Lihtsalt teadmiseks neile kellel samu probleeme esineb.
| Kommentaarid: 754 loe/lisa |
566 |
08.01.2004 22:52:31
| mul küll probleeme polnud...win98se
201 |
Nicko
13.01.2004 21:37:12
| Mul näiteks oli WinXPpro-ga sama asi.
| Kommentaarid: 11 loe/lisa |
tsihh
17.01.2004 21:13:05
äkki see abix
After January 7, 2004, your computer slows down and Microsoft Word and Excel will not start
Situation:
Symantec is currently investigating reported computer slow downs and instability. This issue appears to be related to VeriSign receiving an unusual number of requests by Windows-based clients to download a certificate revocation list (CRL) on January 7-8, 2004. This increase in traffic resulted in intermittent VeriSign CRL server availability. For security purposes, Symantec products routinely verify the integrity of system components and at times were unable to achieve the authentication they were seeking due to the unavailability of VeriSign's server; therefore, customers experienced delays and instabilities. Symantec and other vendors are cooperatively working with VeriSign to mitigate this situation
Solution:
To fix this problem, you must obtain the updated version of Verisign's Root Certificate Authority.
A full set of instructions is available on this page to walk you through the installation.
If you are unable to access Verisign's Web site, follow these instructions to temporarily fix this problem until you can obtain a copy of Verisign's Root Certificate Authority:
To install the updated version of Verisign's Root Certificate Authority
Close all programs.
Do one of the following:
Windows 95/98/Me/NT/2000. Click Start > Settings > Control Panel
Windows XP. Click Start > Control panel.
Windows 95/98/Me/NT/2000. Double-click Internet Options.
Windows XP. Double-click Internet Options.
Note: If when you open the Windows XP Control Panel, you do not see the Internet Options item, in the left pane, click "Switch to Classic View" and then double-click Internet Options.
On the Advanced tab, scroll down through the list box to the Security section.
Uncheck the "Check for publisher's certificate revocation" option
Click OK and restart the computer.
| Kommentaarid: 59 loe/lisa |
58 |
muhv
20.01.2004 15:09:41
Mul oli ka sama jama XP-ga. Saatsin selle NAV-i kus seda ja teist, panin peale Eset NOD32-e (http://www.nod32.com/home/home.htm) mis töötab palju vähem resursinõudlikumalt! Ja palju paremini leiab mul ka viiruseid üles! On juba paar maili ära blokkinud ja ka mõned downloadimised! Muideks ka paar vana maili, mille vanasti NAV korrektseks tunnistas!
Viimane NAV oli minuarust tõeline ressursi röövel! Eriti kui midagi installima asusid või suuremaid faililiigutamisi tegid vindi peal!
SIIN lähem võrdlus ka erinevate AV-programmidele W2003 all!
_________________ * Tarkus on relv mida ei tohi anda lolli kätte!
* Kõige hullem on vägisi targaks tehtud loll!
* Pole olemas lollikindlaid asju, kuna lollid on kõige leidlikumad! |
| Kommentaarid: 7 loe/lisa |
