uus teema   vasta Hinnavaatlus »  Andmeside ja kõnelevi »  Using old Telia router (Thomson TG784) märgi kõik teemad loetuks
MikePrince
sõnum 26.09.2017 12:20:58 Using old Telia router (Thomson TG784) vasta tsitaadiga
Hi, firstly sorry about writing in English, hope it does not bother too many. I was told this would be the best place to write my question.
I have Telia home internet with router - Thomson TG784. Works fine. i use the lowest cheapest internet package 5down/1up. I noticed now on Telia homepage I can get faster (10down/2up) for the exact same price that I am currently paying. But when I tried to upgrade on their website it says my router (same as above) is not supported and I have to now take one of their 100€ routers (Inteno DG200). I cant upgrade without agreeing to pay for one of these new ones or declaring I already have one. But my point is that I don't understand why I should need one when I believe my current router can have no problems handling such a slow speed of 10down/2up.
Does anybody else have the same experience and can anybody confirm that I would have no problems just pretending to Telia I already own one of these Inteno routers and just use my old one. According to Thomson TG784 it should be able to handle way higher broadband (100down/10up).
Mikey
maty
sõnum 26.09.2017 12:27:25 vasta tsitaadiga
Because 10/2 is VDSL technology (5/1 is ADSL technology) and TG784 does not support that, so that's why you need to get Inteno DG200 that supports VDSL. If you don't want to pay 100€ for new router, then you can rent it for 2.99€/month.
viimati muutis maty 26.09.2017 12:30:41, muudetud 1 kord
Kommentaarid: 82 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 70
MikePrince
sõnum 26.09.2017 12:29:46 vasta tsitaadiga
I'll stick to what I have and Telia can stick their rent up their A** icon_biggrin.gif
raviool
raviool
sõnum 26.09.2017 19:43:57 vasta tsitaadiga
Judging by the information on this page the older Thomson TG789vn seems to support VDSL, too. However, I have never used that router on VDSL so I wouldn't know first-hand. People often sell this router second-hand on this forum or over at osta.ee.
Etsike
Etsike
sõnum 26.09.2017 20:18:31 vasta tsitaadiga
Indeed Thomson TG789vn works with VDSL and it's widely available on the second hand market for about 10 EUR.
As long as you don't have a VDSL compatible router available, don't upgrade to newer VDSL package. Upgrading will disable the current ADSL package and leave you without internet with your current ADSL-only router (that's exactly what happened to me and the ADSL>VDSL change can not be reversed).
Auction results https://osta-ee.postimees.ee/en/index.php?q%5Bq%5D=TG789&fuseaction=search.search&q%5Bshow_items%5D=1&q%5Bshow_shop%5D=1&q%5Bcat%5D=1000
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 69
MikePrince
sõnum 26.09.2017 21:10:38 vasta tsitaadiga
icon_cool.gif 10 Euro router, sounds like what I want to hear!
Thanks for the great tips guys
