praegune kellaaeg 21.09.2026 05:45:57
05.01.2017 00:14:52
1. Symantecilt Malware tõrjega WiFi-ruuter / 2. Maailma esimene, 2TB mahuga USB-pulk Rejoice, Kingstonilt |
Uus aasta on siis käes ja mitmeid uusi tooteid lubatakse:
1. Symantecilt sisseehitatud Malware tõrjega WiFi-ruuter / 2. Maailma esimene, 2TB mahuga USB-pulk Rejoice, Kingstonilt.
1. Antivirus Maker Symantec Launches Router That Keeps Malware Outside Your Home
Antivirus solutions are becoming so yesterday in 2017, so security company Symantec has decided to go to the next level with a brand-new router whose purpose is to block intrusions before they actually reach your connected devices.
Called Norton Core, the router was on display at CES 2017, and it is capable of scanning packets of data transmitted by your connected devices to detect malware or any form of suspicious activity that could put your information at risk.
Symantec equipped the router with super-powerful hardware to make sure that connection speed is not impacted, so it features a 1.7 GHz dual-core processor that can guarantee a maximum speed of 2.5 Gbps.
“4K streaming, you’ve met your match. Core is a performance powerhouse. With a 4x4 MU-MIMO foundation and ultrafast 802.11ac WiFi, Core is designed to achieve maximum throughput speeds of 2.5 Gbps. Its innovative phased-array antenna design, combined with advanced beamforming, provides unbelievable coverage and range,” Symantec explains.
http://news.softpedia.com/news/antivirus-maker-symantec-launches-router-that-keeps-malware-outside-your-home-511507.shtml
2. Rejoice, the World’s First 2TB USB Flash Drive Is Here
Although it looked like laptops stole the show at this year’s CES in Las Vegas, Kingston just couldn’t stay away from the celebration and unveiled what seems to be the world’s first 2TB USB flash drive.
Called the DataTraveler Ultimate GT (Generation Terabyte), the new device has bigger capacity than many of our hard drives and it’s insane just to imagine how much space manufacturers manage to offer these days on a product this small.
Kingston’s new USB flash drive measures only 72mm x 26.94mm x 21mm, so it’s super-easy to carry around at all times, without having to worry that you’ll run out of space. And what’s more, it’s nearly impossible to lose it because of shocks or things like that because Kingston designed it specifically to be shock-resistant with a zinc-alloy metal case.
http://news.softpedia.com/news/rejoice-the-world-s-first-2tb-usb-flash-drive-is-here-511510.shtml
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
