uus teema   vasta Tarkvara »  Turvalisus »  Probleem meilide saatmisega märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
djkiller
djkiller
sõnum 22.06.2019 11:54:48 Probleem meilide saatmisega vasta tsitaadiga
Tere kaasvõitlejad!
Pöördun järgmise murega
Tihti e-mailide saatmisel tuleb veateade nt
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
xxxxx@gmail.com
Domain sacito.eu has exceeded the max defers and failures per hour (10/10 (90%)) allowed. Message discarded.
"xxx.ee xx"@xx.ee
host mx1.elion.ee [194.126.101.123]
SMTP error from remote mail server after RCPT TO:<xxx
554 5.7.1 xxxxx:
Relay access denied
host mx1.loginet.ee [185.31.92.37]
SMTP error from remote mail server after end of data:
550-Your message to was classified as SPAM. Please add
550-more content, cut down on HTML links, use fewer naughty words etc. Also,
550-ask your IT dept to make sure your mailserver has REVERSEDNS, SPF, DKIM,
550 and is not on any black lists. Your score:
120
@hotmail.com
host mx2.hotmail.com [207.46.8.167]
SMTP error from remote mail server after RCPT TO:@hotmail.com>:
550 Requested action not taken: mailbox unavailable
@gmail.com
host gmail-smtp-in.l.google.com [173.194.73.26]
SMTP error from remote mail server after RCPT TO:< 96@gmail.com>:
550-5.1.1 The email account that you tried to reach does not exist. Please try
550-5.1.1 double-checking the recipient's email address for typos or
550-5.1.1 unnecessary spaces. Learn more at
550 5.1.1 https://support.google.com/mail/answer/6596 r7si5727792lbr.144 - gsmtp
Problem nii gmail.com, mail.ru jne
Kasutan Virtuaal.com teenust + e-maili programmiks Thunderbird.
Tihti kui vaja saata mitmed arved nt üüriarved (programmiks intellisoft) ei jõua inimesteni e-mailid.
Mingi aeg oli neid vähem,kuid ca 3-4 kuud tagasi tuleb kõik käsitsi saata.
Saab ehk keegi kuidagi aidata?
Vajadusel ka väikse tasu eest.
Kirjas ei jõu kohale ka riigiasutusteni.
Jäädes abi või mud infot ootama
Lugupidamisega
Djkiller
Kommentaarid: 223 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 202
A.S.
sõnum 22.06.2019 13:18:14 vasta tsitaadiga
Kui kasutad Virtuaal.com poolt pakutavat meiliserverit kirjade saatmiseks, siis peaksid vast nende endi käest küsima, miks nende teenus normaalselt ei tööta.
djkiller
djkiller
sõnum 22.06.2019 13:22:40 vasta tsitaadiga
olen pöördunud nii nende kui ka selle raamatupidamise programmi tootja ,kuid abi ei ole saanud. vb mul endal nt mõned sätted valesti.
Saan saata need sätted mis mul on ja vb keegi targem näeb kohe vea ära.
SMTP port 465
ühenduse turvalisus ssl/tls
autentimsie viis tavaline parool
server on siis domeeni nimi
kasutajaks on e-maili aadress
A.S.
sõnum 22.06.2019 14:30:11 vasta tsitaadiga
Aga kas internetiteenuse pakkuja SMPT serverit ei soovi kasutada, on ehk sellega rohkem õnne?
Kas meiliaadressid on ilusasti õiged, pole seal mingit tühikut/sümbolit juurde tekkinud? Sest mõnel juhul tundub ju kurtvat, et saajat pole olemas. Seal pead igat kirja eraldi analüüsima, et milles konkreetselt probleem.
djkiller
djkiller
sõnum 22.06.2019 14:37:49 vasta tsitaadiga
kõik samad meilid mingi aeg töötab nüüd ca nädal või vähem umbes tagasi hakkas selline hullem probleem .
ei saa öelda ,et oles vahepea
A.S.
sõnum 22.06.2019 14:42:03 vasta tsitaadiga
See sacito.eu oled siis sina, eks? Või mis seos sellel xxxxx@gmail.com aadressiga on?
Ja kas selle "SMTP error from remote mail server after RCPT TO:" järel olev aadress on täpselt see, mis peab olema?
djkiller
djkiller
sõnum 22.06.2019 14:45:16 vasta tsitaadiga
sacito jah minu aadress. ma ei hakanud xxx õiget meili siis tooma lihtsalt ,et on lõpuga gmail.com
meilid kuhu olen saatnud on koguaeg samad ei ole seal n.ö trükiviga
see suurem nali hakkas pihta n.ö ca nädal või vähem.
arv ete saatmine läbi intellisofti( raamatupidamise programm milles siis automaatselt genereerib pdf arved jakasutab thunderbird ja saadab salvestatud e-mailidele).Mingi aeg ei saanud kätte arveid .ru lõpuga kasutajad siis lisandus ka hotmail ja gmail
nüüd tehtud kõik käsitsi,kuid kui olemas lahendus siis oleks imelik teha kiviaja moodi
A.S.
sõnum 22.06.2019 15:04:59 vasta tsitaadiga
djkiller kirjutas:
smeilid kuhu olen saatnud on koguaeg samad ei ole seal n.ö trükiviga
Ja seda trükiviga ei tekita ka teenusepakkuja, kes kirju sihtkohta saata üritab? Sest saaja aadressi mitteeksisteerimise teade igatahes tekitab säherduse mulje.
See RCPT TO on "ümbrikul" (mida ei näe ei sina ega saaja) asuv saaja aadress, selle tekitab kirja väljasaatev programm. Ja nii nad liiguvad, ümbrik ees ja kiri järel, kirja kohalejõudes ümbrik kustutatakse. Kui nüüd teenusepakkuja seda aadressi äkki omaenese tarkuses muutma ei kipu.
Mnator
sõnum 22.06.2019 15:25:17 vasta tsitaadiga
djkiller, oled sa mõne lihtsa, ainult teksti sisaldava, mailiga saanud kontrollida, et kas need tundmatuteks muutunud mailiaadressid eksisteerivad enam?
Seoses earvete puukfirmade poolse survega ähvardati ju hulk vanu emailaadresse liikvideerida, kuhu seni pdf-arveid sai saata.
djkiller
djkiller
sõnum 22.06.2019 16:20:36 vasta tsitaadiga
ei ole ma midagi teinud.
Ma räägin mitte midagi ei ole teinud.Ei block ,ignore või midagi veel
See pole ju ainule e-mail kuhu ei lähe mul kohale.
Tihti lähevad minu kirjad rämpsposti alla.Samas ei ole nad minu kirju sinna tahtlikult suunanud.
Kogu jama ongi üks imelik komöödia
viimane gmail oli link+ tekst
ka ainult tekst on sama jama
vb minu domeen kuskil mustas listis või kehva turvalahendusega millega automaatselt blokitakse?
sõnum 22.06.2019 18:54:07 vasta tsitaadiga
mxtoolbox.com kaudu saad uurida, kas oled mustas nimekirjas.
Konkreetselt on veateadetes kirjas, et su kirjad blokeeritakse, sest need tunduvad olevat spämm. 554 ja 550 on spämikirjade errorid. Kontrolli, et su kirjades pole linke ega ebasoovitavaid sõnu või elemente. Tihti spämifiltrid võivad mõnd sõna poolikult käsitleda roppusena.
Lisaks uuri, kuidas su kirjad välja lähevad. Võimalik, et kui mingi programm saadab kusagilt Send as või muul sarnasel viisil mingi kolmanda osapoole kaudu, siis seda käsitletakse samuti spämmina.
Ja võiksid lasta oma postiserveri konfi mõnel teadjamal üle vaadata.
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 750 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 563
djkiller
djkiller
sõnum 22.06.2019 19:57:02 vasta tsitaadiga
sai virtuaali käest sellise kirja
Saatja aadress viitab, et antud kirjad on saadetud Teie kodulehekülje tagasisidevormi vms kaudu. Konsulteerige vajadusel lehekülje haldaja või valmistajaga, et välja selgitada antud vormi turvalise tagamine (captcha kontroll nt).
samas kodulehte ei ole ,aga ju on jäänud siis ftp mingi failid alles mille kaudu saab antud olukorda ära kasutada.
kas ftp alt võin antud kodulehe kausta täielikult kustutada?
See ju ei mõjuta e-mailide kasutamist ega kustuta neid ära?
sõnum 22.06.2019 22:40:07 vasta tsitaadiga
Sul on kodulehel mingi elukas sisse roninud ja saadab kirju laiali? See nõuab juba asjatundja kätt sellisel juhul.
djkiller
djkiller
sõnum 22.06.2019 22:49:38 vasta tsitaadiga
Betamax kirjutas:
kodulehte ma ei kasuta kunagi oli joomla põhjal.
Kas see ftp kausta võin täielikult kustutada ,et e-mailide kasutamist ei häiriks ehk kas e-mail kontod ja koduleht on eraldiseisvad süsteemid joomlas?
A.S.
sõnum 23.06.2019 09:10:16 vasta tsitaadiga
Ei tea ftp kaustast mitte midagi, aga ei usu, et see meilivärgiga kuidagimoodi seotud on ja selle kustutamine kirjade (mitte)edastamist mõjutab. Aga saada enda gmaili kontole kiri ja vaata, mida sellele kirjale juurde lisatakse, siis ehk oskad edasi mõelda.
sõnum 23.06.2019 14:20:30 vasta tsitaadiga
Saan ma õigesti aru, et see Joomla on endiselt sul sinna teenusepakkuja serverisse paigaldatud ja ligipääsetav veebist? Lihtsalt sina seda enam ei kasuta ega uuenda? icon_rolleyes.gif
napoleon
Unknown virus
napoleon
sõnum 23.06.2019 15:47:35 vasta tsitaadiga
Kirjuta mulle PS ja annan aadressi kuhu testiks üks kiri saata. Vaatan siis mis seal valesti võib olla.
djkiller
djkiller
sõnum 23.06.2019 17:10:12 vasta tsitaadiga
Dogbert kirjutas:
jah said õigesti aru sp küsingi kas vòin selle kausta ära kustutada
maty
sõnum 23.06.2019 17:37:31 vasta tsitaadiga
võid ikka kustutada veebikausta sisu, ei ole seotud meiliga
Kommentaarid: 81 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 69
djkiller
djkiller
sõnum 24.06.2019 22:04:09 vasta tsitaadiga
suured tänud.eks proovin vaatan kas saan jagu sellest veast
sõnum 26.06.2019 13:23:56 vasta tsitaadiga
djkiller kirjutas:
Dogbert kirjutas:
Kui see tõepoolest veebist brauseriga ligipääsetav on endiselt, siis selline hüljatud ja uuendamata Joomla või mistahes CMS on script kiddie'de jaoks nagu meepott, sinna võib olla paigaldatud jumal teab mis sitta, spämmi väljapritsivad botid sealhulgas. icon_rolleyes.gif
Ja kui sama domeeninime / IP peal töötab legitiimne MX server, siis on sellega blacklistidesse sattumine vaid aja küsimus. Lisaks satub domeeninimi varem või hiljem antiviiruste, Google Safe Browsingu ja muudesse veebilehtede blacklistidesse sinna paigaldatud ja brausereid nakatada püüdvate "asjanduste" tõttu.
Veebirakendusi ei tohi hüljata. Neid peab kas järjepidevalt hooldama ja uuendama turvaparanduste ja uute versioonide paigaldamisega või tuleb need täielikult "kinni keerata" (mis tähendab üldjuhul eemaldamist avalikust veebist).
Osiris
Osiris
sõnum 26.06.2019 14:09:31 vasta tsitaadiga
"xxx.ee xx"@xx.ee
554 5.7.1 xxxxx:
Relay access denied
See näitab seda, et üritad e-maile välja saata telia ühenduse tagant pordi 25 kaudu mis nüüd kinni keerati ja on lubatud ainult autentimisega smtp-d kasutada.
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 103
djkiller
djkiller
sõnum 26.06.2019 21:54:57 vasta tsitaadiga
Dogbert kirjutas:
djkiller kirjutas:
Dogbert kirjutas:
kogu sisu sai kustutatud.
Osiris
eks mida täpselt tegema?
maty
sõnum 26.06.2019 22:10:45 vasta tsitaadiga
https://arve.virtuaal.com/knowledgebase.php?id=54
E-posti klientide (Outlook, Thunderbird, telefonid jm) seadistamise üldised andmed on alljärgnevad.
Kasutajatunnus: Sinu e-posti aadress
Parool: Parool, mis määrati e-posti konto loomisel
Sissetulev server: mail.sinudomeen.ee
IMAP port: 993
POP3 port: 995
Väljaminev server : mail.sinudomeen.ee
SMTP port: 465
IMAP, POP3 ja SMTP autoriseerimised on nõutud.
Ehk siis mail.sacito.eu paned väljuvaks meiliserveriks, pordiks 465. Vali SSL/TLS ka.
djkiller
djkiller
sõnum 27.06.2019 11:48:03 vasta tsitaadiga
suured tänud eks vaatan kas saan thunderbirdi ja profiti tarkvara ka jooksma
uus teema   vasta Tarkvara »  Turvalisus »  Probleem meilide saatmisega mine lehele 1, 2  järgmine
