uus teema   vasta Tarkvara »  Turvalisus »  Probleem meilide saatmisega märgi kõik teemad loetuks
djkiller
djkiller
sõnum 22.06.2019 11:54:48 Probleem meilide saatmisega vasta tsitaadiga
Tere kaasvõitlejad!
Pöördun järgmise murega
Tihti e-mailide saatmisel tuleb veateade nt
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
xxxxx@gmail.com
Domain sacito.eu has exceeded the max defers and failures per hour (10/10 (90%)) allowed. Message discarded.
"xxx.ee xx"@xx.ee
host mx1.elion.ee [194.126.101.123]
SMTP error from remote mail server after RCPT TO:<xxx
554 5.7.1 xxxxx:
Relay access denied
host mx1.loginet.ee [185.31.92.37]
SMTP error from remote mail server after end of data:
550-Your message to was classified as SPAM. Please add
550-more content, cut down on HTML links, use fewer naughty words etc. Also,
550-ask your IT dept to make sure your mailserver has REVERSEDNS, SPF, DKIM,
550 and is not on any black lists. Your score:
120
@hotmail.com
host mx2.hotmail.com [207.46.8.167]
SMTP error from remote mail server after RCPT TO:@hotmail.com>:
550 Requested action not taken: mailbox unavailable
@gmail.com
host gmail-smtp-in.l.google.com [173.194.73.26]
SMTP error from remote mail server after RCPT TO:< 96@gmail.com>:
550-5.1.1 The email account that you tried to reach does not exist. Please try
550-5.1.1 double-checking the recipient's email address for typos or
550-5.1.1 unnecessary spaces. Learn more at
550 5.1.1 https://support.google.com/mail/answer/6596 r7si5727792lbr.144 - gsmtp
Problem nii gmail.com, mail.ru jne
Kasutan Virtuaal.com teenust + e-maili programmiks Thunderbird.
Tihti kui vaja saata mitmed arved nt üüriarved (programmiks intellisoft) ei jõua inimesteni e-mailid.
Mingi aeg oli neid vähem,kuid ca 3-4 kuud tagasi tuleb kõik käsitsi saata.
Saab ehk keegi kuidagi aidata?
Vajadusel ka väikse tasu eest.
Kirjas ei jõu kohale ka riigiasutusteni.
Jäädes abi või mud infot ootama
Lugupidamisega
Djkiller
Kommentaarid: 225 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 204
A.S.
sõnum 22.06.2019 13:18:14 vasta tsitaadiga
Kui kasutad Virtuaal.com poolt pakutavat meiliserverit kirjade saatmiseks, siis peaksid vast nende endi käest küsima, miks nende teenus normaalselt ei tööta.
djkiller
djkiller
sõnum 22.06.2019 13:22:40 vasta tsitaadiga
olen pöördunud nii nende kui ka selle raamatupidamise programmi tootja ,kuid abi ei ole saanud. vb mul endal nt mõned sätted valesti.
Saan saata need sätted mis mul on ja vb keegi targem näeb kohe vea ära.
SMTP port 465
ühenduse turvalisus ssl/tls
autentimsie viis tavaline parool
server on siis domeeni nimi
kasutajaks on e-maili aadress
A.S.
sõnum 22.06.2019 14:30:11 vasta tsitaadiga
Aga kas internetiteenuse pakkuja SMPT serverit ei soovi kasutada, on ehk sellega rohkem õnne?
Kas meiliaadressid on ilusasti õiged, pole seal mingit tühikut/sümbolit juurde tekkinud? Sest mõnel juhul tundub ju kurtvat, et saajat pole olemas. Seal pead igat kirja eraldi analüüsima, et milles konkreetselt probleem.
djkiller
djkiller
sõnum 22.06.2019 14:37:49 vasta tsitaadiga
kõik samad meilid mingi aeg töötab nüüd ca nädal või vähem umbes tagasi hakkas selline hullem probleem .
ei saa öelda ,et oles vahepea
A.S.
sõnum 22.06.2019 14:42:03 vasta tsitaadiga
See sacito.eu oled siis sina, eks? Või mis seos sellel xxxxx@gmail.com aadressiga on?
Ja kas selle "SMTP error from remote mail server after RCPT TO:" järel olev aadress on täpselt see, mis peab olema?
djkiller
djkiller
sõnum 22.06.2019 14:45:16 vasta tsitaadiga
sacito jah minu aadress. ma ei hakanud xxx õiget meili siis tooma lihtsalt ,et on lõpuga gmail.com
meilid kuhu olen saatnud on koguaeg samad ei ole seal n.ö trükiviga
see suurem nali hakkas pihta n.ö ca nädal või vähem.
arv ete saatmine läbi intellisofti( raamatupidamise programm milles siis automaatselt genereerib pdf arved jakasutab thunderbird ja saadab salvestatud e-mailidele).Mingi aeg ei saanud kätte arveid .ru lõpuga kasutajad siis lisandus ka hotmail ja gmail
nüüd tehtud kõik käsitsi,kuid kui olemas lahendus siis oleks imelik teha kiviaja moodi
A.S.
sõnum 22.06.2019 15:04:59 vasta tsitaadiga
djkiller kirjutas:
smeilid kuhu olen saatnud on koguaeg samad ei ole seal n.ö trükiviga
Ja seda trükiviga ei tekita ka teenusepakkuja, kes kirju sihtkohta saata üritab? Sest saaja aadressi mitteeksisteerimise teade igatahes tekitab säherduse mulje.
See RCPT TO on "ümbrikul" (mida ei näe ei sina ega saaja) asuv saaja aadress, selle tekitab kirja väljasaatev programm. Ja nii nad liiguvad, ümbrik ees ja kiri järel, kirja kohalejõudes ümbrik kustutatakse. Kui nüüd teenusepakkuja seda aadressi äkki omaenese tarkuses muutma ei kipu.
Mnator
sõnum 22.06.2019 15:25:17 vasta tsitaadiga
djkiller, oled sa mõne lihtsa, ainult teksti sisaldava, mailiga saanud kontrollida, et kas need tundmatuteks muutunud mailiaadressid eksisteerivad enam?
Seoses earvete puukfirmade poolse survega ähvardati ju hulk vanu emailaadresse liikvideerida, kuhu seni pdf-arveid sai saata.
djkiller
djkiller
sõnum 22.06.2019 16:20:36 vasta tsitaadiga
ei ole ma midagi teinud.
Ma räägin mitte midagi ei ole teinud.Ei block ,ignore või midagi veel
See pole ju ainule e-mail kuhu ei lähe mul kohale.
Tihti lähevad minu kirjad rämpsposti alla.Samas ei ole nad minu kirju sinna tahtlikult suunanud.
Kogu jama ongi üks imelik komöödia
viimane gmail oli link+ tekst
ka ainult tekst on sama jama
vb minu domeen kuskil mustas listis või kehva turvalahendusega millega automaatselt blokitakse?
sõnum 22.06.2019 18:54:07 vasta tsitaadiga
mxtoolbox.com kaudu saad uurida, kas oled mustas nimekirjas.
Konkreetselt on veateadetes kirjas, et su kirjad blokeeritakse, sest need tunduvad olevat spämm. 554 ja 550 on spämikirjade errorid. Kontrolli, et su kirjades pole linke ega ebasoovitavaid sõnu või elemente. Tihti spämifiltrid võivad mõnd sõna poolikult käsitleda roppusena.
Lisaks uuri, kuidas su kirjad välja lähevad. Võimalik, et kui mingi programm saadab kusagilt Send as või muul sarnasel viisil mingi kolmanda osapoole kaudu, siis seda käsitletakse samuti spämmina.
Ja võiksid lasta oma postiserveri konfi mõnel teadjamal üle vaadata.
Kommentaarid: 763 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 571
djkiller
djkiller
sõnum 22.06.2019 19:57:02 vasta tsitaadiga
sai virtuaali käest sellise kirja
Saatja aadress viitab, et antud kirjad on saadetud Teie kodulehekülje tagasisidevormi vms kaudu. Konsulteerige vajadusel lehekülje haldaja või valmistajaga, et välja selgitada antud vormi turvalise tagamine (captcha kontroll nt).
samas kodulehte ei ole ,aga ju on jäänud siis ftp mingi failid alles mille kaudu saab antud olukorda ära kasutada.
kas ftp alt võin antud kodulehe kausta täielikult kustutada?
See ju ei mõjuta e-mailide kasutamist ega kustuta neid ära?
sõnum 22.06.2019 22:40:07 vasta tsitaadiga
Sul on kodulehel mingi elukas sisse roninud ja saadab kirju laiali? See nõuab juba asjatundja kätt sellisel juhul.
djkiller
djkiller
sõnum 22.06.2019 22:49:38 vasta tsitaadiga
Betamax kirjutas:
kodulehte ma ei kasuta kunagi oli joomla põhjal.
Kas see ftp kausta võin täielikult kustutada ,et e-mailide kasutamist ei häiriks ehk kas e-mail kontod ja koduleht on eraldiseisvad süsteemid joomlas?
A.S.
sõnum 23.06.2019 09:10:16 vasta tsitaadiga
Ei tea ftp kaustast mitte midagi, aga ei usu, et see meilivärgiga kuidagimoodi seotud on ja selle kustutamine kirjade (mitte)edastamist mõjutab. Aga saada enda gmaili kontole kiri ja vaata, mida sellele kirjale juurde lisatakse, siis ehk oskad edasi mõelda.
sõnum 23.06.2019 14:20:30 vasta tsitaadiga
Saan ma õigesti aru, et see Joomla on endiselt sul sinna teenusepakkuja serverisse paigaldatud ja ligipääsetav veebist? Lihtsalt sina seda enam ei kasuta ega uuenda? icon_rolleyes.gif
napoleon
Unknown virus
napoleon
sõnum 23.06.2019 15:47:35 vasta tsitaadiga
Kirjuta mulle PS ja annan aadressi kuhu testiks üks kiri saata. Vaatan siis mis seal valesti võib olla.
djkiller
djkiller
sõnum 23.06.2019 17:10:12 vasta tsitaadiga
Dogbert kirjutas:
jah said õigesti aru sp küsingi kas vòin selle kausta ära kustutada
maty
sõnum 23.06.2019 17:37:31 vasta tsitaadiga
võid ikka kustutada veebikausta sisu, ei ole seotud meiliga
Kommentaarid: 82 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 70
djkiller
djkiller
sõnum 24.06.2019 22:04:09 vasta tsitaadiga
suured tänud.eks proovin vaatan kas saan jagu sellest veast
sõnum 26.06.2019 13:23:56 vasta tsitaadiga
djkiller kirjutas:
Dogbert kirjutas:
Kui see tõepoolest veebist brauseriga ligipääsetav on endiselt, siis selline hüljatud ja uuendamata Joomla või mistahes CMS on script kiddie'de jaoks nagu meepott, sinna võib olla paigaldatud jumal teab mis sitta, spämmi väljapritsivad botid sealhulgas. icon_rolleyes.gif
Ja kui sama domeeninime / IP peal töötab legitiimne MX server, siis on sellega blacklistidesse sattumine vaid aja küsimus. Lisaks satub domeeninimi varem või hiljem antiviiruste, Google Safe Browsingu ja muudesse veebilehtede blacklistidesse sinna paigaldatud ja brausereid nakatada püüdvate "asjanduste" tõttu.
Veebirakendusi ei tohi hüljata. Neid peab kas järjepidevalt hooldama ja uuendama turvaparanduste ja uute versioonide paigaldamisega või tuleb need täielikult "kinni keerata" (mis tähendab üldjuhul eemaldamist avalikust veebist).
Osiris
Osiris
sõnum 26.06.2019 14:09:31 vasta tsitaadiga
"xxx.ee xx"@xx.ee
554 5.7.1 xxxxx:
Relay access denied
See näitab seda, et üritad e-maile välja saata telia ühenduse tagant pordi 25 kaudu mis nüüd kinni keerati ja on lubatud ainult autentimisega smtp-d kasutada.
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 103
djkiller
djkiller
sõnum 26.06.2019 21:54:57 vasta tsitaadiga
Dogbert kirjutas:
djkiller kirjutas:
Dogbert kirjutas:
kogu sisu sai kustutatud.
Osiris
eks mida täpselt tegema?
maty
sõnum 26.06.2019 22:10:45 vasta tsitaadiga
https://arve.virtuaal.com/knowledgebase.php?id=54
E-posti klientide (Outlook, Thunderbird, telefonid jm) seadistamise üldised andmed on alljärgnevad.
Kasutajatunnus: Sinu e-posti aadress
Parool: Parool, mis määrati e-posti konto loomisel
Sissetulev server: mail.sinudomeen.ee
IMAP port: 993
POP3 port: 995
Väljaminev server : mail.sinudomeen.ee
SMTP port: 465
IMAP, POP3 ja SMTP autoriseerimised on nõutud.
Ehk siis mail.sacito.eu paned väljuvaks meiliserveriks, pordiks 465. Vali SSL/TLS ka.
djkiller
djkiller
sõnum 27.06.2019 11:48:03 vasta tsitaadiga
suured tänud eks vaatan kas saan thunderbirdi ja profiti tarkvara ka jooksma
sõnum 29.06.2019 12:43:16 vasta tsitaadiga
Osiris
CMS-i poolt kasutatud andmebaasi kasutaja parool kuluks ka vahetada igaks juhuks. Siis peaks rahu majas olema.
djkiller
djkiller
sõnum 01.07.2019 11:27:58 vasta tsitaadiga
Dogbert kirjutas:
Osiris
saaks palun täpsemalt mille parool? cpaneli sisse logimise või mõne andmebaasi?
maty
sõnum 01.07.2019 12:08:12 vasta tsitaadiga
Tolle andmebaasi parool mida su joomla cms kasutas
djkiller
djkiller
sõnum 01.07.2019 15:14:05 vasta tsitaadiga
maty kirjutas:
pm võin ju andmebaasi kustutata?
ehk kõik andmebaasid kui lehte ei ole?
sõnum 02.07.2019 16:58:54 vasta tsitaadiga
Sõltuvalt su teenusepakkujast ja Joomla paigaldusest (kas Joomlal eraldi andmebaas või mitte), võib baasi kustutamine ka midagi muud kustutada.
Kui seda baasi kasutas vaid Joomla, siis võib kustutada.
parkenTOSH
sõnum 02.07.2019 18:28:27 vasta tsitaadiga
Ma ise olen aastaid serverites emaile konfides kasutanud esimese testina seda: https://www.mail-tester.com/
Enamus levinud probleeme tulevad kohe välja. Kui selle testi ära teed ja skoor on kehv siis võid tulemusi foorumisse jagada ja tõenäoliselt oskavad kasutajad sind paremini aidata.
djkiller
djkiller
sõnum 02.07.2019 21:40:46 vasta tsitaadiga
Dogbert kirjutas:
peal oli ainult joomla.kodulehti enam ei kasuta ainult e-maili.
kui kodulehe avamisel lööb ette
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at webmaster@cito.mebelland.eu to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
on see piisavalt turvaline või tuleb veel midagi teha turvalisuse tõstmiseks?
LKits
LKits
sõnum 05.07.2019 12:52:17 vasta tsitaadiga
parkenTOSH kirjutas:
+1
djkiller
djkiller
sõnum 05.07.2019 14:16:44 vasta tsitaadiga
sain siis sellise tulemuse
Kuulus spämmifilter SpamAssassin. Skoor: -1.
Skoor alla -5 loetakse spämmiks.
-0.972 SPF_SOFTFAIL SPF: sender does not match SPF record (softfail)
Sinu SPF kirje ei ole korrektne ja vajab parandamist (vaata serveri tuvastamise alajaotust).
-4
Sul ei ole lubatud kasutada ühte saatja-aadressidest
Me kontrollime, kas saatmiseks kasutatav server on tuvastatud
-3
[SPF] sacito.eu ei luba sinu serveril 185.169.70.137 saata igor@sacito.eu e-posti
-1
Sinu kirjal puudub DKIM digitempel
Sul ei ole DMARC kirjet
Sinu serveri IP 185.169.70.137 vastab nimele smtp17.virtuaal.com
Your domain name sacito.eu is assigned to a mail server.
Nimi smtp17.virtuaal.com vastab postiserverile.
Sinu kirja sisu vajaks parandamist
Kontrollib, kas sinu kirja sisu on korrektselt vormindatud.
Sinu kirjal puudub HTML versioon.
Sinu kirjas ei ole ühtki pilti
Sinu kirja sisu on turvaline
Me kontrollime, kas sinu kirjas on kasutusel lühendatud URLe.
Sinu kirjas puudub List-Unsubscribe päis
List-Unsubscribe on nõutav massi-posti puhul, see võimaldab kirja saajal hõlpsalt listist lahkuda.
Sinu server ei ole mustas nimekirjas
parkenTOSH
sõnum 05.07.2019 16:15:18 vasta tsitaadiga
Tõenäoliselt on su suurim probleem see: [SPF] sacito.eu ei luba sinu serveril 185.169.70.137 saata igor@sacito.eu e-posti
Kui spf kirje ei klapi serveriga kust kirjad välja lähevad siis on 2 võimalust: kiri läheb spämmi või kiri ei jõuagi kohale
Viimati kui ma virtuaal.com'i teenuseid kasutasin siis minu mäletamist mööda ei saa seal ise dns kirjeid muuta (saab ainult nimeserveri välja vahetada... vb nüüd saab.. ei tea).
Praegu on su spf kirje selline: "v=spf1 ip4:185.169.68.29 ip4:185.169.68.24 +a +mx +ip4:185.169.68.21 +ip4:212.47.218.35 ~all"
Reaalne ip kust kiri välja läheb annab spf kontrolli puhul: SPF Failed for IP - 185.169.70.137
Sinu praeguse spf kirje järgi on lubatud kirju saata ainult nendelt ip'delt mis on kirjes sees (seda näitab ~all märge).
Ma ise olen kõik enda hallatavad meiliserverid konfinud nii, et kui spf kirje ei klapi siis kiri kustutatakse (suht levinud käitumine... spf on esimene kaitse skämmerite ja spämmi vastu).
napoleon
Unknown virus
napoleon
sõnum 05.07.2019 16:29:19 vasta tsitaadiga
parkenTOSH, ~all on softfail, sellega peaks pigem spämmiks märkima või spämmi skoori suurendama mitte koha prügikasti saatma.
Teiseks esimese kontrollina on parem hoopis DNSRBL. Skämmer võib ju teha domeeni kuriskammer.com vms. ja sellel SPF, DKIM ja DMARC täiesti korrektselt ära seadistada. Võib isegi +all SPF kirjele lisada, et saaks botneti kaudu ka saata ja sinu kontroll rahule jääks
SPF aitab saatja aadressi võltsimise vastu, aga spämi/skämi vastu see küll mingi imerohi pole.
parkenTOSH
sõnum 05.07.2019 16:44:24 vasta tsitaadiga
napoleon kirjutas:
Spämmi vastu tõesti ei aita aga ikka suur vahe on küll kas skämmer saadab kirja kirja näiteks minginimi@swedbank.ee või minginimi@swedbank.lambicrap.lampi
Kui minu otsustada oleks siis ma kustutaks ka siis kirja ära kui kirjes on see +all
Spämmi pärast isiklikult eriti ei muretse aga inimesed on piisavalt ignorantsed, et skämmerid tekitavad muret küll. Meil on kontoris olnud olukord kus raamatpidaja hakkas tegema ülekannet välismaale, sest "juhataja" saatis talle sellekohase kirja (täiesti lambi aadressi pealt.. nüüd on korraldus jälgida, et domeen klapiks) ja üks suutis kunagi endale ransomware'i arvutisse tõmmata (minu jaoks) väga kahtlase sisuga meilist (peale seda võeti kõigilt oma arvuti admin õigused ära)
djkiller
djkiller
sõnum 07.07.2019 21:29:17 vasta tsitaadiga
ehk siis pole parim ja turvalisem teenusepakkuja või siis ala tarkvara mida ta kasutab?
Mida annaks antud olukorrast maksimum võtta?
Kas sp ka ei toiminud kirjasaatmised kui sai kasutatud raamatupidamise programmi arvete laiali saatmiseks?
napoleon
Unknown virus
napoleon
sõnum 08.07.2019 00:19:34 vasta tsitaadiga
djkiller kirjutas:
Ma korra pakkusin sulle juba seda varianti. Kui see raamatupidamisprogramm võimaldab mingit testarvet saata vms., siis saada mulle PS ja annan sulle aadressi kuhu saata. Siis saab uurida mis seal valesti on.
Teenusepakkuja turvalisus on hetkel natuke teine teema, enne peab välja selgitama kuidas neid maile saadad ja selleks ongi vaja, et ühe testmaili saadad. Sisu pole üldse oluline, oluline on ainult see, et saadad selle täpselt samamoodi nagu pärismailid kliendile.
djkiller
djkiller
sõnum 08.07.2019 09:09:17 vasta tsitaadiga
ta saaadab need meilid läbi thunderbirdi kindla e-maili mis on programmi määratud.Ja nii saadab umbes 85 e-maili koos pdf arvega.
rohkem polegi nagu midagi lisada.
eks algul oli probleemiks see ,et joomla oli uuendamata ja seal oli meilid spämm listis.
eks lähipäevil proovin uuesti ja vaatan kas lähevad laiali.seniks tee muu valiku ,et seda vältida.
siis annan lisainfot ,kas asi töötab või mitte
montez
sõnum 02.08.2019 17:13:13 vasta tsitaadiga
Virtuaal on täiesti tasemel teenus. Küsimuse esitajal on poolik seadistus, mis lubab tema domeeni nime kasutada võõraste kirjade saatmiseks(need märgitakse kõigest spamina, mitte ei blokeerita).
Virtuaalis saab muuta kõiki domeeni kirjed, nagu seda cPanel lubab(halduse lehel Zone Editor, nimekirjast valid domeeni).
Praegu on SPF erinev kirja saatmise serverist(telia?) ja selle pärast saadetakse kirjad tagasi:
Selgitad välja, millise serveri kaudu kiri välja saadetakse(virtuaali halduses saadad iseendale ja vaatad kirja päiseid) ja võtad sealt aadresse vähemaks, jättes SPF näiteks sellise:
v=spf1 +ip4:185.169.68.24 -all (ainult selle viimase virtuaali välja saatva serveri IP).
Seejärel seadistad ümber oma arvutis kirjade välja saatmise programmi, et kirjad läheksid välja virtuaal.com serveri.
Kui on selline probleem, et domeeni kasutatakse spami saatmiseks ja võltsitakse aadressiks sinu .eu domeen, siis tuleks tsooni lisada veel DMARC kirje. See meeldib gmail ja sarnastele suurtele e-maili teenuse pakkujatele, sest ütleb serverile, mis saab kirjast kui kirjal on 1) vale saatja server SPF või 2) vale digitaalne allkiri(DKIM, mille väärtust näeb Zone Editoriga real, mille alguses on "default._domainkey." Näiteks saab testida dmarcian.com/domain-checker/ (seal tuleb määrata, kas soovitakse raportit 1x päevas kirjade kohta, mille nad peatasid, nt gmail.com, mail.ru)
Kommentaarid: 46 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 45
djkiller
djkiller
sõnum 09.08.2019 23:11:07 vasta tsitaadiga
montez kirjutas:
Tere!
Jah on samas nii Telia kui ka Elisa. kahest kohast teen tööd. hetkel pean kirja teksti süvenema kuna minu jaoks on see hiina keel
montez
sõnum 12.08.2019 11:36:17 vasta tsitaadiga
1) Seadistad oma kirjade saatmise programmi nii, et see kasutab virtuaali kontol olevat postkasti: Incoming Server: mail.***.ee IMAP Port: 993 POP3 Port: 995
Outgoing Server: mail.***.ee SMTP Port: 465
2) uuendad cPanelis valiku Zone Editor alt oma domeeni SPF kirjet. Seda on varem kirjutatud, et see ongi probleem kirjade kadumisele ja blokeerimisele. Kui saadad välja 185.169.70.137
siis kirjutad/muudad praegust v=spf1 ip4:185.169.68.29 ip4:185.169.68.24 +a +mx +ip4:185.169.68.21 +ip4:212.47.218.35 ~all
ja uueks saab
v=spf1 +ip4:185.169.70.137 -all
NÜÜD ütleb SPF, et ainult see IP saadab kirju ja teised blokeeritakse. Praegu olid kirjade välja saatmiseks Telia ja Elisa serverid, mille IP-d ei vastanud domeeni SPF kirjetele.
